Rythmik FV18 vs JTR HT118 - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #121 of 141 Old 11-19-2018, 09:43 PM
tvuong's Avatar
Quoted: 2540 Post(s)
Liked: 2182
Originally Posted by chucky7 View Post
Do you own any version of the Cap 1400, the Cap 118HT or the Rythmik FV18? I DO.
Have you compared any version of the FV18 vs the Cap 1400 vs the Cap 118HT in the same room? I HAVE.
All you have is anecdotal evidence... Have you even compared any Rythmik sub vs JTR sub in the same room?
Both my Cap 1400 and the Cap 118HT were ON A DIFFERENT LEVEL from the Rythmik FV18 I heard at Marc's open den on concrete slab.
Don't get me started on durability and usability... At Marc's GTG, we tested all subs equally and only the Rythmik FV18 was damaged. Why was that?
I have not but I don’t ever make vague statement like yours UNLESS I have compared the same subs. Again, you DID NOT audition the same subs the op was asking; therefore, your statement is meaningless regardless of what subs you own or have heard. Perhaps the FV18 aluminum driver you heard was too clean for you if that was what you meant by ‘on a different level’. Now it is that you own the cap 1400 and 4000ulf that make you think JTR subs must be on a different level? Really? There is a difference between sub enthusiastic and brand loyalty and you are obviously the later. By the way, I said enough and I think the op or folks here understand the point I am trying to make. There is no need to derail this thread.
iceatola likes this.
tvuong is online now
post #122 of 141 Old 11-19-2018, 09:44 PM
chucky7's Avatar
Quoted: 3402 Post(s)
Liked: 4156
Originally Posted by imureh View Post
There's the Limiter switch; turn it on to protect the driver from over-excursion during demanding movie soundtracks. Off is primarily for those who use their subwoofer for 2 channel music.
Here is my take:
Movies are much more demanding for the sub due to the ULF. There is rarely any content below 30Hz in normal music. Unless the limiter degrades the sound quality, it should be on at all times. Then why give the user the chance to blow up the driver?
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #123 of 141 Old 11-19-2018, 09:46 PM
tvuong's Avatar
Liked: 2182
You really should put the subs in the cart to find out... I did...
Unless something has changed, Rythmik always gives 10% discount on both subs if orders them at the same time.
post #124 of 141 Old 11-19-2018, 09:48 PM
imureh's Avatar
Quoted: 2672 Post(s)
Liked: 3199
The $1599 includes the discount. Its $1699 and when you add 2 to cart and update the price changes to $1599
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #125 of 141 Old 11-19-2018, 09:49 PM
chucky7's Avatar
Liked: 4156
Nope. Why don't you re-read Marc's GTG thread?
chucky7 is offline
post #126 of 141 Old 11-19-2018, 09:55 PM
tvuong's Avatar
Liked: 2182
I read that thread many times and I also talked to Marc in person so I know exactly what his take is for the subs. Again, your post has NOTHING to do with the op’s question. You just don’t ever get it.
post #127 of 141 Old 11-19-2018, 09:55 PM
imureh's Avatar
Liked: 3199
Here is my take:
I am sure Brian can give you a half page answer on this...however he has indicated that most of his customer base requires this type of optionality and demand that the natural sound is not electronically controlled.
Again from Jim:
Most subwoofer companies overcome small cabinet dimensions by using DSP (Digital Signal Processing) to boost the low frequencies and extend the effective range. Rythmik does not use DSP, preferring physics and their patented servo system instead of electronic aids. That suggests to me even though the cabinet is not terribly large it's still close to ideal for the parameters of the drivers. As with food, naturally derived beats artificially added.
post #128 of 141 Old 11-19-2018, 09:57 PM
tvuong's Avatar
Liked: 2182
Doesn’t come out to be 10% discount though. Perhaps the margin is so thin on the FV18 already?
post #129 of 141 Old 11-19-2018, 10:44 PM
chucky7's Avatar
Liked: 4156
I have not but I don’t ever make vague statement like yours UNLESS I have compared the same subs. Again, you DID NOT audition the same subs the op was asking; therefore, your statement is meaningless regardless of what subs you own or have heard. Perhaps the FV18 aluminum driver you heard was too clean for you if that was what you meant by ‘on a different level’. There is no need to derail this thread.
Below is your post:
Based on what, the Cap1400 is at a different level? Cost? Output? Extension? Size? Look? SQ? Adjustability? Have you heard them both in the same room?
Below is my reply:
Based on output from 16~50Hz, size, look, SQ, TR, durability, usability and port wind...
I compared my 2015 Cap 1400 and the original Rythmik FV18 extensively at Marc's huge open family room.
Now, I have not heard the FV18 paper cone vs the Cap 118HT. The 1400 is a step above the Cap 118HT, an entry level 18" sub. Having 3db more output above 40Hz and wider ports do not magically make the FV18 paper cone a $2000+ sub killer.
