Official Seaton Sound Subwoofer Thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1001Likes
post #31 of 567 Old 08-22-2017, 06:06 AM
Quoted: 1012 Post(s)
Liked: 1261
Originally Posted by BrolicBeast View Post
Oh? Mine is a standard IEC power cord, I believe.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Are you running yours on 120V?
Pradeep2 is offline
post #32 of 567 Old 08-22-2017, 06:33 AM
BrolicBeast's Avatar
Quoted: 1886 Post(s)
Liked: 2272
Yup, dedicated 20A 120v line w/ nothing else connected.
BrolicBeast is offline
post #33 of 567 Old 08-22-2017, 06:45 AM
Liked: 1261
Have you considered switching that circuit over to 240V? My understanding is that the Sp2-12000 can only deliver about half its maximum potential when used with 120V.
Pradeep2 is offline
post #34 of 567 Old 08-22-2017, 07:19 AM
Mark Seaton's Avatar
Quoted: 919 Post(s)
Liked: 2571
His amplifier is my custom DSP version of the SP2-8000HT. For those in North America, I generally recommend sticking to the 120V line and simply run a dedicated circuit. Depending on what else is in the system, mixing the 240V with 120V can create some headaches with hum or buzz, and it only takes 1 component to cause a big headache. The 2x4000W amp is designed and optimized for 120V operation. The 2x6,000W version is less sensitive to power line sag due to the more complex power supply, but it adds cost unnecessarily. I only have a few customers in the US with the 6,000W amplifiers for unique situations or desires, and I generally only recommend them for our international customers who need them where the power systems are 230-240V AC.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #35 of 567 Old 08-22-2017, 01:01 PM
Quoted: 40 Post(s)
Liked: 5
Mark,
I emailed you about 11 days ago and again today. Please check for mail regarding Submersive F2 amp replacement. Thanks!
pdxaudio is offline
post #36 of 567 Old 08-22-2017, 03:38 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
Mark could you comment on the XLR pinout you use on your amps. There is a discussion in the Inuke thread about XLR pinout and two standards the old US and the current one most use of the 2 pin hot. Shreds mentioned Brian of Speakerpower amps "Brian O. was testing the inuke12k, he mentioned the same thing with the polarity being reversed." https://www.avsforum.com/forum/155-di...l#post54635152
Do you wire the 2 pin hot? Because I compared the 1000watt Submersive I have using the XLR and it is reversed to the other amps I have(Sunfire, Inuke 3000, Inuke 6000) using the 2 pin hot. So just wondering if you wire them 2 pin hot and mine had a mix-up or do you wire them all 3 pin hot?
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #37 of 567 Old 08-22-2017, 03:50 PM
torii's Avatar
Quoted: 3589 Post(s)
Liked: 2023
my velodyne sealed subs loved having the driver face the wall. made a noticeable difference and well worth a try with a sealed sub. mine liked 6-8inches.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #38 of 567 Old 08-22-2017, 03:51 PM
torii's Avatar
Liked: 2023
what does it usually cost to pay for a 240v line? is it hard to do? need a new box?
torii is offline
post #39 of 567 Old 08-22-2017, 04:46 PM
Quoted: 919 Post(s)
Liked: 2571
While there used to be some companies using the "old US convention" of pin 3 hot, most all current products I know of are pin 2 hot. That is also the AES standard. More likely with the iNuke is an inverting amplifier design or some gain stage in the mix.
Your SubMersive wasn't wired out of polarity and the amplifier has the pin 2 hot. The DSP response shaping I use in the amplifiers has a similar effect as a Linkwitz Transform to maintain a more ideal sealed subwoofer response, especially through the roll off of the speaker. This is required to achieve the very deep in-room response our customers often observe. This response shaping creates an expected phase shift which causes what you observed. Nothing is physically wired backwards.
bscool and FattyMcButterPants like this.
Mark Seaton
Seaton Sound, Inc.
post #40 of 567 Old 08-22-2017, 05:35 PM
bscool's Avatar
Quoted: 889 Post(s)
Liked: 713
Interesting thank you. So much to learn. I was verifying the phase or polarity? using the Impulse response in REW to check if all my subs are in phase. So the LT will skew that, or is Impulse response not an accurate way to verify polarity or am I confusing polarity and phase?
