Buttkicker LFE for movie. Receiver or Amp - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #61 of 106 Old 03-28-2018, 03:26 AM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
Originally Posted by keeper View Post
You could be waiting awhile.
I probably will.
And you Keeper?
You have the Earthquakes already. Are you going to wait, of are you trying an Amp and ship it back if not satisfying enough?
Candle is offline
post #62 of 106 Old 03-28-2018, 03:43 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
I probably will.
And you Keeper?
I’m looking and weighing my options. I’d like to pick up something relatively soon. I’ll post back when I have things hooked up.
keeper is offline
post #63 of 106 Old 03-28-2018, 09:39 AM
T100's Avatar
Quoted: 62 Post(s)
Liked: 37
Here the email I received today,
Hi Charles,
We are working on refreshing the BKA1000 amplifier and working towards having it available later on in the spring. You can signup for our mailing list at TheButtKicker.com.
Andrew Luden
Business Development / Marketing
The Guitammer Company
tel.614-898-9370 ex.103
fax.815-346-9532
www.thebuttkicker.com
www.guitammer.com
Marc Alexander likes this.
T100 is offline
post #64 of 106 Old 03-28-2018, 03:28 PM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
So I just purchased a used bka1000r at a good price to use with the earthquakes. Should install them early next week. I will report back.
keeper is offline
post #65 of 106 Old 03-28-2018, 11:46 PM
Dolus's Avatar
Quoted: 83 Post(s)
Liked: 66
Owning a BKA1000-N I was curious what a 1000-R was but I could not find it at all. Are you sure it is not a 1000-4 you have bought.
If you are interested here is a review of the 1000-4
https://hometheaterhifi.com/volume_1...er-9-2003.html
The only obvious difference I can see is that the 4 has selectable voltage switch on the rear panel while the N does not.
keeper likes this.
Denon AVR-X6400H,Sony KDL50W829 ,Virgin Media V Box HD, WDTV, PS3, Philips DVP9560, Marantz CD67, BK Monolith Plus x 2, KEF TDM 23C,23F & 34DS, Jamo D500, Darbee Darblet, Belkin F9G6223uk3M, Buttkicker LFE kit, IsoAcoustics L8R430, Mede8er 800X3D, Behringer B1200d, AC Infinity Aircom T9
Dolus is offline
post #66 of 106 Old 03-29-2018, 01:58 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
Oops, sorry you are correct. It’s the 1000-4. I purchased this for well below $200 shipped. Didn’t want to spend a lot on an amp for shakers since this amp is rated so highly. Will check out the new Buttkicker amp this summer.
keeper is offline
post #67 of 106 Old 03-30-2018, 07:54 AM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
Should install the BKA1000-4 early next week. I will report back.
Can hardly wait, for your experience.
Candle is offline
post #68 of 106 Old 04-01-2018, 04:16 PM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
So I just wanted to give a quick update. I’ve been working on my first chair using one earthquake MQB1. Unfortunately I don’t really have any great spots on these theater chairs to mount transducers. So I attached a piece of oak board to the metal bottom frame. Off center because the recliner mechanism is right down the middle. My bka-1000 hasn’t come in yet so I’m using an old Sony 100 watt receiver. First impressions are very good. I use a v1801 sub right behind my middle recliner and these earthquakes give a similair effect. It’s like @markmon1 said “ it’s like having a giant sub firing into the back of the chairs”. My only issue is that because I had to mount off center I get more vibration off one side of the chair. I might install two per chair and wire them in parallel 4 which I believe will be 2 ohms which the buttkicker can handle no problem. These things don’t need a lot of power for a great effect.
keeper is offline
post #69 of 106 Old 04-02-2018, 12:39 AM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
So I just wanted to give a quick update. I’ve been working on my first chair using one earthquake MQB1. Unfortunately I don’t really have any great spots on these theater chairs to mount transducers. So I attached a piece of oak board to the metal bottom frame. Off center because the recliner mechanism is right down the middle. My bka-1000 hasn’t come in yet said I’m using an old Sony 100 watt receiver. First impressions are very good. I use a v1801 sub right behind my middle recliner and these earthquakes give a similair effect. It’s like @markmon1 said “ it’s like having a giant sub firing into the back of the chairs”. My only issue is that because I had to mount off center I get more vibration off one side of the chair. I might install two per chair and wire them in parallel 4 which I believe will be 2 ohms which the buttkicker can handle no problem. These things don’t need a lot off power for a great effect.
