Recommendation for a sub - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By derekmoore
  • 1 Post By MIX_MASTER_ICE
post #1 of 5 Old 05-03-2018, 09:32 PM - Thread Starter
Liked: 0
Hi All,
I recently completed gathering speakers for a full Elac Debut 7.1 system (previously, I had mixed fronts and rears). So I will be running:
2 F5 Towers for the fronts
C5 Center
4 Debut B5s as the surrounds
I'm primarily looking for a sub for movies; I'm pretty happy running my music 2.0 through the F5s. I'm trying to keep my budget at or below 400, but would stretch to 500 if no other good option exists. I have the ability to run 2 subs, but right now, for my wallet's sake, I'm just looking for one to start (I'm coming from an old Sony 10" sub, so pretty much anything is an upgrade).
Reading a few posts, I've noticed that two names seem to appear more than others: Hsu and SVS, so currently the VTF-1 MK3 and the PB-1000 are my front runners.
Finally, the room it is going to be in is roughly 20x13, with a sloped ceiling going from 12 ft to about 8 ft (sloped along the length), with a large opening towards the back left of the viewing area into the adjoining room, along with a hallway on the back. I realize a 2 sub solution would probably be better, but as I only have the funds for a single sub, lets keep the recommendations to subs that can work solo please.
Hunter55 is offline
post #2 of 5 Old 05-03-2018, 10:05 PM
MIX_MASTER_ICE's Avatar
Quoted: 2669 Post(s)
Liked: 2477
The Monolith THX Select 10 is $500 and what I would go with over either of your two mentioned subs.
MIX_MASTER_ICE is offline
post #3 of 5 Old 05-04-2018, 04:08 AM
Quoted: 338 Post(s)
Liked: 222
@MIX_MASTER_ICE And I noticed you pointed out this discovery a bit after posting here. This would keep the OP real close to preferred budget.
"Just a heads up that today from 8AM-4PM PST Ebay will have a posted code for 15% off, with a max discount of $100. You can buy the Monolith THX Select 10 from Monoprice via their ebay store, so it would be priced $424.99 after discount.
https://www.ebay.com/itm/Monoprice-M...IAAOSwCDZa6AHO "
MIX_MASTER_ICE and karps1987 like this.
5.1: Power - Denon 4308ci, Fronts - Def Tech BP9040's, Center - Def Tech CLR 2000, Surrounds - Def Tech PM1000's, Sub's - Rythmik E15HP x2, Display - Panasonic TC-55AS530U, TT - Rega Planar 2 w/ Dynavector 10x5
derekmoore is offline
post #4 of 5 Old 05-04-2018, 06:26 AM - Thread Starter
Liked: 0
Looks interesting, will add it to the short list. I noticed Monoprice doesn't honor coupons on their own website for this sub, so these ebay coupons are probably the next best bet.
Hunter55 is offline
post #5 of 5 Old 05-04-2018, 12:26 PM
Liked: 2477
I would snatch up the Monolith THX Select 10 for $425. Heck of a deal and the last thing I need is another sub, but I ordered one.
derekmoore likes this.
Subs>RBH I-12e, I-12. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB32,XB31. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. SIVGA SV004. SA HDTwo. HyperX CloudPS4. TB Elite AtlasAero. LG FH6,RK8,RK7,PK5. HK Onyx Studio4(x2).
