JL Audio F112 V2 Sealed Subwoofer Hands-On - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
post #91 of 113 Old 12-17-2018, 08:19 PM
519audiofan's Avatar
Quoted: 40 Post(s)
Liked: 71
Christmas came a bit early this year.....
Sent from my LG-H873 using Tapatalk
Spizz, xcjago, fullshred and 4 others like this.
519audiofan is offline
post #92 of 113 Old 12-19-2018, 07:08 PM
Quoted: 110 Post(s)
Same for me too 🙂
gakbw is offline
post #93 of 113 Old 12-24-2018, 01:25 AM
fullshred's Avatar
Quoted: 42 Post(s)
Liked: 45
Heh, I love how the box has feet. Congrats on the purchase, you won't be disappointed!
xcjago likes this.
Main Room: Dynaudio Confidence C1 Platinum + Stand6; Confidence Centre Platinum + Centre Base 2; Contour S1.4 + Stand4; Dynaudio S4-C80 x 4 (ceiling); 10 gauge speaker cable; JL Audio Fathom F112; Pioneer LX-88 AVR; Epson Home Cinema 8350.
Second Room: Dynaudio Xeo 2 + Xeo desk stands
Civic Type R: Dynaudio MD102; Dynaudio MW152
fullshred is offline
post #94 of 113 Old 01-18-2019, 09:33 PM
Quoted: 110 Post(s)
I hate to say my brand new JL Audio Fathom V112 v2 died suddenly! I don’t know what’s the issue, We had power loss for 10 mins, After that everything is worked! Except JL sub, I do have wattbox power surge! And on the same outlet other devices connected everything is working! With in 30 days it’s dead 😞, I reached out to my dealer he said fuse might gone, but fuse looks good and also my dealer sent new fuses nothing works no power at all! Dealer said he sent email to JL let’s see what JL says and etc! I am afraid about it’s high expensive product, Do they really send replacement brand new one? (or) jut an refurbished ones! My dealer says this is first time which he is seeing JL sub has issue like this! So he don’t know the reason, Other brands send just an replacement amplifier, where dealer can replace for their customers! Anybody encountered same type of issues? I should have bought SVS SB 16 ultra! But my dealer says JL audio is better than SVS! I just went by his recommendation. I am disappointed about JL quality check.[IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
gakbw is offline
post #95 of 113 Old 01-19-2019, 01:48 PM
xcjago's Avatar
Quoted: 73 Post(s)
Liked: 69
Sorry to hear about your trouble! I have not had any trouble like that with my JL subs. Are any of the lights on your sub on? Usually there's a green light under "master" below Input Mode to the left of the volume knob.
xcjago is offline
post #96 of 113 Old 01-19-2019, 03:24 PM
jmschnur's Avatar
Quoted: 128 Post(s)
Liked: 62
I keep a 20 amp surge suppressor on mine. Sounds like a surge on power up fried a board.
How old is it?
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #97 of 113 Old 01-19-2019, 09:49 PM
Quoted: 110 Post(s)
Thank you! No green light turning on! And Which is the best single outlet surge protector helps? I do have Furman elite 20 PFI, But from my sub power conditioner almost 15 feet away, So I used wattbox single outlet surge protector connected to outlet, I have 2 JL fathom112v2’s both are connected with wattbox single outlet surge protector and one sub perfectly fine, BUT second one is died!
gakbw is offline
post #98 of 113 Old 01-19-2019, 09:56 PM
drewTT's Avatar
Quoted: 2265 Post(s)
Liked: 2454
Any word when these might get completely revamped? Just look so dated these days IMO.
