SVS Unleashes 16-Ultra Series Subwoofers Featuring 8" Voice Coil Drivers - Page 132 - AVS Forum | Home Theater Discussions And Reviews
 2818Likes
post #3931 of 3934 Old 05-05-2019, 11:07 AM
Liked: 0
my 3 week old pb 16 ultra went down after contacting the usa and going through the fault process they told me to contact my local dealer who will send an amp out to me for replacement
i told them this will take forever if they have to get one from the usa first. They said they keep spares!! so i told them this is a known issue not very good. They replied it is not a know issue so i said why do the local dealers keep spare amps then he could not answer it
whatever it is not good reliability is it
johnjohn777 is offline
post #3932 of 3934 Old 05-05-2019, 12:13 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5554 Post(s)
Liked: 10772
Hi,
Everyone gets a little frustrated when a product doesn't work properly. It happens with almost every electronic component from time-to-time. Subwoofer amplifiers are covered by dealer warranties precisely because they can fail, after three weeks or after three years. Knowing that, I would say that an SVS dealer who is not in the USA is smart to keep spare amplifiers available for his customers.
SVS products are generally reliable, and are backed by a good warranty and by good customer service. The PB16 is no more subject to amp failures than most other subwoofers. But, as noted, all subwoofers can fail, as can most other electronic components. As long as your dealer can take care of the problem for you, I don't think you have anything to be concerned about.
I have owned a dozen SVS subwoofers, including three PB16's. I upgraded several times from my original starting point, and I added more subs as I learned more about my personal bass requirements. I have only had one real amp failure in all that time. SVS took care of it immediately, as your dealer is doing for you. (Incidentally, the first SVS sub I ever bought is still going strong at a friend's house.)
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #3933 of 3934 Old 05-05-2019, 02:39 PM
drh3b's Avatar
Quoted: 2100 Post(s)
Liked: 4249
The amp is easily the least reliable part of any brand's subwoofer. The fact that your dealer keeps spares on hand for warranty service says great things about either SVS, your dealer, or both.
drh3b is offline
post #3934 of 3934 Old 05-10-2019, 05:41 PM
Hopinater's Avatar
Quoted: 3585 Post(s)
Liked: 11409
I wouldn't worry about this being a reliability issue or a statement against SVS products... its simply bad luck because you got a bad amp. As MThomas said, amps are the most likely part to fail on any subwoofer and any dealer worth their salt will know enough to keep spare amps on hand so they can maintain good customer service. I've had amp failures on subs from more than one highly respected subwoofer manufacturer, it happens.
gene4ht, galonzo and mthomas47 like this.
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
pb16-ultra , sb16-ultra , Svs
