Guide to Subwoofer Calibration and Bass Preferences - Page 41 - AVS Forum | Home Theater Discussions And Reviews
 2353Likes
post #1201 of 1411 Old 04-03-2019, 04:31 PM
bigzee3's Avatar
Quoted: 171 Post(s)
Liked: 122
Originally Posted by mthomas47 View Post
Hi,
First, I think it's a good call to believe that Audyssey can reduce your overall headroom somewhat, depending on how much it is pulling-up dips, compared to pulling down peaks. Audyssey attempts to compensate for that by allowing its software to pull-down peaks by up to 20db, but it can only pull-up dips by a maximum of 9db. Most rooms have both peaks and dips in the frequency response, so the loss of headroom from pulling-up dips, and the gain in headroom from pulling-down peaks, tends to even out. In your case, though, they may not even out, if you don't have many frequencies peaking to start with.
Second, although the graphs that you see aren't totally accurate (for instance, they only depict what Audyssey was trying to do, not what it actually did) they do indicate some issues that might be ameliorated with better subwoofer placement. Fortunately, fixing dips in the 40Hz to 80Hz range doesn't consume as much headroom, as fixing even lower dips would, but you might get better results if you experiment a bit more with sub placement and test the results with Audyssey calibrations.
Third, your volume level is pretty high. Combined with the sub boost you are using, you are putting a good bit of demand on your subs. Remember to keep your trim levels well in the negative range (say about -5) and use your sub gains to add most of your subwoofer boost, post-Audyssey. That will help to prevent clipping, which is a form of distortion, but one that might be harder to hear. Section II of the Guide explains gain/trim relationships in detail.
I definitely think that a couple of PSA V1510's would be a significant upgrade for the content and preferences you describe. The current line of PSA ported subs roll-off a little faster below 20Hz than some other subs do, but they are designed to have a lot of >25Hz SPL. I think that you would enjoy the upgrade, but remember that subwoofer placement is what causes the dips you are seeing in the before graph, and you would still want to maximize your pre-Audyssey response, even with the new subwoofers.
This is just something to experiment with. If you get serious about it, you might want to invest in a calibrated UMIK-1 and download REW. It's free, but takes a little time and effort to learn. You might, for instance, want to change the phase on one of your subs, in an effort to reduce cancellation currently occurring in the 40Hz to 80Hz range. But, I'm not sure that you will be able to do that successfully by ear, or just with an SPL meter. You can try though, by listening/measuring the volume of some test tones in that range, while adjusting the phase control on just one of your subs.
I think that trying to reduce the potentially large area of depression in your frequency response, between 40hz and 80Hz, will be helpful regardless of which subs you have, although the PSA subs will absolutely have a lot more native volume in that range than your Outlaw subs have.
Mike
Not sure if it helps but at -10 MV and DEQ off i boost bass 4db in the AVR which gets me to -5.5 in AVR. I've also done the 4db boost just using the sub gain and leaving AVR at -9.5. The only difference i can notice is that doing it using the sub gain instead of AVR gives it a more robust sound.Im guessing its because the sub amp is doing more of the work that way.
mthomas47 likes this.
bigzee3 is offline
post #1202 of 1411 Old 04-03-2019, 06:32 PM
darthray's Avatar
Quoted: 2100 Post(s)
Liked: 2996
Originally Posted by adam2434 View Post
darthray, mthomas47, and drh3b, thanks for the input.
Regarding phase adjustment to reduce cancellation, I thought that SubEQ HT was supposed to set the delay optimally. If I were to adjust phase on one sub 180 degrees (these subs only have 0/180 settings) prior to Audyssey calibration, wouldn’t SubEQ HT readjust the delay based on what it’s trying to achieve?
One thing I could try is to flip 1 sub to 180 degrees phase, rerun Audyssey, and see if the before plot is any better/different.
Regarding sub positioning, I am very limited in this room.
Current sub locations are in the front of the room – orange and green circles in the first pic. Note that picture is old and right before I added the second sub. Currently, The Outlaw X-12 is in the orange circle and the Outlaw LFM-1 is in the green circle.
My only 2 other placement options are:
1) Move both subs to the side walls, somewhat near the midpoints of the room, although not perfectly symmetrical – yellow and blue circles in the second pic. Running a sub cable to the blue circle would be a pain.
2) Or, keep one sub in one of the current orange or green front positions and move the other to one of the side wall blue or yellow circles.
I do have some concern that moving the subs to the side walls, closer to the couch, could cause localization for music.
Also, the couch is about at the midpoint of the room, which I believe is also less than ideal, regardless of sub positioning.
So, it this room, I feel like I have some real sub placement limitations and compromises, so that is why I was thinking that bigger subs with more headroom, combined with SubEQ HT equalization, might be a viable upgrade path forward.
