Official JTR Speakers Subwoofer Thread - Page 460 - AVS Forum | Home Theater Discussions And Reviews
 19341Likes
post #13771 of 13821 Old 11-26-2019, 01:49 PM
Naylorman32's Avatar
Quoted: 506 Post(s)
Liked: 221
Hey guys,
I use a pair of 118Ht's in my theater these days. I've noticed recently that during movies they will both switch on and off seemingly out of the blue. Has anyone seen this before? I typically set the power switch to Auto, and even tried it with just being On, and got the same result.
Thoughts?
JTR Speakers, RSL Atmos, Kaleidescape, Lumagen Radiance Pro, Marantz Processor, Emotiva Amps, JVC RS540
Naylorman32 is offline
post #13772 of 13821 Old 11-26-2019, 03:18 PM
Quoted: 56 Post(s)
Liked: 67
Originally Posted by Naylorman32 View Post
Hey guys,
Thoughts?
I leave my 118HTs powered On all the time because I mostly listen to music and it bothers me when the subs turn on/off with the Auto setting when bass varies so much between recordings. Since leaving the subs On always, I've never had them turn off/on by themselves.
Seems odd that both of your subs are suddenly having the same problem. Could it be an issue with the electrical circuit?
Jack
Jack1949 is offline
post #13773 of 13821 Old 11-26-2019, 04:23 PM
dpc716's Avatar
Quoted: 188 Post(s)
Liked: 286
Hey guys,
Thoughts?
If they're both going on and off in tandem with the power switch on, it seems unlikely that the cause would be either a defect with the amps or low trim levels triggering the auto on circuit. If you have both subs running off of a single sub out with a splitter I'd try replacing the main RCA cable and maybe the splitter itself. If the subs are on separate sub outs, maybe an AVR issue, try a reset?? (obviously an AVR issue is possible in the first case also)
Naylorman32 likes this.
dpc716 is offline
post #13774 of 13821 Old 11-26-2019, 05:57 PM
darthray's Avatar
Quoted: 2329 Post(s)
Liked: 3443
Also, it is possible the gain on the subs are set too low before calibration. And would result the signal send to the plate amp, for not having a strong enough signal.
Hopefully this will give a better explanation;
II-C: Where And How To Add Bass
Darth
darthray is offline
post #13775 of 13821 Old 11-26-2019, 08:15 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
I believe That is a issue that some were having with a certain run of JTR amps. I would pull the power cord from the Amps and see if they will reset.
basshead81 is offline
post #13776 of 13821 Old 11-26-2019, 09:03 PM
Quoted: 506 Post(s)
Liked: 221
I've tried this. I wonder if potentially replacing the power cord would make a difference. I will also try adjusting the settings on the back of the sub as referenced below.
post #13777 of 13821 Old 11-27-2019, 08:58 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Try hooking your phone directly to one of the subs with a 3mm to RCA and play some music. If it goes away then you know it's a source/signal issue, if it still persists then it's likely a amp issue.
ahblaza likes this.
post #13778 of 13821 Old 11-27-2019, 12:15 PM
umjs78's Avatar
Quoted: 26 Post(s)
Originally Posted by chucky7 View Post
Wait a minute...
You are the guy that bought madhuski's JTR Noesis 228HTs 5 minutes after he listed them for sale?
https://www.avsforum.com/forum/209-a...l#post58767268
I hate you!
Just kidding!
Congratulations on receiving your JTR subs! Welcome to the family!
Oh, I didn't even know I replied after 5 min he posted. I was lucky haha.
I have ordered more JTR from Jeff to complete my room and now They sound phenomenal.
Only one thing for me to hesitate to get these bad boys was there no where to demo this brand.
Now I can tell It worth to blind shot for those who has same issue as I did.
I have never been happy like this during all other speaker purchase.
I may put these back for surround duty and get bigger one for LCR near future.
Thanks Jeff and all other who gave me a advise.
umjs78 is offline
post #13779 of 13821 Old 11-27-2019, 12:42 PM
chucky7's Avatar
Quoted: 3672 Post(s)
Liked: 4865
What do you have in your HT already?
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #13780 of 13821 Old 11-29-2019, 07:06 AM
umjs78's Avatar
Quoted: 26 Post(s)
228ht lcr w/ dual 1200xs, thinking to get (3) 212htr to replace them.
umjs78 is offline
post #13781 of 13821 Old 11-29-2019, 07:25 AM
chucky7's Avatar
Liked: 4865
Good job!
The Noesis 212HTRs as L/C/R with the 228HTs as surrounds is gonna be sick!
chucky7 is offline
post #13782 of 13821 Old 11-29-2019, 08:20 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Was able to fire up REW and play around a little tonight. Results are pretty good and shows you can mix subs with different tuning points if placed right. Looks like I am +/-3db or so from 11-80hz.
