Large volume room: single Hsu VTF-3 MK5 vs. dual Emotiva BasX S12's? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #31 of 38 Old 05-04-2018, 01:59 PM
MIX_MASTER_ICE's Avatar
Quoted: 2589 Post(s)
Liked: 2416
Originally Posted by bargugl View Post
Exactly. Different class. The correct Rythmik sub to compare with the Hsu VTF15 is the Rythmik FVX15. Maybe the smaller class is enough sub for the OP, but on the other hand you may find yourself always asking, what if?
As far as VTF15 vs VTF3.5 - Honestly there is not much difference. Same amp, same driver, just the VTF15 has a bit bigger box which gives just a tad more extension and a bit more output below 30 hz. Above 30 hz, they might as well be the same sub, and the extra 2db at 20 and 1 db at 25 hz may not be obvious to the vast majority of people.
Dual VTF3.5 is the biggest value play you can make if you want duals now.
One key difference in the HSU subs is the increased port area the VTF-15H.2 has over the VTF-3.5. Port noise will be less of an issue with the big brother.
bargugl likes this.
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Infinity P363/163. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5 bs. Polk RTiA1/CsiA4. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31. Sennheiser HD58X, HD4.50, PC37X. SIVGA SV004. HyperX Cloud PS4 HS. Plantronics RIG500 Pro HS. LG FH6,RK8,RK7,PK5. UE Boom3.
MIX_MASTER_ICE is offline
post #32 of 38 Old 05-04-2018, 02:14 PM
unretarded's Avatar
Quoted: 1686 Post(s)
Liked: 2072
While I am a tower guy, I think bookshelves will work or smaller towers if the budget size is a concern.
For towers to bring anything to the game, they need to have 12 or 15 inch woofers and even then, you are just using them to fill in a tactile hole left when switching from high power large cone subs to the mains. They do have their uses, but assuming pops is not going for earthquake tactile with chest punch, bookshelves will be fine.
Speakers are tools, pick the one that accomplishes your goals is the best value you can get.
palehorse likes this.
Link to Stereo Integrity SI HT 18 sub build......https://www.avsforum.com/forum/155-di...-pedestal.html
Speakers and subs for sale...https://www.avsforum.com/forum/209-au...kers-subs.html
unretarded is offline
post #33 of 38 Old 05-04-2018, 02:35 PM
chucky7's Avatar
Quoted: 3404 Post(s)
Liked: 4163
How about the following:
XTZsound is have a 30% off sale. www.xtzsound.us
SUBWOOFER: XTZsound sub-3x12 $1499
https://www.xtzsound.us/shop/us/spec...t-studio-black
FRONT L/R
: XTZsound Spirit 11 Matte black: $630
https://www.xtzsound.us/shop/us/Spea...11-matte-black
CENTER
: XTZsound Spirit 8 Matte Black: $259
https://www.xtzsound.us/shop/us/Spea...-8-matte-black
REAR SURROUND
: XTZsound Spirit 8 Matte Black: $294
https://www.xtzsound.us/shop/us/Spea...-2-matte-black
Total: $2682 shipped.
XTZsound is a highly regarded ID company in Europe. The star of the above package is of course the XTZsound sub-3x12. This is regularly a $2500 sub comparable to the JTR Captivator 1400. Each JTR Captivator 1400 is roughly equal to 2 Hsu Research VTF-15H MK2s.
alwaller and palehorse like this.
Speakers: L/C/R: JTR Neosis 212HT. Surrounds: Jamo C103, KEF Q100, Polk Audio RTiA3.
Subwoofer: JTR Captivator 4000ULF.
AVR: Denon AVR-X4400H. TV: Samsung UN75NU8000FXZA.
FS: Jamo C103, KEF Q100 and Polk RTiA3
chucky7 is offline
post #34 of 38 Old 05-04-2018, 02:48 PM
bargugl's Avatar
Quoted: 235 Post(s)
Liked: 300
True. if you see yourself pushing the sub hard in the 25 hz and under range (like I know you do ), that can be a concern.
bargugl is online now
post #35 of 38 Old 05-05-2018, 04:05 AM
Balbolito's Avatar
Quoted: 95 Post(s)
Liked: 172
Single HSU, then after a while add the second, which would be the same sub.
if you get two smaller subs then after a while it will be a bit hard to upgrade as most people wouldn't have room for 3 or 4 subs.
Balbolito is online now
post #36 of 38 Old 05-05-2018, 08:30 AM
Tyborg's Avatar
Quoted: 102 Post(s)
Liked: 72
For a large room, you’ll want to start with something as near as possible to the MLP to get any significant tactile response. If this is mainly just for your Dad, then no point in worrying about a flat response across the room which would be the point of multiple subs. Dad is only in one place at a time so get the biggest sub you can and park it as close to his seat as you can. +1 for HSU VTF-15 which I have in a similar large room. Intrigued by Chucky’s post about the Xtz 3x12, but it will cost a bit more.
Tyborg is offline
post #37 of 38 Old 08-16-2018, 06:58 PM - Thread Starter
palehorse's Avatar
I did exactly as you suggested with the VTF-15, and my Dad is ecstatic about his new setup. The sub sits just 4 feet from his MLP, and you can feel it down deep in your soul when it booms during action sequences.
His entire Emotiva+HSU combo is just plain epic, so I'm actually jealous as hell. LOL
Tyborg likes this.
palehorse is offline
post #38 of 38 Old 08-16-2018, 07:41 PM
Tyborg's Avatar
Quoted: 102 Post(s)
Liked: 72
LOL, That's awesome for your Dad!! I put in two 18" drivers in an infinite baffle that's setup right behind my MLP in a new theater I'm doing. I'm really enjoying it, but what surprised me the most is how impressed I am with the HSU after experiencing the dual 18" drivers. VTF-15 is an amazing sub! Too bad you're feeling jealous now, maybe a new sub purchase in your future
Tyborg is offline
