Official JTR Speakers Subwoofer Thread - Page 457 - AVS Forum | Home Theater Discussions And Reviews
 19318Likes
post #13681 of 13817 Old 11-12-2019, 10:51 PM
chucky7's Avatar
Quoted: 3671 Post(s)
Liked: 4858
Originally Posted by giomania View Post
Good evening.
I am looking for input on possible inclusion of 1-2 Cap 4000 ULF's in my room. I have attached a drawing that should explain the current setup. The subs were placed in the optimal location for four subs in the room by Mark Seaton in 2011 during a paid calibration. I am just trying to figure out where I would put one or two Cap's, and how to incorporate them with the Marantz AV8805 processor; would I need a Mini DSP? The room placement will probably dictate the specific Cap model. I only have around 24" clearance behind the screen wall, but they don't have to be hidden behind there.
Thanks for any input.
Mark
https://www.avsforum.com/forum/attac...1&d=1573615971
Assuming that you have a regular, non-AT, projector screen, the easiest way for you to add 2 more Cap 4000ULF would be to put the stacked master and slave Submersives combo at where your current slave locations, then put the Cap 4000ULFs at where the masters are. This way, the Cap 4000ULFs won't fire into the room. You can go with the regular 4000ULFs or the 4000ULF-TLs.
Alternatively, you can also put the stacked master and slave Submersives combo at the current master locations. Then you just put 2 4000ULF-LP/STs at where the slaves are.
Either of the choices above are very easy to implement. I recommend still getting a miniDSP to that you can adjust each sub independently.
giomania, audiofan1 and basshead81 like this.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #13682 of 13817 Old 11-13-2019, 08:20 AM
basshead81's Avatar
Quoted: 335 Post(s)
Liked: 9646
I agree with Chuck on the alternative option. Stack your Submersives in the locations by the seats, then put the Cap4000's up front. I would also recommend installing some "oh ****" handles on all seats!!
basshead81 is offline
post #13683 of 13817 Old 11-13-2019, 01:24 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
Thanks for the input. I noticed that there was no recommendation for just one 4000ULF! For some reason, I have this vision that the room will be flexing like the walls in the hall at the end of the Matrix when Neo realized he was "The One".
What is the current recommended MiniDSP model, and I assume I would need two?
Regarding the recommendations, I do in fact have a non-AT screen. The only limitation I have with the recommendations is that the four SubMersives do not match; 2 are flat black, and two are black oak. To summarize and be sure I understand the recommendations, in what I think is the order of preference:
Option 1: Stack the four SubMersives behind the screen wall, and place two 4000ULF or 4000ULF-TL in the locations behind the seats.
Option 1 Comment: Since the SubMersives do not match, this IS optimal aesthetically. I could use the 4000ULF-TL, dropped right where the existing SubMersive HP's are located. Alternatively, I could use the 4000ULF-ST model horizontally and place the Noesis 212 HT surround speakers on top of the subwoofer. The current Noesis stands are 18" tall, and the ST model is 28" high, so the tweeter would be raised by 10" for these surround speakers. The standard 4000ULF would not fit without relocating the chairs in that area.
Option 2: Stack the four SubMersives behind the seats on the sides of the rooms, and place two 4000ULF standard units behind the screen wall, with the ports facing the side walls.
Option 2 Comment: Since the SubMersives do not match, this IS NOT optimal aesthetically.
Option 3: Proposal: How about the rear wall of the room? I could use the 4000ULF-ST model horizontally and place the Triple 12 HT rear surround speakers on top of the subwoofer.
Thanks so much for the input.
Mark
SuperFist likes this.
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #13684 of 13817 Old 11-13-2019, 01:30 PM
beastaudio's Avatar
Quoted: 5668 Post(s)
Liked: 5533
My guess is with a pair of cap 4000's you won't find the submersives even necessary after a short honeymoon period with everything hooked up at once. That just me being dead honest.
If you do anything I'd find the best location for the two cap4000's for room response and then use the subM's as nearfield tactile response subs as their total capability won't equal the two cap4000's. The closer they are to your seats, the more you may end up benefiting from actually keeping them. Again tho, my guess is you'll realize that they won't be adding much if anything to the presentation if you end up with a pair of Cap4's in the same room.
beastaudio is online now
post #13685 of 13817 Old 11-13-2019, 04:22 PM
zeus33's Avatar
Quoted: 1869 Post(s)
Liked: 1945
2x4 HD. One is all you need. It has 4 outputs.
giomania likes this.
zeus33 is offline
post #13686 of 13817 Old 11-13-2019, 05:58 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
Thanks. If I kept the SubMersives, and added two 4000ULFs, I would need five outputs, unless you recommending splitting some of the MiniDSP output connections?
I wish they had an updated balanced model.
Mark
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #13687 of 13817 Old 11-13-2019, 06:00 PM
chucky7's Avatar
Liked: 4858
Mark
Without pictures of the room, it's really hard to make the most proper recommendation.
Option1: The 4000ULF-STs placed upright would work best here because they take up pretty much the same real estate. This also means they should have the same acoustic center and integration is the easiest. Any time when you add more subs to new locations, it's best to start anew.
