Need help picking subs. $3.5k budget. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Alan P
  • 1 Post By mthomas47
post #1 of 22 Old 11-02-2015, 08:13 AM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
I initially had planned to run 2 x JL audio E112's but with the help of JimWIlson(Thanks!) I have narrowed it down to a few options that might be better suited for my space. I am however having a hell of a time actually pulling the trigger on something.
I have Monitor Audio Silver 8's (LCR) and gold in ceiling rears. The room is big. We determined it near 5600cu/ft. Budget 3-$3.5k give or take for the 2 subs. I could stretch it if there was something exponentially better. My one issue is I am some what space limited the max width of the subs can not exceed 18". I would say I my listening is 70/30 Music/HT.
These are the contenders:
PSA V1500(Or maybe even s3000i)
Rythmik FV15hp
HSU VTF-3 MK5
SVS PC13 Ultra
I am fairly stumped here. All seem like strong contenders. The one benefit I see to the SVS is the form factor. Being the width is only 16.5 it does give me a touch more room on each side. But am I losing performance over the larger 15" drivers?
Any input is appreciated.
AZtitan123 is offline
post #2 of 22 Old 11-02-2015, 08:54 AM
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 290
With 13.5" ultra driver in SVS and 1000 watts behind it, you are not loosing anything if pitched against 15" DS1510 driver of Rythmik and 600 watts of amplifier power.
Rythmik FV15HP is more efficient compared to PC13 Ultra due to larger cone area. What the later loses in size, it makes up for it with more watts in amplification.
Both these subs are more similar in performance than different. I'd say go for dual PC13 Ultras; they are more placement friendly and easy to lug around.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 22 Old 11-02-2015, 09:16 AM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
And your opinion is that is also the better choice over the HSU and PSA? Dual PSA s3000i do intrigue me.
post #4 of 22 Old 11-02-2015, 09:42 AM
Kini62's Avatar
Quoted: 2757 Post(s)
Liked: 2602
I think in your space a pair of ported subs makes more sense. You could always try both the Ultras and the S3000s since shipping both ways is included in the price of each.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #5 of 22 Old 11-02-2015, 09:49 AM
checker9's Avatar
Quoted: 1656 Post(s)
Liked: 378
I am not sure - you should check on it first: I think I recall reading that the PC13-ultra is the one SVS cylinder that is measurably different from its PB version. So confirm that before going by PB13-ultra reviews. Or ask SVS, they would tell you if it is. They would also give you internal numbers on both, if you ask.
checker9 is offline
post #6 of 22 Old 11-02-2015, 10:05 AM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
SVS said that PB vs PC were equals in terms of performance and sq when I had asked.
That is what I was leaning towards. The S3000 is the only non ported on the list. But after speaking with Tom V it sounded like the s3000 would have only positives over the v1500.
post #7 of 22 Old 11-02-2015, 10:10 AM
checker9's Avatar
Liked: 378
On the other two PCs, the PCs and PBs are nearly identical, but on the Ultras, while they are close, there is more difference, so I just wanted to point out that it is not as apples to apples as the other PCs and PBs.
Per this post by Ed Mullen, SVS director:
As others have alluded, the PB13-Ultra is tuned a few Hz deeper than the PC-Ultra and also has more internal enclosure volume. As such, it has somewhat higher maximum output capability at the very deepest frequencies. With that said, subjectively they perform very similarly on source material as the Norway comparo pointed out.
The PCU is obviously easier to physically integrate into a smaller room - being lighter, easier to move, and having a much smaller footprint. Also, the minor output/extension deficit of the PCU tends to be offset in a smaller room, which will have more boundary reinforcement and earlier onset of room gain.
Ed Mullen
Director - Technology and Customer Service
SVS
http://www.hometheatershack.com/foru...html#post61447
checker9 is offline
post #8 of 22 Old 11-02-2015, 10:13 AM
Alan P's Avatar
Quoted: 6589 Post(s)
Liked: 5993
A comment such as this always throws up a red flag for me...I assume you have already picked out where the subs are going to be placed?? This is not how you should go about it and will most times end in disappointment with your new subs.
The subs will tell you where they want to go, not the other way around.
dsrussell and Scott.C.McMahon like this.
Alan P is offline
post #9 of 22 Old 11-02-2015, 10:15 AM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2331
Check out the Seaton SubMersive forum in this subform. Mark is coming out with a "1/2" SubMersive this month designed for placement and space limitations like yours. It looks like the new amps he has could run 4 "1/2" SubMversives in a slave configuration for a price within your budget. I would at least look into this option before you rule it out. You could also add an additional Master unit in the future for an option to run 8 1/2 Submersives with control over two banks.
jjackkrash is offline
post #10 of 22 Old 11-02-2015, 10:20 AM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
I don't have any choice in the matter. I have one place they can go, and it will have to do. So it is either this, or nothing.