As soon as the BKA1000 is in, you have more tuning possibileties.
Do you have Pacific Rim?
It seems that with the heartbeat scene, you can tune the delay really good.
keeper likes this.
Candle is offline
post #70 of 106 Old 04-02-2018, 01:25 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
My delay will be fine hopefully as I have a nearfield sub that I will be splicing into. The biggest thing with these transducers are having a good place to mount. 1 is pretty potent but in my situation I just have limited places to mount. 1 shakes the chair really well with a low power amp. These earthquakes are no joke. They are tiny but do the job.
keeper is offline
post #71 of 106 Old 04-02-2018, 02:36 AM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
If you connect it parallel on you sub, it will probably be in sync.
I was thinking about only using 1 Earthquake MQB1 for each sofa, placing it in the middle of a two seater, but that is a no go?
Candle is offline
post #72 of 106 Old 04-02-2018, 04:18 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
[QUOTE=Candle;55959830]If you connect it parallel on you sub, it will probably be in sync.
I was thinking about only using 1 Earthquake MQB1 for each sofa, placing it in the middle of a two seater, but that is a no go?[/QUOTE
You might have more tactile toward the middle and little on the ends. It’s all about experimenting. My issues is not having a good spot to mount. Of course it will depend on how much shake you want. If I could attach to wood base 1 would be enough per chair.
keeper is offline
post #73 of 106 Old 04-02-2018, 09:56 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
Well one chair done for now. Took me many hours lol. On my cHairs there are not many good places to mount transducers. No wood on base just steel. I looked over the Crowsons thread with some guys that own the same chair as me. They found that attaching to the steel frame gave best results, so that it what I did. I first tried one earthquake and that shook the seats very well but most of the shaking was done on one side of the chair. Today I added a second and that made all the difference. My Buttkicker 1000 came in today so things are great. I’m tweaking the level as I find lower is better, especially with two transducers. My plan is to purchase two more and add to my other seat. As I understand it the amp can handle close to 2000 watts on a 2 ohm load. Combining 4 8ohm transducers in parallel would make a 2ohm load I believe? I’m new to transducers and more complex wiring but I think I have everything set up correctly. Thanks to those that recommended the earthquakes. They are pretty awesome. I was lucky to buy both the earthquakes and buttkicker used so I don’t have a ton of money into this.
ID:	2383934   Click image for larger version
keeper is offline
post #74 of 106 Old 04-02-2018, 12:39 PM
Marc Alexander's Avatar
Quoted: 5360 Post(s)
Liked: 4859
It's nice to see the Earthquake TTs getting some love. IME their build quality is far superior to Buttkicker's. Their torque multiplying brackets also make a big difference. I'm guessing Earthuake has a patent which is why we don't see other similar brackets. If I had access to my subfloor I would install a Q10-B. 1 MQB-1 per chair works wonderfully (directly to chair or to platform).
NNG likes this.
Marc Alexander is online now
post #75 of 106 Old 04-02-2018, 10:13 PM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
You have the Earthquakes on top of their plate. Do they work the same underneath the plate, pointed downwords?
Candle is offline
post #76 of 106 Old 04-03-2018, 04:59 AM
Dolus's Avatar
Quoted: 83 Post(s)
Liked: 66
Hi Marc
Did you make that up? I was intrigued and Googled "Earthquake transducer torque multiplying bracket" but no hits. I visited the Earthquake site and not a mention. It must be a closely guarded secret and you have just given it away.
