Help! No real bass from PB-4000 with Yamaha RX-A3070 - AVS Forum | Home Theater Discussions And Reviews
 25Likes
post #1 of 74 Old 01-28-2018, 06:45 AM - Thread Starter
ilikeallofu's Avatar
Quoted: 58 Post(s)
Liked: 42
This's probably a better section to post my question. I'm very new to this and with help from my original thread, I bought a setup for my home theater. I've Klipsch RP speakers for my 5.2 setup with Yamaha RX-A3070 as the receiver. For the subwoofers, I bought 2 of the SVS PB-4000. I set everything up and Klipsch speakers sound great, but most of the bass I hear is coming from center and the fronts and there's hardly any "thumping" from the subs. I've seen video where I could see the subs shaking but nothing like that happens in my setting.
Here's what I've done so far based on all the reading. I tried setting everything using the YPAO Auto, that didn't sound good. Then changed the setting manually for all speakers to Low, 80Hz, LFE as Off, Level at -10 to -3 and Subs volume at -10db. None of this's working. Any help would be appreciated.
thanks
Here's the screenshot of the back of the receiver and subs...
ID:	2352348   Click image for larger version
Name:	Screen Shot 2018-01-28 at 9.49.43 AM.png
ilikeallofu is offline
post #2 of 74 Old 01-28-2018, 07:03 AM
Quoted: 200 Post(s)
Liked: 111
thanks
Something is definitely set up wrong, because it should be rumbling with that set up! I own a yamaha rx-a3050 with two svs pb-2000 subs. hmm. Let me take stab at it. So, LFE as off? I think that is what actually drives the signal to your subs? Shouldn't that be on? How is it wired to the subs? You should be running from the sub out on the receiver(double check you plugged into the correct spot,by the center channel rca out) to the LFE IN(RIGHT) on the subwoofer. Make sure you have your wiring correct, and then double check it again. Power? Last but not least, never hurts to try a different wire, cheap thing to try, but unlikely to be it.
My subs have a volume knob on the back that you set at 12 o'clock before you run the YPAO, but it looks like yours do not?
If the wiring is right, the LFE is on, you could do a a complete "reset" on the Yamaha to factory settings for the receiver and then go from there. I once bought a used Yamaha receiver and it was not working correctly and once I did the reset on the receiver everything started working. Hope that gives you a few things to try out.
James Stephens 2 is offline
post #3 of 74 Old 01-28-2018, 07:13 AM
B T C's Avatar
Location: Lansing, MI via Kentucky, Georgia & Tennessee
Quoted: 669 Post(s)
Liked: 308
I don't have any subs, but I would think LFE should be enabled.
Front L&R - Polk LSiM703
Center - Polk LSiM706c
Surround L&R - Polk LSiM703
Subs - Two Rythmik F18-SEs
AVRs - Denon AVR-X6200W, Yamaha RX-A3040 : Amp - Yamaha M-80
B T C is offline
post #4 of 74 Old 01-28-2018, 07:25 AM
B T C's Avatar
Quoted: 669 Post(s)
Liked: 308
I just looked through the 3070 owner's manual, and I didn't see anything indicating that you could turn "LFE" on or off. There are settings to "Use Normal/Reverse" or "Not Use/None" the subs under manual setup.
B T C is offline
post #5 of 74 Old 01-28-2018, 07:31 AM
PioManiac's Avatar
Quoted: 3342 Post(s)
Liked: 8461
1st Run YPAO "Auto" to EQ your Speakers/Subs and set the correct distances/delays.
Then go to Manual mode and change your speakers to "Small" not Low, 80Hz is a good crossover.
Parametric EQ to "Flat"
In manual mode, turn on "test tone" and use an SPL meter to level match all your speakers,
Adjust your subs levels to read about 10dB higher than your speakers.
(Adjust the gain on the sub so the level in the AVR is close to "0")
There are no LFE settings in Yamaha AVR's,
they send all <120Hz LFE frequencies to the sub by default.
+ all frequencies below the crossover point from your speakers set to small.
That's all you need, don't turn on Extra Bass from the options menu.
PhantomDriver likes this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #6 of 74 Old 01-28-2018, 07:38 AM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
The LFE setting is on the Subs, not the AVR... Since there's no knobs on the subs, it's controlled through an app... please see a screenshot from the app of the SVS Subs... should I turn it ON?
post #7 of 74 Old 01-28-2018, 07:44 AM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
Here're some pics from the setting after manual adjustment:
ID:	2352382   Click image for larger version
ID:	2352384   Click image for larger version
ID:	2352386   Click image for larger version
ID:	2352388   Click image for larger version
post #8 of 74 Old 01-28-2018, 08:11 AM
PioManiac's Avatar
Liked: 8461
is Airplay your only source?
I don't use any of those settings you posted from the options menus,
You may want to try playing a Bluray movie that you know has great bass.
