Official JTR Speakers Subwoofer Thread - Page 403 - AVS Forum | Home Theater Discussions And Reviews
 17142Likes
post #12061 of 12603 Old 03-07-2019, 09:59 PM
sonicgroove's Avatar
Quoted: 40 Post(s)
Liked: 77
The isolation transformer should work. It sounds like a ground loop caused by a double ground from your cable box. When power is grounded at more than one location power will travel between both paths causing too much circuit noise leading the annoying speaker/subwoofer hum. Once that isolation transformer is in place there should be less ground paths thus reduced or eliminated hum, or so we hope. May the odds be in your favor.
-groovin
chucky7 likes this.
sonicgroove is offline
post #12062 of 12603 Old 03-07-2019, 10:44 PM
tanbyte's Avatar
Quoted: 41 Post(s)
Liked: 47
The beasts are here! Still figuring how to get them moved to the 3rd floor
The pics don’t do justice. The actual size of these things is a little intimidating (in a good way)
chucky7, tebling, serith and 9 others like this.
tanbyte is online now
post #12063 of 12603 Old 03-07-2019, 11:45 PM
Quoted: 40 Post(s)
Liked: 77
Man what a tease... showing us just the tips... The picture of them next to the car provides a pretty good perspective of just how intimidating those pair of knockers are. Ohhh man... can't wait to see more.
-groovin
post #12064 of 12603 Old 03-08-2019, 12:50 AM
chucky7's Avatar
Quoted: 3368 Post(s)
Liked: 4050
Originally Posted by gutcheck2001 View Post
And I can’t kill these hums. I can’t turn the gain up past two clicks. Now when I unplug the cable I still have a hum. Tomorrow a coax ground filter and a line level filter are coming from blue jeans. I really want to keep these. If this doesn’t work I may have an electrician take a stab at it.
If you unplugged the RG6U cable and there is still a hum from sub 1(I assume sub 2 doesn't hum anymore), then the line level filter should work. It's recommended by the most professionals, but also the most expensive.
If you use the cheater plug, does sub 1's hum go away completely?
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #12065 of 12603 Old 03-08-2019, 12:53 AM
chucky7's Avatar
Liked: 4050
Attachment 2535876
Attachment 2535878
So you went from the S2 to 2 4000ULFs ?
No wonder!
tanbyte likes this.
post #12066 of 12603 Old 03-08-2019, 07:39 AM
MinnesotaGreg's Avatar
Quoted: 119 Post(s)
Liked: 97
Hum
Hey All, While I'm waiting for my Ebony Madagascar 4000ULF I've been reading a lot of sites. Over on Facebook an electrician and maybe DJ commented on audio equipment hum, topic of interest on this page. He states hum will exist if the power circuits are on different phases in the electrical panel. If I understand him correctly, the breakers in odd slots are on the same phase (or all those in the even slots are on the same phase), so all your audio equipment power circuits should be in odd or even slots in the panel. For what its worth....and not sure if it's true.
MinnesotaGreg is offline
post #12067 of 12603 Old 03-08-2019, 07:53 AM
gutcheck2001's Avatar
Quoted: 209 Post(s)
Liked: 162
That was a response to my post lol. I will have an electrician look into that if I can't silence them.
MinnesotaGreg likes this.
gutcheck2001 is offline
post #12068 of 12603 Old 03-08-2019, 07:56 AM
Quoted: 209 Post(s)
Liked: 162
Hey Chucky.
So ever since the cable guy came the coax hum seems to be gone. I turned the gain up a few clicks (I would like to land at gain 50%) and there is still a soft him from sub 1. Sub 2 is really loud. A cheater plug fixes sub 1 and greatly reduces the hum from sub 2 but it is still there a little. Both subs are silent with the rca removed and powered on so I don't suspect it is the subs themselves.
Today my filter gets here so I will try that.
post #12069 of 12603 Old 03-08-2019, 09:29 AM
chucky7's Avatar
Liked: 4050
Hey Chucky.
Yeah, I am a little lost here because you have before and after the cable guy came, compounded with Sub 1 and 2...
Hopefully the BJ Subwoofer Isolation Transformer is all you need for both subs.
post #12070 of 12603 Old 03-08-2019, 09:38 AM
Quoted: 209 Post(s)
Liked: 162
I think the issue is that cable appointment. He claims the cable wasn’t grounded to the house, direct TV was (which I used to have years ago). So he supposedly fixed it and we both expected the hum to be gone. Now, it’s actually worse but doesn’t seem to have anything to do with the cable coax being connected or disconnected.
I may order a bunch of SVS or BJ RCA cables to connect my amps up and the subs as the cables now are mixed brands. Let’s see if the isolation stuff works, will for sure update. I am confident they will as the cheater plugs really help sub 2 and silence sub 1.
chucky7 likes this.
post #12071 of 12603 Old 03-08-2019, 11:00 AM
04rex's Avatar
Quoted: 320 Post(s)
Liked: 64
Some cables that I used in the past that reduced the effect of Hum where the Acoustic Research Master Series RCA cables. Unfortunately they aren't made anymore, but in the past when I had a hum, I used these cables instead and the Hum was virtually gone after. Only noticeable if you put your ear to the woofer.