Just for info, I agree with Mike to try the other locations placement before calibration.
Since you use REQ, it is a strong advantage you got over me.
Since I try different locations, run Audyssey and go by hear.
Repeat the process, until happy with the way it sound.
You are very welcome! Let's take some of those issues one at a time. First, with respect to room modes, your couch is not actually at the midpoint of the room. Some bass will escape to the space beyond your room, but the primary room modes are determined by the four walls which enclose the space, and not by the openings to other spaces. So, your couch location is not a principle factor in the mid-bass cancellation, in my opinion. If I'm right, that's a good thing, because that's a harder thing to fix!
FWIW, I think that you will get better overall sound quality, if you move your couch about a foot away from the wall, and put a painting or something absorbent on the wall behind the couch. That will help your mid-range and treble sound quality. Reading Section I of the Guide will help you to understand why that would be helpful, and you will also see some suggestions in that section about running a better Audyssey calibration. The bare wall directly behind your couch is a factor in what you hear, and in how Audyssey performs.
Second, I would experiment with other subwoofer locations before running Audyssey, and I would experiment with changing the phase on one of the subs after running Audyssey. It is important to understand that there is a degree of trial-and-error in all of this. You observe a large area of cancellation and try different methods of fixing it, without knowing in advance whether you can find physical locations which will work better. And, you won't know whether you will have localization either, until you try the placement you mentioned. Especially, with more than one sub in a room, nearfield placement of a sub can sometimes work very well.
The same thing applies to making changes in the phase on one of the subs. You just have to experiment to see if it helps. Audyssey sets the distance for each sub separately, but it EQ's the two subs together, based on their combined response. Where you know that you have a large area of cancellation, especially in a portion of the frequency range which is very important to you, you can experiment with a phase adjustment, or a distance adjustment for that matter, to see if it helps. The suggestions I am making are not just random ones, but I still can't tell you which subwoofer locations will work best, or whether a post-Audyssey phase adjustment will be helpful. You still have to experiment to find out.
I think that having better subs with more mid-bass headroom, does represent a good path forward. But, more headroom won't, by itself, fix a null. If the null remains after your Audyssey calibration, the new subwoofers will be able to play all frequencies louder than the current ones could, but that portion of the frequency range, which dips down, will still play softer than the rest of the frequency range played by the subs.
If Audyssey is fixing the problem sufficiently that you aren't aware of any loss of SPL in the mid-bass range (40Hz to 80Hz, in this case), then more capable subwoofers will absolutely give you more of what you want, and they won't have to work as hard to do it. In that case, I think that the two PSA subwoofers would be a great choice, because they are especially strong in the range you care most about. And, I would also expect you to notice an overall improvement in your bass sound quality with better subs.
If however, there is an ongoing issue in the 40Hz to 80Hz range that you are aware of, then some experimentation may be helpful to you, either with your current subwoofers, or with the new ones. That's really all I was saying.
We all decide for ourselves how much experimentation is enough. Some people really like to tinker with subwoofer placement, and with other things including measurements, and many others just like to put subwoofers where they seem to fit and work fairly well. I think that there is no absolute right or wrong answer to any of this--just the answer that your own sense of curiosity, and/or level of satisfaction, dictates.
Mike
Very well said!
While I like to experiment with locations, and AVR/Sub settings.
It come a time, when fishing in the dark for the best results.
Without a tool like the REQ. Can become a very difficult thing to do.
Since my bass sound good by hear after calibration, therefore happy.
Is there room for improvement, more likely.
But will not happen until, I understand how to use something like REQ. Due to my lack of skill for computer/laptop stuff
Ray
darthray is offline
post #1203 of 1411 Old 04-03-2019, 10:42 PM
Liked: 5
Originally Posted by legierk View Post
Thanks Alan. Yep, I am gonna bypass (disable) PEQ for subs and re-run Audyssey. THEN I will break out REW and check on things. It will most likely be towards the weekend. My days are pretty full. Thanks for the continued assistance. Keith
I gave up using PEQ in my miniDSP 2x4-HD, now I use it only to time-align both subs, without Audyssey on, and save that setting. I’ll run Audyssey and let it set the filters. In the AVR. Once done, I’ll save another config file in slot 2 in the 2x4 with the Audyssey DynEQ AVR settings I like for a “daytime.xml” file, and load that daytime settings file again, but in slot 3 — I open the outputs side of the 2x4, and turn on the compressor (even the default compressor “on” values are pretty good), I turn down level for each sub -6dB or so, and change the low pass starting at 20Hz up to starting at 60 Hz or so. Amazing how my mind “adds” the missing bass while not messing much with the upper frequencies. Best, it does not disturb the upstairs neighbors, and I love my neighborhood, so being a good downstairs neighbor has value to me.