To make sure your SVS is setup properly, try posting here: https://www.avsforum.com/forum/113-su...pc-4000-a.html
post #9 of 74 Old 01-28-2018, 08:29 AM
pase22's Avatar
Quoted: 3356 Post(s)
Liked: 2829
The volume setting on the sub is too low. Turn the volume on the sub up little more. You're aiming to be closer to -5 or lower after calibration. Set all speakers to small in the AVR menu.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #10 of 74 Old 01-28-2018, 08:49 AM
PioManiac's Avatar
Liked: 8461
I never set crossover or filters in the subs, they should get a full range signal,
Only speakers set to small need to have a crossover setting.
post #11 of 74 Old 01-28-2018, 09:01 AM
Falconsfan71's Avatar
Quoted: 1544 Post(s)
Liked: 524
LFE to “ON”
I commented under your other post also...
Denon X4300H * Def Tech BP8080st front L/R * Def Tech CLR2002 center * Def Tech ProMonitor 800 surrounds (x4) * Hsu VTF-3 MK5 HP sub * Outlaw OAW4 wireless sub kit * Vizio 60" 4K HDRtv * Sony UBP-X800 Bluray * PS4 * AC Infinity S9 AVR fan
Falconsfan71 is offline
post #12 of 74 Old 01-28-2018, 01:13 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
Just a quick update: Talked to Ed from SVS... he suggested to test the subs directly from a smart phone and I can see it shaking the room... I can see the woofer about to come out of the subs . From what I read up on here, it seems like Yamaha has very "low output" or whatever it is to manage the subs, even though I understand that subs don't need much input. I don't understand how the same music connected from iPhone can get the subs to thump and Yamaha won't... I'm going to the dealer tomorrow and getting a Denon and return the Yamaha... I will report back here... thanks to all for your help... thank you!
post #13 of 74 Old 01-28-2018, 01:25 PM
PioManiac's Avatar
Liked: 8461
That's outrageous to even suggest, there are millions of happy Yamaha owners that have working Subs.
You have a Flag Ship model that is very capable so either your unit is defective or there is user error to blame.
You seem to have some very unusual selections based on your screen shots, perhaps you should have asked in the 3070 thread?
I've never had issue with any Yamaha AVR's sub output, (I've had many Yamaha's over the past 30+ years)
Did you ever try another input, preferably a bluray movie with decent bass levels, or did you only try Airplay?
I currently have 4 subs, over 13K watts of power all running off my RX-A3050, no issues at all playing right down to 10Hz.
SuperFist, llang269, Stove and 2 others like this.
post #14 of 74 Old 01-28-2018, 01:55 PM
Liked: 524
Yea, I don’t think it’s the AVR! You need to double check yourself.
post #15 of 74 Old 01-28-2018, 02:00 PM
indebtbassfreak's Avatar
Quoted: 1455 Post(s)
Liked: 2794
I read on the Yamaha thread that the higher end Yamaha's had the low voltage issue corrected (i dont know this as a fact mind you). You still have not confirmed or responded to Falconsfan's question if in fact you had the LFE, or (sub) in your avr turned to the (on) position?
Also if you have only tried music have you tried all channel stereo (if there is that feature) I still think you have missed a setting.
-Marantz SR-8012
-Yamaha BD-A1060
-Funk 21.0LX Master/Slave combo 4800 watts RMS/9600watts (peak)-
-Chane A-2.4 L/C/R
-Chane A-1.4 side/rear surrounds.
indebtbassfreak is offline
post #16 of 74 Old 01-28-2018, 02:08 PM
Stove's Avatar
Quoted: 12 Post(s)
Liked: 24
My Yamaha RX-A3070 with my SVS PB13-Ultra/Polk Audio LSiM 5.1 setup rips my house apart....... I wish I could help with your issue.
Stove is offline
post #17 of 74 Old 01-28-2018, 02:11 PM
B T C's Avatar
Quoted: 669 Post(s)
Liked: 308
If you wanted the Yamaha AVR, you should do some more troubleshooting.
B T C is offline
post #18 of 74 Old 01-28-2018, 03:01 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
I tried with LFE = OFF and ON (both) and still having issue. I tried 4K UHD disc and there's a bit more thumping, but still nothing impressive. I also tried Musicast that's built in Yamaha to see if the content from Blu-ray player or Airplay or TV isn't being the issue. The music coming directly from Yamaha receiver's builtin Musicast still doesn't produce nice bass. It's almost like no matter what setting I change, the bass seems to come more or less from the Center and the Front speakers. It's such that I can shut the subs off (power off) and can't tell the difference in the same song/scene. I'm just learning things now and bought Yamaha cause of it's good review and with the hope that it'll be good enough out of the box.
I'm not sure what else can I try... I changed the cables, I changed the Level, Speaker Size, Trim and while there'll be slight differences, but nothing that I can feel. I saw how those woofer moves when I plugged in the cable from iPhone, it was like a thunder and had to pull the cable out quickly.
post #19 of 74 Old 01-28-2018, 03:05 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
Can u send me ur actual setting on the A3070 and I'll copy that to see if it works on mine... like, when I go to YPAO Speaker --> Manual Setup, what should I keep the Level, Configuration etc etc... plus the Trim and Subwoofer in the Sound setting.
thanks
post #20 of 74 Old 01-28-2018, 03:09 PM
torii's Avatar
Quoted: 3594 Post(s)
Liked: 2028
is there an on / off selection for subs in avr menu?
