SVS Launches 4000 Series Subs: SB-4000, PB-4000 and PC-4000 - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 248Likes
post #211 of 226 Old 04-24-2018, 05:39 PM
BRAC's Avatar
Quoted: 563 Post(s)
Liked: 458
Originally Posted by theaterofpain View Post
Hmmm, sounds like a self-justification rant for settling on the PB13 purchase. I was going to get dual PB13s, but then got dual PC-4000s but that's because some of us love the form factor (it allowed me to tighten up the false wall in the dedicated theater) and the convenience of bluetooth control after the acoustically transparent false went up. If form factor and ease of sub control don't matter, then I don't see why dual PB13s wouldn't be OK for you.
I suppose you could look at it that way haha...I don’t mind. I did have the the choice between the new line and the old and I guess you could say common sense took over. An easy decision for me not needing the new ease of use features.
The main point of my post was simply to point out that performance wise, the new and old are pretty much a wash. I was getting the impression reading through this thread that people were thinking they were getting some sort of major bump in performance over the outgoing Ultra line. Maybe by pointing this out I can help save some folks a huge sum of cash.
Samsung 82” Q90R * Denon X4500H * 5.2.4 Atmos * Xbox One X * PS4 Pro
BRAC is offline
post #212 of 226 Old 04-25-2018, 08:34 AM
Quoted: 26 Post(s)
Liked: 6
The performace difference between the new 4000 line and the old Ultra line is significant. I believe testing has shown anywhere from 3-6 dB. Combine that with the ease of use features and the 4000 series is a no-brainer.
natedog1959 is offline
post #213 of 226 Old 04-25-2018, 09:51 AM
confinoj's Avatar
Quoted: 1194 Post(s)
Liked: 998
I don't believe there is that much difference. I'm sure there is some with overall better FR but mostly in the same ballpark. To put those numbers in perspective a 6db increase is equivalent to adding a second co-located subwoofer. I have not seen any direct compares done from the same third party but if you look at the measurements of the PB-4000 from hometheaterreview (only measurements I see) and PB13 ultra measurements from audioholics they are pretty similar. Now these are different 3rd parties in different testing environments so needs to be taken with a grain of salt. Have you seen other any direct comparisons or other 3rd party testing of 4000 series done?
https://hometheaterreview.com/svs-pb...viewed/?page=2
https://www.audioholics.com/subwoofe...3-measurements
mthomas47 likes this.
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is online now
post #214 of 226 Old 04-25-2018, 10:56 AM
BRAC's Avatar
Quoted: 563 Post(s)
Liked: 458
Link please?
Now you can see my point...this is the type of misinformation that is misleading people. The numbers this guy is claiming would put it at, or above, the performance level of the new PB16 Ultra.
cchunter likes this.
BRAC is offline
post #215 of 226 Old 04-25-2018, 11:13 AM
bargugl's Avatar
Quoted: 226 Post(s)
Liked: 259
Link please?
I'm betting it's the old someone confused a frequency response chart with max output. The PB-13 Ultra graph was done with 90 db signal and the PB-4000 was done with a 95 db signal.
bargugl is online now
post #216 of 226 Old 04-25-2018, 01:57 PM
AVS ***** Member
mthomas47's Avatar
Quoted: 5313 Post(s)
Liked: 9878
I think that this has already been laid to rest by several people on the thread, but just in case, Ed Mullen has said that the difference between the PB4000 (with its slightly larger cabinet size and its extra 200 watts RMS) and the PB13 is about 0.5db. There was always a little bit of max output difference between the PB13 and the PC13, due to the difference in cabinet volume between the two, and that difference would presumably remain with the PB4000 and the PC4000. I think that the difference was approximately 1.5db.
We all want our subs to have as much max output as possible, but it is extremely unlikely that anyone would ever be able to appreciate a max output difference in the 0.5 to 1.5db range. On the other hand, improvements in DSP and in ease of functionality, with the new models, might be very welcome to some sub owners.
Mike
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #217 of 226 Old 04-25-2018, 02:20 PM
Quoted: 26 Post(s)
Liked: 6
That may have been the difference I saw. Didn't SVS themselves say the improvement was significant earlier in this thread on on the PC-4000 AVSforum test thread?
post #218 of 226 Old 04-25-2018, 02:27 PM
Quoted: 26 Post(s)
Liked: 6
Originally Posted by Ed Mullen View Post
It's a typo on the FR graphs - we fixed it.
The PC-4000 is a better performer than the PC13-Ultra in every respect. It has higher dynamic output, more refined behavior at the limits, better optimized FRs in each tune, more comprehensive menu options, and of course the front panel display, credit card remote and smart phone app.
