The VibSensor Accelerometer Test Thread - Page 71 - AVS Forum | Home Theater Discussions And Reviews
 950Likes
post #2101 of 2157 Old 05-10-2019, 12:11 PM
tvuong's Avatar
Quoted: 2540 Post(s)
Liked: 2186
I started reading this thread recently. Is there an explanation somewhere about these numbers? What they mean? Thanks.
^^ These are Nalleh's measurements.
tvuong is online now
post #2102 of 2157 Old 05-10-2019, 12:17 PM
3ll3d00d's Avatar
Quoted: 2286 Post(s)
Liked: 2372
they just summarise the data presented and are (IMO) basically irrelevant because they are rather meaningless in the context of this sort of signal
http://www.now-instruments.com/get-h...sor-user-guide for details though
3ll3d00d is online now
post #2103 of 2157 Old 05-10-2019, 02:29 PM
Gorilla Killa's Avatar
Quoted: 1326 Post(s)
Liked: 1832
I got bored and went back to a full riser for all seats and put my 18's in, can't find my xlr cable so the 12's are idle atm. This scene is why I went back, way too realistic, and I knew what I was missing. At this poiunt I may just get 2 more 18's and call it done, or maybe not.
ID:	2565022   Click image for larger version
ID:	2565024   Click image for larger version
ID:	2565026   Click image for larger version
SBuger likes this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
post #2104 of 2157 Old 05-10-2019, 02:48 PM
Nalleh's Avatar
Quoted: 2403 Post(s)
Liked: 3132
Here is coolrda’s guide, which explains what it all means. Part 2 a few posts down:
https://www.avsforum.com/forum/113-s...l#post55191874
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #2105 of 2157 Old 05-10-2019, 02:55 PM
Nalleh's Avatar
Liked: 3132
WAY to long sample. It is almost never advisable to use more than 10 max 20 seconds measurements.
Gorilla Killa likes this.
Nalleh’s HT
post #2106 of 2157 Old 05-10-2019, 03:22 PM
Liked: 1832
Redeux
ID:	2565078   Click image for larger version
ID:	2565080   Click image for larger version
ID:	2565082   Click image for larger version
post #2107 of 2157 Old 05-10-2019, 04:32 PM
Nalleh's Avatar
Liked: 3132
^^ Much better. Those are some fine graphs, man
What were your drivers again? Pictures?
You only need to post that third pic, power spectrum, the others aren’t that important for what we are looking at here.
Nalleh’s HT
post #2108 of 2157 Old 05-10-2019, 05:00 PM
Nalleh's Avatar
Liked: 3132
@Gorilla Killa :
Here is a old one of mine:
See it has two peaks at 6 and 19hz. Yours have multible more, it almost looks like EOT ! I wonder why?
The timestamps is in the graph title, could you try it like that ?
(Nevermind mine is in G units, it’s the shape of curve i am looking at)
Nalleh’s HT
post #2109 of 2157 Old 05-10-2019, 05:03 PM
Liked: 1832
Pierce Audio made the drivers several years ago, they've held up well.
The White Noise file is somewhat curious the way it falls off at 10hz. This is from LS drop at 5x and it certainly captures down low. Anyone validate the file is what it claims.
ID:	2565232   Click image for larger version
post #2110 of 2157 Old 05-10-2019, 05:05 PM
Liked: 1832
@Gorilla Killa :
Mine was started at 21:20 so we are at the same stamp. This is in G/unit
Nalleh likes this.
post #2111 of 2157 Old 05-10-2019, 06:17 PM
Liked: 1832
This is cool, the waveform on the disc is true to real world harmonics. Shows which part is hitting each frequency. Lines up with the vibsensor.
From the referenced article:
The first notable peak occurs at 24.0 Hz. A series of harmonics occur at 12 Hz intervals thereafter. These are the blade passing frequencies of the main rotor.
The main rotor blade passing frequency is: 5.40 Hz x 2 blades = 10.8 Hz
The Doppler shift increases the apparent blade passing frequency to 12 Hz. The theoretical speed of the helicopters was 76 mph based on this shift.
SBuger and Nalleh like this.
post #2112 of 2157 Old 05-10-2019, 06:50 PM
Nalleh's Avatar
Liked: 3132
It’s legit all right. Here is a RTA i did in REW with Umik, also showing the peaks at 6.5 and 19 hz.
Peaks are clearly visible in the BEQ graph too
This is SPL from the subs, not TR.
