Sub $200 sub for entry level 5.1 system - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By gajCA
  • 1 Post By gajCA
  • 1 Post By RayGuy
post #1 of 17 Old 05-19-2018, 01:21 AM - Thread Starter
mayhem13's Avatar
Quoted: 47 Post(s)
Liked: 30
Hey folks. My daughter just got her first place away from home and I gave her an older Pioneer Elite AVR that does DD and set her up with fronts, a center and surrounds I had sitting unused.......but being a basshead, there's no subs available for charitable donation that won't get her evicted so I want to buy her a sub......for less than $200
After lots of research and currently available deals I've narrowed it to three subs
BIC F-7
Dayton Sub1200
Polk Audio PSW505
All are within 5% of each other on price, but given the original MSRP and specs of the now discontinued Polk, it looks to me to be the far and away winner.
Thoughts?.........and please, no upgrade suggestions or over $200 options or DIY........there's simply no time or $$$ left in dad's wallet at the moment!
mayhem13 is offline
post #2 of 17 Old 05-19-2018, 06:53 AM
bargugl's Avatar
Quoted: 226 Post(s)
Liked: 260
Bic F12 and Polk 505 will be better than the Dayton. F12 and PSW 505 are pretty close. My preference would be for the Polk (sounded a bit cleaner from what I recall from years ago), but that is me.
bargugl is offline
post #3 of 17 Old 05-19-2018, 09:10 AM
MIX_MASTER_ICE's Avatar
Quoted: 2560 Post(s)
Liked: 2398
I don't believe I've ever heard of the Bic F-7. Frys.com often runs the Klipsch sub-12hg for under $300 w/promo code. Sometimes they offer shipping, sometimes they don't. I like that sub a lot for under $200 and I had a couple of them in the past. The Polk PSW505, which is currently $189.99, is also a solid performer in this price range. From my experience with owning these subs, I would pay the extra $40 or so and get that over the Dayton sub-1200, which has a really cheap build quality.
Subs>RBH I-12e/I-12. HSU VTF-15H mk2. Monolith THX 12(x2)/THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL 270/235c/230/225c, Arena 130/125c. Jamo S807/S803. Infinity P363/163. Pioneer FS52/BS22A/C22. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith AM Cinema 5 bs. Polk RTiA1/CsiA4. Other Audio>Sony MDR-Z7m2, WH-XB700, XB32, XB31.JBL Live500bt. Logitech GPro HS. Plantronics RIG 500 Pro HS. LG FH6,RK8,PK5,PH4. UE Boom3.
MIX_MASTER_ICE is offline
post #4 of 17 Old 05-19-2018, 10:44 AM
gajCA's Avatar
Quoted: 8493 Post(s)
Liked: 5674
BIC F-7
Dayton Sub1200
Polk Audio PSW505
I'd get the Emotiva BasX S8.
Rgarc likes this.
Geoff A. J., California
gajCA is offline
post #5 of 17 Old 05-19-2018, 01:59 PM - Thread Starter
mayhem13's Avatar
Quoted: 47 Post(s)
Liked: 30
Can't say I'd agree with a much smaller driver with a stamped frame and 150w over the Polk.
mayhem13 is offline
post #6 of 17 Old 05-19-2018, 02:06 PM
gajCA's Avatar
Liked: 5674
Well, according to this review the Polk is a 35hz sub.
I'm sure it will play louder than the BasX S8 though.
https://hometheaterhifi.com/volume_1...er-4-2005.html
gajCA is offline
post #7 of 17 Old 05-19-2018, 02:22 PM
Liked: 2398
That very same review by Ed Mullen (of SVS) shows in the 2000 ft^3 room he was testing in the PSW505 held flat down to 25Hz and had a mid-bas hump in the 60-70Hz region, which is very typical of a ported budget sub. It was then -10dB @20hz . Flat to 25Hz is about as good as you will get from a sub under 200 bones.
As far as the BasX S8, what I've read is people having port noise issues with it and it certainly wouldn't be a good choice for movies. I've even read of people on this board stuffing the port to stop the chuffing even at only moderate volume levels. That's reminiscent of what I used to hear of people doing to the very poor performing 50w Polk PSW10. I think the S8 would be a better fit for a small room or PC set up to add some bass to say a pair of bookshelf speakers that down have much lower range.
post #8 of 17 Old 05-20-2018, 04:51 AM
pase22's Avatar
Quoted: 3014 Post(s)
Liked: 2503
+1
These are likely your best options for your budget, unless you can find a good deal on the used market.
