Official Monoprice THX Subwoofers - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 488Likes
post #61 of 1286 Old 02-01-2018, 09:22 PM
MIX_MASTER_ICE's Avatar
Quoted: 2666 Post(s)
Liked: 2471
I'm not aware of any 20% codes working on the Monolith subs. I think the $50 off code last week was the first discount of any kind on those 3 subs.
EDIT: The current 20% off code VS20 doesn't apply to the Monolith subs. I just checked it out.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c, Arena 130/125c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2, MDR-V6, XB900n, XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. Philips SHP9500. SIVGA SV004. HyperX Cloud PS4. TB Stealth300. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is offline
post #62 of 1286 Old 02-27-2018, 07:28 AM
jeff43's Avatar
Quoted: 274 Post(s)
Liked: 169
I just bought a pair of the 10" THX's for a 23x11 room (they're $450 each if you purchase 2 or more). You can get to the point of overanalyzing these things to death but if your goal is to simply have a full sound with decent low's it all depends on what speakers you currently have.
If you're speakers are modest in a small to mid-sized room, there are decent subwoofers out there for under $200 each. Assuming you have a good receiver and some sort of surround system, you'll more than likely be able to set your speaker size and use the sub's for just the lowest frequencies and the THX's may be overkill. Don't forget how important placement is. If your goal is to simply fill out the sound you don't really need to break the bank. However, if you have a larger room and your other system speakers are mid to high end then to get the subwoofer to enhance the sound you'll need to go a bit more expensive. Monoprice items has always been known to be a great value and it appears these THX's conform to Monoprice's reputation.
I've only had these a week or so but I have to say they are really, really good. I set my crossover point low at 50hz, because my main's are very good, and after a little playing around I think they match very well to my system. I ended up going with these because of Monprice's reputation and the fact they are THX certified (which may or may not mean much). I absolutely recommend them and I think you get alot for the money. That being said, the reality is SVS and other sub's at this price point are pretty similar to each other so I doubt you could go wrong with any of them. The key is to match to your system and room cubic feet.
gajCA likes this.
jeff43 is offline
post #63 of 1286 Old 02-27-2018, 07:34 AM
Quoted: 189 Post(s)
Liked: 80
When it comes to audio, especially speakers, I think the THX logo still means something.
AVS Commenter is offline
post #64 of 1286 Old 05-03-2018, 10:10 AM
Gorilla Killa's Avatar
Quoted: 1430 Post(s)
Liked: 2043
If a $150 set of computer speakers can get THX certification, Id rather they save the money on the logo and pass it on to me.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #65 of 1286 Old 05-03-2018, 11:20 AM
gajCA's Avatar
Quoted: 8990 Post(s)
Liked: 6152
IDK, the Monolith 10 has an almost identically sized cabinet and the same size driver but 500watts vs. the PB1000's 300watts.
The only advantage I can see with the PB1000 is the ability to return it in the time window with SVS covering the shipping and replacing them with the Monoliths!
Comparing the 12" Monolith vs the 12" PB2000 the advantages are less clear cut as, again, they are at identical price points.
The PB2000 is slightly smaller, has only one port vs two for the Monolith, and actually has a 200 watt advantage in the peak power spec though identical rms power.
Geoff A. J., California
gajCA is offline
post #66 of 1286 Old 05-03-2018, 02:07 PM
Liked: 2471
Having owned both the PB-2000 and PC-2000, the Monolith THX Ultra 12 is superior. I actually had both the PB-2000 and the PB12-NSD at the same time. Level matching them and running both in the same spot, it was very hard to tell the difference in the two in my 2700 ft^3 room. I ened up craigslisting the PB-2000. Still owning the PB12-NSD and now having the Monolith 12, the difference in sound, output and depth is very noticeable.
jermar and gajCA like this.
post #67 of 1286 Old 05-03-2018, 03:48 PM
blake18's Avatar
Quoted: 632 Post(s)
Liked: 353
It's not that simple. The THX certificate for these is far more meaningful.