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #21 of 74 Old 01-28-2018, 03:09 PM
d-rail34's Avatar
Quoted: 450 Post(s)
Liked: 859
thanks
Here is what I suggested in your other thread in regards to your level settings...
If the sub gain shows levels from -10db to +10db then +10 would be the max gain. At -3 you're not even half way. Think of those levels as a dial and set it at around 1 or 2 o'clock. So +1, +2?. Then rerun your calibration and see what that sets the trim at on the AVR. You want it to be somewhere around -6 to -8 ideally. Then you'll have room to raise or lower them a few db if neccessary.
Your main goal here is to keep your subs trim levels in the negative numbers on your AVR so that you aren't drawing unneccessary power away from the speakers.
Also, as others have already stated, your subs should be set to LFE (120Hz. Leave as-is), FL/C/FR and surrounds should be set to small at around 80Hz. You can always tweak that if you feel it neccessary. Just make sure you don't lower them from what the calibration sets them at. Always go up and never down is how I was instructed.
FYI...I was exactly where you are a little over six months ago whenever I started researching for my setup. AVS has provided me with a great crash course in understanding how this stuff works...and I still feel stupid sometimes. Lol
Hope this helps.
Darrell
SuperFist likes this.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is offline
post #22 of 74 Old 01-28-2018, 03:10 PM
H Stevens's Avatar
Quoted: 173 Post(s)
Liked: 125
Did you go into the Configuration menu and select the proper configuration that coincides with your setup? Did you check in the configuration menu that you have two subs?
I have a Yamaha 2070 and a single Rythmik F12 and that little girl can whoop some *ss, so as others have said: something is wrong in your setup and I would suggest you start with the Configuration menu before running YPAO
H Stevens is offline
post #23 of 74 Old 01-28-2018, 03:12 PM
Gob Bluth's Avatar
Quoted: 248 Post(s)
Liked: 505
Have you tried changing listening modes on the AVR between stereo, Dolby Digital, DTS, Pure Direct?
Denon AVR-X3300W | Samsung UN65KS8000 | i7 6700K / GTX 1080 Ti HTPC
Front L/R: Klipsch RF-7 II | Center: Klipsch RP-250C | Surrounds: Klipsch RP-280F
Subwoofers: PSA V3601 | (2) PSA V1500 | Velodyne CT-120
Gob Bluth is offline
post #24 of 74 Old 01-28-2018, 03:25 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
No.
Hope this helps.
Darrell
I changed it to all the way up to +3 on the AVR and it does improve the bass a little bit. Yes, the sub LFE is OFF and FCR is set to Small at 80Hz.
Yes, the configuration menu shows 2 subs and I selected them as located in the Front Left and Right. You can see from the pictures that Yamaha knows where my Speakers are and what settings they're in.
Yes, I changed the "Program" which allows me to change settings, such as Movie: Sci-fi, Movie: Drama, Music: Concert Hall etc etc.
Please see the pics... the pictures were taken at a point in time and since then I've tried all different settings suggested, such as changing the Subs Level to +3 etc.
ID:	2352686   Click image for larger version
ID:	2352688   Click image for larger version
ID:	2352690   Click image for larger version
ID:	2352692   Click image for larger version
ID:	2352696   Click image for larger version
ID:	2352698   Click image for larger version
ID:	2352700   Click image for larger version
ID:	2352702   Click image for larger version
post #25 of 74 Old 01-28-2018, 04:08 PM
Liked: 2794
What are the max/min AVR (sub trim) levels on your Yamaha? If the minimum is -10, turn up the gain on your subs, rerun YPAO so that you have a -9 AVR sub trim on both sub channels (aim for 1DB below the max negative trim available). Then go into your settings and add 6db's hot to each sub channel. This should solve your issue. If not try doing a factory reset and repeat.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #26 of 74 Old 01-28-2018, 04:21 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
Subwoofer Trim is from -6db to 6db.
post #27 of 74 Old 01-28-2018, 04:25 PM
B T C's Avatar
Quoted: 669 Post(s)
Liked: 308
If you go into Manual Setup, what are the settings for Subwoofer 1 and Subwoofer 2? Are they enabled?
B T C is offline
post #28 of 74 Old 01-28-2018, 04:30 PM
Liked: 2794
Really thats it??? That doesnt leave much room to boost the trim and stay in the negative, my Integra goes from -15/+15 giving lots of play room. If thats the case aim for -5 or -5.5 then bump up to 0.
-Marantz SR-8012
-Yamaha BD-A1060
-Chane A-2.4 L/C/R
post #29 of 74 Old 01-28-2018, 04:36 PM
MIX_MASTER_ICE's Avatar
Quoted: 2669 Post(s)
Liked: 2477
Yamaha receivers have a seperate sub trim setting (+6to-6) independent from the sub level included with the speakers menu. I never had a Yamaha receiver that I really liked. The lower voltage sub jacks were always irritating to me.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
MIX_MASTER_ICE is online now
post #30 of 74 Old 01-28-2018, 04:40 PM - Thread Starter
Quoted: 58 Post(s)
Liked: 42
Yes