Alternatively, you can get dual Yamaha YST-SW216 and still be under budget.
https://www.accessories4less.com/mak...r-black/1.html
Kef Q100 FL/FR,SL/SR, Q200C, SVS SB-2000, Denon AVR-X3400H, , Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #9 of 17 Old 05-20-2018, 09:01 AM
gajCA's Avatar
Liked: 5674
The review I linked indicated he employed a parametric equalizer to get his in room results.
The BasX S8 at moderate to loud volumes in a smaller room would be an excellent choice and promise to measure far flatter if BasX S12 results to spec are a good measure.
The vast majority of AVS owners have not mentioned chuffing or stuffing ports with the S8.
If my dual 50 watt Yamaha SW012s in my 400 sq/ft secondary room, albeit with minidsp, sound just fine, no chuffing, plenty of volume, a single more powerful 150 watt basX might be all the op needs.
Sure, they don't rattle windows like my main 1250 watt 15" sealed servo but different horses for courses.
But if loud is what the OP wants the larger more powerful and peaky Polk is a better choice as I mentioned in my first post.
gajCA is offline
post #10 of 17 Old 05-20-2018, 09:09 AM
Quoted: 437 Post(s)
Liked: 229
monoprice 12" / 150 wpc or the 8" / 200 wpc 99/@.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #11 of 17 Old 05-20-2018, 11:07 AM
Liked: 2398
What I posted previous on the 25Hz was the sub performance in-room only with no EQ. Yes, Ed did follow that by using a parametric EQ to achieve better results and an even lower ± 3dB of 23Hz.
post #12 of 17 Old 05-20-2018, 12:04 PM
gajCA's Avatar
Liked: 5674
I think we can both agree that by definition a $200 sub has to be compromised in some fashion.
But, then again, the "budget" sub category $600 or less has never been better here in the US, which is something to be thankful for.
My first sub was in the late 80s and to get a real sub back then cost the equivalent of $3500 +/- in today's money, (ULD 15)!
MIX_MASTER_ICE likes this.
gajCA is offline
post #13 of 17 Old 05-20-2018, 02:36 PM
RayGuy's Avatar
Quoted: 2531 Post(s)
Liked: 2280
Polk. That peaky bass is what she would want. Flat frequency response subs are wasted on the young!
gajCA likes this.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #14 of 17 Old 05-21-2018, 11:56 AM
Quoted: 411 Post(s)
Liked: 304
In the sub $200 category I would prefer a smaller,tighter, more efficient bass sound than large and sloppy. The Emotiva S8 and Yamaha's won't pressurize a room but could be enough to enjoy the sound without the risk of eviction. When you can go to a $500+ sub, the small sub will still be useful for smaller secondary setups or 2.1 systems. The large "budget" sub will eventually make you unhappy no matter how or where you place it.
Rgarc is offline
post #15 of 17 Old 05-21-2018, 12:29 PM
gajCA's Avatar
Liked: 5674
I think I agree but it is hard to argue with RayGuy's comment that many youngsters prefer "in your face...hey I can hear the subwoofer" bass.
gajCA is offline
post #16 of 17 Old 05-21-2018, 12:59 PM
Quoted: 411 Post(s)
Liked: 304
It's like you said. In this price range you have to prioritize and decide what you are going to compromise on. Young people may prefer loud but if they grew up around quality gear then they may have developed a more discerning ear from their exposure, but there is a strong case for the Polk in this situation.
Rgarc is offline
post #17 of 17 Old 05-21-2018, 01:04 PM
iceatola's Avatar
Quoted: 247 Post(s)
Liked: 227
My vote would be for a young adult get the Bic-F12, it did me well when I started out in this hobby a longggggg time ago.
Video: Epson HC 1060 projector - Elite Screens Manual Grande Series - 128inch
Receiver: Emotiva Fusion 8100 / Amps: Emotiva XPA-3, UPA-700
Polk Signature Series - S20 for L/R, S35 Center, S15 Surrounds
Subwoofer PSA 2xV1801
Roku 4, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
