Dual Monolith+ setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-17-2017, 06:42 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 3
Need a little advice.
Just about to get an extra Monolith+
BEFORE i do the Pioneer Mcacc Calibration, what position should the Gain dial be on the rear of the subs?. 9.o clock?
After i do the full calibration on all speakers, i need to get the levels correct (75Db) with a SPL meter. Again what position should the Gain dial be at the rear BEFORE i do this? Is it done by dialing up the gain on rear of sub or using the levels on the Pioneer amp? Little bit confused with this bit!
Paul Greenwood is offline
post #2 of 3 Old 05-17-2017, 10:06 AM
indebtbassfreak's Avatar
Quoted: 1346 Post(s)
Liked: 2543
Not familiar with the Mcacc calibration but i'm sure the premise is similar to Audyssey. The gain setting on your sub will vary based on how far your sub is from the MLP and the potency of the sub itself. Your goal is to play with the gain setting then run room correction so that (post) calibration should set your AVR sub trim well into the (-). Find out what your AVR max (-) trim level goes to manually and aim to have Mcacc set it post calibration within one pr two db's of that. That will allow you to then add as many db's (hot) to your avr sub trim and still stay in the (-) keeping a clean signal to your sub.
indebtbassfreak is online now
post #3 of 3 Old 05-18-2017, 01:29 AM - Thread Starter
Quoted: 31 Post(s)
Liked: 3
Thank you for the info! That makes sense.
Weirdly info and tutorials etc on Pioneer's Mcacc is MUCH harder to find. Audyssey is clearly much more popular.
