Official JTR Speakers Subwoofer Thread - Page 501 - AVS Forum | Home Theater Discussions And Reviews
 22379Likes
post #15001 of 15297 Old 05-13-2020, 01:52 PM
tvuong's Avatar
Quoted: 3004 Post(s)
Liked: 3091
Here is my experience from mixing different port tunes. if you run room eq with the 4000 and the v1801s, your lower end extension will be less than just running room eq off just a 4000. I would run room eq with just the 4000 alone and add the v1801s in after to maintain the lowest possible extension.
tvuong is offline
post #15002 of 15297 Old 05-13-2020, 02:40 PM
chucks0's Avatar
Quoted: 606 Post(s)
Liked: 1575
I think a lot of it is room dependent. I have had best results integrating all of the subs together using a MiniDSP (EQ, Time Align, etc) first and then presenting them to the AVR for room correction as one sub.
Electronics: Denon X4400, Vizio M65
Sub: Rythmik FV18-PC x 2
Speakers: 3 x Chane A2.4 LCR, DIYSG Volt-6 Surrounds
chucks0 is offline
post #15003 of 15297 Old 05-13-2020, 02:45 PM
tvuong's Avatar
Liked: 3091
^^ Yeah, he has a couple options to try there.
tvuong is offline
post #15004 of 15297 Old 05-13-2020, 04:30 PM
desertdome's Avatar
Quoted: 1590 Post(s)
Liked: 1952
Originally Posted by chucks0 View Post
Will using Channel 4 instead of Channel 3 result in achieving higher SPL levels, or does it just affect how the relative levels?
In most processors and receivers, the subwoofer output channel (channel 4), will have an opamp in the output circuit that increases the level +10 dB. This channel is therefore capable of higher output voltage. Depending on ones setup and input sensitivity of the subwoofer amplifier, one could get higher SPL level from channel 4.
Ponderosa Theater
High Impact AV
- JTR Speakers Customer Appreciation Sale
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #15005 of 15297 Old 05-13-2020, 05:16 PM
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
Received a replacement woofer from Jeff and swapped it out last Saturday. Ran low volume sweeps on the new sub with the new driver and the other sub as well as test tones and they both sounded the same with no strange low hz rattles. Jeff offered to send another woofer but I said I didn't think I needed one. Great service!
Also did notice some inherent chuffing in the 10-12hz range on both subs and it also appears that the tune on these Cap 2400s is actually 12hz, not 10hz. Tested this by running tones from 10hz to 20hz. The woofer doesn't move at 12hz but does extrude at 10 and 11hz. Not a big deal but seems to be the case.
I reran Audyssey and the lowest I could get them to produce without bottoming at -12 was at 9am on both which gave me -8.5 and -7db of sub trim. I then increased the sub trim 2db to -6.5 and -5db and set the gain on the subs to 11am on both one click from 12pm. I reran my sweeps at -20mv and the result was almost EXACTLY THE SAME as when I had them barely at -12db On both increased to -6db on both with the gain on one at 10am and the other at 11am.
Long story short, I don't think I was overdriving them and that the one defective sub was a fluke. Now I don't need to continue to be scared to crank these up!
giomania, serith, schwaggs and 2 others like this.
acribb is offline
post #15006 of 15297 Old 05-13-2020, 07:09 PM
schwaggs's Avatar
Quoted: 302 Post(s)
Liked: 435
Great news! Thanks for posting the resolution.
I've not had to push my 2400ULF to where I worried about damaging it.
My ears and fear for my home gave in before JTR did.
schwaggs is offline
post #15007 of 15297 Old 05-13-2020, 07:29 PM
farsider3000's Avatar
Quoted: 1720 Post(s)
Liked: 1098
Originally Posted by Dutch-boy View Post
Thanks so much for sharing serith. I am just so afraid that I will feel it from behind...I know, I know...Bass is not directional, maybe it is a bias I can't overcome.
Maybe I did not have minidsp or crossovers set right last time I tried it also. I just have the perfect place for that bad boy and I wonder (hoped) it would work. I mean, according to "the man" (O'Toole) center wall is good with multiple so I was wondering about single. I really like the balance of my setup now with two V18's in front and 3601 in back but the 2400's are just too big for me to put up front and keep the screen at the height I like it to be...oh yeah, and the price lol
I find that bass can be directional. I can definitely feel the missing bass coming from my side wall area when I turn off my two RS2. Whether that is pressure, vibration of my floor or a combination I am not sure. I had an acoustic engineer design the room and he insisted the best set up for my room was a sub in the center front and a sub in the center rear. I was going to do away with my subs on the side wall but (Seatons Before my Dual RS2 purchase) when I turned them off the bass did not fill the entire space nearly as evenly.
Sent from my iPhone using Tapatalk Pro
SuperFist and skylarlove1999 like this.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is online now
post #15008 of 15297 Old 05-13-2020, 08:14 PM
imureh's Avatar
Quoted: 3576 Post(s)
Liked: 4883
That seems inconsistent with the numbers on data-bass for the 2400...
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #15009 of 15297 Old 05-14-2020, 03:56 AM
Dutch-boy's Avatar
Quoted: 78 Post(s)
Thanks so much tvoung and chucks0.
