JBL L8400P popping - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-19-2017, 12:53 PM - Thread Starter
Scurly's Avatar
Quoted: 44 Post(s)
JBL L8400P popping
I'll admit my knowledge of subs are limited, so need some assistance. This sub is starting a loud popping at certain frequencies. Also, starting to crackle upon startup.
Should I just trash it or worth trying to fix? This a second sub for a dedicated media room and cannot handle this sound anymore.
Sub is about 5-7 yrs old.
Scurly is offline
post #2 of 3 Old 08-19-2017, 08:15 PM
Tom Vodhanel's Avatar
Quoted: 3034 Post(s)
Liked: 10320
Almost certainly amplifier related and likely caps. If you are comfortable with a soldering iron replacing caps is usually easy enough(and cheap). Or, you can try to find a used amp. A quick google shows "rebuilt" amps for $165.
Tom V.
Power Sound Audio
The woods are lovely, dark and deep, But I have promises to keep,
Tom Vodhanel is offline
post #3 of 3 Old 08-19-2017, 10:55 PM - Thread Starter
Scurly's Avatar
Quoted: 44 Post(s)
Tom V.
Power Sound Audio
Thx Tom. Not sure it's worth the time and effort for me. I would just end up screwing it up then out the money for the amp. I'll probably just a new one.....not JBL. Match the B&W sub is a better bet.
Scurly is offline