Here is the REW impulse graph and you can see they are out of phase.
I hope you didn't take it as I was insulting you or the Submersive, I should have worded it differently as what I think I am observing is the polarities seem opposite. I am probably not understanding something. I am just trying to learn.
File Type: jpg Submersive and XS30 Impulse response.jpg (171.7 KB, 59 views)
bscool is offline
post #41 of 567 Old 08-22-2017, 05:59 PM
Liked: 1261
Thanks for the info Mark.
Pradeep2 is offline
post #42 of 567 Old 08-22-2017, 06:10 PM
Liked: 1261
In the USA it can be easily performed by switching an existing 120V receptacle and using two hot wires on a new 240V (2-pole) breaker. But only if this is a dedicated branch circuit (i.e. there are no other receptacles on this circuit, just your panel box and then wire and then the receptacle, as all receptacles on the circuit will be delivering 240V and destroy anything you plug in thats expecting standard 120V. Make sure you label both wires as hot, on both ends.
I would engage the services of an electrician if you have any doubts on what you are doing. If you are comfortable doing it yourself the cost would just be a new breaker and a new receptacle, assuming you have 2 adjacent breaker positions available in your main panel.
torii likes this.
Pradeep2 is offline
post #43 of 567 Old 08-22-2017, 07:48 PM
jjackkrash's Avatar
Quoted: 2223 Post(s)
Liked: 2331
It posts like these that remind me why I don't feel there is any real value associated with saving a few bucks on subs by going DIY.
jjackkrash is offline
post #44 of 567 Old 08-22-2017, 08:14 PM
torii's Avatar
Liked: 2023
think I would have better luck running my sub to my dryer outlet in laundry room think thats only 240v outlet I know of...i watched my kill o watt meter and Im not killin my electrical system that bad under 120db...this sub has crazy headroom efficiency or Im just not doing it right lol
torii is offline
post #45 of 567 Old 08-22-2017, 08:24 PM
Liked: 1261
Yeah dont plug your sub into 240V unless you are certain it is designed for it. Not many are in the USA.
Pradeep2 is offline
post #46 of 567 Old 08-23-2017, 08:48 AM
calentz's Avatar
Quoted: 198 Post(s)
Liked: 127
Running my two SubMs & three Cats off a controlled 240v 40Amp circuit has worked well for me.
When I turn on my system (processor's remote) the processor's 12v trigger controls a solidstate relay which controls a 120v contactor which in turn controls a 240v contactor. (My system is now ready)
--Carl
calentz is online now
post #47 of 567 Old 08-23-2017, 05:44 PM
Marc Alexander's Avatar
Quoted: 5472 Post(s)
Liked: 4972
No issues with noise from the 120V gear. What do you have on 120V vs 240V?
Marc Alexander is online now
post #48 of 567 Old 08-23-2017, 05:53 PM
torii's Avatar
Liked: 2023
mirage had some sweet sounding gear back in 90's....they still in business? omnipolar right? I compared mirage with martin logan back in day and it was close.
torii is offline
post #49 of 567 Old 08-23-2017, 05:58 PM
calentz's Avatar
Quoted: 198 Post(s)
Liked: 127
No issues. The surround sound amps & bios lighting.
--Carl
post #50 of 567 Old 08-23-2017, 06:56 PM
Ediddy's Avatar
Quoted: 160 Post(s)
Liked: 150
Glad to see this official thread!
BrolicBeast likes this.
