Power Sound Audio's New Flagship: S7201 Quad-18" - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 931Likes
post #421 of 512 Old 09-01-2017, 04:42 PM
Kini62's Avatar
Quoted: 2795 Post(s)
Liked: 2674
Originally Posted by climber07 View Post
Whether you can see the front side of the driver or the back, there is no "port" or "slot" that is tuned to a specific frequency. Bass reflex ports boost the output around the enclosure's port tune freq. This sub has no hole from which the signal exits the enclosure in phase with the driver wave, hence sealed.
Still lost.
It has two openings that 2 drivers output into, so even though the openings are not tuned to a specific frequency doesn't it still funnel the output much like a port?
I'll probably never quite get it, but that's ok.
As an aside, that sub doesn't look all that big in your room. That room must be quite large. You have more than enough space for 2 or 3 more.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #422 of 512 Old 09-01-2017, 04:45 PM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 677 Post(s)
Liked: 323
Originally Posted by Kini62 View Post
I still can't understand how it can be a "sealed" design with the top and bottom drivers firing into the opening. Or is there something I'm not seeing?
Don't all/most sealed subs fire into an opening, which is usually the room? The part I don't really understand is the dual driver configuration in the middle. Those two drivers appear to be firing into each other. How does that work?
Actually, I probably don't understand any of it.
B T C is offline
post #423 of 512 Old 09-01-2017, 05:25 PM
chucky7's Avatar
Quoted: 3697 Post(s)
Liked: 4983
Technically speaking, the openings are not ports so it is still not a ported sub. The cabinet itself is sealed and the openings are excluded from the internal volume. In this case, the openings are necessary because how else do you install the drivers that are moved into the openings?
M&K is known for using the push pull design, except one driver is on the front baffle and the other is in the opening. The S7201 is interesting because the drivers that are supposed to be on the front baffle were also move into the openings, making the 4 drivers inline. This combines push-pull and dual opposed, thus lowers distortion (due to push-pull) and provides force canceling effect (due to dual opposed).
18Hurts likes this.
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #424 of 512 Old 09-01-2017, 06:15 PM
bscool's Avatar
Quoted: 890 Post(s)
Liked: 715
As far as I know, the slots(manifold) are "tuned" so to speak as the size of the slot will affect the frequency response, output, and peaks. They cannot be just a random size and have to be designed to a specific height, depth and width or it will have resonances(peaks in the frequency response) that will not sound good. From the little, I know about slot loaded subs like the S7201 the slot usually increase efficiency in the upper end.
I would imagine they modeled the enclosure and slots in software first and then built them and fine tuned and made changes if the models/simulations didn't match the real world results they were looking for. Maybe Tom will expand on it more and correct me if I am wrong.
For more info for anyone interested in the more technical details http://www.diyaudio.com/forums/subwo...nclosures.html
It is a lot more involved than a simple sealed enclosure to design and build.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #425 of 512 Old 09-01-2017, 07:03 PM
Quoted: 1012 Post(s)
Liked: 1263
The three cavities (top, bottom and center) all connect to each other "in the back", they are all working on the same air mass. Thats why its much deeper than the 18" driver would otherwise require.
Pradeep2 is offline
post #426 of 512 Old 09-01-2017, 07:17 PM
Hopinater's Avatar
Quoted: 3625 Post(s)
Liked: 11684
What makes this sub fun is it's warping a lot of our minds, and we are subwoofer freaks. It's nice to have something that makes us scratch our heads go
Subwoofers: PSA TV36 iPal X2 ...Speakers: PSA MTM-210T L/R - PSA MTM-210C Center- PSA MT110SR's Surrounds - RSL C34E Atmos... Motion Actuators: Crowson Shadow 8 - X2
Video: Samsung UN65KS9000 4K SUHD - Oppo UDP-203... AVR:Denon X4400... Gaming: XBOX ONE S
Guide to Subwoofer Calibration and Bass Preferences
Hopinater is offline
post #427 of 512 Old 09-01-2017, 08:13 PM
Marc Alexander's Avatar
Quoted: 5910 Post(s)
Liked: 5470
SLPP = Slot Loaded Push-Pull
Google if you need detailed descriptions of what is going on.
