Official JTR Speakers Subwoofer Thread - Page 486 - AVS Forum | Home Theater Discussions And Reviews
 22410Likes
post #14551 of 15332 Old 04-08-2020, 12:55 AM
mechtheist's Avatar
Quoted: 103 Post(s)
Liked: 99
Crown puts out this publication, Amplifier Application Guide that is pretty through for various best-practices in hooking up to their amps based on whether the source is three-prong or 2 and balanced vs. unbalanced for a huge array of different connectors.
giomania and Reddig like this.
mechtheist is offline
post #14552 of 15332 Old 04-08-2020, 04:34 AM
femi's Avatar
Quoted: 334 Post(s)
Liked: 432
i know this is jtr subwoofer thread but check out Jeff monster 2ch speaker setup:
Femi
tebling, serith, SuperFist and 5 others like this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #14553 of 15332 Old 04-08-2020, 07:13 AM
pitchcut29's Avatar
Quoted: 71 Post(s)
Liked: 110
Originally Posted by giomania View Post
Originally Posted by zeus33 View Post
Yeah, lots of conflicting info on the correct wiring for RCA to XLR from reputable sources.
As far as your issue, one of the DIY guys was having a noise issue and IIRC, he grounded the chassis of the Mini to his amp and it fixed the issue. I know lots of people have had some noise and ground their AVR/Pre to their sub amps and it works. Don't know if it will help, but it's worth a shot. Good luck.
Not the same thing, but I tried grounding the case to the AVP via a wire connected to the miniDSP case screw to the AVP Phono ground. I also have a ground wire connected to the Phono ground that connects to the electrical isolated ground. This did not make a difference. I am thinking to make the gain adjustments to reduce the noise.
I wish there was a true balanced miniDSP as capable as the 2x4 HD.
Mark
Is the miniDSP 10x10HD truly balanced? I think it does a bit better than the miniDSP 2x4HD but definitely a lot more expensive.
Main: 3 x JTR 212RT | Surrounds: 2 x JTR 110HT | Subwoofer: 1 x JTR Captivator 4000ULF-LP | 2 x Crowson Motion Actuators w/ Crown DSi 4000
Amplifier: DAC 5-Cherry | Processor: Monolith HTP-1 | Projector: JVC DLA-NX7 | PJ Screen: SeymourAV 130" W 16:9 Center Stage XD
pitchcut29 is offline
post #14554 of 15332 Old 04-08-2020, 08:21 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10967
There are some limitations present in the 10x10HD that are not there in the 2x4HD which is why most are still running the latter. I forget off hand what they all are but perhaps somebody else can chime in. I know one limitation was delay adjustment.
basshead81 is offline
post #14555 of 15332 Old 04-08-2020, 09:39 AM
tvuong's Avatar
Quoted: 3007 Post(s)
Liked: 3092
Originally Posted by femi View Post
i know this a jtr subwoofer thread but check out Jeff monster 2ch speaker setup:
Femi
+5 LS at 120Hz for speakers with bass bumped up +5, Why? Cuz Jeff can . I heard the JTR 215 speakers pair in Sacramento a long while back. This speaker can play EXTREMELY LOUD, but that is not its only strength (Big JBL also can). It has more low deep bass than most subs, plus the midbass from these is out of this world chest punchy. The mid range and vocal are crystal clear. It was quite a surprising experience.
Ph8te, SuperFist, femi and 1 others like this.
tvuong is offline
post #14556 of 15332 Old 04-08-2020, 01:33 PM
blake's Avatar
Quoted: 1036 Post(s)
Liked: 155
Any suggestions for a 3rd subwoofer to add to my HT under construction. It will be 9.2.4 Atmos in a sealed/acoustically treated 2500 cu feet space. There are two JL Audio f113 (v2) sealed subs that must sit in the front two corners.
I would like to add a 3rd subwoofer along the back wall (probably mid point or a corner). I am leaning towards a sealed sub as this will integrate with the sealed JL Audio's. Suggestions?
blake is online now
post #14557 of 15332 Old 04-08-2020, 02:59 PM
zeus33's Avatar
Quoted: 2004 Post(s)
Liked: 2289
Considering you're in the JTR thread, an RS1 or RS2 would be your options. Both excellent choices. Both will dig much deeper than the JLs.
llang269 likes this.
zeus33 is online now
post #14558 of 15332 Old 04-08-2020, 03:32 PM
blake's Avatar
Liked: 155
Thanks for the recommendation.
How does RS2 compare to Rythmik G25HP: dual opposed 15”, servo controlled, sealed subs? They are releasing a G28HP soon as well (dual 18”).
