2015 Bass Demo Disc - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 218Likes
post #271 of 496 Old 05-26-2016, 09:25 PM
Archaea's Avatar
Quoted: 3868 Post(s)
Liked: 3678
I still can't get this to burn right after 3 attempts on a 50GB rewritable bluray disk that I always use first to test (saves $).
This is the IMGBurn error. Anyone else seeing this?
I 18:51:34 Verifying Layer 0... (LBA: 0 - 12219391)
W 19:13:09 Failed to Read Sectors 12083296 - 12083327 - Reason: L-EC Uncorrectable Error
E 22:20:54 Miscompare at LBA: 12083296, Offset: 0, File: \BDMV\STREAM\00019.m2ts
E 22:20:54 Device: 0x1A
E 22:20:54 Image File: 0x61
E 22:20:54 Total Errors in Sector: 2,040
E 22:20:54 Failed to Verify Sectors!
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #272 of 496 Old 05-26-2016, 10:32 PM
Iron Maiden's Avatar
Quoted: 575 Post(s)
Liked: 218
I will be in the same boat with no way to play the demo unless it is on a disc. I will go buy a pack of blanks to send to someone who is willing to burn a copy for me.
Iron Maiden is offline
post #273 of 496 Old 05-27-2016, 01:23 AM
LastButNotLeast's Avatar
Quoted: 2518 Post(s)
Liked: 2149
Did you do a full (not quick) format of the disc?
I had no trouble with my bargain brand BD-RE (I would offer the brand name, but it's in Chinese ).
Michael
Did you really need to quote that entire post in your reply?
Welcome to AVS - Get out while you still can!
Don't guess, measure: https://www.avsforum.com/forum/91-au...l#post22789786
LastButNotLeast is offline
post #274 of 496 Old 05-27-2016, 04:08 AM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
Michael
Have you been able to burn another ISO to this disc? Perhaps try another ISO to verify the disc is viable. And as LastButNotLeast recommended, erase disc then do full format. I purposely left 2 GB of space free so there wouldn't be size issues.
Quickett is offline
post #275 of 496 Old 05-27-2016, 04:13 AM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
Originally Posted by WereWolf84 View Post
Deadpool, Gods Of Egypt, The Finest Hours, Batman vs Superman, CA: CW, X-Men: Apocalypse
Add SW:FA as well. @Fatshaft also mentioned Zoolander 2.
But this does bring up a quandry, do i start a new thread for the 2016 disc? Or just continue this one?
Quickett is offline
post #276 of 496 Old 05-27-2016, 05:01 AM
Archaea's Avatar
Liked: 3678
I didn't try to reformat it first I've never had to do that before. But I'll try it.
Maybe my rewritable disk has failed. . How many writes do you get on them before they fail. I've probably used this one at least a dozen times. It's a verbatium
Archaea is offline
post #277 of 496 Old 05-27-2016, 05:16 AM
Liked: 2149
Since there still seem to be a few issues with this disc , I'd suggest a new thread for 2016.
Brave soul, indeed.
Michael
post #278 of 496 Old 05-27-2016, 05:16 AM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
I just noticed on your error report you have verify checked. Uncheck verify and try it again.
Quickett is offline
post #279 of 496 Old 05-27-2016, 05:22 AM
imrf's Avatar
Quoted: 213 Post(s)
Liked: 144
Send me a PM and I'll hook you up.
Quickett and Iron Maiden like this.
imrf is offline
post #280 of 496 Old 05-27-2016, 07:48 AM
wambo's Avatar
Quoted: 46 Post(s)
Downloading now. Will seed off and on for a while on a 1Gbps line.
Quickett likes this.
Denon AVR-X5200W [] 7.3 [] Klipsch RF-82ii [] Klipsch RC-62ii [] Klipsch KG 4.2 [] Bose 301-V [] Dual SVS SB-2000 + SVS PB-1000 [] Vizio E60-C3 [] HTPC [] Harmony Elite [] Samsung SmartThings
wambo is offline
post #281 of 496 Old 05-27-2016, 08:40 AM
KennyLSU's Avatar
Quoted: 119 Post(s)
Liked: 45
Downloaded and seeded for a while last night. Enjoyed a lot of the scenes in movies that I would typically never watch. Great job overall!