I took a compression sweep as well and looks like I am reference capable down into the 12hz range. Above 20hz there is gobs of headroom left. Subs are barely working on these sweeps.
Name:	JTR 1200 + PSA 15's base response.jpg
ID:	2647376   Click image for larger version
Name:	JTR + PSA compression sweep.jpg
chucky7, Alan P, tebling and 7 others like this.
post #13783 of 13821 Old 11-29-2019, 09:51 PM
tvuong's Avatar
Quoted: 2731 Post(s)
Liked: 2545
^^ Looking great BH81 . I bet it sounds pretty dang good. Do you happen to have graphs of the 1200SX only and xv15 only and perhaps Center and 4 subs?
tvuong is offline
post #13784 of 13821 Old 11-29-2019, 10:35 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Thanks. I did 1200xs solo(Far field) no eq, then the PSA's solo(near field)no eq, then combined with no eq, then combined with Audy. Didn't measure with the Center. I took the solo measurements -6db so they were not stacked on top of each other and a little easier to read.
Side note, the first graph I posted of base response was actually my last measurement. I tweaked the distance settings and flattened those peaks a little...hence why it looks smoother then the other graphs.
Name:	JTR+PSA measurements.jpg
drh3b and rhelliott2 like this.
post #13785 of 13821 Old 11-30-2019, 12:52 AM
tvuong's Avatar
Liked: 2545
^^ How do they connect to your Denon AVR? JTR on one sub out and the 3 psa’s on another sub out? When you said PSA’s near field, do you mean all 3 PSAs or 1 PSA? Want to make sure I understand your set up and graphs.
tvuong is offline
post #13786 of 13821 Old 11-30-2019, 08:53 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
JTR is on 1 sub out, 3 PSA's on the other. The PSA's are nearfield equidistant from the MLP.
post #13787 of 13821 Old 11-30-2019, 10:18 AM
zeus33's Avatar
Quoted: 1871 Post(s)
Liked: 1947
Thanks. I did 1200xs solo(Far field) no eq, ........
That combined graph looks good bh! I'm curious though, is that fall off @ 30 hz with the JTR due to it's position? Is that a spot you previously measured with one of your PSAs, or is it new? I know you probably mentioned it in one of your posts already. Thanks
zeus33 is online now
post #13788 of 13821 Old 11-30-2019, 02:13 PM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
I am not sure what you consider drop off but the JTR is pretty much flat 11-32hz. I have it placed in the 3rd location where I had one of my PSA subs. This spot Lacks mid bass but it provides good low end where the near field placement lacks.
post #13789 of 13821 Old 11-30-2019, 10:37 PM
zeus33's Avatar
Liked: 1947
That's what I meant, above 30 hz. It clearly doesn't fall off below.
OK, so it's the spot causing that. Thanks
basshead81 likes this.
post #13790 of 13821 Old 12-01-2019, 08:44 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Yep, Its the spot and as you can see my room needs multiple subs to get a good response without excessive EQ. The large opening mid wall on the left side of the room causes some response issues a single sub could never over come. Anyhow, I still plan on doing more testing when I get a chance. One will be comparing FR between PSA and JTR in same locations. However the main reason I bought the JTR was for the added low end in hopes that the spot I reserved for it would work out. As you can see, it's working well and gets quite a bit of room gain below 30hz. I have more then enough 30-80hz with the PSA's.
One thing to note, Those that have mentioned the low tune subs having a different sound signature were right! when I auditioned the v1801 in my room it didn't work well where my current JTR and 15v sub was placed. I had to move it opposite wall where you enter the room. Never liked the looks of it there. Also even though it got me reference level output ( down to 13-14hz according to REW), I didn't really notice the added depth. The JTR just adds weight to the low end that is noticeable.
I only wish there was more content to make use of it because I don't notice a big difference unless I am playing material that has <20hz content. That being said, My listening habits have shifted 40% TV/ 40% movies / 20% music these days, so this was another big factor in trying a low tuned offering paired with my current subs instead of jumping to NEO driver upgrades.
chucky7 likes this.
post #13791 of 13821 Old 12-01-2019, 09:18 AM
imureh's Avatar
Quoted: 2992 Post(s)
Liked: 3838
Look into BEQ to get all the low end you need.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #13792 of 13821 Old 12-01-2019, 12:19 PM
ereed's Avatar
Quoted: 2346 Post(s)
Liked: 1647
I second this!
leehan76 likes this.