Is the Rythmik design/performance superior in terms of lower distortion, since they are direct opposed and have servo control (I do not think JTR has this technology but I may be wrong)? I realize I am asking this on JTR forum but I still value everyone’s opinion here !
blake is online now
post #14559 of 15332 Old 04-08-2020, 03:37 PM
imureh's Avatar
Quoted: 3590 Post(s)
Liked: 4904
I think @muscles will be best placed to share his thoughts since he has owned the G25HP and has the RS1s now
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #14560 of 15332 Old 04-08-2020, 03:58 PM
tvuong's Avatar
Liked: 3092
Output wise, you probably need a g42 to be able to compare to the rs2. ATM, JTR does not offer DO Sub. Sound quality wise, they are different with the JTR/Rythmik I have heard. Depends on your preference, what you like might be different than what I like. Sorry for not much help here.
tvuong is offline
post #14561 of 15332 Old 04-08-2020, 09:24 PM
muscles's Avatar
Quoted: 950 Post(s)
Liked: 1559
I've actually owned the JL F113 Fathoms, G25HPs, and the RS1's! Whoot! Hat trick. I will say this if you are using this primarily for movies go with an RS1, I would say an RS1 has about as much output or maybe a bit more than a G25HP. The RS1 has a sound similar to a JL Audio, high excursion woofer with a ton of power. If you are using this for music, I would get the G25HP. You just can't believe how clean a sub can sound until you've heard one of these. It will pick up every nuance of the bass with a ton of high speed separation.
If space is an issue the RS1 is the highest output sub you can find for the smallest size (not footprint, just overall size Chucky hehe). If you need even more output get the RS2. I don't even want to try to calculate how many F113's it would take to equal its output.
Let me know if there is anything else i missed, or if you have questions.
Greg
chucky7, ahblaza and feistyacorn like this.
Subwoofers: Dual JTR RS1's - SB13 Ultra (bedroom)
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #14562 of 15332 Old 04-08-2020, 10:21 PM
chucky7's Avatar
Quoted: 3934 Post(s)
Liked: 5603
If space is an issue the RS1 is the highest output sub you can find for the smallest size (not footprint, just overall size Chucky hehe). If you need even ore output get the RS2. I don't even want to try to calculate how many F113's it would take to equal its output.
Greg
Awwwww.... You remembered!
muscles and feistyacorn like this.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
chucky7 is offline
post #14563 of 15332 Old 04-08-2020, 10:27 PM
jamiebosco's Avatar
Quoted: 1015 Post(s)
Liked: 2658
Greg
With the 20Hz HPF JL employ on the Fathoms - I'd guess under 15Hz it would be somewhere around ∞ lol - Above 80Hz it would be a [email protected] too!
chucky7, muscles and feistyacorn like this.
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is offline
post #14564 of 15332 Old 04-08-2020, 11:19 PM
blake's Avatar
Liked: 155
Greg
Thanks for this comparison ! Interesting that you owned one sub I have (JL) and two I am debating between.
I think the RS2 would be a good fit for what I need and my space. I am 20% music usage but I think it will be more than capable for tight fast bass for music and movie soundtracks. Do you think you lose any of that going from RS1 to RS2 , or is it simply more dB with no down side ?
The only question I have is the upcoming G28HP from Rythmik. I wonder how this will compare with RS2 - more of a level playing field given they both have dual 18” drivers.
blake is online now
post #14565 of 15332 Old 04-08-2020, 11:39 PM
jamiebosco's Avatar
Liked: 2658
There is ONLY gain going from the RS1 to RS2 (well there is a loss of $$$ lol) An RS2 will not only play louder than an RS1 - but if played at the same volume - it will do so with much lower distortion
feistyacorn likes this.
post #14566 of 15332 Old 04-08-2020, 11:44 PM
muscles's Avatar
Quoted: 950 Post(s)
Liked: 1559
I can't comment on the RS2 because I have never owned/heard it. I could theoretically make the claim that it sounds the same, same driver, same amp manufacturer (4000 watts though). I would say JTR would sound most like JL Audio, the Rythmik has its own sound that is super fast and tight, I am not saying you can't get them to work together nicely, its just a much different sound. If you are only 20% music, get an RS2 you will not believe how much better it is than your more expensive JL F113 Fathom. It is a big heavy, sub though. Keep that in mind.