(2) GoldenEar References, GoldenEar SuperCenter XXL, (4) GoldenEar HTR 7000 (atmos), (2) GoldenEar SuperSat 50’s, (2) GoldenEar Triton 7 (rears), Dual Seaton Sumbersive HP (Master / Slave), JVC NX5, Dalite 119 inch UTC, Panasonic BP - UB 820, Marantz 8805, Emotiva XPR 2, Emotiva XPA 9 (gen 3) Panamax 5102, Harmony Elite, 4K Apple TV
Ediddy is offline
post #51 of 567 Old 08-23-2017, 07:33 PM
Liked: 4972
API [Audio Product International] manufactured Mirage, Energy, and Athena brands out of Canada. Klipsch bought API and killed Athena off while moving Mirage and Energy production to China. I believe Klipsch was acquired and the distribution of Energy and Mirage was eventually halted. Klipsch liquidated Mirage stock via Amazon's woot.com. Klipsch actually ran some extra production batches based on fan demand on woot.com.
I don't believe the OMD-28s are worth their $7500 retail price but they are worth much more than I paid! I like them because they are a unique design (Omnipolar) with high WAF. The imaging doesn't collapse when you move your head or even switch seats. Not a bad seat in the house.
post #52 of 567 Old 08-23-2017, 07:46 PM
torii's Avatar
Liked: 2023
I agree marc...the omnipolar design i listened to back then was very appealling and sounded downright great...think it was janet jackson back then i auditioned lol...
torii is offline
post #53 of 567 Old 09-07-2017, 09:08 PM - Thread Starter
bulls's Avatar
Quoted: 270 Post(s)
Liked: 167
is the umik in REW display the correct SPL ?
i adjusted my AVR levels in one of the settings but it doesnt feel this hot
display - vizio p65
AVR x4300h +lepai 2ch amp = 7.2.4
L/C/R - Chane 2.4, SURROUND - dayton 3in cubes *temporary
BASS - 2x Seaton F18 + JTR 1400 "the wind machine" (not port noise)
2100 ft^3
bulls is offline
post #54 of 567 Old 09-08-2017, 05:35 AM
Liked: 2272
Do you have the Umik-1 calibration file?
Sent from my iPad using Tapatalk Pro
post #55 of 567 Old 09-09-2017, 02:43 PM - Thread Starter
bulls's Avatar
Quoted: 270 Post(s)
Liked: 167
yep
did some testing today. seems theres a possible null or black hole around 25hz depending on sub position on the MLP wall side
for now the back(mlp) and left walls are covered completely with shelves... which might mess something up
anyway, im not complaining, it sounds good to me, im just trying to see if i hear any difference compared to the measurements
the Chane 2.4 seem to be measuring to ~ 22000 hz then drops off. my hearing seems limited to around 17000
display - vizio p65
2100 ft^3
bulls is offline
post #56 of 567 Old 09-09-2017, 03:57 PM
chucky7's Avatar
Quoted: 3569 Post(s)
Liked: 4592
yep
bulls,
Can you post a FR with the Limits changed to: Left: 5.0, Right: 200.0, Top: 125.0, and Bottom: 65.0?
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #57 of 567 Old 09-09-2017, 05:08 PM - Thread Starter
bulls's Avatar
Quoted: 270 Post(s)
Liked: 167
Originally Posted by chucky7 View Post
bulls,
display - vizio p65
2100 ft^3
bulls is offline
post #58 of 567 Old 09-09-2017, 07:33 PM - Thread Starter
bulls's Avatar
Quoted: 270 Post(s)
Liked: 167
ok yep. F18s moved to front pointing at MLP just like the LCR ... kinda sounds better too ... its not WAFable tho (covers the windows)
had to turn down the vol wifes home
display - vizio p65
2100 ft^3
bulls is offline
post #59 of 567 Old 09-09-2017, 11:33 PM
chucky7's Avatar
Liked: 4592
The good news is that you have decent extension down to 9 Hz. At what dB did you take the green and purple graphs?
If we ignore the 2 nulls, the front locations ( green ) provides pretty flat FR. However, the purple graph is easily correctable with a minidsp 2X4 HD.
bulls likes this.
post #60 of 567 Old 09-09-2017, 11:43 PM
torii's Avatar
Liked: 2023
i wouldnt care about extension...i would move or aim subs around...at least thats what i did when i got new gear. my 25hp sub at 200+ pounds got tested in 5 spots before I settled
just a turn up the master volume and see if its ok graph....still more work to do but its ok....
torii is offline
