Official Monoprice THX Subwoofers - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 580Likes
post #391 of 1513 Old 08-08-2018, 11:55 PM
Liked: 3
Originally Posted by mpk1970 View Post
Based on this chart the HSU VTF-15H MK2 is the best value by far for $2095 I could save $700 over the SVS PB13 I just bought
THe Monoliths seem good but probably too dam big for my room
I own 2 HSU VTF-15H MK2, I ordered the Monolith 15" a month ago and it's in a different league than the VTF-15H MK2. The Bass is so much tighter and definitely moves alot more air and pressurizes the room significantly more than the HSU. I was ecstatic with just 1 Monolith 15" and would choose that over the 2 HSU VTF-15H MK2... The 15% off ebay coupon made me order a second Monolith 15" today..... These Monolith 15" subs are special. The HSU VTF-15H MK2 's are being kicked out of the theater and split up to the computer room and master bedroom.
chucky7, corey99699 and Mavinwow like this.
Neo33 is offline
post #392 of 1513 Old 08-09-2018, 12:38 AM
drh3b's Avatar
Quoted: 2224 Post(s)
Liked: 4680
These Monolith definitely seem the real deal. I think only one person hasn't like theirs, and I don't recall anyone complaining about defects or amps dying. Fortunately, the brand I went with has been just as good, at least for me.
My World Beating System!
Spoiler!
drh3b is offline
post #393 of 1513 Old 08-12-2018, 10:32 PM
PoorSignal's Avatar
Quoted: 344 Post(s)
Liked: 85
I would like to know if I order from eBay is the liftgate already included ? From what I heard the liftgate was extra $150 on the monoprice site ?
PoorSignal is offline
post #394 of 1513 Old 08-13-2018, 07:34 PM
Quoted: 43 Post(s)
Liked: 31
It will probably be delivered FedEx
Sent from my SM-N950U using Tapatalk
threshold350 is offline
post #395 of 1513 Old 08-23-2018, 02:23 PM
Quoted: 232 Post(s)
Liked: 108
I Got my monolith 15" the other day, and it rocks. However, i have noticed a very small issue. Sometimes, when it kicks on with the auto-on function, it will make a higher pitched pop noise before playing content. It doesn't always do this. Has anyone else run into this issue?
Colozeus is offline
post #396 of 1513 Old 08-23-2018, 03:00 PM
ack_bk's Avatar
Quoted: 1345 Post(s)
Liked: 1507
That doesn't sound right. I would double check all your connections and make sure everything is tight.
ack_bk is online now
post #397 of 1513 Old 08-23-2018, 03:37 PM
sorka's Avatar
Quoted: 68 Post(s)
I have not noticed that at all on my 15". Might be an actual issue.
This thing is a MONSTER.
My wife said it was so big that she was going to use it as a vase table!!!!!!
Bizarro_Stormy likes this.
sorka is offline
post #398 of 1513 Old 08-23-2018, 08:46 PM
Gyroscopics's Avatar
Quoted: 218 Post(s)
Liked: 285
... it was so big that she was going to use it as a ...
That's what she said.
SuperFist and johnny hotsauce like this.
Gyroscopics is offline
post #399 of 1513 Old 08-24-2018, 09:09 AM
Quoted: 232 Post(s)
Liked: 108
Yeah. It's odd. My old JBL sub never did this and i'm using the same cables. The sub sounds just fine, despite this weird pop noise when it turns on. Perhaps it's dirty power? I have it plugged into the wall with a wall surge protector.
Colozeus is offline
post #400 of 1513 Old 08-24-2018, 09:17 AM
Norris Kasey's Avatar
Quoted: 161 Post(s)
Liked: 75
Try it without the surge protector. I have a subwoofer that was less than a year old and the plate amp died. I didn't have any issues until I used a surge protector. Replaced the amp got rid of the surge protector and had been fine since
Sent from my Pixel XL using Tapatalk
Norris Kasey is online now
post #401 of 1513 Old 08-24-2018, 12:08 PM
Quoted: 232 Post(s)
Liked: 108
You mean a monolith sub where the amp died? Or just a part of the amp died? And were you having the same symptoms as me?
Colozeus is offline
post #402 of 1513 Old 08-24-2018, 01:44 PM
MIX_MASTER_ICE's Avatar
Quoted: 2676 Post(s)
Liked: 2486
It might be your receiver. I had a sub that would make a pop noise when it woke up from standby. It was running through a Pioneer receiver. When I switched it to an Onkyo receiver it stopped.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #403 of 1513 Old 08-24-2018, 03:05 PM
DCMlover's Avatar
Quoted: 146 Post(s)
Liked: 50
I like my dual 12's. Love the opening of Defenders on Nexflix. The bass is so deep and clean.