Greg
chucky7 likes this.
muscles is offline
post #14567 of 15332 Old 04-08-2020, 11:47 PM
drh3b's Avatar
Quoted: 2484 Post(s)
Liked: 5541
The G28HP probably will be more equal in output to the RS1. It comes down to sound signature, and weight. The G28 will probably weigh about 220 pounds. I suspect most music leaning people would be happy with either.
My Stuff.
Spoiler!
drh3b is offline
post #14568 of 15332 Old 04-09-2020, 03:47 AM
Quoted: 190 Post(s)
Liked: 116
Anyone know if a member is running an OSPro in their HT?
FOHTech is offline
post #14569 of 15332 Old 04-09-2020, 06:12 AM
femi's Avatar
Quoted: 334 Post(s)
Liked: 432
@N8DOGG has two JTR OS pros in his theater.
Check out his amazing theater here: https://www.avsforum.com/forum/19-de...m-finally.html
Femi
BassMojo likes this.
femi is offline
post #14570 of 15332 Old 04-09-2020, 09:19 AM
ereed's Avatar
Quoted: 2466 Post(s)
Liked: 1765
Greg
Greg
You mentioned you liked the sound of Rythmik over the jtr subs for music applications in the posts. I'm curious why you kept the jtr over rythmiks? Was it the overall output you needed or perhaps watching movies more vs listening to music lately?
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio 18.0L (2), 21.0LX (2 coming soon) | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | CyberPower UPS | GIK room treatments
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #14571 of 15332 Old 04-09-2020, 09:48 AM
muscles's Avatar
Quoted: 950 Post(s)
Liked: 1559
Several factors actually. Let me start by saying that my decision to keep the RS1 is not because I found it to be the best subwoofer but because it checked the most boxes, but it isn't perfect (for me). I can't really compare them for music because of the 7ms delay in the JTR sub when running it with my McIntosh C2600 (it cannot add delay to L and R channels to match) so it doesn't sound as good as the Rythmik (no DSP delay). Another thing was I would take a bigger hit trying to sell the JTRs and they were newer, Rythmik stuff is pretty easy to sell, its more known than JTR. The last thing is the the footprint of the JTR is much smaller and enables me better options for placement. The JTR does have a lot more output than the F18, I would guess probably 4db or so more across the frequency chart. For my room this is probably the maximum amount of bass it can comfortably handle, it gets scary with how loud these 2 little guys go, truly remarkable.
Couple of side points, I have OCD and having everything match (I have JTR speakers) makes me feel better mentally. This is crazy, I know but its real for me. I also love the way the driver looks, I find it to be the sexiest looking woofer out there, especially with the carbon fiber dust cap and the way she moves when shes putting out sound. I love watching the high excursion woofer dance
Greg
bulls, ereed, SuperFist and 1 others like this.
muscles is offline
post #14572 of 15332 Old 04-09-2020, 03:37 PM
N8DOGG's Avatar
Quoted: 1494 Post(s)
Liked: 1760
DO IT!!!! Best thing Ive ever done in my HT.
femi likes this.
Blasting brown notes for 20 years and counting!
N8DOGG is offline
post #14573 of 15332 Old 04-09-2020, 03:47 PM
muscles's Avatar
Quoted: 950 Post(s)
Liked: 1559
I have always wondered about doing this. What are the disadvantages? It doesn't go below like 40hz? I know it has some ridiculous high output for music, but what about movies?
Greg
muscles is offline
post #14574 of 15332 Old 04-09-2020, 04:20 PM
N8DOGG's Avatar
Liked: 1760
Greg
I only run them to 40hz, then the 24s take 40hz to 5 hz. No blending , just separate xover points and it's by FAR the easiest /best solution in my case. There is just so much firepower that both are not needed to run over each other.
Disadvantages? Nothing other than size and their tune I guess.
But for movies? It has good output to 25hz in room. But above 35 hz or so, it's scary. Right now, I have them running on a crest 7.5 at 1/4 gain, -12 on the processor and they will still blast you out of the room. It's chest thumping, feels like your In a car bass lol. They are just so damn impressive!
SuperFist and muscles like this.
N8DOGG is offline
post #14575 of 15332 Old 04-09-2020, 04:43 PM
bear123's Avatar
Quoted: 3563 Post(s)
Liked: 5509
Step 1: Buy a JTR S1 or S2. Or Rythmik G25HP. Or PSA S18 IPAL or S36 IPAL.
Step 2: Be blown away
Step 3: Sell the JL's and add another two of whichever of the above subs you purchased.
ahblaza and drh3b like this.
bear123 is online now
post #14576 of 15332 Old 04-09-2020, 05:29 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2529 Post(s)
Liked: 4091
The OS can be heard from a block away - literally - but given your history and past issues with the HOA do you really need that kind of hassle?
muscles likes this.