It looks like the 4000ULF-STs would fit as well. However, this involves making changes to your current setup and the subs' acoustic centers are also different. I didn't know you are OK with this. I also don't want to act like the furniture salesman that says: "Get this set... you just need a bigger house..." LOL...
Option 3: Of course you can put a single Cap 4000ULF at the back of the room. I didn't know you are open to this. However, I don't know if that is a good spot for a subwoofer. Doing so could potentially be a lot of work. I also think putting a Cap 4000ULF furthest from the seating is kind of a waste. Personally I prefer to use the powerhouse as the main feature. It also adds the TR and port wind to the overall experience.
chucky7 is offline
post #13688 of 13817 Old 11-13-2019, 06:17 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
Option1: The 4000ULF-TLs would work best here because they take up pretty much the same real estate. This also means they should have the same acoustic center and integration is the easiest. Any time when you add more subs to new locations, it's best to start anew.
Thanks again Chuck I was thinking the same thing about the 4000ULF-TL and was remembering when Mark did the calibration we moved the subs all around the room to find the best location for the four units. He was very meticulous and was here around 13 hours so I’m certain that the four existing locations are the best for the room.
Plus that location places the monsters out in the room and I think will allow the port wind to be felt.
Here are some pictures; please excuse the mess.
Rear
Rear
Right side
Front
Left side
Left side
Right side SubMersive HP
Right Front SubMersive HP+ Master unit
Behind screen wall looking over to the right front SubMersive
chucky7, SOWK, serith and 4 others like this.
giomania is offline
post #13689 of 13817 Old 11-13-2019, 10:35 PM
chucky7's Avatar
Liked: 4858
thanks again chuck i was thinking the same thing about the 4000ulf-tl and was remembering when mark did the calibration we moved the subs all around the room to find the best location for the four units. He was very meticulous and was here around 13 hours so i’m certain that the four existing locations are the best for the room.
Plus that location places the monsters out in the room and i think will allow the port wind to be felt.
Argh, I meant to say that the 4000ULF-ST would work well... They are shallower and would fire into the room. The 4000ULF-TL would not work as they would protrude too much into the room. You also have sound panels.
Based on your pictures, it seems the Cap 4000ULF-STs (only 20.5" deep) upright would work really well placed behind the seats. You would need to move the surround speakers back a couple of inches though.
chucky7 is offline
post #13690 of 13817 Old 11-14-2019, 06:17 AM
irishluck73's Avatar
Quoted: 293 Post(s)
Liked: 195
After a lot of thought and reading I've decided to stay ported and not go sealed.
Contemplating snagging (2) 1200XS to replace the Cap 1400 I have... Thoughts? How much more output would there be compared to a 1400?
I could easily fit those little guys into some corners. The wife wouldn't even notice.
Sony 75X940E JTR 110HT/8HT JTR Captivator 1400 JBL SP8CII Denon X4200W Sony X800M2 ATV4K
irishluck73 is offline
post #13691 of 13817 Old 11-14-2019, 07:40 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
I see that, based upon the dimensions, the 4000ULF-ST would work best. It is hard not having pictures of the ST and TL models on the JTR web site for reference. In order to not block the sound panels, what about placing them horizontally (laying down) and placing the surround speakers on top? I know you mentioned changing the acoustical center might cause issues.
Mark
giomania is offline
post #13692 of 13817 Old 11-14-2019, 07:51 AM
basshead81's Avatar
Quoted: 335 Post(s)
Liked: 9646
You better hurry...as of Yesterday there was only 2 left!!
It depends on where you are wanting more output. Below 16hz the pair of 1200XS would be substantially stronger(+10db depending on placement at 12hz). Above 30hz they likely will be close, slight advantage to the 1200XS.
irishluck73 likes this.
post #13693 of 13817 Old 11-14-2019, 08:26 AM
chucky7's Avatar
Liked: 4858
Mark
The 4000ULF-ST:
4000ULF-ST in the wild: (Bassmojo's room)
4000ULF-TL:
4000ULF-TL in the wild:
chucky7 is offline
post #13694 of 13817 Old 11-14-2019, 08:34 AM
basshead81's Avatar
Quoted: 335 Post(s)
Liked: 9646
Man that TL with a 3rd 18 in it would look Awesome!! That being said in 2019 nobody should be using a potato camera. lol
SuperFist and rhelliott2 like this.
post #13695 of 13817 Old 11-14-2019, 08:44 AM
drh3b's Avatar
Quoted: 2096 Post(s)
Liked: 4237
Is that because you bought some of them, or are you hoping someone will get the last 2, and save you from yourself?
giomania, ahblaza and basshead81 like this.
My World Beating System!
Spoiler!
drh3b is offline
post #13696 of 13817 Old 11-14-2019, 09:13 AM
chucky7's Avatar
Liked: 4858
Haha, I know what you are saying.