I supplied my impression and why I stated the Cap 1400 is on a different level from the FV18 I heard. That is more meaningful than your post of:
I don't own any of these subs...
I have not compared the said subs in the same room.
Please stop derailing this thread.
chucky7 is offline
post #130 of 141 Old 11-19-2018, 11:29 PM
tvuong's Avatar
Liked: 2182
Again, you are all about output. A sub that has more output must be on a different level. No, there are a whole lot more to a sub than just plain output especially when we are talking about a pair of subs at these levels of the 118/1400/FV18. I do not say or ever indicate that the FV18 paper cone is a $2000+ sub killer, so please do not put words in my mouth. Speaking of putting words in my mouth, I don’t know how you can quote something I never posted. Seriously, be real man.
I rest my case with you. What was the op’ s question again?
Originally Posted by avsnoob10 View Post
Between a pair of Rythmik FV18 paper cone and pair of 2019 JTR 118HT which is better?
Then you went ahead and suggested the 1400. Have you heard the 1400 and FV18 paper cone? You also have not, but the 1400 is on a different level. See the discrepancy I have been trying so hard to point out? I am done and OUT.
post #131 of 141 Old 11-19-2018, 11:58 PM
chucky7's Avatar
Liked: 4156
Thank you for the laugh! I haven't laughed this hard for a while!
It's easy... See below...
You win! I rest my case with you.
Then you went ahead and suggested the 1400...
I did so because the Cap 1400 at $1799 each shipped is a great deal! Don't forget, that's almost $600 off from its price just before the Cap 1400 was discontinued. It's all moot now because they are no longer available!
chucky7 is offline
post #132 of 141 Old 11-20-2018, 06:18 AM
Quoted: 1304 Post(s)
Liked: 1456
@chucky7 LOL
FWIW Chucky7 has been neutral on many occasions with subs. He is one of the few that identify; some subs dont work for everybody in their specific "room"
Just my 2 cents
chucky7 likes this.
Set up #1 Speakers LRC: Emotiva T2 & C2, Rears: Emotiva B1, Subs (2) 2019 JTR 118HTs, Receiver: Marantz SR5012, 7.2,100 Watt, AMP: Outlaw5000
Set up #2 Son's Room: QA3020i LR, Emotiva C1 Center, Denon AVR, Subs (2) HSU VTF2 MK5,
Set up #3 Elab B6 2.0 Debut w Fosi Audio amp 50W Set up #4 QA3020 w Fosi Audio amp 50W Set up #5 Chane's A1.4 w Fosi Audio 50W amp
mpk1970 is offline
post #133 of 141 Old 11-20-2018, 06:22 AM
imureh's Avatar
Liked: 3199
Originally Posted by mpk1970 View Post
@chucky7 LOL
Just my 2 cents
You mean not every JTR sub?
mpk1970 likes this.
post #134 of 141 Old 11-20-2018, 09:19 AM
chucky7's Avatar
Liked: 4156
Just FYI, when mpk1970 was sub hunting in his thread, I called him to discuss how to make the FV25HP work in his room. I always recommend getting the biggest subs the room allows, then get a second down the road, if necessary. He insisted on dual and did not want to spend close to $5000 on subs.
mpk1970 likes this.
chucky7 is offline
post #135 of 141 Old 11-20-2018, 09:22 AM
imureh's Avatar
Liked: 3199
That’s one for the history books then eh?
It’s all good man.
jamiebosco, drh3b and mpk1970 like this.
post #136 of 141 Old 11-20-2018, 12:01 PM
Liked: 1456
It’s all good man.
He also spoke highly of the Monolith 15 and liked the HSU also. Yes @chucky7 was doing a great job trying to get me to spend like $20K on subs
chucky7, iceatola and BluesDaddy56 like this.
mpk1970 is offline
post #137 of 141 Old 06-05-2019, 08:00 PM
Landmonster's Avatar
Quoted: 104 Post(s)
Question
Sorry to resurect this dead thread, but these are 2 subs I am highly interested in.
The new (2019) version of the JTR 118th, vs. the 18" Rythmik aluminum cone.
Did we ever reach a conclusion on this topic, apart from all the arguing?
How does the new JTR distortion compare to the low-level distortion on the Rhtymik?
Landmonster is offline
post #138 of 141 Old 06-05-2019, 08:15 PM
imureh's Avatar
Liked: 3199
Read my sub comparison thread. Jeff lowered the tune a bit since.
post #139 of 141 Old 06-06-2019, 05:09 AM
imureh's Avatar
Liked: 3199
Here is the link to thread I mentioned above
Subwoofer comparisons and impressions
https://r.tapatalk.com/shareLink?sha...2&share_type=t
post #140 of 141 Old 06-06-2019, 05:28 AM
Quoted: 104 Post(s)
So what is your key takeaway? Which is the superior sub and why?
post #141 of 141 Old 06-06-2019, 05:38 AM
imureh's Avatar
Liked: 3199
Did you read the first post? Its all in there