Nalleh’s HT
post #2113 of 2157 Old 05-10-2019, 08:57 PM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
I'm in process of building a BOSS platform to see what this whole TR thing is all about. There were several mentions of this thread in the reading I did on BOSS and this looked really interesting. The user guides are great and this info seems awesome. I wanted to get a baseline as to where I'm at right now with no BOSS. Ive attached the EOT scene below. I've got nearfield VBSS's right now and a Marty in the corner. Here's to a lot more learning and shaking in the near future!
Sent from my SM-N960U using Tapatalk
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is online now
post #2114 of 2157 Old 05-11-2019, 09:10 AM
SBuger's Avatar
Quoted: 1161 Post(s)
Liked: 3597
If I could stand to be another 3" taller or a little more (I'm already tall enough), I think I'd do the same thing and put my 3 18's that are VNF behind me into the riser instead. I have no doubt they would bring the ULF TR in a major way!!
EDIT: Hell I may have to try the 18's anyway, even if it puts me higher LOL
Gorilla Killa and Nalleh like this.
My "Blacked Out" Home Theater Room
1400cuft sealed room, suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo 203 | Epson 5040 4K | Eyes 7' to 120" AT Seymour Screen | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' 6x JBL12s | MiniDSP 10x10HD
SBuger is offline
post #2115 of 2157 Old 05-11-2019, 10:10 AM
Liked: 1832
2 reasons to do it
1. Headroom is not a problem when you are reclined.
2. When you slide out of the seat you are standing
If I had not of tried it I wouldnt have done all the seating.. I had a friend over few weeks ago and did a few demos before watching JW and the LS chopper scene was one of them. He was beside himself, as I sat there I was like eh, this is not the same. If you have the drivers and can fit it, its leaps and bounds over the 12's which is saying a lot imo.
SBuger likes this.
post #2116 of 2157 Old 05-11-2019, 10:11 AM
Liked: 1832
Uhh 116db at 6hz is a bit over the top don't ya think
post #2117 of 2157 Old 05-11-2019, 10:29 AM
Nalleh's Avatar
Liked: 3132
If you look at the LZpeak it is 125.8dB
SBuger likes this.
Nalleh’s HT
post #2118 of 2157 Old 05-11-2019, 10:32 AM
Nalleh's Avatar
Liked: 3132
I think the major difference here is Xmax. You can get more mms by multiplying JBL’s, but you can’t get the stroke capability.
SBuger likes this.
Nalleh’s HT
post #2119 of 2157 Old 05-11-2019, 01:47 PM
Liked: 1832
Agree 100%, the big player here
Nalleh likes this.
post #2120 of 2157 Old 05-11-2019, 06:48 PM
trhought's Avatar
Quoted: 537 Post(s)
Liked: 981
Jeff....looks awesome! In the BOSS thread, I've recently started a normalized comparison of a couple different drivers for a BOSS platform.
Basically, after comparing FR in an open baffle using WinISD, the product of Xmax normalized and Mms normalized is compared to the baseline JBL to give a sense of expected performance gain. My bet is the 18 will be at least 3x the 12" JBL after multiplying the Xmax increase by the Mms increase.....maybe even more:
Adding your 18 to the BOSS driver list also would be great if you have the model number....is it still in production?
trhought is online now
post #2121 of 2157 Old 05-12-2019, 06:50 AM
Liked: 1832
Pierce doesn't do that unfortunately, each build is per customer request. Sucks but I think it keeps him from having to be consistent build to build. My 18's came out great, my 12's he did not so much.
The mms is almost 700g and the bl is 14. qts is.65 xmax is 90 they are abuse tolerant. Id say anything made for a IB and are hard to bottom out would be great. I paid $700 shipped to me.
