Z5500 farting noise not from subwoofer. - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By rush2049
  • 1 Post By HagenK
post #1 of 15 Old 11-19-2015, 08:19 AM - Thread Starter
Liked: 0
Unhappy Z5500 farting noise not from subwoofer.
So, i got a set of Logitech Z5500 second hand, and first thing i noticed was a farting sound like air escaping out of the back of the cabinet @ 30-40 Hz
So i got elastic silicone and made a new seal between the enclousure and the amplifier rack, (i also played the sub with the rack out resulting in no farting sound, so i figured it was not the sub making it. (kind of predicted that.
Sealed it good and screwed it all back together. 24h later waiting for the seal to get solid, i played 35Hz and the sound is still here, im very frustrated because the sound is very annoying.
Also gone all over the back plate with a piece of paper while playing 35 Hz, with no noticeable shaking due to air leaking.
When i cover the port the sound seems to minimize/almost go away.
Anyone have a clue? I just want it to sound proper, and if anyone here might have a solution that works id be out of my mind from happiness
Kristian Tveiten is offline
post #2 of 15 Old 11-19-2015, 08:25 AM
Quoted: 45 Post(s)
Liked: 7
port chuffing?
HagenK is offline
post #3 of 15 Old 11-19-2015, 08:56 AM
Transmaniacon's Avatar
Quoted: 1745 Post(s)
Liked: 1555
Originally Posted by HagenK View Post
port chuffing?
Yeah this would be my guess too. Turn the volume down some.
5.1: Samsung PN60F5300 | Sony BDP-S1700 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
2.0: Apple Airport Express | Topping D50 | Parasound HCA-1500a | Chane A1.4
Transmaniacon is online now
post #4 of 15 Old 11-19-2015, 08:57 AM - Thread Starter
Liked: 0
I dont think its port chuffing, its not coming from the port really, its coming from the backplate. And port is really big, the air isnt really being forced through to say it like that.
Thanks for answer though
post #5 of 15 Old 11-19-2015, 09:33 AM - Thread Starter
Liked: 0
Also i dont push it THAT hard Transmaniacon, its even noticeable under half volume.
post #6 of 15 Old 11-19-2015, 09:52 AM
AllenA07's Avatar
Quoted: 704 Post(s)
Liked: 579
I would start by turning it down to see if that makes a difference. Also make sure the screws on the plate AMP are all tight. If the AMP is loose that might be giving air a place to escape. That being said, I'm going to agree with what others said, this does sound like port chuffing.
My Theater: The Ugly Theater
AllenA07 is offline
post #7 of 15 Old 11-19-2015, 10:04 AM - Thread Starter
Liked: 0
Yeah, the sound is volume dependent, all screws on amp are checked tight.
Ill make a video of the sound maybe it will be easier.
Shouldnt a port chuffing noise come from the port? :P
The port is like 4 inches in diameter and has tapered edges, and it takes alot to get air pressure through that port, which it is far from doing when i play it below half volume @ 35 Hz.
I can make a video of the sound if the bass doesnt crap up the mic.
post #8 of 15 Old 11-19-2015, 10:16 AM - Thread Starter
Liked: 0
You can hear the fluttering from behind the subwoofer, not port at all.
This post is just so i can post link in next: (min 5 posts for link)
post #9 of 15 Old 11-19-2015, 10:16 AM - Thread Starter
Liked: 0
post #10 of 15 Old 11-19-2015, 11:02 AM
superbabyboy1984's Avatar
Quoted: 92 Post(s)
Liked: 41
You should open up the amp plate and check on the sealant around speakers connectors,main,power cable connector and also the fuse holder.
superbabyboy1984 is offline
post #11 of 15 Old 11-19-2015, 11:50 AM - Thread Starter
Liked: 0
I already sealed the speaker connections and the power connection very well from the backside and front, applied plenty of silicone. The sound seems to originate from the speaker connections, which i have sealed from both the front and back. I dont think i will attempt opening it again since its probably sealed shut now. One would believe though that there would be plenty of air coming through with that sound, but putting a little paper infront of the connections and to the sides, reveals no air flow.
post #12 of 15 Old 11-19-2015, 12:25 PM
rush2049's Avatar
Quoted: 85 Post(s)
Liked: 101
Sounds to me like there is a piece of paper or plastic that got into the port hole. and is inside moving about.
Alan P likes this.
rush2049 is offline
post #13 of 15 Old 11-19-2015, 01:15 PM - Thread Starter
Liked: 0
The port is so big i can stick my whole arm in there, nope theres nothing stuck there, again not coming from the port.
post #14 of 15 Old 11-19-2015, 02:48 PM
Quoted: 45 Post(s)
Liked: 7
You could save some money and upgrade to a decent subwoofer
Alan P likes this.
HagenK is offline
post #15 of 15 Old 11-20-2015, 07:24 AM
rush2049's Avatar
Quoted: 85 Post(s)
Liked: 101
I used to own this speaker set so I know.
I mean like... it is in the box part of the sub, not in the tube any longer.
rush2049 is offline
cabinet issue , leaking air , logitech z5500 , sound , subwoofer