@climber07 what size is the projection screen? The large room, projection screen, and main towers make the S7201 appear properly sized!
chucky7, ahblaza and climber07 like this.
Marc Alexander is online now
post #428 of 512 Old 09-01-2017, 09:01 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
Originally Posted by marc alexander View Post
slpp = slot loaded push-pull
google if you need detailed descriptions of what is going on.
@climber07 what size is the projection screen? The large room, projection screen, and main towers make the s7201 appear properly sized!
106"
Power Sound Audio S7201 Quad 18" 4000W Sealed Subwoofer - Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Epson 5030UB Projector - Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - - XBox One S - Logitech Harmony One, and custom DIY media console...
climber07 is offline
post #429 of 512 Old 09-01-2017, 09:52 PM
Jim Farina's Avatar
Quoted: 70 Post(s)
Liked: 325
The attached picture shows a 3D model of the S7201 with one side missing. The inside of the cabinet makes a "3" shape.
Jim Farina
Jim Farina is offline
post #430 of 512 Old 09-02-2017, 12:55 AM
Mike Butny's Avatar
Quoted: 1142 Post(s)
Liked: 2649
I think some of the confusion is with the drivers firing inside the cabinet and it looks like their output is trapped inside. If we were just comparing the output potential. Would a quad opposed with 2 drivers firing out the front and 2 drivers firing out the back have more output than the S7200 design?
Equipment List: Benq W6000, Darbee DVP-5000S Video Processor, JKP Affinity 100 inch 16x9 .9 gain reference screen, Marantz SR7013 Receiver, 3-Marantz Ma700 and 2-Ma6100 monoblocks, 7.4.2 Atmos, B&W Nautilus 805 front speakers, B&W Nautilus HTM2 center speaker, 2 Volt 6 Atmos Speakers, Mirage HDT-R side speakers, Jamo THX surround one rear speakers, 2 LaVoce 21inch Neo DIY subs and 2 PSA S3600I'S.
Mike Butny is online now
post #431 of 512 Old 09-02-2017, 06:04 AM
Quoted: 28 Post(s)
Speakers generate sound pressure from both surfaces of their drivers. Even though it appears that some of the drivers are pointed inwards, the back side of the driver is still in contact with outside air. As this driver vibrates it generates positive pressure (compression) on one side and negative pressure (rarefaction) on the other. It is producing sound from both surfaces with the only caveat that the sounds produced will be out of phase with each other. I would assume that this design would have the same potential output as quad opposed drivers as long as the phase relationship of the drivers is handled properly.
This space intentionally left blank
marcdorfman is offline
post #432 of 512 Old 09-02-2017, 06:46 AM
Hopinater's Avatar
Liked: 11684
That's a cool look at this sub. It needs to become the avatar for one you guys who own this sub.
Mike Butny and oneeyeblind like this.
post #433 of 512 Old 09-02-2017, 08:40 AM
Orijen's Avatar
Quoted: 85 Post(s)
Liked: 69
Originally Posted by fastninja76 View Post
Hahahaha I showed my wife the comparison to the A9's in those pics. She asked if your wife left this week lol.
Sent from my SM-G950U using Tapatalk
It's called keeping your pimp hand strong!...
Thanks for the pics Climber07!
climber07 likes this.
Orijen is offline
post #434 of 512 Old 09-02-2017, 09:51 AM
Liked: 1263
Originally Posted by Tom Vodhanel View Post
Compression graph for the S72 pushed out a bit louder..
Tom V.
Power Sound Audio
Looks like a significant increase in extension when compared to the T18HT.
Pradeep2 is offline
post #435 of 512 Old 09-02-2017, 10:50 AM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
That and distortion is reduced. The push-pull sealed design helps to compensate for motor non-linearities. This also helps the sub extend much deeper than would otherwise be possible with the same size cabinet.