Lumenlab "Community driven video lab".
blake18 is offline
post #68 of 1286 Old 05-03-2018, 03:52 PM
torii's Avatar
Quoted: 3519 Post(s)
Liked: 1982
whats thx?
who needs a 3rd party quality assurance scam?
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #69 of 1286 Old 05-03-2018, 04:33 PM
Liked: 2471
Originally Posted by torii View Post
whats thx?
I certainly wouldn't call it a scam. A THX certification might carry importance to some, but not to others. It does mean that, in the case of the Monolith subs, that they passed certain performance standards. We don't know what all the process includes, but we do know that the Monolith 12" and 15" are THX Ultra rated. According to them, this means they will achieve at least 115dB down to 20Hz with extremely low distortion in a 3000 ft^3 room with a seating distance of 10-12 feet. The THX certification isn't something that is just "tacked on", but rather a guideline that is used in the process of creating these subs. I'm by no means a THX guy, but the reason these monolith subs are so dang good is attributed to how they were made to meet the THX certification.
The THX Ultra certification is also a rather impressive achievement. Audioholics stated the Ultra certification was basically equal to their "extreme" rating, which is 5000 ft^3 rooms.
post #70 of 1286 Old 05-04-2018, 12:59 PM
Liked: 2043
So are you saying its only meaningful in certain instances? When they came up with multimedia category for pc's they lost me, money grab, nothing else. The THX cert says it meets their standards, but nobody outside THX knows what they are.
Well known reviewer is questioning the way they are reporting and scoring measurements of amps during testing. 3rd party testing should be done by a 3rd party, not someone with skin in the game.
A review from Josh or Audioholics means more in the real world. They show how they got from A-Z.
Razer is now the THX pimp, I can see a plethora of gear stamped with the logo in the near future. If it makes you feel warm and fuzzy, have at it.
post #71 of 1286 Old 05-04-2018, 02:21 PM
Chubtoad's Avatar
Quoted: 84 Post(s)
So I am planning to upgrade my Subwoofer soon and I was planning to go with an SVS PB-1000, possibly even PB-2000 but I am a little hesitant on that. Are these Monolith subwoofers actually a better value? There actually more Expensive than SVS subwoofers in Canada so I'll have to do some more research.
Chubtoad is offline
post #72 of 1286 Old 05-04-2018, 02:25 PM
imureh's Avatar
Quoted: 2815 Post(s)
Liked: 3513
Remember the service aspect especially being in Canada. No one services like SVS and PSA
denze and SuperFist like this.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #73 of 1286 Old 05-04-2018, 03:26 PM
BRAC's Avatar
Quoted: 685 Post(s)
Liked: 590
You can order these through Amazon.ca in Canada now, but fulfilled by Monoprice, CA. Of course we get shafted on pricing as usual. Still about 370 cheaper than a PB4000 all said and done though, in CAD.
Samsung 82” Q90R * LG 55” C8 * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is offline
post #74 of 1286 Old 05-04-2018, 03:31 PM
Kini62's Avatar
Quoted: 2716 Post(s)
Liked: 2527
Which Monolith sub is less expensive than the PB4000? The PB4000 is more comparable to the Mono 15.
Def Tech SC8000
Onkyo RZ820
Roku Ultra, Apple TV, Sharp 70" Quattron
Kini62 is offline
post #75 of 1286 Old 05-04-2018, 03:40 PM
BRAC's Avatar
Quoted: 685 Post(s)
Liked: 590
Monolith 15
BRAC is offline
post #76 of 1286 Old 05-04-2018, 04:46 PM
Marc Alexander's Avatar
Quoted: 5458 Post(s)
Liked: 4953
Originally Posted by Marc Alexander View Post
The one thing to keep in mind is the port tuning frequency of each sub when combining. Mismatching may cause unwanted cancellation. Or it may not.