That setting, then I save as “nighttime.xml”
I rarely use my Denon AVR “low frequency containment” setting, since the result sounds “emasculated” compared to the miniDSP method above. (Forgive the unintended gendering implication of my word choice. )
—Thumprchgo
a.k.a., Mark, Prairiedawg, OldCrankInTheBack
Setup: Mostly plebeian, but carefully curated.
Denon AVR-X4400H, 9.2; Audyssey MultiEQ-XT32
Polk Audio RTiA series for L/C/R,
FXi series for Side Surrounds,
OMW5 for on-ceiling Atmos, at 5.2.4
Polk DSW-550 subs, two.
AppleTV 4K, Fire Stick 4K, QNAP NAS,
nanoAVR-DL (useless, don’t get me started)
MiniDSP 4x2HD for sub EQ and time-alignment
LG 55” 4K Dolby Vision
Innumerable beads of sweat
Thousands of frustrated, misspent hours
And one radiant smile just up ahead, off in the gloaming...
(Sent from my tablet)
darthray, legierk and mthomas47 like this.
thumprchgo is offline
post #1204 of 1411 Old 04-05-2019, 08:24 AM
legierk's Avatar
Quoted: 169 Post(s)
Liked: 144
—Thumprchgo
Interesting. My Dayton Audio DSP-408 does not have a compressor. Would have been a nice feature. One of the features I like with it however is the ability to use my phone via bluetooth to adjust things. I really just adjust levels, but could also adjust delay and PEQ if I wished.
I listen to alot of two channel music in my living room (where the DSP-408 is), with Audyssey, no DEQ. I find bass content varies GREATLY from record to record. I use my phone to adjust the subs outputs subjectively to get it full. Most of the time I can leave levels at the default values. But, just yesterday, I listened to TNT: Encore Live in Milano, just released. The kick drum was really hurting one of the sub drivers. This driver has a slightly rubbing voice coil and needs to be replaced (again). At any rate, I had to reduce both sub levels significantly for it not to overwhelm the rest of the music. I prefer this however, to having to crank the subs just to hear any bass at all.
legierk is offline
post #1205 of 1411 Old 04-05-2019, 09:11 AM
Liked: 5
Oh! Whoops, I was unclear, sorry.
I use a DSP EQ box (miniDSP 2x4HD) that sits between my Denon AVR’s two sub RCA outputs and the subs RCA inputs themselves. This box can time-align the 2 subs, (with REW, RoomEQ Wizard.)
After that calibration, then I run my AVR’s built-in Audyssey program. The little miniDSP box can load files with different parameters that only affect my subs. That’s why I have a daytime setting, and a nighttime be-considerate-of-neighbors setting. It’s the mini that has compressors that can be adjusted to kick in a certain levels and stay in until the movie quiets below a threshold I can tweak, and save as text files on my laptop.
I now have a “nervous friends” setting to use when friends who live in paper thin walled apartments come to watch a movie at my place and worry the upstairs neighbors will bang on the ceiling! I’ve lived here nine years, and it’s never been a problem in this old, brick building built more than 100 years ago..
post #1206 of 1411 Old 04-10-2019, 05:06 PM
bearr48's Avatar
Quoted: 21 Post(s)
Sub mis-match
Hoping for some advice...I recently moved and now have a more-or-less rectangular room. Front wall center is a PB-13U, back wall center is a PC12+. Hoping to use this sub arrangement to cancel the length mode peaks @ 32, 64, 96 Hz at the mlp (12' back from the front, as far as the very low frequencies are concerned).
Since I can't yet locate my calibrated SPL meter, I ran some tests using a flat signal generator and my ears. Running each sub by itself in a appx 1500 ft3 room, I find that the PB 13U has good response down to 20 Hz, while the PC12+ (all ports open & 20 Hz tuning) falls off dramatically below 25 Hz. Tried plugging one port and setting PC12+ tuning to 16 Hz, no audible change in room response, still rolls off below 25 Hz.
Should I: figure that the PB13U will "take up the slack"; start saving for a better sub to replace the PC12+; decide to live with 25 Hz as a low-end? The system is not yet set up, so I can't yet drive both subs together thru the Marantz receiver. Your thoughts would be gratefully appreciated. And thanks so much for the thread; still going through it!
Jack
bearr48 is offline
post #1207 of 1411 Old 04-10-2019, 06:35 PM
darthray's Avatar
Liked: 2996
Jack
Hi Jack
How old is your Marantz AVR, and does it have a calibration system like Audyssey?
If it has Audyssey, it might show you a more truthful reading.
That said, Audyssey will do it's corrections for the lesser sub (PC12, in your case).
From my previous subs, two PB12Plus/2. I did not mind the 25Hz setting (Original tune).