Subjectively I think the apples to apples mms and xmax doesn't work for this. 4jbl to 1 18 on same platform was different. @Nalleh mentioned stroke and I think this applies here. The Jbl is reversing direction and the 18 is still moving ahead, even while the jbl has reversed course yet again the 18 is still cruising. 3-1 easily stroke to stroke. So the perception is going to be vastly different. Especially at sub 15hz, much more wobble..........wobble..........wobble as opposed to wobble..wobble..wobble
post #2122 of 2157 Old 05-12-2019, 07:27 AM
trhought's Avatar
Quoted: 537 Post(s)
Liked: 981
Jeff....Thanks....wow, that's some serious mass and excursion. A driver as a shaker is a combination of stroke and mass. The frequency of the stroke will be the same for the 18 or the 12, both will be reversing course at the same time. It's just the 18 covered a lot more ground in that same time period for the wave. So it's acceleration and deceleration at the peaks and valleys of the wave are incredibly higher because of the higher velocity going into the turn so to speak. That's why it feels so much more violent than the JBL's. That higher acceleration/deceleration into and out of the turns multiplied by the higher mass of your 18.....well, that's off the charts and for just one driver
In comparison to the JBL, the 18 has 3.9x the mass and 6x the excursion.....that's a shaker potential of 23.4 times more than 1 JBL.....no wonder you like it so much! It would take about 23 JBL's to equal one of the 18's if ignoring real-world limitations (platform bending, speaker suspension losses at their limits of travel, BOSS suspension losses, furniture transfer losses to the butt, etc)
Will try to model tomorrow using those parameters when I get to a computer....curious of the power needs and frequency response. Since, it's an IB design, I bet it's FR will favor a BOSS application also with a natural roll-off towards higher frequencies and stronger response in the singles....I think we've found the ideal MEGA BOSS driver!
post #2123 of 2157 Old 05-12-2019, 09:48 AM
LastButNotLeast's Avatar
Quoted: 2362 Post(s)
Liked: 1988
At $700, no thanks.
Michael
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #2124 of 2157 Old 05-12-2019, 10:32 AM
Liked: 1832
I agree, that's why I used the term subjectively to begin the paragraph. More describing the feel than anything.
fs 18hz
qts .65
qes .77
qms 4.4
le .93 mH
vas 9.4 ft^3
sens 85.5 db 1w1m
spl 91.1 db @ 2.83 vrms
Bl 13.7 Tm
xmax30mm
xmech 100mmp-p
The coil was made to take up to 1000 watts since initially I was going to throw more power at them. Right now they get about 500 per which is plenty to bottom them out if I tried hard enough. Close to 30db of boost at 10hz which leaves some cushion.
post #2125 of 2157 Old 05-12-2019, 10:35 AM
Liked: 1832
Originally Posted by LastButNotLeast View Post
At $700, no thanks.
Michael
Thats for 2 with shipping for what thats worth to you. Not a economy build, its a MOAR build
post #2126 of 2157 Old 05-12-2019, 10:43 AM
trhought's Avatar
Quoted: 537 Post(s)
Liked: 981
Like a MEGA BOSS! Thanks for the parameters Jeff. Very interested to see how this looks in WinISD....if it doesn't break it first
post #2127 of 2157 Old 05-12-2019, 11:04 AM
Nalleh's Avatar
Liked: 3132
fs 18hz
qts .65
qes .77
qms 4.4
le .93 mH
vas 9.4 ft^3
sens 85.5 db 1w1m
Bl 13.7 Tm
xmax30mm
xmech 100mmp-p
Hmm, yeah i guess even repurposing my SI18HT v2 would be a childs toy compared to that monster !!! That is some serious gear you got there
(Now, technically the SLAPS M12’s passive radiators i use have 4inch Xmax and can be loaded with more than a 1 kg of mass, if it could be made to work, it should have some heft to it )
Nalleh’s HT
post #2128 of 2157 Old 05-12-2019, 12:35 PM
Liked: 1832
You know you need to try the SI 18's
post #2129 of 2157 Old 05-12-2019, 12:44 PM
Nalleh's Avatar
Liked: 3132
Shut up !!
SBuger and Gorilla Killa like this.
Nalleh’s HT
post #2130 of 2157 Old 05-13-2019, 08:51 AM
trhought's Avatar
Quoted: 537 Post(s)
Liked: 981
fs 18hz
qts .65
qes .77
qms 4.4
le .93 mH
vas 9.4 ft^3
sens 85.5 db 1w1m
Bl 13.7 Tm
xmax30mm
xmech 100mmp-p
Well.....I'd say the Pierce is a one-of-a-kind and there's no doubt why you like it so much.
Below is the FR when looking at excursion as modeled in WinISD in an open baffle.....the y-axis is mm of excursion up to 100 mm full scale. Red is the Pierce 18" and that Blue curve at the very bottom is the JBL This is with about 800 watts rms to get close to Xmech.
The Pierce doesn't start to roll off until after 30Hz and behaves quite strongly between 10-20Hz. With the extra mass and displacement (acceleration) below 10Hz....well, I think you have the single digit TR covered pretty well also.
Name:	Pierce 18 inch.jpg
