ready to order 2 s1500's from psa. any reason not to? - AVS Forum | Home Theater Discussions And Reviews
 24Likes
post #1 of 47 Old 11-30-2015, 02:37 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
my room is 14x13x8.5, dedicated and closed off home theater. the tuner is the denon x4100 and my speakers are listed below. my current klipsch 12" sub sounds decent but I really want to get blown away when I turn it up.
after much reading and flip flopping from psa to svs to rythmik and back to psa I think I have landed on a pair of s1500's.
I am open to any input but my main question is would more sub have any positive effect given that it is a fairly small space? would a pair of s3000i's sound any better or just cost more and take up more space.
thanks in advance. I am sure you guys get these questions all the time.
klipsch rf82's, rc62, rb51, r-112sw sub
80" vizio M801D-A3
denon x4100 in a 14x13x9 dedicated room.
parish8 is offline
post #2 of 47 Old 11-30-2015, 03:12 PM
PoppaC's Avatar
Quoted: 29 Post(s)
Liked: 40
Originally Posted by checker9 View Post
For home theater, ported might be better. A single V1500 would have more output in the low 20s as two S1500. Also, with your size room, two might not be needed.
Unless you know you want sealed, I would get both a S1500 and V1500 to see which one you like better and send the other back. And then you can decide if one is good or if you need two and order a second, if so.
Whether you decide ported or sealed, I would try one, and then add a second if you think you really need one. Not a huge room, so one might be all you decide you need.
I would reach out to Tom at the web site. I think he will steer you the right way.
PoppaC is offline
post #3 of 47 Old 11-30-2015, 03:12 PM
PoppaC's Avatar
Quoted: 29 Post(s)
Liked: 40
PoppaC is offline
post #4 of 47 Old 11-30-2015, 03:34 PM
eljaycanuck's Avatar
Quoted: 1867 Post(s)
Liked: 2621
Your room is sealed and fairly small. Dual S1500s should perform very well in there, both in terms of overall output and, thanks to cabin gain, sub-20Hz extension.
Transmaniacon likes this.
eljaycanuck is offline
post #5 of 47 Old 11-30-2015, 03:45 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5430 Post(s)
Liked: 10225
Hi,
As you might expect, the advice you got is all over the place. The problem is that no one but yourself can really know how much will be enough for you. I think if I were you, I would go ahead and pull the trigger on the two you have picked. If they aren't quite enough, you can always exercise free return shipping to move up in size, or to ported subs. But until you actually try something in your room, there just won't be a definitive way to tell.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #6 of 47 Old 11-30-2015, 04:38 PM
dsrussell's Avatar
Quoted: 2263 Post(s)
Liked: 3109
I use a single S3000i in my 3,400 cu. ft. room (that’s rather open). It shakes the walls, my feet, my couch and my body. And it’s sitting 9-1/2 feet away on laminate flooring over a concrete slab. It’s a powerful subwoofer. Your room volume is less than half that size and isn’t open, so I would fully expect the S1500 to be as impressive in that smaller volume. I would always tell a person to try out a single sub first. If there are problems with room modes at the MLP that moving the subwoofer cannot correct, then you can always order a second.
Music area: Magnepan 3.6, McIntosh MC2205 amp & C48 preamp, SVS SB13-Ultra, Oppo BDP 95, dbx 3BX, and assorted equipment.
Movie area: EMP Tek E5Bi (were rebadged to R5Bi), RBH/EMP Tek R55Ti, PSA S3000i, Denon X2000, Oppo BDP 83.
dsrussell is offline
post #7 of 47 Old 11-30-2015, 04:46 PM
AVS ***** Member
mthomas47's Avatar
Liked: 10225
I have a friend with two Submersives in a 1000 cu ft. room. And he boosts his subs big time. Different strokes...
post #8 of 47 Old 11-30-2015, 05:37 PM
dsrussell's Avatar
Liked: 3109
Different strokes indeed . But I like my hearing and don't want to fix cracks in the drywall....
BTW, very small rooms that are symmetrical often have the worst room modes and are very difficult to mitigate without a second sub.
jjackkrash likes this.
post #9 of 47 Old 11-30-2015, 06:40 PM
Cvetan1's Avatar
Quoted: 36 Post(s)
Liked: 50
Cracking drywall is a REAL problem... Especially with dual JTR S1's.
