Official JTR Speakers Subwoofer Thread - Page 404 - AVS Forum | Home Theater Discussions And Reviews
 18722Likes
post #12091 of 13411 Old 03-10-2019, 01:48 PM
tanbyte's Avatar
Quoted: 47 Post(s)
Liked: 47
[quote=mir3acles;57716258]
Originally Posted by tanbyte View Post
The beasts are here! Still figuring how to get them moved to the 3rd floor
Please let us know how you moved them to the third floor. I want to get them too but am really worried about moving them around and then fit them in my space. Enjoy the beasts
I got a mover at first thinking i would be able to help out. He came with a dolly. We strapped one sub to it. We could only do it length wise rather than sideways, since the width of my stair case is smaller than than the width of 4000ULF.
When we attempted to tilt the dolly, it just wouldn’t stay and even the full weight of the mover wasn’t enough to keep it tilted. This would be a big problem going up the stairs since we needed not only to keep it tilted, but at the same time drag it up the stairs, one step at a time. Too risky, so we gave up!
Second day, i got a couple of movers from thumbtack who specialized in heavy items moving. They had done a lot of pianos. I had posted the sub snaps and specified the weight so they knew the size of the job. They assured me it would be done with care.
They came right over, removed the grills and double strapped the sub to a motorized dolly. It was still a mission maneuvering the sub due to limited space but they managed to get it up. After they were done, he told me he had underestimated the job coz it was ‘just a couple of speakers’. But in fact, these were the heaviest speakers they had come across
ID:	2537040Click image for larger version
ID:	2537042Click image for larger version
cannga, chucky7, tebling and 11 others like this.
tanbyte is offline
post #12092 of 13411 Old 03-10-2019, 02:05 PM
imureh's Avatar
Quoted: 2857 Post(s)
Liked: 3579
[quote=tanbyte;57724902]
Attachment 2537040Attachment 2537042Attachment 2537044
Wow, how big is that room? And looks like it’s on a suspended floor? Look out for some Sheetrock damage!
DRC3 likes this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #12093 of 13411 Old 03-10-2019, 03:28 PM
tanbyte's Avatar
Quoted: 47 Post(s)
Liked: 47
[quote=imureh;57724984]
Its an open room about 23’ x 30’ x 8’ but the theater section is only about half of it
tanbyte is offline
post #12094 of 13411 Old 03-10-2019, 06:52 PM
gutcheck2001's Avatar
Quoted: 215 Post(s)
Liked: 167
I just read the mini dsp manual and their suggested procedure for methods A,B, and C. I need some Advil.
Alan P, ahblaza, leehan76 and 1 others like this.
gutcheck2001 is offline
post #12095 of 13411 Old 03-10-2019, 09:03 PM
sonicgroove's Avatar
Quoted: 40 Post(s)
Liked: 77
That screen is massive! 120+ inches? Is that going to be your final layout or is that just temporary until you get everything settled? Either way that looks to be a nice setup. I'd also like to have an entire wall as a screen. Maybe my wish will come true in the future if I live long enough.
-groovin
tanbyte likes this.
sonicgroove is offline
post #12096 of 13411 Old 03-11-2019, 01:00 AM
tanbyte's Avatar
Quoted: 47 Post(s)
Liked: 47
-groovin
Its at 158” scope. Most of the theater is done but there’s still some work required to conceal wires and the equipment, and some room treatment as well. And atmos too, some time soon hopefully!
ziocomposite likes this.
tanbyte is offline
post #12097 of 13411 Old 03-11-2019, 01:45 PM
Quoted: 215 Post(s)
Liked: 167
Ok my DSP is here and I’m ready to give this a shot. When you build this down my plan is:
1) Run ARC with subs there with the idea of “cleaning up” the bass with REW/DSP.
2) setup DSP so one RCA comes from the anthem splitting two outs to the subs. Configure DSP with the plugin.
3) Get a baseline curve with sub 1, run three tests and auto EQ the average with REW.
4) use multi sub method B as they are not symmetrical. Run three more measurements with sub 1’s auto EQ’ed settings.
5) run same measurements with sub 1 and 2 on. Play with gain settings and timings to get the best curve I can. Verify that it is “better” then my single sub auto EQ’ed baseline.
6). Apply global eq and note changes in measurements.
7) enjoy my life.
Does this procedure look ok? Missing anything?
post #12098 of 13411 Old 03-11-2019, 04:44 PM
Quoted: 215 Post(s)
Liked: 167
Ok, got through 1 and 2. My output 2 on my mini dsp is either dead, or I am hooking it up wrong but when I put the subs on outs 1 and 3 and played a test tone they both fired, so I will leave em there. Pretty cool little device.
post #12099 of 13411 Old 03-11-2019, 04:49 PM
Gorilla Killa's Avatar
Quoted: 1458 Post(s)
Liked: 2070
Input 1 does output 1&3, Input 2 does Output 2&4
ahblaza likes this.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #12100 of 13411 Old 03-11-2019, 06:06 PM
Quoted: 215 Post(s)
Liked: 167
Well that would explain that.
post #12101 of 13411 Old 03-11-2019, 06:47 PM
ereed's Avatar
Quoted: 2304 Post(s)
Liked: 1625
Yes by default Input 1 does output 1 and 3 but you can go in there on plugin and change it to where Input 1 does all 4 outputs without the need to connect 2nd input.
ahblaza and leehan76 like this.
Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1075 | Rotel RMB-1077 | Rotel RSP-1068 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
ereed is online now
post #12102 of 13411 Old 03-12-2019, 10:17 AM
Quoted: 215 Post(s)
Liked: 167
Hi guys,
Ok, my mic is here and I have a pretty stupid question. So, to get my PreAmp to fire off the level tones for calibration I assume I run an HDMI cable from my mac to the Pre? First time doing this....
post #12103 of 13411 Old 03-12-2019, 10:36 AM
Alan P's Avatar
Quoted: 6347 Post(s)
Liked: 5683
Hi guys,
Have you read through AustinJerry's REW guide (linked in my sig)? I don't have a Mac, but I think he has a section in there for Mac users.
To answer your immediate question;, yes, the computer needs to be connected to the AVR/pre-pro via HDMI.
Alan P is offline
post #12104 of 13411 Old 03-12-2019, 10:57 AM
beastaudio's Avatar
Quoted: 5621 Post(s)
Liked: 5458
You absolutely need to get your two subs dialed in to each other via distance/phase/delay settings to get a good impulse response in REW before running ARC. Some preliminary global EQ to that "One" sub you get afterwards may also yield better results before running ARC so arc won't have to apply as many filters. If you intend to have a rising house curve for your sub, you won't want to do this part until AFTER arc is run as it will attempt to smooth out your response and negate any attempts at a house curve prior to running the EQ software...
beastaudio is online now
post #12105 of 13411 Old 03-12-2019, 11:22 AM
Quoted: 215 Post(s)
Liked: 167
Reading now. Quite the novel.
post #12106 of 13411 Old 03-12-2019, 11:25 AM
Quoted: 215 Post(s)
Liked: 167
Ok, I can do this.
From what I read on mini dsp's site the only way to auto cal the phase / gain is with MSO, which looks to give the best results anyway. Have you tried that?
post #12107 of 13411 Old 03-12-2019, 11:34 AM
beastaudio's Avatar
Liked: 5458
Ok, I can do this.
I cannot use MSO as it's calculations assume a rectangular room of some sort. I have a bar/alcove off to one side of my room with a stairwell and hallway to exterior door also coming off the two back corners of the room so between all of that, I wouldn't trust it to get it right...plus, I just do it manually as I have done for 10 years now... If you've got the standard rectangular room, I would absolutely give MSO a try.
ahblaza likes this.
post #12108 of 13411 Old 03-12-2019, 11:35 AM
Quoted: 215 Post(s)
Liked: 167
It is a square, but open to a kitchen.....
Can I ask how you set the gain / phase? SPL for gain and by ear for phase?
Thank you as always for your help. High effort high reward.
post #12109 of 13411 Old 03-12-2019, 11:54 AM
The Ultimate chest punch!
Adamg (Ret-Navy)'s Avatar
Quoted: 947 Post(s)
Liked: 2087
Originally Posted by cannga View Post
What I don't understand is why is it that so often it's the cable box that is the culprit for ground loop problem?? I mean there are so many components, what is it about the cable box that is different?
Does it have something to do with the RG6 input cable? This seems the only thing "unique" electronically to the cable box.
Hi Can,
It has to do with the way the Cable Box manufacturers use/apply the HDMI CEC Pins assignment. From what I have been able to research, there is a mismatch ground pin between the Cable Box Out and the AVR in and the HDMI chain. The subs seem to be affected the most and they normally have the highest/sensitive Amps.
https://www.avsforum.com/forum/113-s...l#post57638260
As to why they do this (the cable box manufacturers) I have no clue. But there is an easy and inexpensive fix. A HDMI Adapter that lifts the ground pin in the HDMI chain. Far safer solution than using an Electrical Outlet Cheater Plug. Here:
Lindy HDMI CEC Less Adapter, Female to Male (41232):
https://www.amazon.com/dp/B00DL48KVI...rum-convert-20
cannga and ahblaza like this.
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is offline
post #12110 of 13411 Old 03-12-2019, 12:23 PM
Quoted: 40 Post(s)
Liked: 77
I just received notice that Jeff is planning to finish my subs today and hopes to get it shipped out! I'm really looking forward to accepting these structural damaging monsters.
