Official JTR Speakers Subwoofer Thread - Page 425 - AVS Forum | Home Theater Discussions And Reviews
 18451Likes
post #12721 of 13208 Old 07-23-2019, 01:14 PM
chucky7's Avatar
Quoted: 3526 Post(s)
Liked: 4504
Originally Posted by muscles View Post
What about the amps that ship with the 2400's? Do they still have any problems? Not too happy if they hum or go out intermittently. Anyone received one recently that can comment on the QC of these going out?
Greg
I can provide more examples.
Back in May of 2018, my Cap 4000ULF was part of a group buy of 7 Cap 2400ULFs and 1 Cap 4000ULF. 2 of the Cap 2400ULFs were for my friend. I delivered them and helped him set up. Both of the amps were good (as in working properly). We put 1 Cap 2400ULF at the front of the living room. There was no cable box there and no hum. The other Cap 2400ULF was put at the back of the room and there was hum because the outlet was on the same circuit as a dining room dimmer switch. Dimmer switch is the number 2 culprit of hum (Cable box is number one). We put a cheater plug on it and the hum was gone. AFAIK, all of the amps in that shipment were working properly. You noticed the hum from my Cap 4000ULF. I found a free remedy for it.
I asked Jeff about this. He said that the law requires all electronics above 2000W to have ground which introduced the possibility of ground loop hum. This is why Rythmik amps (Max 1800W), or PSA's ICE Power amp modules (700W or 1400W) don't have ground (2 prongs). They are all under 2000W.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #12722 of 13208 Old 07-23-2019, 01:20 PM
torii's Avatar
Quoted: 3488 Post(s)
Liked: 1970
my old 1200 watt velodyne hgs 12 sub had bad ground in an old house rental...cheater plug solved it. same sub in my new home has no issues with ground loops...or any sub....it has to be house wiring imo.
chucky7 likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #12723 of 13208 Old 07-23-2019, 01:26 PM
chucky7's Avatar
Liked: 4504
Originally Posted by nirosha View Post
I was lucky enough to get 2 demo Cap 1400s and Jeff is going to ship them this week. I already have 2017 tall Cap 2400ULF. Seems 1400s are slightly different (e.g. LF Adjust) as they were built in 2015. I really appreciate if you can share your expert thoughts/recommendations.
Good job!
Your 2017 Cap 2400ULF's LFA should look like below: At Boost (Max), the FR is flat outdoors. At Cut (Min), you are down 12dB @ the port tune of 15Hz. The LFA range is -12 dB to 0.
The 2015 Cap 1400's LFA should look like below: At middle, the FR is flat outdoors. At Boost (Max), it is +6 dB @ the port tune of 17Hz. At Cut (Min), it is -6 dB @ 17Hz. The LFA range is -6 dB to +6 dB.
You can ask Jeff to re-program them so that their LFA range matches that of your 2017 Cap 2400ULF.
chucky7 is offline
post #12724 of 13208 Old 07-24-2019, 01:02 PM
nirosha's Avatar
Quoted: 25 Post(s)
Thank you, Chucky. Today Jeff is going to ship them. I think it is late to ask reprogramming.
nirosha is offline
post #12725 of 13208 Old 07-25-2019, 10:37 AM
chucky7's Avatar
Liked: 4504
Ahhh, Ok! You shouldn't have problem matching the LF Adjusts if you have the 2017 2400ULF's LF Adjust higher than mid.
Just a quick guide:
2015 Cap 1400's LF Adjust @ mid = flat outdoors (0dB) = 2017 2400ULF's LF Adjust @ max.
2015 Cap 1400's LF Adjust @ min = -6 dB = 2017 2400ULF's LF Adjust @ mid.
Hope this helps!
jamiebosco likes this.
chucky7 is offline
post #12726 of 13208 Old 07-25-2019, 05:23 PM
nirosha's Avatar
Quoted: 25 Post(s)
Just a quick guide:
Hope this helps!
Thanks Chucky. Definitely this helps. Currently I keep LFA of 2400ULF at 9’O clock
nirosha is offline
post #12727 of 13208 Old 07-28-2019, 02:05 AM
chucky7's Avatar
Liked: 4504
I just watched Alita: Battle Angel. The movie was mixed hot and had bass in the right places. I would say it's on Interstellar level but mixed slightly hotter and extended 10Hz lower.
When the bass hits, I was afraid that my neighbors would call the police. Alas, that didn't happen.
chucky7 is offline
post #12728 of 13208 Old 07-28-2019, 07:46 AM
chucky7's Avatar
Liked: 4504
First pictures of the Captivator 2400XS in the wild:
https://www.facebook.com/pg/youthman...g&__tn__=-UC-R
chucky7 is offline
post #12729 of 13208 Old 07-28-2019, 10:39 AM
jamiebosco's Avatar
Quoted: 729 Post(s)
Liked: 1766
Damn....that's a good lookin' sub!!!!
chucky7, Phil1975m and Sweet Jimmy like this.