Cvetan1 is offline
post #10 of 47 Old 11-30-2015, 06:41 PM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
My vote is YES for the pair of S1500's.
lovinthehd likes this.
Red99 is offline
post #11 of 47 Old 11-30-2015, 06:49 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
hmm... thanks for the opinions.
I was thinking more people would say great choice, cant go wrong.
I thought going dual subs was the hot ticket and the denon with audyssey sub eq is ready to run them. I think I am going to just stick with duals.
I also thought sealed was an obvious choice given the small room. I guess I need to do more reading on the sealed vs ported.
80" vizio M801D-A3
parish8 is offline
post #12 of 47 Old 11-30-2015, 06:52 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
I should have mentioned this as it may effect the responses. my walls are about 1" thick plaster which resembles concrete.
80" vizio M801D-A3
parish8 is offline
post #13 of 47 Old 11-30-2015, 06:53 PM
dsrussell's Avatar
Liked: 3109
There is nothing at all wrong with your thought process. You've done solid homework, and the PSA S1500 should slam that room really hard. Enjoy, and let us know how you like them.
Red99 likes this.
post #14 of 47 Old 11-30-2015, 06:55 PM
sk373's Avatar
Quoted: 759 Post(s)
Liked: 1069
I run dual XS-15se's in a room larger than yours (22x11x8), and they do very well. Sealed will work very well in your room, as long as it's not open to a much larger space. You will see quite a bit of room gain, as the longest dimension of your room is just 14'. And duals is the way to go. Chat with Tom at PSA--he will do right by you!
Red99 likes this.
My humble main system:
Vizio M75-E1; Oppo 203 universal UHD player; Denon 4300H AVR, Dual PSA S1801's; Monitor Audio Silver RX-6 mains, RX center, and RX surrounds; one pair NHT mini Atmos speakers; Home-built HTPC (Xeon E1230, 16gb RAM, Crucial M500 480gb SSD, GeForce 980Ti, Corsair CX600, CoolerMaster mini-ITX case); Roku Premiere+; Amazon 4K Fire TV
sk373 is online now
post #15 of 47 Old 11-30-2015, 07:50 PM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2329
For couple hundred more than dual S1500s you could get a SubMersive master unit that gives you the option to add a slave unit down the road for about 1/2 price.
http://www.seaton-sound-forum.com/po...pid=1289926103
For the record, there's nothing wrong with your initial choice, and I am confident based on its specs ands reputation it would work great for you, but I am just tossing out an option.
jjackkrash is offline
post #16 of 47 Old 11-30-2015, 08:44 PM
Tony~M's Avatar
Quoted: 50 Post(s)
Liked: 44
Hello,
Hope you are well.
I am afraid you should not order them, since they don't come in pink....
Seriously though, your room is small, 2 S1500's is plenty. You should get some serious room gain in that room too.
Later,
Tony
Tony~M is offline
post #17 of 47 Old 11-30-2015, 09:48 PM
Prime316's Avatar
Quoted: 190 Post(s)
Liked: 207
OP,
Whatever you decide to order, order two of them.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #18 of 47 Old 12-01-2015, 12:01 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4794
Let us know when the dual S1500's arrive.
lovinthehd is offline
post #19 of 47 Old 12-01-2015, 06:17 AM
Red99's Avatar
Quoted: 776 Post(s)
Liked: 418
IF this helps the op! I had the same subs XS-15se's in a open family room that its total volume is over 6000 cubic feet. The subs were about 10 feet from MLP. They had lots of bass and vibrated some things. Here is a graph using REW with the MLP 10 feet from the subs in my open room. Bottom two lines are each sub. The top 2 are both subs together. (One has Audussey EQ on).
NOTE: This is a good example of how 2 subs will smooth out the FR.
In your small room, those S1500's should work very well.
I would talk to Tom. And if you dont like the results ( which I think you will ), then you can always return them.
sk373 likes this.