Dolus is offline
post #77 of 106 Old 04-03-2018, 08:01 AM
Liked: 4859
Yes
Hi Marc
The brackets they come with increase the effectiveness vs mounting directly without the bracket.
Here is the platform bracket for the Q10-B, https://www.amazon.com/Earthquake-Sh.../dp/B00EEDAVZI
Q10B platform
http://earthquakeeurope.com/Products...ingInfo_US.pdf
post #78 of 106 Old 04-03-2018, 04:39 PM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
I just wanted to report that I had to modify my existing placement somewhat due to contact with the mechanisms underneath. I moved each transducer forward about 4 inches and have no issues. This resulted in even better tactile. I can’t say enough how much I am impressed with these little transducers. They blend right in with my subs and give the perception of many more subs in the room. I use a very nearfield v1801 right behind my chair and I’d say with it turned off it still seems like it is on with the use of these transducers. Now my chairs are on cork flooring. How much benefit does adding those absorbers give you? I was looking at the small little pads you place under each end.
keeper is offline
post #79 of 106 Old 04-03-2018, 06:35 PM
Liked: 4859
@keeper what is under the cork? Hard slab or floating subfloor?
post #80 of 106 Old 04-03-2018, 11:27 PM
Dolus's Avatar
Quoted: 83 Post(s)
Liked: 66
Thanks for that Marc.
Now you pointed me in the right direction it is easy to find.
Dolus is offline
post #81 of 106 Old 04-03-2018, 11:43 PM
markmon1's Avatar
Quoted: 4821 Post(s)
Liked: 3100
Yea the earthquakes are much more like a sub in your chair while the butt kickers are more like a transducer in your chair. You’d appreciate them even more if you had butt kickers before to compare.
keeper likes this.
markmon1 is offline
post #82 of 106 Old 04-03-2018, 11:54 PM
Quoted: 86 Post(s)
Liked: 38
I love my transducers - it enabled me to get back to reference sub channel levels rather than massively boosting them for tactile impact I liked. They still give tactile impact at reference settings (2x SVS PB13 Ultra in a small room!) but in order to get the kind of response I wanted I was running 12db hot.
There's some good info on the Quake's on AVForums - https://www.avforums.com/threads/ear...#post-26026510
I posted my thoughts there. But this is relevant for anyone setting these up:
Issue - getting clean sub output in receivers with Auddssey or Dirac will PEQ the LFE channel. My Quake 10B was working fine with one sub and Auddssey but when I added another the Trim levels in particular and the PEQ really sucked the life out of the transducers.
The solution - use a secondary receiver. My primary is a Marantz SR6011 and I have an old RXV375 laying around. In the primary receiver make sure you enable Zone 2 HDMI sound. Input the Zone 2 from primary to input of the secondary and feed your tactile transducer amp from the sub output of the secondary. Voila you have clean output to your secondary.
You need a reciever with at least TrueHD/DTS Master audio decoding if you want to play Atmos/DTS:X. The good thing is the secondary reciever doesn't need to be Atmos/DTS:X compataible only TrueHD/Master audio because the object based effects are in meta data. This won't impact on bass performance.
To minimise cost and to get around any video limitations (HDR, 4k) of a secondary receiver I use a HD Fury integral. Otherwise your primary recievers video output will be limited to the HDCP/specs of your secondary. My RXV375 doesn't do 4k or HDR but the Fury gets around this problem.
Also in getting a new Sofa I attached my two Quakes to a single Ikea chair. Justice league with that was the best movie experience I've ever had. It was a freakin ride!
I should also add the Earthquake XJ amp seems to be the best for tactile transducers. There's a good FAQ here: http://www.earthquakesound.eu/info/faq/tactile-faq.aspx
Q: What type of amplifier should I use to run tactiles at ultra low frequencies (15Hz and lower)?
A: To run the tactile at ultra low frequencies an old school "Heavy Iron" Class AB amplifier should be used, as switching output amplifiers (Class D and derivatives) are not designed to operate at those frequencies as they come too close to DC for comfort and they usually have a high pass filter or modulator limiter build in to prevent passing of super low signals.