It is very nice to know that it is possible to get good result with a little work.
I really like the combination of size/sound of the v1811's.
Vizio m801d ISF calibrated in a light controlled room 15.5'x20.5'x8' with MLP 10'-14' from screen
Anthem MRX 510, MiniDSP 2x4HD/WI-DG
Oppo 103d, Apple TV 4K, GIK MBT Panels
Paradigm studio 60, 20 & 10's v5, cc 590, PSA V3601 & 2 V1811
Dutch-boy is online now
post #15010 of 15297 Old 05-14-2020, 04:03 AM
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
I do not know if the test I performed means conclusively that the tune is at 12hz, I'm only stating what I witnessed as an actual owner of two of these Cap 2400 subwoofers.
Would be curious to see what other actual owners here witness by running a tone at a low volume of say -25mv, with noEq at 10-15hz. Tell me which frequency it vibrates the least at.
https://www.szynalski.com/tone-generator/
acribb is offline
post #15011 of 15297 Old 05-14-2020, 04:44 AM
giomania's Avatar
Quoted: 918 Post(s)
Liked: 730
The biggest issue with mixing ported with sealed or ported subs with different tunes is that you can end up with cancellations where the subs are out of phase. Although a little more effort is required to get everything dialed in, using REW to measure the subs and get them all time-aligned, you can end up with a really good result. I know @basshead81 has mixed PSA subs with a 20'ish tune with a JTR sub with a 10 hz tune with good success. Lots of the DIY guys are mixing ported with sealed and even using horns with sealed and all kinds of exotic setups.
I mixed two Cap 4000ULFs with four sealed Seaton SubMersives in my room. I used the Multi-sub Optimizer software to accomplish this, and the results were great.
Mark
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #15012 of 15297 Old 05-14-2020, 05:35 AM
chucks0's Avatar
Quoted: 606 Post(s)
Liked: 1575
Mark
I downloaded the MSO a while back but never got around to doing the measurements to use it. It sounds like it could be very useful to test a bunch of different sub locations virtually to figure out the optimum locations.
chucks0 is offline
post #15013 of 15297 Old 05-14-2020, 05:41 AM
giomania's Avatar
Quoted: 918 Post(s)
Liked: 730
Not sure it works that way, based on my experience, but you could always ask in the dedicated thread.
giomania is offline
post #15014 of 15297 Old 05-14-2020, 08:18 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10955
I have measured both the JTR 1200xs(10hz tune) and PSA 15v's(18-19hz tune) together and separate...either way the +/ -3db point still remains 12.5hz with or without the PSA's. Without the JTR it moves up to 16.5hz. The -3db point is above port tune on the JTR because it has a HPF placed around 12-13hz where normally the -3db would be a couple hz below port tune on most ported subs.
SuperFist and rhelliott2 like this.
basshead81 is offline
post #15015 of 15297 Old 05-14-2020, 08:33 AM
juanchibiris's Avatar
Quoted: 107 Post(s)
Liked: 84
I guess in the midbass the PSA should sum more dB?
juanchibiris is offline
post #15016 of 15297 Old 05-14-2020, 09:18 AM
tvuong's Avatar
Liked: 3091
Good to know. In my case I have the 12Hz tuned main subs and 55ish hz MBMs and there were differences in extension running Audyssey with main subs alone versus main subs + MBMs.
tvuong is offline
post #15017 of 15297 Old 05-14-2020, 09:25 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10955
For reference I have 3 PSA XV15 Ice/SE subs and 1 JTR1200xs. Each subs was level matched to 76db, amp gains 9:00, RC/LF adjust set mid. Post calibration came back -10/-11 on the amp gains.
The way I have my subs placed the JTR lifts the response below 30hz, has a big null around 34hz, and a roll off in response above 40hz. The PSA are nice and smooth in the 40-80hz, big 12db peak in the 34hz area and roll off below 30hz. So the combination equals a nice smooth rising response(+6db) from 80-12hz. The PSA are better in the mid bass and the JTR is better below 30hz. Honestly I couldn't of asked for the setup to work any better. They compliment each other well.
Below is a REW graph showing results post Audy then my tweaks.
Purple line- Just post Audy sweep. Notice how low it set the bass. That is why many never reach the full potential of their subs. You will run out of sub trim adjustment without going extreme positive to get good bass.
Teal line- I bumped sub trim from -11 to -6.
Blue line- Set the JTR LF adjust from mid to max.
Yellow line- Set the PSA RC from mid to 3/4 from max.
Red line- Set the PSA RC to max bumped sub trim to -4.
Name:	new base response.jpg
post #15018 of 15297 Old 05-14-2020, 10:43 AM
tvuong's Avatar
Liked: 3091
^^ Look good BH. The extension could have been a bit better in room with the 10hz xs1200 though.
tvuong is offline
post #15019 of 15297 Old 05-14-2020, 10:54 AM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
Thinking of turning my audyssey xt32 filter off for now.
My seats are against the back wall and there is a null for the mains and subs around 80hz. The audyssey tries to correct it too much, it sounds "corrected" at lower volumes but at higher volume the system sounds strained.