Theater room: Sony 45es | 120 inch screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M (x4) | Funk Audio subs (x2) | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x2) | Monster Power Conditioner | GIK acoustic panels
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8
ereed is offline
post #13793 of 13821 Old 12-01-2019, 01:04 PM
leehan76's Avatar
Quoted: 75 Post(s)
Liked: 74
Originally Posted by ereed View Post
I second this!
I third this! BEQ is a game changer for bringing out the low end in movies. It made a huge difference with “just” 2 S1’s.
Speakers: KEF R300 (R,L), KEF R600C (C), JBL 306p mkII (Surrounds), KEF Ci160QR (In-Ceiling) Subs: JTR Captivator S1 x2 Processor/Amps: Anthem AVM60, ATI AT4003, Rotel RB985 mkII Misc: ATV 4k, Sony PS4, Samsung K8500, MiniDSP 2x4HD Video: BenQ HT2050, 100” Screen Room: 2500 cu sq. ft. sealed on suspended floor
leehan76 is offline
post #13794 of 13821 Old 12-01-2019, 10:26 PM
muscles's Avatar
Quoted: 765 Post(s)
Liked: 1081
This may be a dumb question but I need to know the answer. I have recently added 2 RS1's to my 2 Rythmik F18s. Rythmik subs do not use a DSP so they don't have any delay whatsoever. The JTR's have a 7ms delay (measured through MiniDSP and audessey). How would I hook these up to my McIntosh C2600 preamp? This is a tube stereo preamp that does not have any way of adding distance to the speakers, so the subs sound horrible. 7ms delay in audio is an absolute eternity. I run the line out from one of the outputs on the C2600 to the minidsp and cross it over around 80hz. Running a hybrid music/movie setup is very easy with Rythmik, but impossible (thus far) with JTR. I am wondering if there is a quick fix I don't know of? It was very easy to hookup with Audessey and minidsp for movies, I just added 7ms delay to the rythmiks and they time aligned nicely. If there is no way, I may have to return them....I don't want to though.
Greg
Subwoofers: Dual Rythmik F18SEs - Dual JTR RS1's - SB13 Ultra
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #13795 of 13821 Old 12-01-2019, 11:33 PM
zeus33's Avatar
Liked: 1947
Yep, Its the spot......
Thanks for the info bh. It sounds like the JTR is a good match for you. I'm glad it works well with your setup.
As others have mentioned, BEQ will utilize that extra bottom end.
post #13796 of 13821 Old 12-02-2019, 08:01 AM
tvuong's Avatar
Liked: 2545
May be trying to swap the 1200XS placement with one of the near field psa to see if they sound/feel better?
tvuong is offline
post #13797 of 13821 Old 12-02-2019, 08:48 AM
basshead81's Avatar
Quoted: 339 Post(s)
Liked: 9684
Yea, I plan on moving the JTR to a near field location to compare differences but I can about bet it will not remain there because it will be defeating the entire purpose. There is little room gain in the near field locations below 20hz so I won't be utilizing the added JTR low end. Here is a response graph of my 3 PSA subs before the JTR. You can see how the 3rd sub mid wall makes a huge impact on the sub 30hz response. It's not really just the JTR, My PSA provides similar results, but down to 16hz instead of 11hz with the JTR.
Edit* Here is a graph of dual PSA vs tri's with no EQ for comparison.
Name:	15v's response wired.jpg
ID:	2648412   Click image for larger version
ID:	2648414   Click image for larger version
Name:	dualxv15se vs tirxv15se.jpg
chucky7 and rhelliott2 like this.
post #13798 of 13821 Old 12-03-2019, 11:19 AM
Quoted: 506 Post(s)
Liked: 221
btw, per my previous post last week... i figured out it was my power conditioner clicking! not the subs (major facepalm!)
They are right next to eachother and i never bothered to stick my ear up to both to hear exactly where it was coming from lol.
drh3b likes this.
post #13799 of 13821 Old 12-03-2019, 11:43 AM
MKtheater's Avatar
Quoted: 2579 Post(s)
Liked: 2794
Greg
You said the JTR has a built in 7 ms delay, and you added a 7 ms delay but the rhythmik sound good and the JTR not? Are they in different locations?
Building the room, speakers, and subs.
MKtheater is offline
post #13800 of 13821 Old 12-03-2019, 12:15 PM
beastaudio's Avatar
Quoted: 5669 Post(s)
Liked: 5533
I think he meant he left JTR's alone and added 7ms to the rythmics to match them up, but he can't do this via his two channel rig that is also part of the setup. I was more confused about the rythmic not having DSP. It absolutely has DSP and they even say that on the website. The adjustments made via the plate amp all require DSP to be functional so there should still be some form of delay happening in both sub offerings.
MKtheater, ahblaza and drh3b like this.
beastaudio is offline