Actually, I changed the contrast/lighting/mid tone level of the originals to better illustrate where the ports are.
chucky7 is offline
post #13697 of 13817 Old 11-14-2019, 09:26 AM
basshead81's Avatar
Quoted: 335 Post(s)
Liked: 9646
Maybe both?
drh3b likes this.
post #13698 of 13817 Old 11-14-2019, 09:44 AM
Quoted: 193 Post(s)
Liked: 95
What's the size of the Captivator RS2 in centimeter? My sofa is about 51cm from the wall behind.
Is RS2 sound different compared to the ported subs from JTR? Music and movie? Thanks for your time!
Jim1290 is offline
post #13699 of 13817 Old 11-14-2019, 10:27 AM
Quoted: 293 Post(s)
Liked: 195
That's a huge increase down low! Now to talk to Jeff and find a buyer for my Cap 1400.
drh3b likes this.
post #13700 of 13817 Old 11-14-2019, 10:47 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
Rear
Rear
Right side
Front
Left side
Left side
After some discussion off-line with @SOWK , I am now thinking to do the following:
Add two 4000ULF-LP or 4000ULF-ST behind the screen wall with the ports facing into the room.
Move the two SubMersive HP+ units (Master & Slave) to the rear wall of the room. I could use them under the existing rear surround speakers (as stands for those speakers) if that location on the rear wall proved to have best response in the rear of the room.
I would need two MiniDSP HD units, as I would have five subwoofer inputs.
This solution does not impede my existing room treatments on the side walls. I guess the one negative point to this is the SubMersive HP+ units (Master & Slave) would not be allowed independent settings in the MiniDSP.
I am also open to eliminating the SubMersives if it turns out they don't add anything to the experience, but maybe with six subwoofer locations in the room, the response will be better.
I welcome any input.
Mark
chucky7, SOWK and feistyacorn like this.
giomania is offline
post #13701 of 13817 Old 11-14-2019, 10:54 AM
drh3b's Avatar
Liked: 4237
Mark
That could be a mistake.
Sell the submersives and buy another 4000 ULF.
Spoiler!
drh3b is offline
post #13702 of 13817 Old 11-14-2019, 01:22 PM
zeus33's Avatar
Liked: 1945
Mark
Whatever you decide to group together (SubM or 4k) can use the same signal.
Besides, unless I'm missing something (very possible), you have two master slave Sub Ms. They only need 2 signals. (The slave can't accept a different signal.) You are adding two 4ks. That's 4 signals. Where are you getting 5 from?
mthomas47 likes this.
zeus33 is offline
post #13703 of 13817 Old 11-14-2019, 01:34 PM
beastaudio's Avatar
Liked: 5533
These were also my thoughts. If the subs are co-located even remotely close to each other or are equidistant from the listening position and placed symmetrically in your symmetrical room, you could effectively consider them a "Single" sub and only use one output from the mini. If the subM's are literally stacked on top of each other, then they definitely should only be considered a single sub.
post #13704 of 13817 Old 11-14-2019, 03:01 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
I currently have the following:
1 SubMersive HP+ Master (1 signal)
1 SubMersive HP+ Slave
1 SubMersive HP (1 signal)
giomania is offline
post #13705 of 13817 Old 11-14-2019, 03:06 PM
zeus33's Avatar
Liked: 1945
I currently have the following....
OK, gotcha. The grouping will still work though. As BA mentioned, anything that is close together can use the same signal.
zeus33 is offline
post #13706 of 13817 Old 11-14-2019, 03:12 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 690 Post(s)
Liked: 434
Thanks gents,
I am thinking they will be equidistant, so I can use one MiniDSP HD; good news!
Any recommendations for decent XLR to RCA adapters?
My cables inside the conduit that run to the subs are XLR that I made with Neutrik connectors and Belden cable.
I am currently using all balanced XLR outputs on the Marantz AV8805, so not sure if I should start with RCA from the 8805 to the MiniDSP and then convert to XLR for the runs to the subs.
Mark
giomania is offline
post #13707 of 13817 Old 11-14-2019, 05:51 PM
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1552 Post(s)
Liked: 761
https://emotiva.com/collections/acce...r-interconnect
ahblaza likes this.
Wisconsin Home Theater Enthusiasts Meet
SOWK Home Theater
SOWK is online now
post #13708 of 13817 Old 11-17-2019, 04:49 PM
madhuski's Avatar
Quoted: 1407 Post(s)
Liked: 888
Anyone know if it’s possible to get a RS1 or RS2 i a a veneer?
Selling in AVS classifieds
FS: McIntosh MX-160 Processor
madhuski is online now
post #13709 of 13817 Old 11-17-2019, 05:02 PM
drh3b's Avatar
Liked: 4237
My understanding is you can get pretty much any veneer or paint job on a JTR subwoofer or speaker, just contact Jeff.
Spoiler!
drh3b is offline
post #13710 of 13817 Old 11-17-2019, 05:07 PM
muscles's Avatar
Quoted: 765 Post(s)
Liked: 1080
Does anyone have any pics of the RS1 in the wild?
Greg
Subwoofers: Dual Rythmik F18SEs - Dual JTR RS1's - SB13 Ultra
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is online now
