SVS, HSU or Rythmik ? - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 2 Post By ironmikey12
  • 1 Post By Falconsfan71
  • 1 Post By TheCarFather
  • 1 Post By torii
  • 1 Post By mikeTRON250LM
  • 1 Post By amit.suhane
post #1 of 20 Old 05-05-2017, 02:21 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Smile SVS, HSU or Rythmik ?
Hi Guys,
I've the following setup:
Martin Logan Motion 40 (main)
Motion 8 (Center Channel)
B&W CCM362/6 1/2 inch ceiling speaker (for Surround)
Yamaha RX-673
Recently, we moved to our own house so I need (or I can now) add sub woofer to the system. The area is 350 sq ft with 9ft ceiling so around 3500 Cubic ft space and has a open layout because of stairs, and open kitchen. My budget is $1000-1200 USD, and sub has to look good (preferably piano black finish similar to our Motion 40). We do 50/50 movies and songs and listen to around -20db in our Yamaha AVR and I do not have space for dual sub.
Based on other forum feedback these are the good subs which fits my budget but aesthetically they do not please my wife.
1. Rythmik LVX12
2. VTF-3 MK5 /VTF-2
3. SVS PB-2000
4. PSA 15V
She does approve these two: 1. SVS SB-2000 -Piano black 2. Rythmik - FV15HP - Piano black
Rythmic FV15HP is great but is costing $1550+Shipping, and based on feedback SVS SB-2000 doesn't do a good job compared to PB-2000. Do you think I do have other choices based on the criteria ?
If not, I am thinking to try SVS SB-2000 as it is free shipping and 45 days trial period and if not happy then either need to consider Rythmik LVX12/HSU VTG-3 MK5 if I do not want to spent $1600 on Rythmik FV15HP.
Please let me know your recommendation, as not all suppliers provide free shipping and these subs are not available is nearby store to try.
amit.suhane is offline
post #2 of 20 Old 05-05-2017, 02:22 PM
ironmikey12's Avatar
Quoted: 216 Post(s)
Liked: 107
There are probably 20 recent threads asking the same question. Not trying to be a jerk; just saying there's lots of info on here.
I'm deciding between HSU and SVS myself...
ChromeJob and mikeTRON250LM like this.
ironmikey12 is offline
post #3 of 20 Old 05-05-2017, 02:31 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Actually, I am new to the forum and also new to the audio system. There are so many options and material, and some are beyond my frequency () . So thought of getting specific recommendations based on my situations. Main questions is SVS SB-2000 is worth trying ?
post #4 of 20 Old 05-05-2017, 02:32 PM
Falconsfan71's Avatar
Quoted: 1543 Post(s)
Liked: 524
OK so.. I tried the PB-1000 (duals) and the PB-2000.. both have the black oak vinyl finish.. looks pretty good.. but, I also have around 3300 cubic feet and they just didn't work for me. If you're gonna listen to 50% or more of music then (like me) you will not be happy. I just got the VTF-3 MK5.. more power and output than both of those.. the black satin finish looks really good.. and to me it's much better quality as far as looks and build and sounds better. It's 85 lbs compared to the 66 lb PB-2000.
amit.suhane likes this.
Denon X4300H * Def Tech BP8080st front L/R * Def Tech CLR2002 center * Def Tech ProMonitor 800 surrounds (x4) * Hsu VTF-3 MK5 HP sub * Outlaw OAW4 wireless sub kit * Vizio 60" 4K HDRtv * Sony UBP-X800 Bluray * PS4 * AC Infinity S9 AVR fan
Falconsfan71 is offline
post #5 of 20 Old 05-05-2017, 02:37 PM
yummer's Avatar
Quoted: 16 Post(s)
Based on your other sub selections, probably not worth it...
You would probably need 3 SB-2000's to match the output of one Rythmik FV15HP.
yummer is offline
post #6 of 20 Old 05-05-2017, 02:38 PM
TheCarFather's Avatar
Quoted: 97 Post(s)
Liked: 101
Buy the biggest sub you can afford, which with your budget means a 15" preferably. I own dual HSU VTF-3 MK5's and they are amazing. The VTF-15H MK2 is a bit nicer and still fits within your budget. The 15H MK2 has +3db more output below 22hz compared to the VTF-3 MK5, and IMO looks nicer with the triangle ports.
The Rythmik FVX15 comes in under your budget, along with the PSA 15V. Just some others to consider.
Receiver: Denon X1200W
Mains: Pioneer FS52
Center: Pioneer C22
Surround: Pioneer BS22
Rears: Polk T15
Sub: (2) HSU VTF-3 MK5 HP
TheCarFather is offline
post #7 of 20 Old 05-05-2017, 02:45 PM
imureh's Avatar
Quoted: 2599 Post(s)
Liked: 3026
Hi Guys,
Yamaha RX-673
1. Rythmik LVX12
2. VTF-3 MK5 /VTF-2
3. SVS PB-2000
4. PSA 15V
Within the budget you have listed, the PSA 15V is your best bang for the buck or the HSU 15 inch. You ideally need duals in that size room, so may be look to add another later but as others have said go with the biggest for now
imureh is offline
post #8 of 20 Old 05-05-2017, 02:46 PM
torii's Avatar
Quoted: 3178 Post(s)
Liked: 1783
options are good
http://www.salksound.com/galleryresults-standard.php
mikeTRON250LM likes this.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5 Subs: Rythmik FV25HP, Rythmik FV15HP
torii is online now
post #9 of 20 Old 05-05-2017, 03:21 PM
Quoted: 216 Post(s)
Liked: 107
Read FalconFan's recent treads. Lots of overlap w your questions. I've subscribed to this thread. I need to fill a basement that's like 25x24. Maybe 4500ft3
post #10 of 20 Old 05-05-2017, 04:35 PM
basshead81's Avatar
Quoted: 310 Post(s)
Liked: 8736
More like 8 around the FV15's tuning point.
