SVS PB-1000 or 2 subs - AVS Forum | Home Theater Discussions And Reviews
 14Likes
post #1 of 46 Old 06-05-2016, 11:49 AM - Thread Starter
Quoted: 275 Post(s)
I have 2 spots where bass hits the hardest. Right next where our seating area is in our basement rec room and on the corner next to our projector screen.
Would it better to get 2 Dynamo 300's and place them in these pots or 1 SVS PB-1000?
sndr15 is offline
post #2 of 46 Old 06-05-2016, 11:58 AM
eljaycanuck's Avatar
Quoted: 1891 Post(s)
Liked: 2655
ML Dynamo 300
- 8" driver
- 75W (RMS/continuous) amp
- 32–150Hz +/-3dB
SVS PB-1000
- 10" driver
- 300W (RMS/continuous) amp
- 19-270Hz +/-3dB
I'd get an SVS for significantly more overall output and much greater extension.
And if/when additional funds become available, I'd add a second one.
-- Edit --
Another option - something in-between the MLs and the SVS - is dual Klipsch Sub-12 subs, when on sale for ~$200-$230/ea. (at, say, Amazon.com).
Klipsch Sub-12
- 12" driver
- 24-120Hz +/-3dB
eljaycanuck is offline
post #3 of 46 Old 06-05-2016, 11:59 AM
MIX_MASTER_ICE's Avatar
Quoted: 2668 Post(s)
Liked: 2477
How large is the room? Not knowing your basement size, I'll assume it's larger rather than smaller. I wouldn't mess with the Dynamo 300's, especially for home theater. Get one good sub and place it in the best location. Then get another one later on and put it in the other hot spot. Is $500 your max budget?
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #4 of 46 Old 06-05-2016, 12:42 PM
Quoted: 50 Post(s)
Liked: 9
Why not the pb2000?
It's not much more money but much more bass.
Recently got a sb2000 and totally in love. It's more than I need, but will be there when I do.
beardedcrow81 is offline
post #5 of 46 Old 06-05-2016, 12:55 PM - Thread Starter
Quoted: 275 Post(s)
sndr15 is offline
post #6 of 46 Old 06-05-2016, 12:57 PM - Thread Starter
Quoted: 275 Post(s)
Originally Posted by eljaycanuck View Post
ML Dynamo 300
- 8" driver
- 32–150Hz +/-3dB
SVS PB-1000
- 10" driver
- 19-270Hz +/-3dB
-- Edit --
Another option - something in-between the MLs and the SVS - is dual Klipsch Sub-12 subs, when on sale for ~$200-$230 (at, say, Amazon.com).
Would it work well with the Yamaha RX-V379BL AV.
My setup is: BenQ W1070, 110" screen, Yamaha AV, Elac B6 bookshelves.
sndr15 is offline
post #7 of 46 Old 06-05-2016, 01:33 PM
golfster's Avatar
Quoted: 789 Post(s)
Liked: 659
I agree. While two $150 subs may not outperform a $500 sub, Two $250 subs will probably give you a better experience by eliminating the nulls in your room. There was a huge improvement when I added my second sub.
golfster is offline
post #8 of 46 Old 06-05-2016, 01:34 PM
Liked: 2477
Looks like you have a fairly large space. I would be saving up for something more capable of filling that space. I wouldn't be looking at the PB-1000 unless $500 is your absolute max budget. If that's the case, the RBH I-12 would be more capable for the same money,
Madmax67 likes this.
post #9 of 46 Old 06-05-2016, 01:39 PM - Thread Starter
Quoted: 275 Post(s)
Would you get a couple of 8 inch subs and place them where you know the bass hits the strongest?
sndr15 is offline
post #10 of 46 Old 06-05-2016, 01:49 PM - Thread Starter
Quoted: 275 Post(s)
Other than that sub what are some options that I can get now because that particular model costs more at the moment.
sndr15 is offline
post #11 of 46 Old 06-05-2016, 01:52 PM
torii's Avatar
Quoted: 3589 Post(s)
Liked: 2023
I wouldnt even consider an 8 or 10 in sub for the size of your space
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #12 of 46 Old 06-05-2016, 01:57 PM - Thread Starter
Quoted: 275 Post(s)
I used to have a Yamaha soundbar with an 8" sub and believe it not when I placed it in the corner area it had great punch and deep bass. That's what made me think 2 of them would be great.
sndr15 is offline
post #13 of 46 Old 06-05-2016, 01:59 PM - Thread Starter
Quoted: 275 Post(s)
What about the Elac S10 sub?
sndr15 is offline
post #14 of 46 Old 06-05-2016, 02:00 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
What is your budget that you need to stay under for a new subwoofer or 2? It helps to understand what kind of money you plan on spending.
Nobody wants to advise you on more than you could afford and at the same time if you are willing to spend X amount of dollars no need to offer suggestions for cheap subwoofers.