With my two present PB13-Ultra, it is now set at 20Hz (also original tune).
While they go deeper, they also open a lot more vibration problems in my room.
Could I live again with a 25Hz tune, Yes. Do I like the 20Hz, also Yes.
Since I am not a person that prefer very low bass, and prefer the chest slam of the mid bass. I could live with both settings.
Just to point out, this is my preference for bass sound. And my personal opinion.
For living with a 25Hz extension. It depend on you.
To save some money, to have a better match to your present PB13. For achieving lower extension, perhaps a new (PB3000 or 4000 may work very well).
Just can't remember at this moment witch one is a better match for the PB13
Ray
darthray is offline
post #1208 of 1411 Old 04-10-2019, 07:48 PM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Quoted: 5383 Post(s)
Liked: 10079
Jack
Hi Jack,
First of all, you are very welcome for the Guide and for the thread, and I'm glad to hear if it is helpful to you. One thing you didn't seem to mention is whether the two subs in conjunction play audibly below 25Hz? When you play both subs at the same time, does their combined sound roll-off below 25Hz, or does the PB13, in either the 20Hz mode or the 16Hz mode, still carry the <25Hz sound?
That's an important question. Intuitively, I would expect the two subs to work better together if they are both in the same 20Hz mode. The PB13 will have a slightly deeper tuning frequency than the PB12+ if they are both in the one-port extended mode. And, that may cause some cancellation below 25Hz or so.
It is possible that the position you selected for the Plus simply has a room mode that causes the sub to have cancellation below about 25Hz. You could try some other positions for that sub in hopes of finding a location where it will be able to play lower. Slightly corner-loading it, for instance might help with that. (The sub doesn't have to be pushed all the way back into a corner to benefit from some additional boundary gain. You just have to experiment.)
Sometimes, we try sub positions which should work the best, in theory, and they simply don't. Some additional placement experimentation is then required. You might also try adjusting the phase on your Plus to see if that makes any difference. That also can't be predicted in advance. But again, it is the combined sound and frequency response of the subs that you really want to concentrate on. Their individual response is not really the issue. It's how well they work together that counts. Personally, I would want to hear/feel the frequencies below 25Hz. It can make a lot of difference for 5.1 movies.
Darth's question about Audyssey was a good one. If you have a system of automated calibration and room correction built into your AVR, that may be able to help you. Ultimately, I think your best solution is to try to find another PB13 (or PC13). Ideally, you want to be able to have identical subwoofers, and if you want more low-frequency performance, the one-port extended mode would be the best way to get it. But, when two subs have different port tunes, as your current subs do, the extended mode may not be the best bet, because the different port tunes may cause some cancellation.
I think you can try to find a better location for your Plus (and perhaps try changing the phase on the Plus). You can try to replace the Plus with another PB13, or you could replace both subs with something new, such as the PB4000. I also think it's possible that you could replace the Plus with a PB4000, and get better results with the two different Ultra models. But, I'm not sure about that. I would discuss that option with Ed Mullen directly, and not just with whomever happens to answer the phone at SVS. If you email Ed, you can arrange to talk on the phone, or you can try to call him directly.
In general, identical subs work best, but the older PB13 and the newer PB4000 may be close enough to work well together. I would trust Ed's advice on that. I hope this helps!
Mike
darthray likes this.
GUIDE TO SUBWOOFER CALIBRATION AND BASS PREFERENCES
* The Guide linked above is a comprehensive guide to Audio & HT systems, including:
Speaker placements & Room treatments; HT calibration & Room EQ; Room gain; Bass
Preferences; Subwoofer Buyer's Guide: Sealed/ported; ID subs; Subwoofer placement.
mthomas47 is online now
post #1209 of 1411 Old 04-12-2019, 12:27 PM
bearr48's Avatar
Quoted: 21 Post(s)
Sub disparities, room resonances, etc
Thank you, Ray and Mike for your valued insights, and for all the help you've provided to us in the community.
I don't yet have my Marantz SR7011 hooked up, so cannot run both subs together just yet (nor use Audyssey MulteqXT32)...but I suspect that the PB13 will still produce strong bass to 20 Hz, and the PC12+ will not. Both are set to 20 Hz, all ports open.
Probably will be lusting for another PB13U or a PB4000 (which SVS says is the best match).
The lowest room mode for a 17' 8" length should be 32 Hz if I understand this correctly. Wanting to put the main listening position abt 3/4 back from the front wall, and take advantage of room mode cancellation per Floyd Toole's book Sound Reproduction (third edition, Chapter 8, Sec. 8.2.6). If that arrangement of subs being located center of front and back walls doesn't help much, then I'll be free to try other sub locations. Hoping to let Audyssey XT32 deal with other room modes, at least up to the transition frequency.