KennyLSU is offline
post #282 of 496 Old 05-27-2016, 09:13 AM
Alan P's Avatar
Quoted: 6344 Post(s)
Liked: 5682
You're welcome, just figured it had been a while and there was plenty of content. Where there's a will there's a way. Now if i could just get the wife to let ne get the reat if the HT toys i need all will be gravy Alas it wont happen, not with a move coming up. When i do i will probably reach out for some REW help as i still have not measured my subs
Yes, once you mount it with VCD you can just copy the individual m2ts files from the STREAM folder to wherever on your NAS. Im unaware of the files supported by kodi, but I would think m2ts files are.
This worked like a charm!
Finally got a chance to extract the M2TS files from the ISO last night. They stream flawlessly through Kodi! I can't attest to the Atmos clips since I have a non-Atmos AVR, but all of the lossless audio is coming through loud and clear...well, the Ultron clips aren't that loud (as expected).
Still seeding!
Alan P is offline
post #283 of 496 Old 05-27-2016, 09:28 AM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
I tried the db boost function on the Ultron clips, but i guess it didn't work. I could have put a disclaimer to turn up your MV for those clips, but i figured most frequenting these threads are aware of the level issue with that particular movie.
Alan P likes this.
Quickett is offline
post #284 of 496 Old 05-27-2016, 09:34 AM
g-man5.1's Avatar
Thanks for the hard work Quickett. This just maybe my favorite disc out of all the demo discs that I have.Thanks to all who put these showcase discs together
g-man5.1 is offline
post #285 of 496 Old 05-27-2016, 11:02 AM
OSUCowboy1389's Avatar
Quoted: 14 Post(s)
Liked: 7
Downloaded last night and have been seeding all day and will continue through tonight. Looking forward to enjoying this when I get my subs in a couple weeks. Thanks to @Quickett for your hard work on this. This kind of stuff is what is great about this forum.
Sent from my SM-G920V using Tapatalk
OSUCowboy1389 is offline
post #286 of 496 Old 05-27-2016, 11:16 AM
Liked: 2
Thank you very much for the Demo.
Greetings from Spain .
hemiutut is offline
post #287 of 496 Old 05-27-2016, 12:59 PM
JosephTonyStark's Avatar
Quoted: 250 Post(s)
Liked: 160
Ha, exactly my thought when I played those tracks last night. Had to reach for the remote...
TV: Samsung 65" UHD LED | Sources: PS4; Panasonic DMP-BT460; LG UB870; Dell 7010 SFF; Roku Ultra | AVP: Marantz AV8802A | Amps: Emotiva XPA-1L\100 (LR\C); Outlaw Audio 7125 | Front LR\C: JBL Studio 590\Studio 520C | Surrounds: JBL P520WS | Subs: PSA S1801 | Heights: JBL Pro Control CRV (2)
JosephTonyStark is offline
post #288 of 496 Old 05-27-2016, 01:00 PM
Quoted: 250 Post(s)
Liked: 160
What subs are you getting?
post #289 of 496 Old 05-27-2016, 01:13 PM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
Now that the disc is in the wild, I'm pretty sure some will finally get to peruse it this weekend.
I have one ask while you are going through it (or if you have already gone through it): critical feedback.
Stuff you didnt like, clips too long, too short? Too many from the same movie etc...?
Please let me know, looking to the 2016 disc.
Would like to have an idea of what people liked and didnt like about this first attempt.
Iron Maiden likes this.
Quickett is offline
post #290 of 496 Old 05-27-2016, 02:01 PM
Alan P's Avatar
Liked: 5682
I did a whole lot of skipping around last night and the only thing I noticed is that there was only ONE clip from Fury Road (?!).
I don't know if it was intentional, but starting off with those two clips from Interstellar kind of makes the following clips a bit of a let down...I mean, those 2 clips are just SOOOO intense...maybe should have left them for the big FINALE! Doesn't matter to me really since I stream them I don't really watch them in order, but I can tell you that the first 3 clips I watched were those first 2 and the MM:FR clip.
On a side note, I did a bit of level tweaking on my subs last night (thanks to the ease of trying out different scenes with your awesome demo disc!) and that Interstellar Launch clip just about made my eyeballs vibrate! I of course own the film, but haven't watched it since going from 2 to 4 subs.