I can tell you that 102 - 105 dB at 10 Hz is something to behold. It honestly feels and sounds like an earthquake.
post #436 of 512 Old 09-02-2017, 02:54 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
These videos show the S7201's power and driver excursion. The audio gets massively clipped on the camcorder. Nothing but pure, smooth, undistorted bass is audible to the ears.
post #437 of 512 Old 09-02-2017, 09:58 PM
Liked: 4
Not sure if It would have been easier to move the media room downstairs or this sub upstairs...
tms500 is offline
post #438 of 512 Old 09-02-2017, 10:08 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
I hear ya brother. It took us two hours to wrap, rig, and pull the beast up the stairs.
post #439 of 512 Old 09-03-2017, 04:26 AM
femi's Avatar
Quoted: 307 Post(s)
Liked: 361
I'm so impress that you and your family move that beast up the stairs . Amazing.
Femi
climber07 and Pradeep2 like this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #440 of 512 Old 09-03-2017, 12:25 PM
bear123's Avatar
Quoted: 2942 Post(s)
Liked: 4485
Tom V.
Power Sound Audio
Wow, that's impressive!! Sandbagging a bit on the first graph released that showed around 112dB at 20Hz. I figured you were all in there before compression down low. But 116+ @20hz ...that's damned impressive. Basically, way above reference capable full bandwidth even calibrated pretty durn hot, as long as there's any room gain at all down low.
Looks like a close match to the HST-24 down low(the most powerful sealed sub ever tested on Data-bass), but obliterates it above that.
bear123 is online now
post #441 of 512 Old 09-03-2017, 09:58 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
I got bored and drew up the S7201 in Sketchup. It's obviously not exactly identical measurement wise, but I thought it was cool. I'm able to manipulate the individual pieces, rotate, and such. Just for fun of course.
Name:	S7201 Front Side.PNG
ID:	2277770   Click image for larger version
Name:	S7201 Exploded.PNG
post #442 of 512 Old 09-04-2017, 07:26 AM
Liked: 1263
So what placement configs are others planning to use? Mine is going into an unfinished 28×48×9ft concrete block basement, floating concrete slab. REW room simulator suggests two subs in diagonal corners would provide the best response. I can colocate two 4 cuft flatpack um18s and two 15S subs in the far corner, and the s7201 in the corner closest to the MLP, about 12 feet away. Can add delay to the far corner as needed to optimize response. Only about a quarter of the space is dedicated for home theater.
Pradeep2 is offline
post #443 of 512 Old 09-04-2017, 10:38 AM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
Sheeesh! 100% of that space will be dedicated to BASS.
post #444 of 512 Old 09-04-2017, 01:37 PM
Liked: 1263
Will prob need more um18s to eventually go to stacks in each corner. They are backordered till end of October now.
What do you have your room size control set to? All the way to large?
Pradeep2 is offline
post #445 of 512 Old 09-04-2017, 03:52 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
Yes large. Speakers and sub crossed at 100 Hz.
post #446 of 512 Old 09-04-2017, 06:50 PM
ahblaza's Avatar
Quoted: 2510 Post(s)
Liked: 3690
Climber have you tried turning the RSC to about 11:00 before running REQ and then after back to large, should give you a nice rising house curve down low out to about 60-70 Hz.
ahblaza is offline
post #447 of 512 Old 09-04-2017, 07:08 PM
Hopinater's Avatar
Liked: 11684
Yeah but how much more can his house take? I think his insurance company has already flagged him for cancellation.
ahblaza likes this.
post #448 of 512 Old 09-04-2017, 08:20 PM
climber07's Avatar
Quoted: 807 Post(s)
Liked: 2597
I'll have to try that when I get the UMIK-1.
post #449 of 512 Old 09-05-2017, 07:07 PM
ahblaza's Avatar
Liked: 3690
Please do your wife will thank you.................I want to see graphs my friend, I don't know when my 72 will be here, I think I'm next to get one on the list, at least I think so.........so I want to live through your measurements, I can't believe you're the only one posting about their 72s........
ahblaza is offline
post #450 of 512 Old 09-05-2017, 07:37 PM
subacabra's Avatar
Quoted: 1805 Post(s)
Liked: 5155
I'm thinking of giving this a try on my four 15's. Currently all at large.
Wonder if it will make a difference.
ahblaza likes this.
subacabra is online now
Power Sound Audio , s7201
