Official Monoprice THX Subwoofers - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 433Likes
post #1081 of 1163 Old 05-19-2019, 04:59 PM
Matthew Wiechert's Avatar
Quoted: 81 Post(s)
Liked: 25
Originally Posted by chucky7 View Post
Get these!!!
A pack of 8 for $4.95 shipped with Amazon Prime!!!
Reliable Hardware Company RH-1606-8-A Guitar Amplifier Cabinet
https://www.amazon.com/Reliable-Hard...KYM1WGATG&th=1
Tried em not the same..while those made it nice to get some height off the floor they are just hard rubber feet.. The svs actually actually do what they are supposed to do..
Sent from my SM-N960U using Tapatalk
Leon! likes this.
Matthew Wiechert is offline
post #1082 of 1163 Old 05-19-2019, 05:06 PM
chucky7's Avatar
Quoted: 3368 Post(s)
Liked: 4044
What about these?
https://www.amazon.com/PneumaticPlus...KK02YN1VAR488J
It depends on what you are trying to achieve here.
The Isolation pads decouple the sub from the surface below it. They do not contain the bass/vibration within the room. Therefore, if you are looking to decouple, then the pads should work very similarly.
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is online now
post #1083 of 1163 Old 05-19-2019, 05:09 PM
Quoted: 81 Post(s)
Liked: 25
What about these?
Well I get a lot of vibration from pics and heat vent.. so I got those cheap ones and they didn't really do anything but raise it.. The svs made most of it gone.. Not all but most of it.
post #1084 of 1163 Old 05-19-2019, 07:50 PM
Leon!'s Avatar
Quoted: 283 Post(s)
Liked: 136
yep have to be big, soft , not too dense to give more wiggle between the sub and floor
Leon! is offline
post #1085 of 1163 Old 05-19-2019, 09:26 PM
Norris Kasey's Avatar
Quoted: 121 Post(s)
Liked: 65
Did the svs come with the correct hardware to mount them?
Sent from my Pixel 3 XL using Tapatalk
Norris Kasey is offline
post #1086 of 1163 Old 05-20-2019, 04:29 AM
Quoted: 111 Post(s)
Liked: 67
Yes they do. The screws that come with the feet will work with the Mono sub so you are good to go. I purchased a set as well but unfortunately I am sitting on cement so it did not make a difference for my theater. So I ended up using it upstairs where I am on a wood floor. Big difference and worth the money.
Matthew Wiechert likes this.
doni01 is online now
post #1087 of 1163 Old 05-20-2019, 10:47 AM
Quoted: 81 Post(s)
Liked: 25
Got my tracking with tomorrow delivery already.. That's fast.
post #1088 of 1163 Old 05-21-2019, 04:13 AM
Quoted: 24 Post(s)
I also got the cheaper Amazon feet for the monolith 15 , they certainly helped lifting it off the floor. but I have some rattles in the windows , baseboard heaters and even a weird vibration coming from my mounted 75inch tv lol.
I was looking for one of them subdude pads but they seem short for the big guy. Which brings me to my next question , will these svs soundpath feet help with any of these rattles ? Or is it possible the bass from heavy lfe content is causing these rattles.
Would love to hear some real experience with these issues , kind of sucks having a very solid sound coming out of my subwoofer only to be accompanied with the random rattles around the house.
vinnyg747 is online now
post #1089 of 1163 Old 05-21-2019, 04:48 AM
Quoted: 81 Post(s)
Liked: 25
It helped me for sure.. Get em from Amazon and try em.. Easy free return if they don't work..
post #1090 of 1163 Old 05-21-2019, 05:35 AM
Quoted: 24 Post(s)
Ok sounds good , ordered them , will definitely report back in a few days. Thank you.
post #1091 of 1163 Old 05-21-2019, 06:13 AM
Quoted: 81 Post(s)
Liked: 25
What kind of floor do you have?
post #1092 of 1163 Old 05-21-2019, 06:27 AM
Quoted: 24 Post(s)
Hardwood floor , I own a raised ranch so my living room is on the second floor above the garages.
post #1093 of 1163 Old 05-21-2019, 07:53 AM
nonstopdoc1's Avatar
Quoted: 514 Post(s)
Liked: 111
Are SVS Soundpath feet compatible with Monolith Subs? Is anyone here using them? It looks like IsoAcoustics ISO-200Sub stands will be too small for these subs even if you use a pair of stands for 1 sub.
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | QSC DPA 4.2 | ATI AT528NC | Procella P8/P5V | Revel C763L | Rythmik FV15HP x2
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia CC | Polk Surrounds | Monolith 12" Subs x 2
nonstopdoc1 is online now
post #1094 of 1163 Old 05-21-2019, 07:54 AM
Quoted: 81 Post(s)
Liked: 25
Yes they also come with the correct size screw..
post #1095 of 1163 Old 05-21-2019, 07:58 AM
Quoted: 514 Post(s)
Liked: 111
Thanks for adding the picture. What floor do you have? Did you see any benefit in your case?