Which brings up another question, semi-off-topic: my receiver is compatible with Audyssey smartphone app, which allows limiting Audyssey eq to frequencies below a user-set limit. There is some controversy about that...what's your take on it? And thanks again!!
Jack
darthray and mthomas47 like this.
bearr48 is offline
post #1210 of 1411 Old 04-12-2019, 01:26 PM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Liked: 10079
Jack
You are very welcome, Jack! I think your initial starting positions sound fine. It's just that you won't know what you like best until you actually try them with your new sub, and with XT-32.
There are two different issues involved with respect to the app. The first is whether you want to limit the use of automated room EQ above a certain frequency. That is strictly a YMMV issue, to be decided on the basis of either theory or experimentation, depending on the individual. The second issue involves the current below 20Hz roll-off that the app provides. Most people consider that feature a glitch, and I understand that a software update, in the very near future, will allow users to disable that feature.
I won't take a strong position on the use of room EQ, above a particular frequency, because I think it depends on too many room, speaker, listener factors. That's why I called it a YMMV issue. Speaking personally, Audyssey works very well for me, full-range. To be fair, I also have a good acoustical starting point in my room, and a lot of experience in using Audyssey.
But, I would definitely not want my subs to roll-off below 20Hz in my room. And, I would always want to have the choice, even if I intended for them to roll-off. Darth, for instance, wants his subs to roll-off below about 25Hz, due to excessive room rattles in his HT. I completely understand that, and I might make the same choice in his room.
But, for those of us who don't have specific reasons for preferring a <20Hz roll-off, there is an awful lot of very low-frequency entertainment to be found in many 5.1 movies. I personally enjoy both the low-frequency sounds and the tactile sensations, and I absolutely wouldn't want my subs to roll-off below 20Hz, due to the operation of the Audyssey app. But then, my room is built like a tank in terms of rattles. I hope this clarification helps!
Mike
post #1211 of 1411 Old 04-12-2019, 07:32 PM
darthray's Avatar
Liked: 2996
Mike
Very true!!!
And I am sure, I am missing a lot from all the posts mentioning very low frequency
Jack
First, you are more than Welcome
Mike and I do-it for our love of Audio, and trying to help out from our knowledge for this Hobby that is slowly dying for convenience (side story, I was told today to move on with time [just bought a flip phone], my reply was [sure, I will watch from now on movies, on a big smart phone instead of my 10ft screen with 11 speakers and 2 subs] it was the end of this conversation).
That said, I really need to order this book since it will be a very good read.
https://www.amazon.ca/Sound-Reproduc...r=8-1-fkmrnull
And I am sure, I will learn new things
While pricy, it might save me money for my future subs. Or push me to a next level of enjoyment with my room
Either way, money well spend!
Thank you, for mentioning this book again!
Forgot many time, to add-it to my Favourite to order-it
Ray
mthomas47 and skypop like this.
darthray is offline
post #1212 of 1411 Old 04-18-2019, 10:26 AM
eBalita's Avatar
Quoted: 21 Post(s)
Exclamation Audyssey says use only 1 output on the AVR
https://audyssey.zendesk.com/hc/en-u...tup-and-MultEQ
In answering the question: "If I have 2 subs, and only 1 output on the AVR, could i use the sub equalizer to integrate both subs into the HT? "
Audyssey Labs on May 17, 2010 11:59 responded: Yes, that is the preferred method even if you have two sub outputs on the AVR.
So use a Y splitter even if you have 2 outputs?
Do you agree?
eBalita is offline
post #1213 of 1411 Old 04-18-2019, 01:47 PM
Alan P's Avatar
Quoted: 6148 Post(s)
Liked: 5376
Do you agree?
Simple answer (that I am sure will be expanded upon) is:
If your AVR can independently calibrate dual subs, and the subs are placed randomly around the room...use both sub outputs.
If your AVR can independently calibrate dual subs, and the subs are placed near the front speakers, equidistant to the MLP...use a single sub output.
If your AVR cannot independently calibrate dual subs, it does not matter.
Alan P is online now
post #1214 of 1411 Old 04-18-2019, 02:31 PM
eBalita's Avatar
Quoted: 21 Post(s)
Denon S740H
I have a Denon S740H.
eBalita is offline
post #1215 of 1411 Old 04-18-2019, 03:38 PM
Alan P's Avatar
Liked: 5376
Only Audyssey MultEQ on that AVR, no SubEQ HT, so your dual sub outputs are in reality an internal y-splitter. Each output gets the exact same signal.
post #1216 of 1411 Old 04-18-2019, 04:19 PM
eBalita's Avatar
Quoted: 21 Post(s)
Ok. Thank you for taking time to respond.
eBalita is offline
post #1217 of 1411 Old 04-19-2019, 05:32 PM
darthray's Avatar
Liked: 2996
+1
And would require manual volume matching for each sub, and phase control for the distance.
