Official JTR Speakers Subwoofer Thread - Page 419 - AVS Forum | Home Theater Discussions And Reviews
 20106Likes
post #12541 of 14144 Old 05-15-2019, 11:28 AM
nb67's Avatar
Quoted: 53 Post(s)
Liked: 57
Originally Posted by desertdome View Post
Switch
  • On - Amp stays on all the time
  • Auto - Amp will turn on with signal and shut off after a period of time with no signal
  • Off/12V - Amp is off but can also be triggered on/off with 12V trigger
Gain - The amp has a fixed gain of +45 dB. With the Gain knob all the way up, the amp will reach maximum power with only 316mV. Turn the Gain knob down to lower the incoming input voltage.
LF Adjust - This adjusts the slope of the low frequency roll-off with a hinge of ~35Hz. Note that it has changed since measured below in 2016.
Crossover - This adjusts the low pass filter of the subwoofer. It should typically be set to off. Your processor or receiver will handle the low pass filter.
Delay - This will allow you to delay a subwoofer up to 20 ms. This can be used to delay a closer subwoofer to match a further away subwoofer. Usually the processor/receiver will be used to set the delay of the subwoofer system.
Use the XLR input if you have balanced output and the RCA Left Input/LFE if you have unbalanced output from your processor/receiver. The XLR Looping Output can be used to send the original signal to another subwoofer.
The top 12V trigger allows one to turn on the amp from a 12V trigger on a processor/receiver. The bottom 12V trigger is for looping the signal to another subwoofer or device like the projector, retractable screen, or amplifier.
Thanks Desertdome, that helps a lot. It was more the function of the "LF adjust" I was after and graph clearly explains that.
nb67 is online now
post #12542 of 14144 Old 05-15-2019, 08:35 PM
chucky7's Avatar
Quoted: 3731 Post(s)
Liked: 5070
Basically, the LF Adjust provides more output down low. Therefore, if you are aiming for a flat FR, the setting for a smaller room will be lower than that for a larger room.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #12543 of 14144 Old 05-17-2019, 10:02 AM
MinnesotaGreg's Avatar
Quoted: 145 Post(s)
Liked: 88
Anyone know what this plug is for on the back of the JTR 4000ULF amp and why it's a unique shape?
Sony HW45ES - Seymour Center Stage XD 145" 16:9 - Sony PS3/4 - Onkyo 830 - (LR) Paradigm - (C) Polk CSI A6 - JTR 4000ULF sub - Micca R-8C (6x)
MinnesotaGreg is offline
post #12544 of 14144 Old 05-17-2019, 10:10 AM
chucky7's Avatar
Liked: 5070
It's a speakON connector by Neutrik. It is usually not used.
In a master and slave configuration, the SpeaKON connector is used to connect the slave unit(s) to the master unit.
I am not sure if a user with 2 JTR subs can connect sub 2 to sub 1 with speakON.
post #12545 of 14144 Old 05-17-2019, 10:39 AM
rangers's Avatar
Quoted: 81 Post(s)
Liked: 63
About two months ago I received my S2 and two slanted 8ht rear speakers. Jeff painted the rears to match the trim color in my room (alabaster).
They came out perfect. They blend sonically with my front 212s and aestheticaly with my room. The S2? Come on man, you know that is a beast!
Jeff does great work and takes the home audio experience to a very high level.
JTR Noesis 212HTR (LR)JTR 228 (Center and Surrounds)Seaton SubMersive HP Plus and Minus (Subs)Denon 3312 (Receiver)Sherbourn PA 7-350 (Amp)Oppo BDP-103 (BluRay Player) and Sharp 80" TV
rangers is offline
post #12546 of 14144 Old 05-17-2019, 04:39 PM
imureh's Avatar
Quoted: 3225 Post(s)
Liked: 4248
Any one know what is the dispersion angle for the Slanted 8LPs? I am looking for something around 120 degrees. The obvious choice seems to be bipole but can't find anything with high efficiency...
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #12547 of 14144 Old 05-17-2019, 06:13 PM
chucky7's Avatar
Liked: 5070
Per Jeff, the coaxial driver's dispersion angle is 90 x 90.
AFAIK, if these have wider dispersion horizontally, then they would be narrower vertically. Therefore you see 90 x 90 or 120 x 60 or less.
post #12548 of 14144 Old 05-17-2019, 06:23 PM
imureh's Avatar
Liked: 4248
I need it for this application for side surrounds
post #12549 of 14144 Old 05-17-2019, 06:54 PM
chucky7's Avatar
Liked: 5070
When you have side surrounds very close to multiple rows of seating, it is pick your poison...
post #12550 of 14144 Old 05-18-2019, 09:22 AM
imureh's Avatar
Liked: 4248
That is what I am dealing if I moved the surrounds to the sides. I am told that it should result in an improvement in my listening experience as the gap from the fronts to the surround is big. I just need to know for sure if the JTR single 8 LP or slanted LP will work in this case. The PSA have a 90 degree dispersion angle. So I could PSA or if JTR is more than JTR. Tried Jeff several times through mediums but can’t get a response.
post #12551 of 14144 Old 05-18-2019, 09:36 AM
The Ultimate chest punch!
