JL Audio F112 V2 Sealed Subwoofer Hands-On - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #61 of 112 Old 03-09-2018, 04:58 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Originally Posted by imagic View Post
I believe the master is doing all the legwork and sending out a pre-EQ'd signal to the second sub. I'd think it would work, there might be a need to level match... anyhow that's a question for JL tech support but it seems like that should work.
I have sent two questions from their web page. Is there a phone number?
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #62 of 112 Old 03-10-2018, 03:16 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
From JL
“Yes, the microphone that we provide with the Fathoms are the same for v1 and v2.
Additionally, may I offer a few suggestions with your setup:
If using both units in the same system, place the v2 the more challenging position in the room to take advantage of the upgraded 18 band parametric EQ function of the DARO.
Unless the subs are side by side nearly touching each other make sure both are being used in the Master mode to so you will be able to tune each Fathom individually at each location. The advantage of slaving the v1 unit to gain the v2's DARO is offset by not being able to phase align it separately.
Since you indicate that you are using your subwoofers in a home theater system I also suggest these guidelines to achieve the best integration to the room and main speakers.
1. Plug the ports of the main speakers if they have them. The port is always out of phase with the speaker and the subwoofer and plays havoc with the phase alignment procedure below.
2. Make sure all speakers are set to small, even big main left and rights to take advantage of the high pass crossover which lowers distortion in your main speakers.
3. Set all crossovers to 80Hz in the surround processor including the subwoofer
4. In the speaker setup of your processor's distance settings take the distance setting of the left and right front speakers and go to the sub channel distance settings and add 12 feet to make the sub channel 12 further than the fronts in the settings.
5. Perform the phase alignment procedure provided in the link below
jmschnur is offline
post #63 of 112 Old 03-10-2018, 07:41 PM
muscles's Avatar
Quoted: 778 Post(s)
Liked: 1107
I tried number 4 and it sounded terrible. I don't think this applies to modern receivers. Audessey seems to do a very good job of getting the distance right. I switched it back and it sounded amazing again. This probably needs to be revisited by JL Audio, at least in my setup it is a no go.
Greg
Originally Posted by jmschnur View Post
From JL
Subwoofers: Dual Rythmik F18SEs - Dual JTR RS1's - SB13 Ultra
Speakers: 2xJTR Noesis 212RT 1 210RM - KEF LS50W
Audio:McIntosh C2600 Pre - Marantz SR-8012 -Dual McIntosh 601's - PS Audio M700 - McIntosh MT5 - GoldNotePH10 - Oppo UDP-205 - BlueSound Node 2
TV: Samsung 75" Q9FN - Sony 75" 940D
muscles is offline
post #64 of 112 Old 03-10-2018, 07:46 PM
jsc79's Avatar
Quoted: 457 Post(s)
Liked: 587
Greg
There is more to it than adding 12’. Did you just add 12’ and stop there?
jsc79 is offline
post #65 of 112 Old 03-10-2018, 07:51 PM
muscles's Avatar
Quoted: 778 Post(s)
Liked: 1107
I actually got the whole calibration PDF from JL Audio, after I did it it didn't sound right. I must have messed something up because it sounded out of phase. I did it the old fashioned way with an SPL meter and another person in the room to adjust. I really like the sound now so I don't really want to mess with it too much more. Part of me wonders if I am leaving anything on the table, but with 4 subs it is probably negligible.
Greg
muscles is offline
post #66 of 112 Old 03-21-2018, 05:30 AM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Randy at JB told me there is a 12 millisecond electronic delay in the unit. In myMarantz 8805 I can set that in the bass sync section without changing distances. That works.
jmschnur is offline
post #67 of 112 Old 03-22-2018, 05:12 PM
Zach_N85's Avatar
Quoted: 230 Post(s)
Liked: 61
I am contemplating between an E110, F110 or F112 V2.
My main reason for considering the F112 is due to the much better DARO system, and a better amp, however, I'm also using Audyssey XT32 in my X3400H and unsure of how much the sub calibration is needed?
I'm currently with an SVS PB-1000 and in need of an upgrade to higher quality, sealed and accurate bass.
What do you think I should get? As any of the 3 will be a great upgrade from the PB-1000.