-groovin
post #12111 of 13411 Old 03-12-2019, 12:35 PM
beastaudio's Avatar
Liked: 5458
Ok, sub closest to you will need to be delayed to match its "Virtual distance" with your furthest sub. Start out with zero delay on your furthest sub, zero out the anthem for "Distance" for the sub channel as well. Turn off your main speakers if at all possible while sweeping the sub response and turn your LPF all the way up on the LFE channel if you can. Run a sweep with just the furthest sub operating and keep that response on your REW screen. Gain match your second sub with the first and run a second sweep with just the second sub operating. put this solo response on your REW screen as well.
Now turn both subs on and start running sweeps while slowly adding ms of delay in the minidsp to the closer (2nd) sub until you see the best (and highest spl across the majority of the bandwidth) response when the two are combined. With the minidsp HD you have a decent amount of delay that should easily cover this. You can also use the ETC graphs and impulse response tabs in REW to double check your findings. Each foot of distance difference in sub distance is roughly equivalent to 1ms of delay. So if your closer sub is 4.5 feet closer than your further sub, that's essentially 4.5ms of delay to get them time aligned. This may not yield the absolute best response to start with, but you can then apply some global EQ in the minidsp to fix that. You should now be in good shape to do that, as well as let ARC "See" the sub as one single entity.
chucky7, ereed, ahblaza and 1 others like this.
post #12112 of 13411 Old 03-12-2019, 05:36 PM
Quoted: 215 Post(s)
Liked: 167
I could buy the Dirac plugin for the mini dsp. Think that would yield better results? Sure sounds easier.
post #12113 of 13411 Old 03-13-2019, 07:23 AM
beastaudio's Avatar
Liked: 5458
Can you? the DDRC is an additional $200 over the HD's price to validate the usage of dirac's licensing...If you just buy the plugin I guess you pay that premium then to be able to get it?
I dunno, yes it would be way easier but, do you actually want to learn something along the way? Or just let the machines do the thinking for you...
post #12114 of 13411 Old 03-13-2019, 08:34 AM
Quoted: 215 Post(s)
Liked: 167
I guess I will see how far / happy I can make myself with REW. I managed to hook everything up and it seems to be working fine. Did a couple LFE only measurements, which also worked (was concerned about this, as I am on a Mac). So now I just need some time alone to figure out how to do proper multi-measurements and apply an EQ and import that into the mini dsp. Getting there....
otismojo likes this.
post #12115 of 13411 Old 03-13-2019, 12:46 PM
Quoted: 73 Post(s)
Liked: 76
The amp on one of my 2400s is bad and Im sending it to speaker power to get repaired or replaced does anyone know how to remove the amp, is it easy and is there any online tutorials I can read as I never replaced an amp before ?
BobZealand is offline
post #12116 of 13411 Old 03-13-2019, 01:10 PM
chucky7's Avatar
Quoted: 3569 Post(s)
Liked: 4591
1. Remove the 12 screws around the opening.
2. Plug in the power cord (make sure it is not plugged into the outlet) and use it as a handle to loosen the amp plate from the cabinet.
3. SLOWLY separate the amp plate from the cabinet.
4. Put it aside as you need to reach into the cabinet to disconnect 2 wires that go to your driver.
5. disconnect the wire to the driver.
The following post has some pictures:
https://www.avsforum.com/forum/113-s...l#post57638714
Hope this helps!
BobZealand likes this.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #12117 of 13411 Old 03-13-2019, 01:12 PM
beastaudio's Avatar
Liked: 5458
Ok, That's enough. By my count IIRC that is like 3 of the last 5 2400's that are suffering amp issues, and even more over the past year or so. It seems there is a systemic issue with the 2400 amps and if I were Jeff I would be LIVID.
chucky7, toddct, ereed and 3 others like this.
post #12118 of 13411 Old 03-13-2019, 04:41 PM
Quoted: 73 Post(s)
Liked: 76
Hope this helps!
chucky7 likes this.
post #12119 of 13411 Old 03-13-2019, 06:29 PM
ereed's Avatar
Liked: 1625
Brian left Speaker Power and I believe that is same time when QC started going down.
ereed is online now
post #12120 of 13411 Old 03-13-2019, 06:36 PM
N8DOGG's Avatar
Quoted: 1321 Post(s)
Liked: 1556
For anyone thinking of moving big subs, shoulder dollys literally are the easiest and best way to go about it. I do a lot of moving of huge subs and demo of buildings etc. 2 normal off the street people can easily do 350lbs-400lbs. 2 adults with even a slight bit of strength can do 500 to 600lbs. These and the forearm forklifts are 2 tools I would never go without. You could lift those 2 JTR4000's up the stairs in any configuration failry easily. I moved my 2 x Ghorns with my and my wife up and down 3 flights of stairs!! 280lbs each!
https://www.amazon.com/dp/B00022749Q...s%20-%20LD1000
Otherwise, moving blankets with handles, rest the sub on the blanket, one push and one pull and slide it up or down the stairs works in a pinch.
N8DOGG is offline