FAMILY ROOM - Totem Tribe II LCR, JL Audio E-112, Anthem MRX 720, Apple TV, WD HDTV, Panasonic 55" Plasma
BASEMENT THEATRE - Paradigm Studio 100 v5, 690 v5, 10x4 v5, Anthem AVM 60, Outlaw Audio 7700 & 7125, 2x JTR Captivator S2s, X-Box One, Apple TV, HTPC, Ben-Q W1070, 106" screen
04rex is offline
post #12072 of 12603 Old 03-08-2019, 01:20 PM
Quoted: 209 Post(s)
Liked: 162
Dead silent!!!! Blue jeans line level filter worked great!
cannga, chucky7, Alan P and 10 others like this.
post #12073 of 12603 Old 03-08-2019, 02:46 PM
Quoted: 40 Post(s)
Liked: 77
I knew the odds would be in your favor! Congrats! The moment you determined the issue stemmed from your cable box your solution solution became clear. Good job hunting down the source. Its not always easy and more often than not ground loop can be quite annoying to isolate.
-groovin
post #12074 of 12603 Old 03-08-2019, 03:11 PM
Quoted: 177 Post(s)
[QUOTE=tanbyte;57712006]The beasts are here! Still figuring how to get them moved to the 3rd floor
Please let us know how you moved them to the third floor. I want to get them too but am really worried about moving them around and then fit them in my space. Enjoy the beasts
mir3acles is offline
post #12075 of 12603 Old 03-09-2019, 01:44 PM - Thread Starter
cannga's Avatar
Quoted: 1848 Post(s)
Liked: 1823
-groovin
What I don't understand is why is it that so often it's the cable box that is the culprit for ground loop problem?? I mean there are so many components, what is it about the cable box that is different?
Does it have something to do with the RG6 input cable? This seems the only thing "unique" electronically to the cable box.
Regards, Can
My System & Theta Casablanca Mini-Review (CB IVa setup help HERE) Uncontrolled passion for music, and sound.
Interesting Audio Diagrams :-) & High-End Speaker Reviews
JTR Subwoofer Thread I don't always listen to subwoofers, but when I do, it's JTR :-).
cannga is offline
post #12076 of 12603 Old 03-09-2019, 02:34 PM
drh3b's Avatar
Quoted: 1747 Post(s)
Liked: 3142
Just a guess, but probably because it is often grounded in a totally different place. Mine, for instance, is grounded in the cable box. I'm not sure what caused the ground loop in my abortive diy subwoofer experiment, but I have figured out that I can avoid it by using only equipment that has lifted ground(2 wire power plug). So, just to make my audio life easier, I won't even touch something with a grounded plug, literally and figuratively. It was blind luck that every thing I bought had lifted grounds until the diy subwoofer debacle. When I replaced my starter subs with better ones, it was one of the things I looked at. I got the subs I really wanted anyway as they had lifted grounds.
drh3b is offline
post #12077 of 12603 Old 03-09-2019, 05:55 PM
Quoted: 209 Post(s)
Liked: 162
Ok guys. Subs are installed and have a few silly questions:
1) hookups - I have the option to go XLR on the front sub, stuck with RCA on the rear. Any benefits to either? Y-split hookup the RCA?
2) my AVM 60 apparently doesn’t calibrate two subs as individuals just tells me to level match them and it tests them as a single sub, which kinda pisses me off. They are sounding ok but I can’t setbdual distances. Makes me want to by an AV7705. Any advice?
I pinged the AVM 60 thread they helped a lot.
3) rubber feet. I am getting quite a bit of rattle. One sub is going on it’s side the other standing both on hardwood. I got some temporary furniture pads but they aren’t cutting it. What about the SVS SoundPath feet? Or maybe some of those subwoofer pads from amazon?
post #12078 of 12603 Old 03-09-2019, 06:57 PM
Quoted: 40 Post(s)
Liked: 77
The dish or cable source is likely grounded then connects to your home power which is also grounded. Grounds are a safety feature normally required by the city just like how your water heater requires a double strap (earthquake prone areas), your gas lines need a lighting shield and a ground, main water line needs a ground, etc. Older homes weren't grounded so ground loop wasn't so much an issue but now laws mandate homes to be grounded so power sources like cable TV that provided its own ground is now being grounded at two or more locations (signal cable ground plus your homes power ground). This is where filters and isolators help minimize or eliminate electrical noise from too many grounds.