My thread link:
https://www.avsforum.com/forum/113-su...-jl-audio.html
Thx
Home Theater
LG OLED 65" C8 | Denon AVR-X3400H | PS4 Pro
Paradigm Monitor 7 v7 | Canton GLE 456 | Morel SP-2 | SVS PB-1000
Zach_N85 is offline
post #68 of 112 Old 03-22-2018, 07:59 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
The 112 V2 does a great job . Equalise before you use Audyssey.
jmschnur is offline
post #69 of 112 Old 03-22-2018, 08:05 PM - Thread Starter
Mark Henninger
imagic's Avatar
Quoted: 9176 Post(s)
Liked: 16189
Yeah twin F112 V2 are my reference, ended many years of chasing my "ideal" for bass. I don't need crazy SPL, just quality at the levels I do listen to.
Dave-T, audiofan1 and Zach_N85 like this.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #70 of 112 Old 03-23-2018, 09:30 AM - Thread Starter
Mark Henninger
imagic's Avatar
Liked: 16189
Today I'm beginning a Dirac Live calibration of an NAD T77 AVR. The speakers are KEF R-series but the subs, as usual, are my two F112 V2s. I've already applied D.A.R.O. correction to great effect, but it will be interesting to see what the before and after graphs from Dirac look like. I'll be back.
Mark Henninger
Editor, AVS Forum
imagic is offline
post #71 of 112 Old 03-23-2018, 09:33 AM
iang153's Avatar
Quoted: 152 Post(s)
Liked: 48
My F112 V2 arrives Monday - can't wait to set it up!
xcjago, fullshred and imagic like this.
iang153 is offline
post #72 of 112 Old 03-27-2018, 09:10 PM
xcjago's Avatar
Quoted: 73 Post(s)
Liked: 69
My thread link:
Thx
One review I read, said the F112 was better than dual F110. So I say go for the F112!
Zach_N85 likes this.
xcjago is offline
post #73 of 112 Old 03-28-2018, 04:16 AM
Zach_N85's Avatar
Quoted: 230 Post(s)
Liked: 61
I think I read that one as well.
Need to start saving up for the F112 then.
xcjago likes this.
Home Theater
Zach_N85 is offline
post #74 of 112 Old 03-29-2018, 11:12 PM
Staged's Avatar
I own a F113 and a pair of E110 in my living room and the solo F113 wins every time although the E110 sound great.
xcjago likes this.
Staged is offline
post #75 of 112 Old 07-09-2018, 06:45 AM
Dave-T's Avatar
Quoted: 1175 Post(s)
Liked: 571
I find this interesting because I have a 8802a which like the 8805 has the same sub delay option, I have a 8805 on order and hopefully I will have it by the end of the month.. When I setup my F112v2 I added the 12'. I looked at the distance audyessy gave the front two main speakers and then added 12' to that for what the sub distance would become, it sounds great. Randy really does know what he is talking about. Did you compare adding the 12' verse adding the 12 mills seconds in the delay? I am wondering if I should do it that way instead. Thanks for the post. I am thinking about adding a second F112v2 to my setup but really do not know what the second would add.
Dave-t
Dave-T is offline
post #76 of 112 Old 07-09-2018, 10:44 AM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Dave-t
I did not compare. I just added the 12 milliseconds and then let audyessy do its ting.
The second sub really smooths out the base out the base in my awkward room.
joel
jmschnur is offline
post #77 of 112 Old 07-09-2018, 11:09 AM
Marc Alexander's Avatar
Quoted: 5659 Post(s)
Liked: 5230
Running Audyssey overrides any manual adjustments you have made.
Marc Alexander is offline
post #78 of 112 Old 07-09-2018, 01:48 PM
Dave-T's Avatar
Liked: 571
you make the changes after running Audyessy, at least I do.
Dave-T is offline
post #79 of 112 Old 07-09-2018, 02:18 PM
Liked: 5230
Yes. I was responding to this post:
With Audyssey, knowing the amplifier's added delay doesn't really help you. It is much better to follow the Sub Distance Tweak procedure and/or utilize REW to blend the subs with mains.
post #80 of 112 Old 07-09-2018, 02:29 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Are you saying that adding 12 feet or adding 12 milliseconds after Audyssey will not work?