For all actual audio uses such as music, home theater and gaming - an Earthquake XJ-300ST or XJ-700R is the optimal amplifier to use. They have superior control of the piston movement due to high emf absorption and high current capability unique to the class J output stage.
Also I've found a Mini DSP really bought mine to life - you can really shape the EQ curve with these to optimise the shake.
NNG, keeper and gordojones88 like this.
rxp91 is offline
post #83 of 106 Old 04-04-2018, 12:18 AM
pdasterly's Avatar
Quoted: 268 Post(s)
Liked: 92
interesting thread, i have 2 buttkicker 1000w amps and 4 lfe & 4 concerts, the lfe's are mounted directly to sofa and the concert's mount on a riser board. For people bottoming out your setup is too stiff, my riser is mounted on buttkicker's Kinetic Isolator for risers and the sofa is mounted on buttkickers Rubber Isolator, the isolators made night and day difference, before i could barely get any volume and they would bottom, you want bouncy, my sub makes sofa bounce as well now
NNG likes this.
pdasterly is offline
post #84 of 106 Old 04-04-2018, 01:02 AM
keeper's Avatar
Quoted: 602 Post(s)
Liked: 248
Hard slab. Basement floor.
keeper is offline
post #85 of 106 Old 04-04-2018, 01:25 AM - Thread Starter
Candle's Avatar
Quoted: 56 Post(s)
Ha Mark Alexander.
You have the Q10B's and the MQB-1's?
Which do you prefer?
I believe markmon1 prefers the MQB-1.
The question now is, wil the XJ-700 be better than the famous and now new coming BKA1000-(x), which is cheaper?
Candle is offline
post #86 of 106 Old 04-04-2018, 02:52 AM
markmon1's Avatar
Liked: 3100
Ha Mark Alexander.
I have 2 Q10B's sitting idle now. The MQB-1's feel exactly the same as the Q10B's but are more audibly silent at low volume and require less power to achieve a similar shake. It would depend on the use. I think the MQB-1 requires a chair mount to be effective. I think the QB10's could be mounted under floor boards or such to be effective and also driven with more power.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #87 of 106 Old 04-04-2018, 10:12 AM
Liked: 4859
The isolators will make significant difference. In a basement it will be even better to build a platform and put the isolation feet under that. Everything is more realistic when you feel the bass through your feet and not just the chair.
https://www.parts-express.com/penn-e...x-1-h--260-772
NNG and keeper like this.
post #88 of 106 Old 04-04-2018, 10:16 AM
Liked: 4859
Dude, is that two Q10Bs on a single chair? OMG! You are mad! Each Q10B is equal to ~3 MQB-1s a single MQB-1 could handle that chair. With enough power the Q10Bs will rip that chair apart! (might make for a cool video though )
NNG likes this.
post #89 of 106 Old 04-04-2018, 10:35 AM
Liked: 4859
Ha Mark Alexander.
I have 4 MQB-1s and a Buttkicker LFE I picked up for its BKA1000.
Class D amps like the iNukes are sufficient for the MQB-1s (response starts rolling off at 15Hz and stops at 10Hz). For the Q10Bs (which go down to 5Hz) I would recommend class B like the BKA & XJs.
I'm not sure the XJ is worth the added expense over BKA… except likely in terms of reliability.
post #90 of 106 Old 04-04-2018, 10:35 AM
Quoted: 86 Post(s)
Liked: 38
Yes it's two! The Ikea chair is very well built actually! But it does have the power to make it dance across the room when I get my ass out of it!
Seriously Justice League was out of this world. For those types of movies it's like a ride and it really added to the movie. I guess almost like a 4DX. But for most movies I tone it down to one Quake 10B at a reasonable volume with no clipping.
I've read a lot about transducers and there's a lot of talk about calibrating them and making sure the level isn't too high. I think there's a ton of personal preference and just do whatever feels good. At lower gain and a flat EQ the Quake's even complement live music well.
rxp91 is offline