LG OLED65E8 | Plinius Hiato | Dynaudio Contour 20 | Dynaudio Stand 6 | REL S/510 | PS Audio DirectStream | Furman IT-Reference 15i | roon
Panasonic DP-UB9000 | Synology DS916+ | Apple TV 4K | BDI Mirage | NEEO | Focal Shape 40 | iFi Pro iDSD | iFi Pro iRack | iFi AC iPurifier
drewTT is offline
post #99 of 113 Old 01-20-2019, 08:52 AM
Quoted: 40 Post(s)
Liked: 71
Sorry to hear. Hopefully you get it addressed quickly.
post #100 of 113 Old 01-20-2019, 10:10 AM
jmschnur's Avatar
Quoted: 128 Post(s)
Liked: 62
Try the Panamax 20 amp protector if you have a dedicated 20 amp line .
You,at need a plug conveyor from. Mono price if the 20 amp circuit has a normal outlet. Code for 20 amps requires a different one and the Panamax 20 amp conforms to code. There is also a 15 amp version.
jmschnur is offline
post #101 of 113 Old 01-20-2019, 10:20 AM
Quoted: 110 Post(s)
Thank you! Mine is 15 amp lined, So 15am line will ok for V112 sub? If yes I can buy panamax15amp surge protector?
gakbw is offline
post #102 of 113 Old 01-20-2019, 01:12 PM
jmschnur's Avatar
Quoted: 128 Post(s)
Liked: 62
I would think so.
jmschnur is offline
post #103 of 113 Old 01-20-2019, 02:36 PM
Quoted: 110 Post(s)
Thank you 🙂
gakbw is offline
post #104 of 113 Old 01-21-2019, 12:47 PM
Quoted: 110 Post(s)
JL back to us this morning with this “The Fathom subs have a software feature that if the unit loses power (either a power outage or unplugging the unit) and the power switch is set to On or Auto, it goes into protect mode. To get it out of protect mode, we need to move the power switch to off and then back to the On/Auto position.” I tried this! But no luck no power on.
gakbw is offline
post #105 of 113 Old 02-08-2019, 10:12 PM
Quoted: 110 Post(s)
Hello Guys,
JL replaced sub amplifier, reason unknown internal surge damaged! Advised to have surge protector! They knew sub amplifier damaged due to surge even though they honored to replace amplifier under warrent!👍
xcjago likes this.
gakbw is offline
post #106 of 113 Old 02-28-2019, 11:28 PM
Thebarnman's Avatar
Quoted: 176 Post(s)
Liked: 75
Does anyone here have one or two JL fathom113v2? There seems to be no thread for the JL fathom113v2, however this is the closest I could find to one. At 13", which reaches down to 19Hz, though not subsonic; would seem like it would have a decent performance quality for movies. As for music, the 13" driver; though may not be as light as a 12" driver, is possibly lighter than a 15" driver.
Would this thread be ok to talk about the JL fathom113v2, or should someone create a JL fathom113v2 thread?
Movies must be OAR, sports and movies must also have 5.1 audio, No EE or NO SALE!
Thebarnman is offline
post #107 of 113 Old 03-01-2019, 10:11 PM
xcjago's Avatar
Quoted: 73 Post(s)
Liked: 69
Here's the thread for the F113
https://www.avsforum.com/forum/113-s...3-sub-239.html
Some people have been told by JL that the F112 is a bit better for music.
xcjago is offline
post #108 of 113 Old 03-02-2019, 12:04 AM
Thebarnman's Avatar
Quoted: 176 Post(s)
Liked: 75
It probably is since the driver is a little bit bigger. At the same time I think it's a excellent compromise for both music and movies.
By the way, thanks for the info about the F113 thread!
post #109 of 113 Old 07-29-2019, 05:28 AM
Dave-T's Avatar
Quoted: 1188 Post(s)
Liked: 584
Looks like JL Had another price increase. The F112v2 went up another $300 from $3700 to $4000 now. of course we kn ow nobody pays list price but regardless the discount price is goining to be more now. I have a friend who is I the process of purchasing 2 sets of the 8' in-wall subs and he is probably going to have a canary since it is the second increase so far this year. I personally love my dual F112v2 which I purchased before either of the two price increases, I was considering a third but I may buy a new TV instead.
anjunadeep likes this.