Ive got some stuff
baron2 is offline
post #15 of 46 Old 06-05-2016, 02:01 PM - Thread Starter
Quoted: 275 Post(s)
With the AV, Elac B6, (no center yet, may not even need one) and the sub around $750. Based on the picture would you stay with the B6's or go with tower speakers like the SP-FS52-LR?
sndr15 is offline
post #16 of 46 Old 06-05-2016, 02:05 PM - Thread Starter
Quoted: 275 Post(s)
ML Dynamo 300
- 8" driver
- 32–150Hz +/-3dB
SVS PB-1000
- 10" driver
- 19-270Hz +/-3dB
-- Edit --
Is this the one?
http://www.amazon.com/Klipsch-Sub-12.../dp/B003VIWK0G
sndr15 is offline
post #17 of 46 Old 06-05-2016, 02:09 PM
torii's Avatar
Liked: 2023
yes and that sub goes on sale for under $200 at times
torii is online now
post #18 of 46 Old 06-05-2016, 02:10 PM - Thread Starter
Quoted: 275 Post(s)
How does its specs compare to previous 2? I'm also considering the Elac S10.
sndr15 is offline
post #19 of 46 Old 06-05-2016, 02:16 PM
torii's Avatar
Liked: 2023
https://www.avsforum.com/forum/113-su...endations.html
https://www.avsforum.com/forum/113-su...-300-less.html
maybe these links can help with research....
torii is online now
post #20 of 46 Old 06-05-2016, 02:17 PM - Thread Starter
Quoted: 275 Post(s)
Read those already but I'm looking for room specific recommendations.
sndr15 is offline
post #21 of 46 Old 06-05-2016, 02:21 PM
torii's Avatar
Liked: 2023
I would get the http://www.rythmikaudio.com/L12.html or something similar from svs, psa
torii is online now
post #22 of 46 Old 06-05-2016, 02:22 PM - Thread Starter
Quoted: 275 Post(s)
The Rythmik vs the SVS? I have read better things on the SVS.
sndr15 is offline
post #23 of 46 Old 06-05-2016, 02:27 PM
torii's Avatar
Liked: 2023
svs has the free shipping/return 45 day policy I believe and rythmik has the servo technology
torii is online now
post #24 of 46 Old 06-05-2016, 02:29 PM - Thread Starter
Quoted: 275 Post(s)
I'm still concerned of having 2 bass areas of my room that I need to fill no matter which sub I get.
sndr15 is offline
post #25 of 46 Old 06-05-2016, 02:34 PM
torii's Avatar
Liked: 2023
call svs up and talk to them to advise...or rythmik....or psa. you might be surprised by the responses you get and offers. They are the true experts on their products.
torii is online now
post #26 of 46 Old 06-05-2016, 02:35 PM - Thread Starter
Quoted: 275 Post(s)
I did and SVS told me to get 2 subs at $950. It's over my budget.
sndr15 is offline
post #27 of 46 Old 06-05-2016, 02:37 PM
torii's Avatar
Liked: 2023
bass waves travel at long lengths (maybe 45-50 feet). you might be surprised how well 1 decent sub fills your space.
torii is online now
post #28 of 46 Old 06-05-2016, 02:39 PM - Thread Starter
Quoted: 275 Post(s)
I have about 500 square ft of space to fill.
sndr15 is offline
post #29 of 46 Old 06-05-2016, 02:42 PM
baron2's Avatar
Quoted: 124 Post(s)
Liked: 147
Cant really advise you on switching your bookshelf speakers for the towers since I have never heard those bookshelf speakers before. I can say this, I have a pair of the Pioneer SF-51 towers and the matching center C-21, that was my 1st H/T setup. For the price they did a good job. They have been sitting in their original boxes though for a few years now. I feel its important to have a center channel, preferably a matching or as close as possible for timbre match. If you live in Colorado and are somewhat close I could let you hear the Pioneers. There is not much difference between the 51 and 52 models, just a little different look. You can go to Best Buy to hear the Pioneer 52 towers.
As far as a subwoofer with a $750 budget I would look for a SVS PC-2000 or a PB-2000. You could also go the Klipsch route with 2 RSW-12 subs on sale. Me personally I would rather have just one SVS PB-2000 or PC-2000 than 2 Klipsch subwoofers.
Edit: Just looked at your post again, are you saying you have a combined budget of $750 for the AVR, speakers and the sub?
Ive got some stuff
baron2 is offline
post #30 of 46 Old 06-05-2016, 02:46 PM
torii's Avatar
Liked: 2023
call tom at psa or enrique at rythmik and see what they say. i have 30x50ft with 15" ceilings and ran it for a while with 1 12 in sub...your ? to us is whether 1 sub is better than 2 lower priced subs and it really depends. I would get the best sub I could afford and add another as I saved if I felt I really needed a second sub.
baron2 and sndr15 like this.
torii is online now