I actually emailed him this morning. Thanks!
post #11 of 22 Old 11-02-2015, 10:28 AM
jjackkrash's Avatar
Liked: 2331
Good deal. I know he has a stack of orders to get out the door because the new amp just got finished, so I'd call mid week if you don't hear anything in the next day or two via e-mail. Good luck on your hunt!
post #12 of 22 Old 11-02-2015, 11:53 AM
Alan P's Avatar
Liked: 5993
Make sure that whatever you buy has a liberal return policy.
Alan P is offline
post #13 of 22 Old 11-02-2015, 12:16 PM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
Will do, although as I said there's no where else I can put them. So if I'm sending them back, I'm giving up on the whole thing lol
post #14 of 22 Old 11-02-2015, 12:26 PM
Alan P's Avatar
Liked: 5993
All I'm saying is that if you're going to spend this kind of cash on subs, you want them to perform in your room.
For all you know, your proposed locations could result in a large null across most of the sub's passband...not likely, but still in the realm of possibility.
I just don't want you to get stuck with $3.5K worth of subs that don't work in your room.
Alan P is offline
post #15 of 22 Old 11-02-2015, 12:30 PM
Alan P's Avatar
Liked: 5993
You could model your room (i.e. REW's Room Sim option) and get a rough idea of what the subs will do in your room. Most room sims only deal with sealed rooms though, so it may only get you close.
My room is completely open on the left hand side, but I am able to trick REW's room sim by setting the absorbancy of that wall to it's highest setting (.90) and it comes pretty close.
Alan P is offline
post #16 of 22 Old 11-02-2015, 12:36 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5554 Post(s)
Liked: 10776
Hi,
FWIW, I have three SVS Ultra's in a room just a bit larger than yours. Two of them are PC's and one is a PB, and I agree that subjectively there is no difference in performance. Also, for what it's worth, I don't know that Ultra's get quite enough credit for what smooth performers they are. Although I upgraded to Ultra's primarily for increased power and low frequency extension, I have been very impressed with how seamlessly they have integrated with my speakers, and with how little attention they attract to themselves. That last feature might be particularly important to you since you identified your audio use as being 70% music. The 45-day free trial will work in your favor here. I would definitely recommend ported in a room your size.
Mike
Kini62 likes this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #17 of 22 Old 11-02-2015, 03:20 PM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
Originally Posted by mthomas47 View Post
Hi,
Mike
Thanks! This is a very tough choice..lol
post #18 of 22 Old 11-02-2015, 04:50 PM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
Thanks I downloaded it and will play around with it. Although I am not sure I will quite be able to interpret the data..lol
I think the S3000 is out. It is too big.
I am down to:
PSA V1500's
Rythmik FV15HP
Hsu Vtf-3
Maybe I should just flip a coin twice.
post #19 of 22 Old 11-02-2015, 05:13 PM
checker9's Avatar
Liked: 378
I am down to:
PSA V1500's
Rythmik FV15HP
Hsu Vtf-3
PSA V1500 would be risk free to try.
checker9 is offline
post #20 of 22 Old 11-02-2015, 06:01 PM
Kini62's Avatar
Liked: 2602
I am down to:
PSA V1500's
Rythmik FV15HP
Hsu Vtf-3
What? No love for the SVS cylinder.
Def Tech SC8000
Onkyo RZ820
Kini62 is offline
post #21 of 22 Old 11-02-2015, 06:42 PM - Thread Starter
AZtitan123's Avatar
Quoted: 31 Post(s)
True that!
Honestly, I just built a box(out of cardboard) about the size of the V1500 and FV15hp and I think it might just be too big for me. The SVS Cyl might be my best option. Could very well order the SVS and V1500 tomorrow and send back which one doesn't "do it" for me. I am thinking the svs will beat it in aesthetics but will lose in performance. However if I have to resort to sealed subs to reduce footprint, to something like s1500 the SVS might be a strong contender.
post #22 of 22 Old 11-02-2015, 07:02 PM
checker9's Avatar
Liked: 378
Honestly, I just built a box about the size of the V1500 and FV15hp and I think it might just be too big for me. The SVS Cyl might be my best option. Could very well order the SVS and V1500 tomorrow and send back which one doesn't "do it" for me. I am thinking the svs will beat it in aesthetics but will lose in performance. However if I have to resort to sealed subs to reduce footprint, to something like s1500 the SVS might be a strong contender.
I am pretty sure that you can put the PC13-ultra on its side, and that might give you more placement option since you could put it behind things or along walls etc like that (confirm with SVS if you would like to do that.)
checker9 is offline