If having the money to upgrade your AVR, to one that do Audyssey XT32.
I would go that road, since after trying to explain the real basic of adjusting the volume for each sub. And there phase control manually on each one.
Unless having lots of basic old school knowledge, it is hard to explain on paper. As seen on this thread;
https://www.avsforum.com/forum/113-s...ind-tv-ok.html
The way an AVR that can do Audyssey XT32, and other calibration system that do two subs (true two sub output, not an internal Y-splitter).
Work that way, on the first sweep of the calibration. It figure out the volume control for each subs (might mention one or both subs, need to be turn-up or down before proceeding to make the sound level closer).
Then the phase for the distance between other and your other speakers, than do a calibration of your room as one sub.
Why one sub, movie/music recording only have only one bass sound track output (the .1).
While my Marantz 7702mkII, say 11.2
It only mean two independent sub cannels, for the first sweep of the calibration.
(To figure out the volume and phase of each subs, after that it does the calibration as one sub, as mention in my previous paragraph).
I use to say, I got a 7.4.2 system. I now say 7.4.1 (two subs) system.
Ray
darthray is offline
post #1218 of 1411 Old 04-29-2019, 01:31 PM
bearr48's Avatar
Quoted: 21 Post(s)
Measurements are better than ears sometimes
Hi folks!
I found my SPL meter, and what a revelation. My PC12+ has useful output to below 20 Hz, and will keep up with my PB13U until the volume demand is too great for the little guy!
Positioning subs to cancel room mode resonance does work, I am pleased to report. I've been using a flat signal generator and the SPL meter from abt 15 Hz to 90 or so, then hooked up front L & R towers and ran Audyssey Iphone app. It told me to reverse the polarity to the towers. I dutifully complied, but found out that caused a huge suck-out between abt 70 to 90 Hz, so flipped polarity back. The app did a nice job of flattening lower bass response, but in the range where the towers are crossing in, there is a rise of 6 dB @ 60 Hz, and +8 dB @ 75 Hz. Looks like I'm gonna have to learn how to use some parametric dsp eq. Thanks again for this wonderful forum.
Jack
bearr48 is offline
post #1219 of 1411 Old 04-29-2019, 06:18 PM
darthray's Avatar
Liked: 2996
Hi folks!
Jack
Hello Jack, thanks for your post and sharing your findings.
For the polarity on your towers, sometime time Audyssey get confuse if having a 4 ways design. Mine is consider 4 ways design, Aperion Verus Grand Tower;
https://www.aperionaudio.com/collect...-tower-speaker
Been an MTMWW design. What happen, is sometime the designer put one of the M (mid driver). In a reverse polarity, to take care of what some MTM problem suffer (way above my pay level, to understand).
That said, Audyssey pick-it up, and the reason it say to reverse-it. Has you saw, not always for the best.
The first time it happen to me, I contacted Aperion to check if there was something wrong with my towers.
This is where, I learn that one mid was in reverse by design. So I ignore Audyssey, and continue with the calibration. Work out very well.
Since then, I did many calibration. I got this warning around 20% of the time, the other 80% I do not.
Could be a variations of a few inches, for the microphone positions during calibration.
Like you, I like to use a SPL meter. Been old fashion and sometime having a hard time to understand better tools, like REW.
Since I cannot find my old test CD, I will order this CD to get ready for my new subs;
https://www.musicdirect.com/optical-...hile-test-cd-1
Mostly, for tracks 20 to 31. And will listen to the first 19 tracks, before and after calibration to see if I can hear a difference.
Ray
mthomas47 and bearr48 like this.
darthray is offline
post #1220 of 1411 Old 05-02-2019, 12:10 PM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Liked: 10079
Hi folks!
Jack
Hi Jack,
That's good news that your two subs seem to be working well together! Are you saying that you are measuring a 6db increase in SPL at 60Hz, and an 8db increase in SPL at 75Hz, compared to frequencies above and below that, after running Audyssey? If so, that's very strange. Audyssey's goal is to make all frequencies play +/-3db from 75db when it sets its filters. And, it can pull down peaks by up to 20db. What it can't do, though, is to EQ the speakers in relation to the subs. It EQ's each channel individually. The subs are all EQed as one, as part of the .1 LFE channel.
I don't know where you are crossing from your front speakers to your subs. If your crossover is lower than 80Hz, I would raise it to at least that number, and I might also try 90Hz. I assume that you are running your front speakers as Small and that you aren't using LFE+Main. That feature can mess things up sometimes (often). I really wouldn't like hearing that much extra mid-bass, so I think it would be worth experimenting a bit to see if I could get rid of it.
