Official Monoprice THX Subwoofers - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 656Likes
post #1231 of 1753 Old 08-23-2019, 12:32 PM
Quoted: 14 Post(s)
Liked: 0
Unfortunately, I think I got a faulty one, I was watching avengers infinity war and on a certain scene, the pop sound happened from the sub and it stopped working.
I uploaded a video with the issue I'm having. the sound appears at the 0:29 mark ( ignore the sound at 0:12 and 0:14 that was coming from my phone )
the sub needs a reset to work again but happens again if I replay the scene.
the link to the video:
is there any way I can fix this by myself?
GloryZ is offline
post #1232 of 1753 Old 08-23-2019, 02:38 PM
bertk's Avatar
Quoted: 85 Post(s)
Liked: 71
It’s hard to say without more info as doni01 suggested.
Did you try plugging it into another outlet on a different circuit?
Denon X4500H | Klipsch RP-280F | RP-450C | RP-160M | RP-240S | RP-500SA | Monolith 12" THX Subwoofer X2
Panasonic UB-820 Player | LG OLED65C8 TV | DirecTV HR54/200 | AppleTV 4K l Monoprice Certified HDMI Cables
bertk is online now
post #1233 of 1753 Old 08-23-2019, 03:38 PM
MIX_MASTER_ICE's Avatar
Quoted: 2678 Post(s)
Liked: 2493
AVS member Dim3nsion just brought to my attention that the Monolith subs have received a price increase recently. Monolith 12 is now $879.99, as well as the 12" sealed model. The other subs also received a price increase, but not as much as the 12". Putting the 12" close to $900 is going to make it hard to recommend compared to the HSU VTF-3 mk5 with a $895 price when not on sale.
https://www.monoprice.com/search/ind...lith+subwoofer
Subs>RBH I-12e. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB72,XB32. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. JBL PartyBox100(x2), Xtreme2,Charge4,Link300. Sivga SV004. LG FH6,RK8,RK7,PK7,PK5. HK Onyx Studio4(x2)
MIX_MASTER_ICE is offline
post #1234 of 1753 Old 08-23-2019, 08:06 PM
Quoted: 14 Post(s)
Liked: 0
No i i did try because i only have one outlet with 110v.
The settings i have on the sub right now are as follow
Crossover : 160hz
Level: +6db
Phase: 0
Crossover switch : off
EQ: THX
Power : on
audyssey set the level of the sub at -12.
GloryZ is offline
post #1235 of 1753 Old 08-23-2019, 08:20 PM
PlanetAVS's Avatar
Quoted: 2479 Post(s)
Liked: 3593
Crossover : 160hz
Level: +6db
Phase: 0
EQ: THX
Power : on
I'd lower your crossover to 80 Hz, lower the sub level to 0. Change the Denon subwoofer level to the same level as your fronts. Overall it seems that you are overdriving it, especially with such a high crossover frequencey.
PlanetAVS is online now
post #1236 of 1753 Old 08-23-2019, 08:40 PM
Quoted: 14 Post(s)
Liked: 0
Alright i will do what you suggested
For sub level i see there is + 0db sould i set there knob there ?
Aslo do i have to recalibrate the avr ?
GloryZ is offline
post #1237 of 1753 Old 08-23-2019, 08:45 PM
PlanetAVS's Avatar
Liked: 3593
Yes change it from +6 to 0. I don't think you need to rerun Audyssey at least right away, but others can chime in.
post #1238 of 1753 Old 08-23-2019, 08:46 PM
Matthew Wiechert's Avatar
Quoted: 88 Post(s)
Liked: 30
Keep the crossover at 160 let the avr do it all.. Something like this..
Sent from my SM-N960U using Tapatalk
Matthew Wiechert is offline
post #1239 of 1753 Old 08-24-2019, 01:59 AM
Quoted: 14 Post(s)
Liked: 0
Crossover : 160hz
Level: +6db
Phase: 0
EQ: THX
Power : on
So i changed the level to +0db and kept everything as above
Audyessy set the level of the sub at -7.5
I played the same scene from the avengers and i t played without issues but got the same problem from the opening of EOT .
does that mean the sub just can't handle it or it's an issue with the unit ?
Do you think the placement of sub can have an effect on the problem ?
Any other recommenda movie scene to test the sub more ?
GloryZ is offline
post #1240 of 1753 Old 08-24-2019, 08:26 AM
evoll88's Avatar
Quoted: 108 Post(s)
Liked: 58
EOT will make a lot of subs sound like they have problems so i would check these out to find out how it sounds. https://www.svsound.com/blogs/svs/10...-movie-moments
evoll88 is offline
post #1241 of 1753 Old 08-24-2019, 09:29 AM
PlanetAVS's Avatar
Liked: 3593
Where are you guys getting the idea of a 160 Hz crossover being appropriate? Maybe I'm missing something but I've never heard of setting a quality sub that high. You are asking the sub to do way more work.
post #1242 of 1753 Old 08-24-2019, 09:48 AM
ratbuddy's Avatar
Quoted: 947 Post(s)
Liked: 1389
That's the sub crossover, I'm sure his receiver is at something lower. Anyway, a good sub can perform just fine at 160, though it will be localizable.
Matthew Wiechert likes this.
ratbuddy is offline
post #1243 of 1753 Old 08-24-2019, 09:57 AM
PlanetAVS's Avatar
Liked: 3593
Good point. OP, what crossover do you have the subwoofer set at in the AVR settings?
post #1244 of 1753 Old 08-24-2019, 09:59 AM
Quoted: 88 Post(s)
Liked: 30
Setting it all the way up.. Let's your avr handle all the xover..
post #1245 of 1753 Old 08-24-2019, 10:21 AM
Quoted: 14 Post(s)
Liked: 0
120hz , keep it as it's the default setting
GloryZ is offline
post #1246 of 1753 Old 08-24-2019, 10:39 AM
Quoted: 54 Post(s)
Liked: 46
One of the switches disables the sub's crossover if you want the avr to handle it.