Ed,
Do you have back to back numbers on the difference to settle this discussion?
post #219 of 226 Old 04-25-2018, 03:24 PM
Writer & Reviewer
JimWilson's Avatar
Quoted: 2137 Post(s)
Liked: 3207
Ed,
Ed might not be monitoring this thread on a daily basis so try @Ed Mullen instead. That may work better.
If you take yourself too seriously expect me to do the exact opposite...
JimWilson is online now
post #220 of 226 Old 04-25-2018, 04:38 PM
BRAC's Avatar
Quoted: 563 Post(s)
Liked: 458
Mike
Well said...and if they are selling for the same price, the choice is obvious to grab the latest model for those DSP improvements and ease of use features.
BRAC is offline
post #221 of 226 Old 04-25-2018, 06:00 PM
Liked: 6
Ed,
+1 for this. PB4000 costs $1000 more than a PB-13 where I'm from. Wondering were the value is.
olock is offline
post #222 of 226 Old 04-26-2018, 10:28 AM
cchunter's Avatar
Quoted: 581 Post(s)
Liked: 865
3-6dbs lol. Can you sell me whatever your smoking? There is only a 3-4db between the 13 and 16 Ultras.
Sony 75X900E 4K
Marantz SR7011 Parasound Halo A52+
Klipsch RF7II's, RC-64II, RS-62II's, RP500SAs Atmos
SVS Dual SB13 Ultra's
Oppo UDP-203 4K Sony PS4 Pro Panamax 5300PM
cchunter is offline
post #223 of 226 Old 04-30-2018, 05:23 AM
Ed Mullen's Avatar
Quoted: 286 Post(s)
Liked: 712
The max SPL (CEA-2010) deltas between the discontinued 13-Ultra and the 4000 series is (as I have mentioned previously and Mike stated above) about 0.5-1.0 dB on average (depending on the test frequency). This is with both amps set to 0 dB, and is consistent with the 1000W vs 1200W rated power difference between the two amp platforms.
The FR sweeps shown on the website are not all taken at the same exact drive level. We adjust the drive level of the FR sweep to obtain an adequate S/N ratio for good data acquisition (some test days simply have higher ambient noise levels than others). Naturally the FR sweep level doesn't reflect the maximum output capability of the subwoofer - and we state that below the FR graphs.
I just did a quick check of the Standard Tune PC13-Ultra vs Standard Tune PC-4000 CEA-2010 test data (these models were specifically mentioned above) and the deltas (in favor of the PC-4000) are:
20 Hz 1.0 dB
25 Hz 1.1 dB
31.5 Hz 0.2 dB
40 Hz 0.8 dB
50 Hz 1.2 dB
63 Hz 1.3 dB
80 Hz 0.7 dB
Again no real surprises here - typical/expected gains given the 1000W/1200W power level differences between the two platforms.
bigguyca, mthomas47 and Audionutta like this.
Ed Mullen
Director - Technology and Customer Service
SVS
"What We Do In Life, Echoes In Eternity"
Ed Mullen is offline
post #224 of 226 Old 05-04-2018, 03:05 PM
Slickman's Avatar
Quoted: 484 Post(s)
Liked: 424
So with those gains the PC-4000 is about equal to the PB13 Ultra in output, and with a much smaller footprint.
Slickman is offline
post #225 of 226 Old 05-04-2018, 03:16 PM
BRAC's Avatar
Quoted: 563 Post(s)
Liked: 458
That’s probably a fair assessment..
BRAC is offline
post #226 of 226 Old 06-13-2018, 07:14 PM
nodoubt's Avatar
Quoted: 416 Post(s)
Liked: 247
Originally Posted by Tom Vodhanel View Post
Oh I know, nothing directed at you.. I *do* have a dog-in-the-fight so to speak. Every time nonsense like this is stated/quoted it has a ripple effect. Might be a tiny ripple but it is still there. Trust me, there's hundreds or maybe even thousands of casual home theater enthusiasts out there right now...who actually believe this horseshi*.
One of the more common themes I get in chat/phone is "I just spoke with one of your competitors and they said all 18" subwoofers will be slow and boomy. That's not what I want so I guess I should only consider your smaller products, right"?
Just perfect. Now I need to spend how much of MY time trying to correct this myth? And I wonder who that "competitor" was?
Rant over..
Tom V.
Power Sound Audio
can a fat man, run as fast, or be as nimble as someone built like a ninja warrior, or a fine tuned athlete ?
without running out of energy, or having a heart attack?
nodoubt is online now