DCMlover is offline
post #404 of 1513 Old 08-24-2018, 03:15 PM
Quoted: 161 Post(s)
Liked: 75
It was a different subwoofer. Yes same symptoms
post #405 of 1513 Old 08-24-2018, 04:02 PM
corey99699's Avatar
Quoted: 73 Post(s)
Liked: 66
Mine do this as well, I assumed it was normal since both of them do it. They sound fine once they switch on so I never thought it was anything to be worried about. Neither of mine are plugged into surge protection.
Sent from my SM-G960U using Tapatalk
corey99699 is offline
post #406 of 1513 Old 08-24-2018, 04:04 PM
corey99699's Avatar
Quoted: 73 Post(s)
Liked: 66
By the way mine do it every time, not just sometimes
post #407 of 1513 Old 08-24-2018, 08:09 PM
DCMlover's Avatar
Quoted: 146 Post(s)
Liked: 50
Mine never do. Hooked up to a Yamaha A-3060
DCMlover is offline
post #408 of 1513 Old 08-24-2018, 09:59 PM
corey99699's Avatar
Quoted: 73 Post(s)
Liked: 66
I have a Denon, I'm not worried about it as long as they work when I need them to.
post #409 of 1513 Old 08-25-2018, 02:37 PM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 291
both of mine running form a yamaha 3060. never noticed any pop when turning on, they just come alive when the movie starts. If they do I never noticed it- will try to listen more carefully next time I boot them up. I used to hear a mild thump from my old mirage sub- but nothing alarming
thetman is offline
post #410 of 1513 Old 08-28-2018, 08:49 AM
Quoted: 232 Post(s)
Liked: 108
Ok, it sounds like it's probably my receiver. It's not a very loud pop and the sub works phenomenally well.
corey99699 and Bizarro_Stormy like this.
Colozeus is offline
post #411 of 1513 Old 09-19-2018, 05:01 PM
Quoted: 161 Post(s)
Liked: 75
Subwoofers back in stock at monoprice. Just ordered mine
YoYo likes this.
post #412 of 1513 Old 09-19-2018, 05:10 PM
darthray's Avatar
Quoted: 2460 Post(s)
Liked: 3839
Mine never do either, when using my AVP, a Marantz AV7702mkII.
The only time, they would make loud pop sound, is I turn Off the power, on the sub,and turn it back On.
Never on Auto.
Ray
darthray is offline
post #413 of 1513 Old 09-19-2018, 05:23 PM
YoYo's Avatar
Back in stock! I have waited so long lol. Glad I held out. Ordered the 12. I bought all new speakers like 4 months ago and it has been hell waiting for a sub. I almost ordered every other sub on the first page here 20 times.
glad to be back on here. Been years
Norris Kasey likes this.
YoYo is offline
post #414 of 1513 Old 09-20-2018, 01:32 PM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 291
congrats on the sub. you'll love it. I've got dual 12's and couldn't be happier. glad they are back in stock. this thread has been kind of quiet lately.
thetman is offline
post #415 of 1513 Old 09-20-2018, 02:21 PM
sorka's Avatar
Quoted: 68 Post(s)
Mine has JUST started making the pop about 75% of the time when it's coming on (set to auto) since last week. It was fine for the first few months.
sorka is offline
post #416 of 1513 Old 09-20-2018, 04:15 PM
boothman's Avatar
Quoted: 99 Post(s)
Liked: 43
So why set it to AUTO in the first place?
boothman is offline
post #417 of 1513 Old 09-20-2018, 04:22 PM
sorka's Avatar
Quoted: 68 Post(s)
Because it's been good enough and the sub is in a corner not near the receiver. I'd have to run the 12v signal wire up the wall, into the attic, and down the other wall. The auto on has been good enough that it's hasn't been an issue.
sorka is offline
post #418 of 1513 Old 09-20-2018, 05:23 PM
Quoted: 259 Post(s)
Liked: 130
Does the SVS isolation feet screws into the monoliths feet? Contemplating about returning my pb-1000 for this.
Paopawdecarabao is offline
post #419 of 1513 Old 09-20-2018, 05:29 PM
Liked: 2486
The bolt diameter is slightly different, so you'll probably have to buy 4 new screws/bolts for the Monolith.
post #420 of 1513 Old 09-21-2018, 11:39 AM
thetman's Avatar
Quoted: 533 Post(s)
Liked: 291
AUTO seems to work good for me. I certainly don't want to go behind the sub and turn on manually every time.
thetman is offline
bestsubs , muchbetterthanpsa , overrated , overrated wannabe sub , psasucks