basshead81 is offline
post #11 of 20 Old 05-05-2017, 04:59 PM
Kini62's Avatar
Quoted: 2660 Post(s)
Liked: 2441
Kind of limited in that price range for piano black. Take a look at SVS outlet.
Currently have several PB12+ in PB ($1199) and an SB13U in PB ($1199).
The PB12+ would be the better option for your space.
https://www.svsound.com/collections/...als/outlet-sub
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #12 of 20 Old 05-05-2017, 05:10 PM
Cutler's Avatar
Quoted: 107 Post(s)
Liked: 95
I would throw Seaton in the mix as well.....
Cutler is offline
post #13 of 20 Old 05-06-2017, 10:48 PM
ChromeJob's Avatar
Quoted: 1984 Post(s)
Liked: 1052
Search is our friend. Saying "I'm new" doesn't mean you can't browse threads and use teh forum search for a targeted look for "help me pick a sub."
Hsu's finish isn't gloss black, but it's not textured matte either. Can be buffed to a nice modest sheen.And the Hsu variability feature trumps some other brands that force you to choose "sealed vs. ported."
"Sell crazy some place else -- we're all stocked up here."
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #14 of 20 Old 05-07-2017, 11:13 AM
Liked: 524
The satin black is a nice finish on the VTF-3 MK5 and a lot easier to maintain than that piano black finish.
You won't regret it! I'm not gonna bash SVS and can't say anything bad about them but this sub is better than the PB-2000 I had and the dual PB-1000's. To me, the quality and the build appears and "feels" better but the weight of this thing.. omg! It's a bulky heavy 85 pounds!!! The finish is much better also. To me, the black satin painted finish is much nicer than black oak "vinyl".
I'm hearing nice bass on rock songs and pop songs that I didn't hear with the SVS subs. I listen to a lot of music on Pandora through the AVR on Extended Stereo mode and I'm having fun with this!
ChromeJob likes this.
post #15 of 20 Old 05-07-2017, 11:29 AM
ottablue's Avatar
Quoted: 39 Post(s)
Liked: 8
For your space one JL Audio F113v2 will be fantastic!! It will complement your Martin Logan electrostatics bottom end seamlessly I owned Summit X and that is what I had in my set up for low frequency lack. Speaking from experience.
Sent from my SM-G935F using Tapatalk
ottablue is offline
post #16 of 20 Old 05-07-2017, 12:24 PM
mikeTRON250LM's Avatar
Quoted: 418 Post(s)
Liked: 342
I have the HSU vtf15h and I wanted a pair. After some research I discovered DIY is absolutely the better bang for the buck. If you have no skills at all you can still buy and assemble a CNC machined flatpack from partsexpress with a um18-22. If you have a bit more skills you can cut and glue a Marty sub or a vbss. I built two VBSS which uses 18" drivers to replace my HSU.
All of the subs you listed are good, it's just tweaking size and output at certain frequencies. I think hsu is the best bang for the buck in the retail arena. Otherwise I strongly suggest diy.
Sent from my SM-G935P using Tapatalk
mikeTRON250LM is offline
post #17 of 20 Old 05-09-2017, 12:28 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Thank you guys !! Finally, I decided to try Rythmik E15HP which is $1325 on piano black finish.
Let's see how it performs. I'll get back with the feedback.
Kini62 likes this.
post #18 of 20 Old 08-15-2017, 02:13 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 3
Just updating: My E15HP is awesome, it fills the room. it is bit big but it can shake the house. Highly recommended.
SunByrne likes this.
post #19 of 20 Old 08-15-2017, 05:54 PM
tomnan24's Avatar
Quoted: 122 Post(s)
Liked: 33
I Appreciate that you reported back. Glad you're satisfied.
Samsung UN55KS8000 purchased 2017
Denon AVR1610 purchased 2010
Cherry Energy RC10 mains purchased 2010, RC-LCR center purchased 2017, RCmini surrounds purchased 2010
PSA 15V purchased 3/26/18
tomnan24 is offline
post #20 of 20 Old 08-16-2017, 02:12 AM
braveheart123's Avatar
Quoted: 337 Post(s)
Liked: 289
Hi Guys,
Yamaha RX-673
1. Rythmik LVX12
2. VTF-3 MK5 /VTF-2
3. SVS PB-2000
4. PSA 15V
All the listed subs or any other quality subs would sound the same within their operating limits. So, you can buy any depending on your budget.
The defining factor is price, listening area (how big an area you want to pressurize), and WAF.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