Alan P is offline
post #291 of 496 Old 05-27-2016, 02:04 PM
Alan P's Avatar
Liked: 5682
Oh, and I wanted to mention that I thought that the clip lengths (of the ones I watched) were perfect. You don't want to get dumped right into the BIG BASS, so I liked how you included a bit of "padding" on the front end of the clips. Well done!
BTW, I'm an editor for a living.
Alan P is offline
post #292 of 496 Old 05-27-2016, 02:44 PM
Quoted: 14 Post(s)
Liked: 7
I am getting a pair of infinity 1262w and building my own enclosures.
post #293 of 496 Old 05-27-2016, 03:02 PM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
Started with Interstellar(variable AR) and Ant-Man (2.00 AR) solely based on their abnormal Aspect Ratios. Tried to keep a little thought in their for fellow projector users.
The "explicit" scenes ended the disc out of consideration for those who demo for a more sensitive audience.
MM:FR, it seemed like everyone has it and besides the whole movie is basically a demo in and of itself. wanted to get some scenes that had been mentioned and graphed by our resident bass pusher(picture @Fatshaft in the corner of your room like "I got that 5hz bass hit right here for you he he.") I mean seriously, Poltergeist? And @tvuong mentioned Tremors 5. If not for this disc how many would have seen these scenes?
But hey that is what feedback is for, if people would rather I stay with the known popular scenes so be it. Just let me know. I am open to any and all feedback. Like I tell my wife when she asks if I tell her the truth about her cooking, "Damn right I tell the truth, because if it was nasty I wouldn't want you to make that crap again!" Thank goodness she hasn't made anything that was terrible lol
tvuong likes this.
Quickett is offline
post #294 of 496 Old 05-27-2016, 03:19 PM
Alan P's Avatar
Liked: 5682
Oh no, don't get me wrong, you DUN GOOD!! And I totally understand that there is only so much room on a single disc...you gotta make your choices.
I actually watched Poltergeist and Tremors 5 , only because of the reports on here of the insane bass. It's much nicer to just have the relevant scenes so I don't have to sit through the entire "film" again.
I didn't realize that the scenes at the end were "explicit"...I'll have to check those out tonight!
Alan P is offline
post #295 of 496 Old 05-27-2016, 04:03 PM
tvuong's Avatar
Quoted: 2614 Post(s)
Liked: 2370
I have not got a chance to view the demo disc yet. Still seeding meanwhile.....
tvuong is offline
post #296 of 496 Old 05-27-2016, 04:23 PM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
Wow, 24 seeds and a share ratio of almost 7 is great. Shouldnt be a problem for anyone who wants to get in on this
[IMG][/IMG]
tvuong likes this.
Quickett is offline
post #297 of 496 Old 05-27-2016, 04:55 PM
Jben04's Avatar
Quoted: 56 Post(s)
Only got BD 25 discs at home,, tried to shrink this to fit with DVDfab, but it doesn't wanna behave,,,GRRRRRR
TCL 55P605 4k HDR - LG 47LW5600 (3D) - Energy take classic 5.0 - SVS PB-1000 - Panasonic BDT220 (3D) - Sony BD S350 - Sony BDP-S1700 (Region Free) -
Denon AVR X2100W - Harmony One Remote - Harmony Ultimate One.
Jben04 is offline
post #298 of 496 Old 05-27-2016, 07:39 PM - Thread Starter
Quickett's Avatar
Quoted: 109 Post(s)
Liked: 149
If you have a PC, why not just mount the ISO? Are you able to connect the PC to your receiver?
Quickett is offline
post #299 of 496 Old 05-27-2016, 10:36 PM
Archaea's Avatar
Liked: 3678
Michael
The full format worked thanks the tip. Weird that I've never had to do that before?
Archaea is offline
post #300 of 496 Old 05-28-2016, 03:18 AM
Jben04's Avatar
Quoted: 56 Post(s)
Oh yea ,, that is what i did,, but was hoping to throw it onto a disc... i have 2 Pc's hooked to the TV( different inputs of course lol )
Jben04 is offline
atmos , bass , demo disc , subwoofer