Dave-T is offline
post #110 of 113 Old 07-29-2019, 08:07 AM
Quoted: 301 Post(s)
Liked: 207
Originally Posted by Dave-T View Post
Looks like JL Had another price increase. The F112v2 went up another $300 from $3700 to $4000 now. of course we kn ow nobody pays list price but regardless the discount price is goining to be more now. I have a friend who is I the process of purchasing 2 sets of the 8' in-wall subs and he is probably going to have a canary since it is the second increase so far this year. I personally love my dual F112v2 which Inpurched before either of the two price increases, I was considering a third but I may buy a new TV instead.
I imagine if you asked, they would point to the tariffs. On top of that, they sell through dealers. They are a real company, employees with health insurance and buildings with overhead, customer service, then they have to make some money on it, then their dealers have to make money on it. I think it's getting really hard to be competitive in anything but a luxury market for a US based builder that isn't a mom-and-pop shop. The volumes are so low on this stuff too.
That said, they fairly recently brought on a guy from B&W to run their home audio division (https://www.cepro.com/article/doug_henderson_jl_audio), so maybe we'll see some more developments in that area?
anjunadeep is offline
post #111 of 113 Old 12-01-2019, 09:13 AM
Quoted: 110 Post(s)
JL Audio Sub failure
My second sub almost 1 year old JL Audio Fathom V112 v2 not working! not powered on, I mean no green lights on, I don’t know what’s the issue, sub connected to surge X protector and it has dedicated 20 amps power line, all other devices is in working condition except JL sub, I reached out to my dealer he said fuse might gone, but fuse looks good, Dealer said he sent email to JL and JL says they will send advance replacement amplifier, which is dealer has to replace amp, I am afraid about it’s high expensive product, do they really send advance replacement brand new one? (or) just old refurbished ones? my dealer says once they receive replacement amplifier they will replace it, I am not sure is that easy and simple to replace amplifier, normal technician vs factory trained technician? dealer says all other brands also sends replacement amplifiers, if they encounter any issues, In the same way where dealer will replace amplifier for their customers! Anybody encountered same type of issues? my friends bought SVS SB 16 ultra!they are happy with svs for less cost when compare to jil fathom 112v2, and also no differences on performance! and they never had any issue so far! but my dealer says JL audio is better than SVS! I just went by his recommendation. I am disappointed about JL sub quality. I don't know how much turn around time to fix this!
gakbw is offline
post #112 of 113 Old 12-01-2019, 05:34 PM
jmschnur's Avatar
Quoted: 128 Post(s)
Liked: 62
? Let us know how this works out
jmschnur is offline
post #113 of 113 Old 12-15-2019, 12:56 PM
Quoted: 110 Post(s)
My second sub almost 1 year old JL Audio Fathom V112 v2 not working! not powered on, I mean no green lights on, I don’️t know what’️s the issue, sub connected to surge X protector and it has dedicated 20 amps power line, all other devices is in working condition except JL sub, I reached out to my dealer he said fuse might gone, but fuse looks good, Dealer said he sent email to JL and JL says they will send advance replacement amplifier, which is dealer has to replace amp, I am afraid about it’️s high expensive product, do they really send advance replacement brand new one? (or) just old refurbished ones? my dealer says once they receive replacement amplifier they will replace it, I am not sure is that easy and simple to replace amplifier, normal technician vs factory trained technician? dealer says all other brands also sends replacement amplifiers, if they encounter any issues, In the same way where dealer will replace amplifier for their customers! Anybody encountered same type of issues? my friends bought SVS SB 16 ultra!they are happy with svs for less cost when compare to jil fathom 112v2, and also no differences on performance! and they never had any issue so far! but my dealer says JL audio is better than SVS! I just went by his recommendation. I am disappointed about JL sub quality. I don't know how much turn around time to fix this! [IMG class=inlineimg]/forum/images/smilies/frown.gif[/IMG]
Yesterday, my dealer replaced amplifier and now sub powered on! All looks good. But no clue why amplifier gone!
gakbw is offline
f112v2 , Jl Audio , subwoofer