You can certainly try to use the PEQ built into your SVS sub to see if you can pull down those peaks, but it would be useful here to be able to measure your frequency response with REW. I assume that you can hear the extra mid-bass in the 60 to 75Hz range as well as measure it with an SPL meter? Don't forget that most uncalibrated SPL meters will lose volume as they try to measure lower frequencies, so unless 60-75Hz measures louder than 100Hz or 120Hz, then you may just be seeing the limitations in your SPL meter; especially if you can't really hear that much more mid-bass.
If you do decide to implement some independent PEQ to try to pull down those frequencies, I might consult with Ed Mullen first, if I were you. I hope this helps!
Mike
post #1221 of 1411 Old 05-03-2019, 10:42 AM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 90
When choosing a sub, how much consideration is it worth giving to built in PEQ? My receiver has Audyssey X32 and dual sub outputs. Right now I have 1 sub, but I'm planning to add a second and then once duals are established as essential upgrade my old sub as well.
I currently don't have a calibrated mic, just a cheap SPL meter. When considering subs in the $900-1500 range like SVS, HSU, Rhythmic, PSA, Paradigm brands, how much sway would included calibration features have for you? I have looked at stuff like miniDSP and REW, but those do increase cost and difficulty level which I'd rather avoid. A big reason I'm going to add a 2nd sub is to smooth the bass response in the room, which I'm hopeful will be more effective than adding software and acoustic treatments.
Denon X4300H; Sony XBR75 900E; Definitive Technology RLS-II/DI 5.5LCR/DI 5.5R; NHT SW12
GoZags13 is offline
post #1222 of 1411 Old 05-03-2019, 11:24 AM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Liked: 10079
Hi,
You will inevitably get different responses to this type of question. Some people are willing to go to great lengths to improve the sound quality in their rooms. Others prefer to keep things simple. If your preference is to keep things simple, then I wouldn't give a great deal of weight to having as much built-in PEQ in your new subwoofers. I would speculate that most listeners don't use all of the available options that their more complicated subs provide, in the same way that most of us (including myself, for sure) probably don't use all of the available functions in our smartphones.
Audyssey is not entirely simple in itself. There are some tips on how to achieve a good Audyssey calibration in Section I-B of the Guide. And, there are a lot of post-calibration settings that can be experimented with, once a successful calibration has been performed. So, just using Audyssey effectively will keep you busy for a while. And, XT-32 is usually pretty effective at EQing our subwoofers, as long as we start with fairly good subwoofer placement. There are some tips on subwoofer placement in Section VIII-E.
So, I probably wouldn't worry too much about which subwoofer models have more built-in PEQ, compared to other models. I would make my selection more on the fundamental from factor and performance characteristics of the subs. If I were planning to buy two good subwoofers, however, I would not buy a second sub like the one I have now, and then try to sell both of them in order to upgrade to better ones in the $900 to $1500 range. I would just start with one good sub, and/or buy two at once, if you can afford to do that.
I suspect that you just want to test the waters with a second sub before committing yourself with more expensive ones. But, the difference between older or cheaper subs, and newer ones in the >$1000 price range, can be pretty substantial, especially with low-frequencies (<30Hz). If I were you, I wouldn't waste my money trying two cheaper subs. I can already tell you that two good subs, which are well-positioned are almost always better at smoothing the frequency response than a single sub. There are exceptions, but in most rooms the exceptions are fairly rare.
Will good dual subs and XT-32 satisfy you? If you are like most people, they should. The people who want to dive more deeply into the rabbit hole with REW and miniDSP's are still very much in the minority, even on AVS, and most of them are probably aware of some latent curiosity even before they start that dive. If you really want to keep things fairly simple, then I think you would be going about it in the right way with two good subwoofers and XT-32. And, if the ones you select happen to have more built-in PEQ than some other comparable models, that will just be a bonus and not a necessity.
I hope this helps!
Mike
Alan P, darthray, Spidacat and 1 others like this.
post #1223 of 1411 Old 05-03-2019, 11:42 AM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 90
Thanks for the insights, yes it helps! I currently have 1 sub (NHT SW12), and want to add 1 quality ~$1000 sub now to test duals. Then in the future I'll replace the NHT with a matching sub. In an ideal world I'd buy duals now, but I can't really swing that cost and as you said, I'd much rather have 1 quality addition than 2 meh ones.
GoZags13 is offline
post #1224 of 1411 Old 05-03-2019, 12:06 PM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Liked: 10079
You are very welcome! I agree with you about having one quality sub rather than two meh ones. I considered the possibility that you would buy one better sub now, and try to pair it with your existing NHT sub, but I was hoping that was not what you had in mind. Dissimilar subs (and especially ported subs) can be very difficult to integrate. I read a 2005 review of your sub from Ed Mullen, before I replied to your first post.