If you take yourself too seriously expect me to do the exact opposite.
BTW, did you really need to quote the entire post?
JimWilson is offline
post #14577 of 15332 Old 04-09-2020, 05:35 PM
muscles's Avatar
Quoted: 950 Post(s)
Liked: 1559
Oh, I have all the bass I could want. Sealed subs go louder in room without disturbing the neighbors as much. They just don't have as much horsepower under 20hz. Being on concrete floors that is wasted on me. This could be why I have such a strong bias to sealed designs. They sound better because I don't get the tactile sensations from ported...apparently my neighbors did...4 houses down. The FV25HP's disturbed every single house in my community (only 6 units). Was all set to move to a bigger house with more privacy, but pandemics can put a real damper on things. I have my health, and thankfully also my home theater...it has been so worth the outlay at this point! I don't mind being quarantined at all
Greg
muscles is offline
post #14578 of 15332 Old 04-09-2020, 05:42 PM
schwaggs's Avatar
Quoted: 302 Post(s)
Liked: 436
Originally Posted by acribb View Post
I ordered 2x monoprice rca to XLR cables. I will just bite the bullet and pull those after I test them outside the walls to see if the hum goes away.
Like I said, the scenario is this-
On one circuit only a Subwoofer is plugged into this entire circuit. With a subwoofer cable plugged into it and the other end plugged into NOTHING. This monoprice 50 ft rca cable runs up the wall in very close proximity to the subwoofers power romex. I get an extremely loud hum which goes away mostly with my cheater plugs but there is still a low level 60hz hum. I'm hoping the new cables I ordered, these, are better shielded. Speakerpower themselves recommend them.
You are on the right path. Since you have the hum with one end of the cable plugged into the sub and the other (AVR) end unplugged, no isolation transformer is going to help you. Isolation transformers can fix hum caused by ground loops, not noise picked up from surrounding sources through the cable or it's routing.
Your 50 foot cable is essentially a long antenna, picking up noise from around it. Cheap cables with cheap connectors, cheap shielding and/or improper internal connections make it worse.
A higher quality RCA cable might work.
A better route for the cable would help, even with your cheaper existing cable.
Switching to balanced XLR type connection is your best bet. Properly configured, they are more resistant to environmental noise than unbalanced RCA type wiring.
schwaggs is offline
post #14579 of 15332 Old 04-09-2020, 06:37 PM
Reddig's Avatar
Quoted: 610 Post(s)
Liked: 1249
Yes I got my 2 Cap 2400s up the stairs by myself by removing the 65lb driver on each. It was not easy getting them out or putting them back in. Luckily my wife plugged in the wire while I held it hovering over the hole.
The one time I removed the woofer in one of my Caps and reinstalled it was not easy. Ive dealt with a ton of woofers and enclosures in my day and that was the hardest woofer to instal into the enclosure. I did it myself. Thats a good idea you had with you wife helping. Next time ill do that.
Jeff told me he wedges a long screwdriver in there some how and kind of pry the woofer either in or out. That 18 is a beast on or off lol.
JTR/JBL/JVC/Denon/Oppo/Monolith/Silver Ticket/Furman/Seatcraft/Acoustimac/AudioQuest/Harrison Labs/Roku
Reddig is offline
post #14580 of 15332 Old 04-09-2020, 07:59 PM
serith's Avatar
Quoted: 927 Post(s)
Liked: 1169
Rythmik stuff is pretty easy to sell, it's more known than JTR.
very true. i still can't believe how effortless it was to sell the 5 i've owned. however, at the end of the day i'd rather be satisfied with a product and use/keep it than worry about how well it can resell. JTR feels like the endgame for myself and i'm sure many others here. i've seen very few captivators being sold here in the classifieds section & elsewhere, and it would appear that when it does happen it's either because the person selling is downsizing their theater/moving, or they were upgrading to something more powerful in the family lineup. i don't think i've seen anyone selling because it wasn't powerful enough.
i wish i didn't need to hide mine, ugh. maybe i'll take a high resolution picture and tape it over the metal mesh i'm going to put in front of the drivers it's funny that even though 90% of my captivator is hidden from view it still has such a menacing visual presence when it's off, never-mind when it's flexing.
chucky7 and muscles like this.
1800ft³ | 7.1.6 | 157" at/cw | hc2150 | x4300h | mtm-210t | 4000ulf | me650c | av5 | avbp2 | rialto | velvet | plex
serith is offline