Adamg (Ret-Navy)'s Avatar
Quoted: 1051 Post(s)
Liked: 2412
Would something like this work for your arrangement. Possible?
https://www.klipsch.com/surround-sound-speakers
AdamG, ...out!
The government cannot give to anybody,
anything that the government does not first,
take from somebody else.
Adamg (Ret-Navy) is offline
post #12552 of 14144 Old 05-18-2019, 09:48 AM
imureh's Avatar
Liked: 4248
Hi Adam, potentially and will try them out. If I could a speaker from JTR or PSA that can work for this application then that would be preference. I have also heard that the new Dolby ATMOS and DTS-X sound modes do not recommend dipole/bipole speakers at all. The main reason is that the new 3D object based up mixers assume you are using direct radiating speakers all around as the effects are totally directional. If that is the case that the bipole may not work but only way to know is to try I guess.
Adamg (Ret-Navy) likes this.
post #12553 of 14144 Old 05-18-2019, 10:24 AM
ahblaza's Avatar
Quoted: 2523 Post(s)
Liked: 3746
Ray, I found these JBLs that have wide horizontal dispersion 110-120 degrees, and variable mounting options, not cheap or small either though and very sensitive. I still think the 110sr would work just fine.....if not send them back.
http://www.jblpro.com/www/products/c...s#.XOAwB9QrIW0
ahblaza is offline
post #12554 of 14144 Old 05-18-2019, 10:31 AM
Liked: 2412
Hi imureh,
Yeah I was just looking at the location you plan to mount these. Right in the middle of two rows of seats slightly forward and rearward. I just tossed it out as an option. Not the perfect solution, but sometimes we have to make compromises. The problem is the distance from the Wall mount location to the seats. So close the dispersion cone will be pretty narrow. However, you could gain some distance by moving your mounting location higher on the wall and slightly angle the speakers downward. Tough choices here. In the end it is what it is. Can only do so much to an existing room and its dimensions.
Good luck and let us know what you experiment with. Will be interesting to learn how you deal with this.
mthomas47 likes this.
AdamG, ...out!
post #12555 of 14144 Old 05-18-2019, 12:00 PM
imureh's Avatar
Liked: 4248
Thanks Jeffrey. Yes I will use my existing 110sr to compare and if they sound better then will order an additional pair.
ahblaza likes this.
post #12556 of 14144 Old 05-18-2019, 12:22 PM
ahblaza's Avatar
Liked: 3746
You're welcome my friend, TBH I think using the existing 110sr you have is the best option for you right now even though it will be a PITA removing them from the rear wall but it's the only way to know for sure before spending more money. I believe you will notice a marked improvement with filling the gap between your front stage and sides, it should keep your bed layer intact with enveloping sound. I suggest not mounting them higher up on the wall so as to not interfere with the Atmos speakers angle even though they're slant boxes...good luck and let us know what you think......
ahblaza is offline
post #12557 of 14144 Old 05-21-2019, 01:23 AM
Nexgen76's Avatar
Quoted: 784 Post(s)
Liked: 224
I'm really thinking about dropping diy solutions & moving towards JTR setup. What solution does JTR offer for Atmos & DTS-X ?
JVC NX5 Panasonic UB820 PC Madvr
Sliver Ticket 120' Cinema white screen
Aggressive 1299 L/C/R/, Volt 10XL x 2 surround, MKII Atmos Modules x 4(Jav's build)
Pioneer Elite SC-LX801 Acurus A125x5
Ported Primate SI 18" HST subs x 2(DIY) V.B.S.S.x 4(MBM)
Nexgen76 is offline
post #12558 of 14144 Old 05-21-2019, 05:50 AM
imureh's Avatar
Liked: 4248
People use their single 8s for that application. Probably overkill for Atmos but this is AVS!
llang269 likes this.
post #12559 of 14144 Old 05-24-2019, 08:42 AM
ratm's Avatar
Quoted: 277 Post(s)
Liked: 114
Hi Jeff (or anyone else that an answer),
I have a 2013 Passive Cap 2400 that I currently power with an EP4000. If I purchased a new Cap 2400, can I power both with the one plate amp on the new Cap?
ratm is offline
post #12560 of 14144 Old 06-03-2019, 02:43 PM
bambam's Avatar
Quoted: 242 Post(s)
Liked: 197
Wow, no activity on this thread for over a week?!? I think that's a new record.
Everyone must be enjoying their JTR subs!
bambam is offline
post #12561 of 14144 Old 06-03-2019, 02:51 PM
DennisPagoulatos's Avatar
Quoted: 61 Post(s)
Liked: 130
I know I am
Review in process for my new Cap 4000 with custom finish...
bambam, chucky7, toddct and 2 others like this.
DennisPagoulatos is offline
post #12562 of 14144 Old 06-04-2019, 07:02 AM
Landmonster's Avatar
Quoted: 110 Post(s)
Hi guys.