JOjr likes this.
My Build Thread
post #1096 of 1163 Old 05-21-2019, 08:00 AM
Quoted: 81 Post(s)
Liked: 25
Yes lots of rattle from pics and stuff went away.. I just ordered a 2nd mono 12 and more feet..
nonstopdoc1 likes this.
post #1097 of 1163 Old 05-21-2019, 02:33 PM
Quoted: 81 Post(s)
Liked: 25
Does anyone actually put those gloves on to inbox it? I did the first time cause I felt special lol..just got my 2nd and ya no..
Norris Kasey likes this.
post #1098 of 1163 Old 05-21-2019, 02:41 PM
Quoted: 121 Post(s)
Liked: 65
I did it too lol. Then when I tried to move it I took them off not much grip
post #1099 of 1163 Old 05-21-2019, 04:22 PM
Quoted: 81 Post(s)
Liked: 25
I can't figure out why movies shake my room.. I switch to Spotify and barley any bass.. Played bass I love you which hits some low 15hrtz and the subs wouldn't move..
post #1100 of 1163 Old 05-21-2019, 05:21 PM
Quoted: 24 Post(s)
Make sure your speakers are set to small. That's the first thing to check.
post #1101 of 1163 Old 05-21-2019, 05:22 PM
Quoted: 81 Post(s)
Liked: 25
They are
post #1102 of 1163 Old 05-21-2019, 08:06 PM
Quoted: 81 Post(s)
Liked: 25
Another thing I'm finding I have both subs set the exact same and it seems the new one has a lot less excursion..
post #1103 of 1163 Old 05-21-2019, 11:47 PM
Quoted: 81 Post(s)
Liked: 25
Anyone have any ideas why?
post #1104 of 1163 Old 05-22-2019, 03:43 AM
Quoted: 36 Post(s)
Liked: 7
Have you re run audyssey since adding the second? Assume you have and have checked the settings (phase etc). If you’ve done all that and everything’s good I have no other ideas other than room placement. Unplug the one that sounds good and sub crawl with #2 ? Alternatively swap locations with the one that sounds good. See if it sounds the same as the first one. If the settings are the same and it still sounds poor in the same conditions as the first one then it would indicate that the problem is with the sub, no?
Brian Lynch is offline
post #1105 of 1163 Old 05-22-2019, 04:28 AM
Quoted: 81 Post(s)
Liked: 25
I really don't know the proper way to set a second sub up..besides ruining Audyssey.. Settings the same phase all the way down..
post #1106 of 1163 Old 05-23-2019, 11:46 AM
bertk's Avatar
Quoted: 47 Post(s)
Liked: 36
For Audyssey start here
Guide to Subwoofer Calibration and Bass Preferences
In particular II-C: Where And How To Add Bass using the Denon AVR.
On the Momolith start with:
Crossover = 160 Hz
Phase = 0
Level will be close to +6 dB to achieve -11 in Audyssey. Set each sub individually. This may take several tries using the first three mic positions. Once the subs are set rerun Audyssey to complete all mic positions.
Crossover switch = Off. Let the AVR handle crossovers.
EQ switch = can go either way.
Power switch = Set to your preference.
Denon X3400H | Klipsch RP-280F | RP-450C | RP-240S | RP-500SA | Monolith 12" THX Subwoofer X2
Panasonic UB-820 Player | LG OLED65C8 TV | DirecTV HR54/200 | AppleTV 4K l Monoprice Certified HDMI Cables
bertk is online now
post #1107 of 1163 Old 05-23-2019, 07:43 PM
Quoted: 81 Post(s)
Liked: 25
I can't get over the fact that my klipsch reference speakers are smoking my monos playing music.. It seems they only play bass that really low... I can play bass songs and they come play.. But play some snoopdogg they won't barley move... Help
post #1108 of 1163 Old 05-23-2019, 07:54 PM
Quoted: 36 Post(s)
Liked: 7
What are your front LR crossovers?
post #1109 of 1163 Old 05-23-2019, 07:57 PM
Quoted: 81 Post(s)
Liked: 25
Small.. 80
post #1110 of 1163 Old 05-23-2019, 08:02 PM
Quoted: 36 Post(s)
Liked: 7
Small.. 80
Hmm. You got me stumped then. Crossover dial on the back of the mono is all the way up at 160? Does it sound good? Could always turn the subs up to get them bouncing. Hehe
muchbetterthanpsa , overrated wannabe sub , psasucks