TV: Panasonic P65ST60 AVR: Denon 4311ci Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Dual Seaton SubMersives
jamiebosco is offline
post #12730 of 13208 Old 07-28-2019, 03:22 PM
Quoted: 164 Post(s)
Liked: 194
Size comparison of the new JTR with a few subs:
My Website; convert audio files or extract the audio from a video - https://freeaudioconverter.net
Ferrari_1996 is offline
post #12731 of 13208 Old 07-28-2019, 03:58 PM
tojo_m's Avatar
Quoted: 131 Post(s)
Liked: 157
That’s a tiny sub! It has no business doing 12Hz 😉. So, I’m assuming the market segment for a sub like this (vs the 2400 or the 2400ulf) is someone who wants the low extension but cannot hide the sub and needs a smaller sub for WAF? Or someone who cannot fit the 2400 in their room? Else, why not just buy the 2400?
Also, since sub dimensions are small and tuning is so low is this ideally a small room sub(headroom)?
If aesthetic purposes dominates the reason for choosing this sub over the 2400, maybe add a few more hundreds to the budget for a custom paint job or wood finish.
Polk LSiM 705 towers, 706 center, RC80i surrounds, Denon X4400H, Emotiva XPA-100 monoblocks, Dual 2019 JTR-118HTs (Color -Mini Cooper Spice Orange metallic), LG 77" C8 OLED, Panny 65" Plasma.
tojo_m is online now
post #12732 of 13208 Old 07-29-2019, 04:22 AM
ratbuddy's Avatar
Quoted: 829 Post(s)
Liked: 1131
I feel like I'm missing something, how does the 2400 XS get away with such a small looking port compared to seemingly every competing sub?
ahblaza likes this.
ratbuddy is offline
post #12733 of 13208 Old 07-29-2019, 02:04 PM
DennisPagoulatos's Avatar
Quoted: 54 Post(s)
Liked: 108
I concur. This track is awesome!!
Spoiler!
chucky7 likes this.
DennisPagoulatos is offline
post #12734 of 13208 Old 07-29-2019, 05:19 PM
chucky7's Avatar
Liked: 4504
Jeff first decided on the cabinet size and 10Hz tune. With a maximum port length allowed by the cabinet, he could figure out the port area to achieve the 10Hz port tune. Air velocity is at the greatest at the tuning frequency. However, since hot bass content @ 20Hz is much more common than at 10Hz, 10Hz port tune with a smaller port is safer than 20Hz with a smaller port (with the same port area but much much shorter port length).
If you block part of your sub's 6" port, you basically lower its port tune.
chucky7 is offline
post #12735 of 13208 Old 07-30-2019, 03:55 PM
Jeff Permanian's Avatar
Quoted: 894 Post(s)
Liked: 1972
For a given cabinet volume, the lower the tuning, the lower the port velocity (smaller port requirement).
chucky7 and jamiebosco like this.
Jeff Permanian is offline
post #12736 of 13208 Old 07-30-2019, 04:10 PM
basshead81's Avatar
Quoted: 323 Post(s)
Liked: 9185
Just curious, Any chance this sub would work well with a higher power ICE amp? Im sure you probably looked at this already, just curious is all. The SP amps are pretty spendy and the 1920watt Ice might be an affordable alternative unless there is a underlying metric that would hinder performance such as impedance? Great looking sub btw!!
basshead81 is offline
post #12737 of 13208 Old 07-30-2019, 04:11 PM
ratbuddy's Avatar
Quoted: 829 Post(s)
Liked: 1131
Interesting, would not have guessed that. I assume there's some tradeoff involved? Otherwise everyone would just make subs with a drinking straw sized port tuned to 1 Hz :P
ratbuddy is offline
post #12738 of 13208 Old 07-30-2019, 04:16 PM
MKtheater's Avatar
Quoted: 2490 Post(s)
Liked: 2546
If the port is too small the port velocity will increase. The key here is how much is too much, especially at 10hz where you have room gain involved.
Nothing right now
MKtheater is offline
post #12739 of 13208 Old 08-02-2019, 08:02 AM
MisterAmazing's Avatar
Quoted: 31 Post(s)
Spoiler!
omg, I completely agree! The wife really wanted to see it but I wasn't sure it was going to be good. I did NOT expect there to be that much bass. It definitely rattled the house. It's definitely on the list of bass movies I'd recommend. And the movie wasn't bad either. I really want them to make part 2.
chucky7 likes this.
Cheers,
Gavin
Subwoofers: 2x JTR Captivator 2400ULF Speakers: 4x PSA MT-110, 1x PSA MTM-210C, 4x Klipsch RP-500SA
Receiver: Denon x4400h Projector: Epson 5040UB
MisterAmazing is offline
post #12740 of 13208 Old 08-02-2019, 11:45 AM
chucky7's Avatar
Liked: 4504
Just saw this on JTR Speakers FB:
The sealed Captivator S1 and S2 were improved upon.