Sent from my SM-N950U using Tapatalk
threshold350 is offline
post #1247 of 1753 Old 08-24-2019, 10:47 AM
ratbuddy's Avatar
Quoted: 947 Post(s)
Liked: 1389
Are you sure that's what the speakers were set at, and not the LPF for LFE setting? It set the mains to small/120 Hz? They must be tiny if so...?
ratbuddy is offline
post #1248 of 1753 Old 08-24-2019, 10:57 AM
Quoted: 88 Post(s)
Liked: 30
This was earlier in the thread from the hardcore dudes lol..
post #1249 of 1753 Old 08-24-2019, 01:22 PM
bertk's Avatar
Quoted: 85 Post(s)
Liked: 71
It's good to see Audyessy has the Trim set to be less then -12 which is it's upper limit of Denon/Marantz units and at that point there is no telling what the sub volume level was actually set at. With the post-calibration AVR sub trim now set to -7.5 and sub level to +0 this is a pretty tame setting for the Monolith Subs. Normally I shoot for a -11 AVR trim level and increase the reduce it as needed on the AVR. Then if more bass is needed increase the Sub Level(s) symmetricly.II-C: Where And How To Add Bass
What AVR are you using? And what was the MV (main volume) set to?
What other speakers are there in the setup, and what are the post-calibration crossovers set to?
How is the sub connected to the AVR? I'm assuming an RCA with on Y-Connectors.
To your questions above:
If your only noticing issues in EOT track then it's most likely not the Sub.
Yes, placement is important. VIII-E: Subwoofer Placement in a Room
Alita: at the beginning where she rescues the dog from under the centurion. And Ready Player One - The Bomb scene towards the end of the movie has massive long lasting bass.
Regard,
Bert
bertk is online now
post #1250 of 1753 Old 08-24-2019, 01:23 PM
Quoted: 14 Post(s)
Liked: 0
the lpf for lef setting is at 120 hz.
My speakers are set to small at 80hz.
GloryZ is offline
post #1251 of 1753 Old 08-24-2019, 01:43 PM
Quoted: 14 Post(s)
Liked: 0
Regard,
Bert
I have a denon avr x2500h , rp-600m and rp-504c
I set the speakers to small and 80hz crossover.
I put the vlomue when watching movies and TV shows at -15 db to -10 db depending on the content .
For the subwoofer i use the regular RCA cable from amazon basic. For now i have not noticed any issue from sub and i hope it's just a problem with that specific scene and not from the unit itself.
GloryZ is offline
post #1252 of 1753 Old 08-24-2019, 02:15 PM
bertk's Avatar
Quoted: 85 Post(s)
Liked: 71
Agreed, and as long as the main speakers can handle down to 80Hz.
Having capable mains I recently implemented Three Step Cascading Crossovers post-calibration.
1. Set main crossovers to 80hz, and surround speakers slightly higher.
2. Set LPF of LFE (which controls a separate bass channel, the .1 low-frequency effects channel, which only the subwoofers play during 5.1 content) to 80Hz.
3. On the subs switch Crossovers Off and set to 80Hz.
Reference: III-C: Cascading Crossovers
Bert
bertk is online now
post #1253 of 1753 Old 08-24-2019, 02:37 PM
bertk's Avatar
Quoted: 85 Post(s)
Liked: 71
Sounds like your getting it dialed in. Not all movies will take the same amount of MV to sound good. You may try just reducing MV for EOT.
The Monolith Subs are excellent subs but can be a bit challenging to setup. They also have there own sound signature that takes some getting use to, particularly if coming from an boomy sounding sub.
Bert
bertk is online now
post #1254 of 1753 Old 08-24-2019, 02:53 PM
PlanetAVS's Avatar
Liked: 3593
The other variable is room size?
bertk likes this.
post #1255 of 1753 Old 08-25-2019, 05:11 PM
Quoted: 323 Post(s)
Liked: 91
they went up in price, checked monoprice just now.
mariogonzalezzz is offline
post #1256 of 1753 Old 08-26-2019, 10:38 AM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Sorry don't take this the wrong way but what you are experiencing is a User Error! Read the material that was provided above in more than one post and you will have all your questions answered
doni01 is offline
post #1257 of 1753 Old 08-27-2019, 04:57 AM
rwestley's Avatar
Quoted: 741 Post(s)
Liked: 472
The price increase probably reflects new tariffs.
rwestley is online now
post #1258 of 1753 Old 08-27-2019, 08:44 AM
Quoted: 24 Post(s)
Liked: 8
wonder if there are any upcoming specials with labor day sales, could finally get my second 15
JOjr is offline
post #1259 of 1753 Old 08-30-2019, 12:23 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2527 Post(s)
Liked: 4084
M15-S review
I just posted my evaluation on the M15-S. For those interested you can find it at this link.
If you take yourself too seriously expect me to do the exact opposite.
BTW, did you really need to quote the entire post?
JimWilson is offline
post #1260 of 1753 Old 09-01-2019, 06:04 PM
Macros73's Avatar
Quoted: 24 Post(s)
Have you reviewed the Monolith minitower and center channel speakers? Looked around but can’t find much on them from third party reviewers.
Macros73 is offline
bestsubs , better than psa , monolith 12" thx ultra 500w sub , monolith 15" thx ultra 1000w sub , psa sucks
