At What Point Do I "Play" With The 0/180 Phase Switch On Dayton 1500 SUB? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By DonH50
  • 1 Post By Alan P
  • 1 Post By Alan P
post #1 of 24 Old 11-30-2016, 08:11 PM - Thread Starter
jhoffy22's Avatar
Quoted: 79 Post(s)
Liked: 33
According to the subs manual, I am supposed to adjust the phase switch based on what provides the most accurate bass output(not even sure how I would measure this). I have a Denon AVR-S710W 7.2-Ch receiver that it's paired with. At what point in the process do I adjust the phase switch? I am going to be doing a sub crawl and setting up my HT tomorrow with Audysey.
jhoffy22 is offline
post #2 of 24 Old 11-30-2016, 08:24 PM
DonH50's Avatar
Quoted: 3483 Post(s)
Liked: 3704
Audyssey should correct the delay so it does not matter. If it gives you an "out of phase" error, flip the switch, but in reality it won't make any difference. Nor will it matter for the sub crawl.
Madmax67 likes this.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 24 Old 12-01-2016, 10:53 AM
Alan P's Avatar
Quoted: 7115 Post(s)
Liked: 6985
You should leave the phase set to 0 on the sub, but you can improve response over the crossover post-Audyssey by adjusting the subwoofer distance in the AVR. Here is a write up I did awhile ago on performing the sub distance tweak with basic tools:
If you don't have measuring equipment, the distance tweak can be done with an SPL meter (or SPL app on a smartphone) and test tones downloadable from the internet, available on YouTube, from a test disc or with REW (free download).
  • For the Center Channel, set your AVR to the Dolby PLII surround mode, you should be getting output from the CC + sub(s) only
  • For the FL/FR channels, set your AVR to the Stereo surround mode, you should be getting output from the FL/FR + sub(s) only
  • Invert phase on your subwoofer(s)
  • Play a sine wave that corresponds to your crossover frequency (i.e. 80hz) and measure the output with the SPL meter about a foot in front of your face at the MLP
  • Gradually increase the sub distance setting in the AVR in 1' increments (on some AVRs you must make sure to back out of the distance setting menu before the new setting will take effect)
  • The sub distance setting that gives you the lowest SPL reading is the setting you want (you can tweak further in smaller increments if you want to, but I have found that 1' increments is usually sufficient)
  • Invert the phase on your sub again and you are done
LastButNotLeast likes this.
Sony XBR75X940D | Denon X4500H | Nvidia Shield | Synology NAS [52TB] | miniDSP 2x4 HD | TiVo Roamio
PSA MTM210 [x3] | Polk LS/fx [x4] | Klipsch RB61 [x2] | Crowson LvL3 MA [x2] | PSA TV42 Ipal [x2]
Alan P is offline
post #4 of 24 Old 01-10-2017, 01:36 PM
Luis5150's Avatar
Quoted: 118 Post(s)
Liked: 117
Alan, which of these two options would be preferred?
| Panasonic TC-P65S2 HD Plasma | Oppo BDP-93 | Paradigm Studio 100's v2 (mains) | Paradigm Studio CC-690 v5 (center) | Paradigm ADP-370 v3 (sides surr.) | Paradigm Studio 20's v2 (sides + back surr.) | SVS PB13-Ultra(x3) | Marantz AV-8801 pre/pro | Emotiva XPA-5 (x2) |
Luis5150 is offline
post #5 of 24 Old 01-10-2017, 01:39 PM
Alan P's Avatar
Liked: 6985
Depends.
If the system is mostly music, use one of the front speakers. If the system is mostly movies, use the CC.
Alan P is offline
post #6 of 24 Old 01-11-2017, 01:52 AM
kevbo123's Avatar
Quoted: 25 Post(s)
I did it a bit differently - not sure if this is flawed in any way?
1. Played tone at my crossover frequency (100Hz) out of LCR and both subs at the same time.
2. Not touching any phase switch I changed both sub distances until I got MAX DB.
What I landed up was both sub distances set 2.6ft CLOSER. This resulted in a + 4DB in the tone.
kevbo123 is offline
post #7 of 24 Old 01-11-2017, 07:53 AM
Alan P's Avatar
Liked: 6985
Mostly fine, but;
- Looking for the null is easier than looking for the peak, this is why reversing phase on the sub is a good idea
- You should only use one of those three speakers (my above post says to use FR+FL and that is incorrect )
Alan P is offline
post #8 of 24 Old 01-11-2017, 08:12 AM
kevbo123's Avatar
Quoted: 25 Post(s)
Thanks. Whats the reasoning around just using one of the LCR?
kevbo123 is offline
post #9 of 24 Old 01-11-2017, 08:33 AM
Alan P's Avatar
Liked: 6985
Two main reasons;
1) Rarely, if ever is the exact same audio output from more than one speaker at a time in real world use
2) Playing the exact same content from more than one speaker can cause issues with comb filtering
Alan P is offline
post #10 of 24 Old 01-12-2017, 01:18 AM
kevbo123's Avatar
Quoted: 25 Post(s)
Two main reasons;
So after doing this I've gained about +5DB at the crossover point. I dont know what exactly this means in terms of overall sound quality from my system but the gain on paper is impressive nevertheless.
kevbo123 is offline
post #11 of 24 Old 01-12-2017, 08:34 AM
Alan P's Avatar
Liked: 6985
It means that your mains (or CC, depending on which you used) are now in-phase with your sub(s). You most likely had a large dip over the crossover region and now you do not. That frequency response region should sound much better now.