I'm building a relatively modest home theater for now
Denon receiver
Polk LSiM 5 speaker setup
Additional amp
2 subs (unsure which type yet)
Thus will go in a 16*16 living room with a stanard 15 amp outlet
Is it worth it for me to consider a JTR subwoofer or 2? Vs the standard recommendations of Svs, hsu, Rythmik, etc
The only JTR sub in my price range would be the 118 Captivator.... I could add a 2nd later.
Alternatively, I could get dual HSU subs now.
Landmonster is offline
post #12563 of 14144 Old 06-04-2019, 07:05 AM
madhuski's Avatar
Quoted: 1484 Post(s)
Liked: 930
Originally Posted by Landmonster View Post
Hi guys.
Denon receiver
Additional amp
I’ve got a 118 and am a big fan.
What’s your total budget for subs?
Selling in AVS Classifieds
FS: D-Sonic Three Channel Amp
madhuski is online now
post #12564 of 14144 Old 06-04-2019, 07:56 AM
Quoted: 110 Post(s)
My budget is flexible. The caveat is the sub would need a nicer finish than the ones that comes standard for JTR.
I would like some kind of black satin or gloss finish. I don't know what he charges for that
I could probably spend about 2k.... Which means 1 sub or 2 smaller ones. I could add more later
post #12565 of 14144 Old 06-04-2019, 08:16 AM
madhuski's Avatar
Liked: 930
I had the same need (nicer finish) and got the black gloss. Looks pretty nice - it’s been a while now so i don’t remember the upcharge but i don’t recall it being too much.
post #12566 of 14144 Old 06-04-2019, 09:21 AM
tojo_m's Avatar
Quoted: 142 Post(s)
Liked: 162
The upgraded trims come in two types. Your choice of wood plus stain would be $300 up charge. $500 would get you automotive paint finish (super glossy) of any car paint of your choice. These were the prices several months back. You may, want to also have rubber feet attached to the bottom for $50 extra to protect the paint surface from touching the ground.
If you go for the 118HT, you may want to ask Jeff about the lower tuned version(18Hz) that should not cost extra.
I’m very happy with my 118HTs. They are much more subs than I need!
Polk LSiM 705 towers, 706 center, RC80i surrounds, Denon X4400H, Emotiva XPA-100 monoblocks, Dual 2019 JTR-118HTs (Color -Mini Cooper Spice Orange metallic), LG 77" C8 OLED, Panny 65" Plasma.
tojo_m is offline
post #12567 of 14144 Old 06-04-2019, 12:08 PM
chucky7's Avatar
Liked: 5070
The black satin (Hsu Research like finish) is much less labor intensive than gloss so the upcharge should be closer to $300 per sub.
post #12568 of 14144 Old 06-05-2019, 06:50 AM
AVS ***** Member
mthomas47's Avatar
Quoted: 5767 Post(s)
Liked: 11595
Hi guys.
Denon receiver
Additional amp
Hi,
You haven't mentioned your listening levels, or how much bass you like. In some respects, those factors can be even more important than your room size. But, since you are running an external amp with only 5 channels, and since you are inquiring about JTR subs, I assume that you like listening at fairly high volumes and that you like having plenty of bass. (You have come to the right place for that.) Given that, the first recommendation I would make is that you follow-through on the plan to get one more powerful sub now, and a second one later, rather than getting two lesser subs now.
Long-term, most serious listeners are going to want to have dual subs. But, starting with the right sub now will save you a lot of upgrade headaches down the road. At the roughly $2000 price point, the quality goes up significantly, and the Cap 118HT with the 18Hz port tune would be an excellent choice. A couple of HSU's now might give you a certain kind of instant gratification. But, long-term, I think that one 118 now and a second one later will be a much better investment, and will give you much more listening satisfaction.
I hope this helps!
Mike
ahblaza likes this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is offline
post #12569 of 14144 Old 06-05-2019, 03:22 PM
Quoted: 110 Post(s)
Question
Originally Posted by mthomas47 View Post
Hi,
I hope this helps!
Mike
It does Mike! I am considering a million different options here. I guess my total "initial" budget is around $2,000.
It seems like I have a few options:
A) Get 2 HSU (or similar) subs
B) Get 1 JTR 118HT sub ... and add a 2nd one several months to a year later.
C) Get 1 high end SVS sub, like a PB-4000 or something ... and add a 2nd one several months to a year later.
In either case, they need to last a long time, have suburb sound quality, and have a good WAF finish for my living room.
I am okay starting with 1 sub for now, as long as that will be decent until I can afford 2 of them. Would having just a single JTR subwoofer cause some kind of sound dispersion problem? in a 5.1 theater setup? Lots of what I read suggests that having 2 subs will sound much nicer than 1 more expensive sub. There will be a long time delay before I am able to add a 2nd JTR sub.... and even then, I would want the custom finish to match the 1st one that I buy.
post #12570 of 14144 Old 06-05-2019, 04:14 PM
imureh's Avatar
Liked: 4248
Why are you not considering a Rythmik FV18 paper cone with all those options plus PSA? JTR would be the only one with custom finish options unless you go to Salk sound and get a custom rythmik.