This list should be fairly accurate:
~32Hz: HSU VTF-1 mk3 (2 ports)
~25Hz: HSU VTF-1 mk3 (1 port)
~22Hz: HSU VTF-2 mk5, VTF-3 mk5 HP, VTF-15H mk2 (2 ports)
~21Hz: Monolith 12 (2 ports open) & Monolith 10
~20Hz: Rythmik LVX12 (2 ports)
~19Hz: PSA V3601, V1801 &15V; Monolith 15 (3 ports)
~18Hz: Rythmik FV15HP & FVX15 (2 ports), HSU VTF-2 mk5 & VTF-3 mk5 HP (1 port)
~17Hz: JTR Cap 118HT & 1400; PSA V1500(?)
~16Hz: Rythmik FV18 (2 ports), Monolith 15 (2 ports), Monolith 12 (1 port), HSU VTF-15H mk2, PSA V1500(?)
~14Hz: JTR Cap 2400ULF; Rythmik LVX12
~12Hz: Rythmik FV25 (3 ports), FV18 (2 ports), FV15HP & FVX15 (1 port)
~10-11Hz: Monolith 15 (1 port); JTR Cap 4000ULF; Seaton Terraform 18 XXXL
It's best to match tuning when mixing ported subs.
Over the last 24 hours I have been testing with the Cap 2400ULF, FV18, and Monoliths 15 & 12. The port tuning frequencies do not have to match when placing subs nearfield.
This is exciting to me because it means the [relatively] diminutive Monolith 10 can be used nearfield regardless of what the main ported sub(s). (I am going to get a Monolith 10 soon and see how it behaves nearfield in a sealed room with sealed main subs.) The Monolith phase control is pretty effective in getting the FR curve right. Unfortunately it has no delay control. So to time align you will need either a AVR/AVP has dual sub outputs with separate distance/delay adjustments or an external DSP like the miniDSP.
I just ordered a Monolith 10 from ebay with today's 15% off coupon. I am going to place it VNF directly behind the MLP with my JTR Captivator 2400ULF in the front right corner of our downstairs den. It should be interesting to see how long it takes them to deliver this 20 miles away.
Today Only! dir
15% Coupon Off $50+
These are the savings you're looking for.
Use code PMAY4TH. Max. $100 discount.
Valid 5/4 8am-7pm PT.
https://pages.ebay.com/promo/2018/0504/64619.html
MIX_MASTER_ICE likes this.
Marc Alexander is online now
post #77 of 1286 Old 05-04-2018, 04:51 PM
Liked: 2471
I also ordered the Monolith THX Select 10 with the ebay discount. Not sure what I'm going to do with it yet, but it did save me $1074 by not buying the demo XTZ 3X12 that had been calling my name in my sleep.
post #78 of 1286 Old 05-04-2018, 04:56 PM
chucky7's Avatar
Quoted: 3539 Post(s)
Liked: 4534
Man, just give in and and get that Monolith 15"...
You know you want it.
By the way, I don't think the $1499 XTZ 3X12 are "demo units". Maybe that's how the Swedish people call "sale"???
Speakers: L/C/R: JTR Noesis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #79 of 1286 Old 05-04-2018, 05:04 PM
Liked: 2471
You are so evil. I think the "demo" tag may be returned or actual demo units. None of their speakers state demo and the "30OFF" code doesn't apply to the 3X12 or 1X12 tagged with demo, which there only appears to be a couple of each available. Not sure, but quit tempting me with either of these. I'm weak of willpower when it comes to home theater gear and guns.
post #80 of 1286 Old 05-04-2018, 05:34 PM
chucky7's Avatar
Liked: 4534
Are you saying that measly 15% off for the Monolith 10" is a better bargain than 40% off for XTZ 3X12???
