AVS Forum | Home Theater Discussions And Reviews (https://www.avsforum.com/forum/)
-   Subwoofers, Bass, and Transducers (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/)
-   -   New placement friendly subwoofer 1700$ max (https://www.avsforum.com/forum/113-subwoofers-bass-transducers/2769921-new-placement-friendly-subwoofer-1700-max.html)
zap123 03-02-2017 06:59 PM
Hi, I wanna buy a new subwoofer for 60% music and 40% HT.
It needs to be very placement friendly because it´s going in a small living room only 322 square feet. My budget is about 1500 dollars.
I'm considering:
Paradigm Millenia subwoofer.
Does that subwoofer deliver a good performance in addition to beeing easy to place?
What are the other models I should consider?
Thanx in advance.
Ps.
Here is the rest of the system if it matters:
2x ELAC UNI-FI FS U5
ELAC UNI-FI CC U5 slim
2x ELAC WS 1445
ANTHEM MRX-720 RECEIVER
bpgunning 03-02-2017 10:00 PM
Originally Posted by zap123 (Post 51198665)
I'm considering:
Most likely not. 300W RMS is not much in general, and it's a small sub - with few notable exceptions, most small subwoofers don't offer much in terms of performance. I'd recommend something like a PSA S1500 which you can get in some very nice finishes for highly visible living room use. It's not exactly small in absolute terms (18x17x17.25"), but is one of the smaller subs you'll see recommended on these boards I suspect. I had the 15V, a ported version, for a little while and was very impressed. If you can fit it, the S1801 would be even better - more output and a newly redesigned driver, but a substantially larger box (22x20x20.5"), and also doesn't have the custom finishes. If you need something with a smaller footprint you might consider the SVS PC cylindrical subs.
No doubt Paradigm makes some nice speakers, but for the price their subwoofers aren't really competitive with many of the fantastic ID offerings these days.
littlefoott 03-02-2017 10:24 PM
To be placement friendly , get 2 nice small ones that still perform great.
With one, you may place it where the room doesn't work with it, room acoustics have a lot to do with effective placement of a single sub.
With 2 you can be much more flexible in where they go
The Svs SB2000
has a small footprint and comes in black ash or piano black
14.6”H 14.2"W 15.4”D
great for music and good for home theater
buy dual and save $100
for 2 subs
Piano black is $1500
Black ash is $1300
enjoy!
zap123 03-03-2017 01:43 AM
Thanks for the recommendation, unfortunately, PSA subs are not sold here in Norway. Most brands mentioned here on the forum, are sold however. What about Rel? They seem to sell some small form factor subwoofers.
zap123 03-03-2017 01:50 AM
The Svs SB2000
for 2 subs
Black ash is $1300
enjoy!
I want 2 subs in the future, but I want to start with one and see if I need it, also I can buy a more expensive sub combo if I wait with the second subwoofer.
littlefoott 03-03-2017 01:59 AM
are you familiar with the subwoofer crawl, if not, google it
it's the best method to find where a subwoofer should go, without using specialized equipment.
if you do choose to start with one subwoofer, use that method to find a place for it.
the paradigm you mentioned was a low profile, so I didn't want to mention larger footprint options.
For your price range there are much better performers, however they are a large single enclosure.
zap123 03-03-2017 04:24 AM
Okay, so what would you recommend in a nice all be it with a larger footprint?
basshead81 03-03-2017 06:09 AM
Rythmik FV15HP.
littlefoott 03-03-2017 06:28 AM
psa S3000I would be on my short list
little bit larger footprint but your movies and music would make the hair on your arms stand up, literally
Shipment dimensions (D x W x H): 28" x 23" x 28"
Shipment weight: 125lbs
basshead81 03-03-2017 06:34 AM
Op said PSA is not available in Norway. Are you not following along in the thread you have posted in 3 times? Lol
bpgunning 03-03-2017 06:41 AM
I don't know much about REL. I would talk to Tom, he's available on the PSA website chat, and see if they have an option for you in Norway. It looks like they have a distributor for most every country in Europe but for some reason Norway isn't on the list (link). Even if it ends up costing some more for importing, I think it would be pretty challenging to find a better performance-per-dollar sub than some of the PSA offerings. And even if it's a bit more of a nuisance to get it, I think it's worth looking into. I'm not sure if the other ID companies do international shipping or have distributors for Norway either. IMO the next best bet would be the SVS subs - a SB13 Ultra is decently small at 18x17.5x20.5", and should fit in your budget ($1600). Or the the PC12 Plus if you like the cylindrical subs, or the SB2000 would be a bigger step down but much cheaper.
littlefoott 03-03-2017 07:05 AM
nope, I missed that post :eeksurprise:
littlefoott 03-03-2017 07:14 AM
ok second choice JTR Captivator 118HT
and the rythmic already mentioned
littlefoott 03-03-2017 07:16 AM
third choice svs PC13-Ultra
Kini62 03-03-2017 12:50 PM
I'm considering:
Thanx in advance.
Ps.
2x ELAC WS 1445
Tell us what is available in Norway to get a better recommendation.
Is XTZ available? They have some pretty good subs and are based in Europe. Try to buy local if possible if nothing more than for peace of mind if the warrant is needed.
zap123 03-03-2017 05:27 PM
It needs to be very placement friendly because it?s going in a small living room only 322 square feet. My budget is about 1500 dollars.
I'm considering:
Thanx in advance.
Ps.
2x ELAC WS 1445
Good point
XTZ and SVS are both available in Norway. Others include Rel, JL Audio, Velodyne and alot more, but those are the pure sub manufacturers I can rember...
What about XTZ, any model recommendations?
Powered by vBulletin® Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