-groovin
cannga and chucky7 like this.
post #12079 of 12603 Old 03-09-2019, 07:05 PM
leehan76's Avatar
Quoted: 61 Post(s)
Liked: 58
If you really want to get the most from your dual subs in different locations of your room, I’d highly recommend investing in a MiniDSP 2x4HD and downloading the REW software. ARC can work well if your subs are equidistant from your MLP. But... you’d need to time align your subs so they hit your ears at the same time. I love ARC but it doesn’t have independent sub controls but instead treats multiple subs as one, not doing time alignment. I might or might not experiment with trying to run ARC on my dual JTR Cap S1’s then equalizing with REW to compare graphs. But currently I just let my AVM 60 calibrate all my speakers above 120hz. I then use REW to figure out the exact time alignment so both subs truly are acting as one sub despite being in two very different locations in my room. Adding peq’s to certain frequencies also helped tame massive peaks which make for better quality bass. Anyway, this is what’s working in my system so far to great effect. I really feel like I’m getting the most from my subs in my room, backed by REW’s measurements! But there are lots of guys with far more sub tuning experience than me here so you’ve come to the right place.
Credit to @ereed for teaching me the powerful effectiveness of using REW with MiniDSP to tune multiple subs.
chucky7 likes this.
Subs: JTR Captivator S1 x2 Speakers: KEF R300 (L/R), KEF R600c (Center), KEF Ci160QR x4 (Atmos), Dynaudio Audience 50 (Surrounds) Processor/Amps: Anthem AVM60, Anthem MCA325, Rotel RB985 mkII Misc: Samsung K8500, ATV 4k, Sony PS4, MiniDSP 2x4HD Video: BenQ HT2050, 100” Screen Room: 2500 cu sq. ft. sealed on suspended floor
leehan76 is online now
post #12080 of 12603 Old 03-09-2019, 07:07 PM
Quoted: 209 Post(s)
Liked: 162
It’s like you were reading my mind. Ok I’ll get a mini dsp but I’m totally scared of this REW stuff. Will the ARC mic be ok with it or do I need one from them?
leehan76 likes this.
post #12081 of 12603 Old 03-09-2019, 07:23 PM
leehan76's Avatar
Quoted: 61 Post(s)
Liked: 58
Unfortunately the proprietary mic that comes with your Anthem doesn’t work with REW.
A Umik mic for around $90 on Amazon or, cheaper yet, a Dayton one work well for running REW measurements.
I was very intimidated with having to learn REW initially. As in very, very hesitant. I though what could it do that ARC couldn’t with my dual subs? Boy was I wrong!! My subs’ response post ARC were anything but flat, as shown on my REW graph, although ARC showed them to be... After getting the hang of what REW with a MiniDSP 2x4HD can do, it becomes a lot easier just like using ARC. Just learn from the guys who’ve used both and man it gets loads easier...
This is a good overview on the topic:
Have fun! Welcome to the rabbit hole.
post #12082 of 12603 Old 03-09-2019, 07:25 PM
Quoted: 209 Post(s)
Liked: 162
Does the rabbit hole have a bottom? Ok adding to cart.....
post #12083 of 12603 Old 03-09-2019, 07:40 PM
leehan76's Avatar
Quoted: 61 Post(s)
Liked: 58
That’d depend on you but the cool thing about the MiniDSP 2x4HD is that it allows independent controls of up to 4 subs if you ever have the need to add more subwoofage.
post #12084 of 12603 Old 03-09-2019, 07:41 PM
Quoted: 209 Post(s)
Liked: 162
Ok ordered a 2x4hd and a umik 1
post #12085 of 12603 Old 03-09-2019, 07:42 PM
leehan76's Avatar
Quoted: 61 Post(s)
Liked: 58
Excited for you. Be prepared to optimize your subs
post #12086 of 12603 Old 03-09-2019, 07:45 PM
chucky7's Avatar
Liked: 4050
I would get the UMIK-1 first and start using the REW. You need these tools to look at your FR.
Then after you have tried all the adjustments and still are unhappy with your FR, get the miniDSP 2x4HD.
post #12087 of 12603 Old 03-10-2019, 10:58 AM
ahblaza's Avatar
Quoted: 2447 Post(s)
Liked: 3376
There's a good tutorial time aligning multiple subs with miniDSP 2X4
https://www.dropbox.com/s/w7jmpozner...%20Version.pdf
Like Chucky said it would be a good idea to get into the excellent REW guide authored by @AustinJerry to get a feel of what's happening with your bass response and what you'll need to work on, the link is in my sig, good luck.
Cheers Jeffrey
chucky7 likes this.
ahblaza is online now
post #12088 of 12603 Old 03-10-2019, 12:13 PM - Thread Starter
cannga's Avatar
Liked: 1823
Great. @chucky7 mentioned these higher power Speaker Power amps are susceptible to hum. Maybe Jeff should send Blue Jeans isolation transformers with all 2400/4000.
I am curious: does any 2400/4000 owner use the balanced (XLR) input? Do 2400/4000 owners have hum if you use XLR input?
Asking because it seems that Blue Jeans Isolation Transformer is single ended (RCA) only.
Regards, Can
cannga is offline
post #12089 of 12603 Old 03-10-2019, 12:17 PM
MKtheater's Avatar
Quoted: 2309 Post(s)
Liked: 2249
I use the XLR from my speakerpower amp and no hum. RCA to xlr even.
MKtheater is online now
post #12090 of 12603 Old 03-10-2019, 12:34 PM
Quoted: 209 Post(s)
Liked: 162
I tried an xlr wire and I liked the way it locked in there but there was still a hum.