Your current sub rolls-off very fast below 30Hz. If you pair it with a better sub, with much improved <30Hz performance, the two subs will almost certainly cancel each other from at least 30hz down, and you will probably get even less low-bass than you have now. If they do cancel each other, XT-32 won't be able to help with that.
If you want to buy a good single sub now, and a second one later, then I would recommend that you just run the single sub by itself. I know that sounds counterintuitive. Wouldn't two subs be better than just one? Unfortunately, where ported subs are concerned, they wouldn't be. Sealed subs with different performance characteristics can be mixed a little more easily, although the results can still be unpredictable. But, with ported subs, mixing subs with different port tunes and different roll-off characteristics, or mixing ported and sealed, can lead to more problems with the frequency response, instead of fewer problems.
I would pick the new sub I like best. Section VIII-A has a sub buyer's guide that may be helpful. Try the new sub by itself first to see how you like it, and of course run Audyssey. (You can always add in the older sub after a while, once you have established a good listening baseline for the single new sub. You will need to rerun Audyssey when you do that.) Then, once you are ready or able to take the plunge on the second sub, just do it. It will require some leap of faith at that point, but I am skeptical that you will get good results by mixing your SW12 with any of the good $1000+ ID (Internet direct) subs. So, that won't really be a fair test of dual subs.
Mike
Alan P, darthray and bearr48 like this.
post #1225 of 1411 Old 05-03-2019, 02:07 PM
GoZags13's Avatar
Quoted: 174 Post(s)
Liked: 90
Wow that's good information to know, I had not considered or heard of that before. The roll off below 30hz is the key reason I'm wanting to upgrade, it is very noticeable.
mthomas47 and thumprchgo like this.
GoZags13 is offline
post #1226 of 1411 Old 05-03-2019, 03:51 PM
darthray's Avatar
Liked: 2996
To get one better sub, instead of two lesser one at the moment is the best way to go.
Cheaper in the long run, while I understand you like to experience with dual at this moment.
I would just use your new sub, and enjoy at the present time. Until you can afford a second one.
As Mike said @mthomas47, matching different subs can be problematic. Due to lower frequencies roll off, and often end-up for the worst.
That said, moving to a much better sub, than your current one. Even playing by itself for now, should be a big improvement over your current SW12.
Making the waiting time, a lot more comfortable
Ray
darthray is offline
post #1227 of 1411 Old 05-03-2019, 11:29 PM
jconjason's Avatar
Quoted: 1165 Post(s)
Liked: 1995
Ray
I will third this suggestion. I too was once in the OPs shoes. I had a Klipsch sub and wanted to use the dual sub output on my Denon 6300, so purchased a HSU VTF 3mk5. After rerunning Audyssey with both subs, I was left wondering why there was no substantial gains. After research I learned the lesser sub just drags down the better sub. After removing the Klipsch, my HSU came to life. I'm currently very pleased with just the one but of course would love to add a second HSU when funds allow.
Just thought my experience could be helpful to @GoZags13
darthray, mthomas47 and GoZags13 like this.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #1228 of 1411 Old 05-04-2019, 01:32 PM
darthray's Avatar
Liked: 2996
Thanks for sharing your experience.
Post like this one can be very informative, for someone like the OP @GoZags13 and other members in the same situation.
And also for making an educated decision, from other experience in the same situation.
Ray
mthomas47 and jconjason like this.
darthray is offline
post #1229 of 1411 Old 05-05-2019, 09:15 AM
Rise & Grind
dinamigym's Avatar
Quoted: 299 Post(s)
Liked: 282
Hi, I'm purchasing 2 Rythmik FV25HPs. They will be placed in the the rear of my dedicated media room which is 15' wide x 28' deep (8' ceiling), carpet over concrete slab. My processor is a Marantz AV8805. For integration purposes would I be better off using the two sub outs on the Marantz (one for each sub) or one sub out and connecting the two subs together by XLR?
Note: the subs will basically be right next to each other centered on the rear wall of the room...so pretty much exactly equidistant from the MLP.
Thanks for any help/thoughts?
dinamigym is online now
post #1230 of 1411 Old 05-05-2019, 09:44 AM - Thread Starter
AVS ***** Member
mthomas47's Avatar
Liked: 10079
Hi,
Congratulations on your new subs! In theory, running each sub into a different sub out in your AVR should give you identical results to using a Y-splitter into a single sub out. In practice, trying just a single sub out often works better, as it requires Audyssey to do a little less processing. Mark Seaton has always recommended trying this method first, when subs are on the same wall and equidistant from the MLP.
Since your subs will not only be equidistant from the MLP, but will also be essentially acting as one sub anyway, due to their side-by-side location, I think that using just one sub out will introduce one less potential variable into the equation. So, that's what I would try if I were you.
Mike
darthray and dinamigym like this.