You are so weak...
post #81 of 1286 Old 05-04-2018, 05:37 PM
oldsteve's Avatar
Quoted: 289 Post(s)
Liked: 317
Monolith 10
I just received my new Monolith 10 early this afternoon. It's replacing (2) SVS SB12-NSD's. Even though I knew the size of the cabinet beforehand by looking at the specs., I was still surprised by it's size. It has basically the same dimensions as my old Hsu VTF-2 mk4 but with a single port instead of two. I would have liked to gotten the 12"but the room is just too small. The little bit I played around with it, I can tell I'm going to like this little guy! It looks kinda strange with that little 10"driver in that big ass cabinet but it seems to be a good match.
chucky7 and MIX_MASTER_ICE like this.
Main 4K Setup: LG OLED55E6P, Oppo UDP-203, Denon AVR X-4500H,AudioSource 2 channel amp,(3) Hsu CCB-8 bookshelf speakers, (2) Hsu HB-1 speakers,(Monoprice Monolith 28" speaker stands, (4) Dayton Audio IO655B speakers, Hsu VTF-2 and VTF-3 subs, 10" Monolith THX sub, Roku Ultra, Amazon Fire TV4K, Monoprice premium certified HDMI cables
oldsteve is online now
post #82 of 1286 Old 05-04-2018, 05:38 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
Ugh I wished I hadn’t read this thread, I resisted the 10” monoprice eBay sale but been looking at the xtz 3x12 at 30% off seems like good deal but these “demo” units tempting...
Someone else buy them so I can’t please...
tgo10000 is offline
post #83 of 1286 Old 05-04-2018, 05:39 PM
imureh's Avatar
Liked: 3513
How does the warranty and service on these XTZs work? Any one know?
imureh is offline
post #84 of 1286 Old 05-04-2018, 05:41 PM
Liked: 2471
You are so weak...
For $425 I'll be sleeping in my bed tonight. For $1499 my wife would probably cast me out to the couch for the weekend. I've pressed my luck a few too many times with various purchases. I still think back to when I showed up at home not in my car, but on a Kawasaki Ninja. Not a fond memory.
chucky7, rossandwendy and Pradeep2 like this.
post #85 of 1286 Old 05-04-2018, 05:42 PM
Liked: 4953
The new issue of Sound & Vision:
tgo10000 likes this.
post #86 of 1286 Old 05-04-2018, 05:45 PM
Liked: 4953
You have two M12s correct? Do you run with both ports open or one? Place the M10 VNF right behind your MLP.
The XTZ 3x12 was tempting me as well. If the 30OFF coupon applied I would have jumped with both feet!
post #87 of 1286 Old 05-04-2018, 05:51 PM
Liked: 2471
I do have dual Monolith 12's, both up front, mostly run 1 port mode. I don't listen to much music on that set up. I have a spot behind my couch, so I probably will try the Monolith 10 there. When I had one Monolith 12 I had it behind the couch, with dual PB12's up front. I need to add on another room to my house. lol
post #88 of 1286 Old 05-04-2018, 06:28 PM
tgo10000's Avatar
Quoted: 20 Post(s)
Liked: 31
Good question, no idea but JimWilson might
https://www.avsforum.com/forum/113-su...rs-thread.html
tgo10000 is offline
post #89 of 1286 Old 05-04-2018, 06:48 PM
Chubtoad's Avatar
Quoted: 84 Post(s)
PB-1000 is generally $699, currently on sale for $675
Monolith 10 is $795 on Amazon.ca
PB-2000 is generally $1050
Monolith 12 is $1418 on Amazon.ca
I haven't personally read enough on these Monoliths to know whether there worth $100 - $400 more than an SVS. For my budget the Monolith 12 is kind of out of reach. The $100 difference between the PB-1000 and the Monolith 10 would be fine If I knew that It was actually that much better.
Chubtoad is offline
post #90 of 1286 Old 05-04-2018, 08:38 PM
BRAC's Avatar
Quoted: 685 Post(s)
Liked: 590
I would guess that the Monolith 12 is probably more on the level of the PB12+
BRAC is offline
muchbetterthanpsa , overrated , overrated wannabe sub , psasucks