If not , how do you set the delay working with Audyssey?
jmschnur is offline
post #81 of 112 Old 07-09-2018, 02:47 PM
Liked: 5230
BTW, I listened to dual F113s vs dual SB16Us last week (along with a pair of Rythmik G25s). While I did not evaluate the SVS and JL max outputs, the differences were quite audible.
The SVS is no slouch. However, the JL sounded cleaner and crisper than the SVS. I suspect most people would prefer the JL for music. For movies I have to give the SVS the edge. I suspect the SVS simply has more low frequency headroom than the JL. The buyer came and picked up the SVS before I could take any significant measurements. I did record some sweeps in REW to evaluate distortion. I will post once I am in front of my PC.
Subjectively, the Rythmik G25 outperformed both the JL and SVS across the board for me.
Pradeep2 likes this.
post #82 of 112 Old 07-09-2018, 03:07 PM
Liked: 5230
Right.
Audyssey can't actually measure distances, it is just measuring delays. You only need to know the sub's added delay when setting up completely manually or with systems like RoomPerfect [which requires distances be entered manually].
https://www.scribd.com/document/3357...surement-Tools
https://www.avsforum.com/forum/113-su...eferences.html
post #83 of 112 Old 07-09-2018, 03:51 PM
jmschnur's Avatar
Quoted: 127 Post(s)
Liked: 62
Thanks. The references were very useful.
jmschnur is offline
post #84 of 112 Old 08-19-2018, 11:34 AM
mypepper's Avatar
Quoted: 54 Post(s)
Liked: 68
I have my little JL Audio E-110 for our smaller front room and the sound quality for both music and movies is amazing for its foot print. JL produces some of finest subs on the market.
xcjago likes this.
mypepper is offline
post #85 of 112 Old 08-19-2018, 11:47 AM
Dave-T's Avatar
Liked: 571
I have quick question about running daro, I bought my second F112v2 last week and am expecting delivery in the next couple of week. When running Daro and I have the mic on my boom stand at the MLP what direction should the mic be facing and should the mic be facing forward against the front wall towards the ceiling. Each F112v2 is place in the front of the on opposite sides of my media cabinet. Thanks in advance for the help. Sorry for the wordy confusing question.
dave-t
Dave-T is offline
post #86 of 112 Old 08-19-2018, 12:41 PM
xcjago's Avatar
Quoted: 73 Post(s)
Liked: 69
dave-t
I have my two F112 v1 setup in a similar way. I think the manual says to point the mic at the subwoofer, but when I did the calibration I pointed the mic straight forward towards my TV. That way the angle to each subwoofer was the same. I don't think it would make much difference doing it like this or pointing it straight at the subwoofer, mainly because the the bass frequencies that we're dealing with are not really affected by such a small angle change.
xcjago is offline
post #87 of 112 Old 08-19-2018, 04:00 PM
Dave-T's Avatar
Liked: 571
I have my two F112 v1 setup in a similar way. I think the manual says to point the mic at the subwoofer, but when I did the calibration I pointed the mic straight forward towards my TV. That way the angle to each subwoofer was the same. I don't think it would make much difference doing it like this or pointing it straight at the subwoofer, mainly because the the bass frequencies that we're dealing with are not really affected by such a small angel change.
thanks appreciate it
Dave-T is offline
post #88 of 112 Old 12-02-2018, 10:16 PM
Quoted: 100 Post(s)
Hi JL Audio Fans,
I am planning to buy this week JL audio fathom F112 V2, I don't have choice to pass signal to sub via wired connection, my dealer suggested I can connect using JLINK TRX transmitter, Do you guys think any difference between wired connection vs J link transmitter? Thanks in advance
gakbw is offline
post #89 of 112 Old 12-03-2018, 06:33 AM
Dave-T's Avatar
Liked: 571
Originally Posted by gakbw View Post
Hi JL Audio Fans,
I never knew JL had a wireless kit, the only one I was familiar with was the one made by Outlaw. if you get it let its know how it works and if it has a delay because it is is wireless. I would possibly be interested in it to move one of my F112v2 to the opposite corner of the room, I run duel F112v2.
Dave-T is offline
post #90 of 112 Old 12-03-2018, 09:18 PM
Quoted: 100 Post(s)
Yes Dave! You can check it for J-Link in JL audio website.
gakbw is offline
f112v2 , Jl Audio , subwoofer