I've attached one of my own more extreme examples of what the distance tweak can do.
Name:	Distance tweak mains.jpg
unretarded likes this.
Alan P is offline
post #12 of 24 Old 02-23-2017, 01:37 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Alan, I would like to play with this with my 2 subs, 1 of which is already set to 180 out. How would I best go about this?
Foggy1 is offline
post #13 of 24 Old 02-27-2017, 08:50 AM
Alan P's Avatar
Liked: 6985
Sorry, I haven't been on the forums in a few days.
Did you see post #3? If that doesn't answer your question, let me know!
Alan P is offline
post #14 of 24 Old 02-27-2017, 10:27 AM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Hi Alan, thought maybe you headed out on vacation?. I don't have audesy, i run dual mono subs currently each sub is set at the physical distance to the mlp, setting 1 sub 180 degrees out gives me a nice 5 db increase on highest volume with a measurement sweep and the spectrogram. Would you recommend running each sub seperately for setting the distance with the crossover measurement?
Foggy1 is offline
post #15 of 24 Old 02-27-2017, 10:57 AM
Alan P's Avatar
Liked: 6985
What AVR or pre-pro are you using? Does it allow you to set separate distances for each sub? Does it not have any sort of automated setup routine??
Alan P is offline
post #16 of 24 Old 02-27-2017, 12:07 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Xmc-1 and also a mini-dsp 2 by 4, xmc has dirac, xmc has dual mono sub outs with independent measurement. Set the time delay in minidsp to smoothest response with time delay. From there a polarity switch in 1 sub produced the 5db volume increase
Foggy1 is offline
post #17 of 24 Old 02-27-2017, 01:32 PM
Alan P's Avatar
Liked: 6985
Hmmm...well, if you set the delay correctly in the MiniDSP (have you read AustinJerry's MiniDSP guide?), then there should be no need for you to adjust phase on the subwoofer.
Alan P is offline
post #18 of 24 Old 02-27-2017, 04:22 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
I have read it, perhaps it is time to revisit it. I will endeavor to persevere
Foggy1 is offline
post #19 of 24 Old 02-28-2017, 12:34 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
Found my error regarding 180 degree phase, sorry Alan. I will totter along now?
Foggy1 is offline
post #20 of 24 Old 02-28-2017, 02:52 PM
Alan P's Avatar
Liked: 6985
No need to totter along, it's all good.
If you don't mind, could you post what your error was...? It would be nice for others to know if they happen to have the same issue.
Alan P is offline
post #21 of 24 Old 02-28-2017, 05:32 PM
Foggy1's Avatar
Quoted: 89 Post(s)
Liked: 45
I had set the time delay for the wrong sub?
Foggy1 is offline
post #22 of 24 Old 12-14-2017, 12:59 PM
banyar's Avatar
Quoted: 245 Post(s)
Liked: 101
hi guys,
i'm newby but i'm trying to learn about MBM and i need your help with my setup.
i have two Rythmiks LVX12s in the front wall and i love the superb SQ they bring me but i want more rumble (TR) because this is a HT only setup.
after reading this thread i realize that i need a beheringer B1200d NF, so i bought one and placed it on the back wall next to the recliner. i also bought a miniDSP 2x4HD, UMIK-1 and download REW.
I already read the Austin Jerry guide for REW. I seem to have everything i need to start measuring and adjusting things but the problem is that i don't know where to start.
maybe i have to run audyssey first then REW and last the miniDSP??
please i need your help to organize the steps to follow.
i have:
2 kefs Q100 (L/R)
kef Q200 (CC)
2 NHTs Superzero 2.1 (SL/SR)
Denon S720w
2 Rythmik LVX12s
thanks in advance...
banyar is offline
post #23 of 24 Old 12-14-2017, 01:26 PM
Alan P's Avatar
Liked: 6985
Originally Posted by banyar View Post
hi guys,
i have:
2 kefs Q100 (L/R)
kef Q200 (CC)
Denon S720w
2 Rythmik LVX12s
First of all, what are you planning to do with the MiniDSP? Are you going to use it for the 1200D only, or are you planning on EQ'ing your current subs as well?
If your current subwoofers are going to stay where they are, there is really no reason for you to take Audyssey measurements with REW.
Do not re-run Audyssey after you connect the 1200D, usually you want to only add in the MBM after you have run Audyssey.
You might be better off re-posting this in the MBM thread. You will get more eyes on it that way.
https://www.avsforum.com/forum/113-su...-response.html
And after you have some REW measurements, post those in the REW thread.
https://www.avsforum.com/forum/91-aud...et-graphs.html
Alan P is offline
post #24 of 24 Old 12-14-2017, 01:37 PM
banyar's Avatar
Quoted: 245 Post(s)
Liked: 101
hi guys,
i have:
2 kefs Q100 (L/R)
kef Q200 (CC)
Denon S720w
2 Rythmik LVX12s
You might be better off re-posting this in the MBM thread. You will get more eyes on it that way. [IMG class=inlineimg]https://www.avsforum.com/forum/images/smilies/wink.gif[/IMG]
thanks alan, my bad
banyar is offline