I rather have the null than have it sound like that. There is simply not enough power to correct a null. At least this is obvious for movies and for music listening I think I can leave audyssey on.
I already used the App to limit to correction so it doesn't apply filter to the sub channel above 60hz. But I think the straining is a result of trying to boost the mains as well.
What do you all think?
PoorSignal is offline
post #15020 of 15297 Old 05-14-2020, 11:28 AM
maxkolonko123's Avatar
Quoted: 56 Post(s)
Liked: 38
Hey guys, dont know if here is the right place to ask but im looking for some help, in near im looking to upgrade my PSA s3010 and cant make my mind what route to take, options are as bellow :
PSA s3012 dual
PSA TV18Ipal dual
or
JTR RS 2 single - with option to go duals in future
It is really bugging me, and cant make my mind, thanks for any ideas and opinions
maxkolonko123 is offline
post #15021 of 15297 Old 05-14-2020, 11:43 AM
imureh's Avatar
Liked: 4883
PSA s3012 dual
PSA TV18Ipal dual
or
What are your goals and what is your room like? From these choices the RS2 is not even in the same league....so its really a simple choice....RS2
jamiebosco likes this.
imureh is offline
post #15022 of 15297 Old 05-14-2020, 12:00 PM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10955
I believe Jeff put a 12hz High Pass Filter on the 1200watt model. So it's basically a 12hz sub and I should probably refer to it as that even though the port tune is 10hz.
skylarlove1999 likes this.
post #15023 of 15297 Old 05-14-2020, 12:39 PM
chucks0's Avatar
Quoted: 606 Post(s)
Liked: 1575
PSA s3012 dual
PSA TV18Ipal dual
or
First of all, you are in a JTR thread so I'm guessing the responses might be slanted heavily in favor of the JTR.
That's an interesting mix since you are considering sealed and ported. While the s3012 will have a cleaner sound than the s3010, I'm not sure that is a cost effective move. You would also lose a little bit of output down low since the 15DS115 has lower xmax than the Eminence driver.
The TV18iPal is going to have a lot more output down low and more tactile response than the sealed PSA, and would be my choice between the 2 PSA options on your list although I would probably save some money and just get the TV1812.
The JTR RS 2 is a very noticeable upgrade over the sealed PSA but you would only have a single so you could end up with a bumpy frequency response. I'm assuming dual RS1 is over the budget you are looking to stick with. If not, that would be a great choice. The JTR is also going to have a thicker sound which you may or may not prefer.
You should also consider the FV18 Paper Cone which is similar in price and size to the TV1812 and has available measurement data to see how it compares to the JTR option.
skylarlove1999 and basshead81 like this.
chucks0 is offline
post #15024 of 15297 Old 05-14-2020, 12:57 PM
Quoted: 56 Post(s)
Liked: 38
From my calcualation my room is 67 cubic meters, and my goal is to feel the output and pressurize it.
Thats great answer buddy, by thicker bass you mean hard punch compared to soft/meaty ? hard for to describe what i have on my mind
post #15025 of 15297 Old 05-14-2020, 12:58 PM
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
Can any owners out there mind running this test? Curious to see what results other owners end up with.
acribb is offline
post #15026 of 15297 Old 05-14-2020, 01:10 PM
chucks0's Avatar
Quoted: 606 Post(s)
Liked: 1575
It can be hard to describe sound in words. When I hear "hard punch", I think of strong tight mid-bass that you feel in your chest. Thick bass to me is less focused on mid bass punch and has a stronger emphasis on deep bass that creates a sense of pressure.
I don't want it to sound like it is an either or proposition, just that some sub designs are often described one way more than another.
chucks0 is offline
post #15027 of 15297 Old 05-14-2020, 01:14 PM
chucky7's Avatar
Quoted: 3931 Post(s)
Liked: 5597
Have you tried the sub distance tweak?
How do you know there is a null? Have you run REW before?
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
chucky7 is online now
post #15028 of 15297 Old 05-14-2020, 01:19 PM
PoorSignal's Avatar
Quoted: 354 Post(s)
Liked: 88
I don't think it's a sub distance tweak issue as audy graphs all individual graphs from sub and each of LCR shows a dip. It's a cancellation issue.
I have run REW on it, shows similar finding as audy. Audy can get it close to flat and REW shows but that does not mean when movies demands it, it can keep it sounding good. I only have the 118HT with 700W so not alot of headroom to correct 15 db or anything.
post #15029 of 15297 Old 05-14-2020, 01:34 PM
chucky7's Avatar
Liked: 5597
All you have to do is run a FR of CC at your MV and see how it looks at 80Hz.
Make sure you compensate for the REW dBFS though. I am surprised many people don't know about this.
For example, say you want to run a FR of your normal MV of -10dB. You measure with the REW dBFS @ -3dB, which is the max, and your AVR MV @ -7dB. The combined SPL is -10dB.
Post the FR here.
bcarlsontx likes this.
post #15030 of 15297 Old 05-14-2020, 01:38 PM
Quoted: 56 Post(s)
Liked: 38
Now it makes perfect sense to me what u mean by it