The revised Captivator RS1 ($2,599) and RS2 ($3,499) will have:
1. lower distortion.
2. lower inductance.
3. higher motor strength for improved sound and output.
Just in case people didn't know, the S1/S2 drivers are different from 2400/2400ULF/4000ULF drivers. I asked Jeff if the driver revision will also be applied to the ported drivers. He said that so far it's sealed drivers only.
NEW 2020 subwoofers 15% off pre-order sale:
Captivator RS1 $2,209.
Captivator RS2 $2,974.
Captivator 2400XS $2,209.
Shipping starts on August 30th.
chucky7 is offline
post #12741 of 13208 Old 08-02-2019, 12:26 PM
zeus33's Avatar
Quoted: 1810 Post(s)
Liked: 1848
3. higher motor strength ......
I like that Jeff is always improving his products. I just wish I had the wallet to enjoy more of them!
chucky7 and drh3b like this.
zeus33 is offline
post #12742 of 13208 Old 08-02-2019, 02:00 PM
Quoted: 103 Post(s)
Liked: 76
Hey Chucky, or anyone else for that matter. I have an older Tall 2400 ULF with 2 ports. It was the 2nd rendition if I remember correctly right after the Horizontal/Low version. I can’t remember who or when but I read a user received a plug from Jeff to lower the tune and possibly updating the AMP. Is this something that continued on or is a consideration still?
Best,
Mark
ziocomposite is offline
post #12743 of 13208 Old 08-02-2019, 02:31 PM
chucky7's Avatar
Liked: 4504
Best,
Mark
Hi Mark,
I believe you read about changing the 2018 20Hz tuned Cap118HT ot 18Hz tune. That was done by extending the port inside the cabinet.
In order to change the 14Hz tuned 2400ULF to 10Hz tuned, there are 2 things you need to do:
1. Block part of the port.
2. Take out the amp plate and send it to Jeff to reprogram the DSP.
Please contact Jeff regarding how you can block the port.
As for the amp plate, Jeff said that there is no fee for reprogramming. You do have to pay the shipping (which shouldn't be that much) to send it back to JTR.
jamiebosco and ziocomposite like this.
chucky7 is offline
post #12744 of 13208 Old 08-06-2019, 05:14 PM
pitchcut29's Avatar
Quoted: 18 Post(s)
Just placed my order for the Captivator 4000ULF-LP and two 110HT speakers. Can’t wait to pick them up! May I request a membership card? 🙂
chucky7, serith, llang269 and 3 others like this.
Main: 3 x JTR 212RT
Subwoofer: 1 x JTR Captivator 4000ULF-LP (On Order)
Surrounds: 2 x JTR 210HT (On Order)
Amplifier: DAC 5-Cherry
Processor: Monolith THX AAA Desktop DAC/AMP (Temporary until Monolith HTP-1 arrives)
pitchcut29 is online now
post #12745 of 13208 Old 08-06-2019, 07:02 PM
d_c
d_c's Avatar
Quoted: 1156 Post(s)
Liked: 1587
That’s going to be a killer 2.1 setup!!!
d_c is offline
post #12746 of 13208 Old 08-06-2019, 07:33 PM
pitchcut29's Avatar
Quoted: 18 Post(s)
Just placed my order for the Captivator 4000ULF-LP and two 110HT speakers. Can’️t wait to pick them up! May I request a membership card? ðŸ™️‚
That’️s going to be a killer 2.1 setup!!!
The 110HTs will be used for the side surrounds. The three 212RTs will be the front stage. Nonetheless, its going to be phenomenal. I will be powering these with the 5-Cherry amp which has been amazing the the JTR speakers.
Main: 3 x JTR 212RT
post #12747 of 13208 Old 08-06-2019, 07:47 PM
chucky7's Avatar
Liked: 4504
Damn!!!
Double damn!!!
BassMojo likes this.
chucky7 is offline
post #12748 of 13208 Old 08-06-2019, 08:30 PM
Quoted: 194 Post(s)
Liked: 349
Damn nice! How do you like the 212RTs? I’ve been dreaming about these? What did you have before? What improvements have you noticed? Thanks.
BassMojo is online now
post #12749 of 13208 Old 08-07-2019, 01:41 PM
madhuski's Avatar
Quoted: 1321 Post(s)
Liked: 857
Well thats intruging. How does it compare to the 118?
madhuski is online now
post #12750 of 13208 Old 08-08-2019, 01:42 AM
chucky7's Avatar
Liked: 4504
Originally Posted by madhuski View Post
Well that's intriguing. How does it compare to the Cap 118HT?
chucky7 is offline