Red99 is offline
post #20 of 47 Old 12-01-2015, 06:51 AM
Tom Vodhanel's Avatar
Quoted: 2994 Post(s)
Liked: 9941
Well, it can be a slippery slope. The Subm is about $600 more at $2500 delivered. So add another $250 onto that and he's got triple 18s and 4000 watts in the room now with the new T-18ht..
Given the room size I'd lean toward a sealed model from Power Sound. Just be a shame not to take advantage of the room transfer function for <10hz extension.
Tom V.
Power Sound Audio
Tom Vodhanel is online now
post #21 of 47 Old 12-01-2015, 07:28 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
Thanks for chiming in Tom.
Back to my original question. Would a pair of the s3000i subs sound any better than the s1500's or just be more sub than I could use? I am not looking to damage the house.
I see double the drivers and more than double the watts for about 50% more money and it had me thinking...
If there was a reason to consider the s3000i how close can one of the speakers be to a wall or furniture?
80" vizio M801D-A3
parish8 is offline
post #22 of 47 Old 12-01-2015, 07:45 AM
Liked: 9941
The primary difference will be headroom(clean output capabilities). The extension and sound quality will be very similar. I bet you would have a difficult time telling one option from the other in a listening session---up until the S1500s are approaching their output limits. Dual S1500s should be hitting >112-115dB from 25-120hz. Around 103-109dB from around 5-25hz in your room environment.
Add 4-5dB going from the S1500s to the S3000i. If you enjoy action oriented movies at LOUD volume levels on occasional AND you prefer the bass to be a little on the *hot* side relative to the main channels that is a good argument for dual S3000i. But, if you stay on the moderate side of the master volume control---say 9-12dB under reference level---dual S1500s should be plenty..
Tom V.
Power Sound Audio
mthomas47 and eljaycanuck like this.
post #23 of 47 Old 12-01-2015, 07:56 AM
oshia86's Avatar
Quoted: 12 Post(s)
Liked: 99
If you're debating on dual S1500's vs dual S3000i's I think the obvious choice is 4 T18HT's.
Got a chance to hear an all PSA setup this past weekend (v1500, 110 speakers). Ya, I'm hooked.
sk373 and Alan P like this.
oshia86 is offline
post #24 of 47 Old 12-01-2015, 08:13 AM
jjackkrash's Avatar
Liked: 2329
I just hopped on your website and this does look like a pretty good value. Are you using a Speaker Power plate amp for this model?
Edit: It looks like from the chart it is a Speaker Power amp.
post #25 of 47 Old 12-01-2015, 08:34 AM - Thread Starter
Quoted: 36 Post(s)
Liked: 6
So 12, 18" drivers and 16000 watts seems about right?
Joking aside I wonder what dual s3600i's would sound like. Two s1800's might be on the list if tom made them.
80" vizio M801D-A3
parish8 is offline
post #26 of 47 Old 12-01-2015, 08:35 AM
Liked: 2621
... I wonder what dual s3600i's would sound like.
Order a pair and find out.
post #27 of 47 Old 12-01-2015, 08:49 AM
shayne54's Avatar
I ordered (2) PSA subs based off of room advice from Tom. Couldn't be happier with my purchase. I say go for it!
shayne54 is offline
post #28 of 47 Old 12-01-2015, 08:50 AM
Liked: 9941
With our sealed products it just comes down to headroom. Dual S1500s will sound much like dual T-18ht subs for example----up until you approach the limits of the S1500s. We had someone upgrade from XS15se to T-18s mention the same in our thread a while back. Really, for the room size, dual S1500s should be plenty and you really don't need to consider anything larger than dual S3000i imo. Dual S3600i would be a bit overkill. Which isn't the worst thing in the world with regards to system headroom...but just be sure you realize how large the enclosures are as they would certainly dominate the decor in a smaller room like this.
Tom V.
Power Sound Audio
post #29 of 47 Old 12-01-2015, 08:51 AM
Liked: 9941
Just a FYI, all options are in stock and a new order would ship out same day/next business day. Not sure how long this will last being December but we're hanging in there..
Tom V.
Power Sound Audio
eljaycanuck likes this.
post #30 of 47 Old 12-01-2015, 08:52 AM
Liked: 9941
Correct.
Tom V.
Power Sound Audio
