Media Room (With pics) | Monolith 12, Monolith 15, or R-115SW - AVS Forum | Home Theater Discussions And Reviews
 5Likes
  • 1 Post By smcmillan2
  • 1 Post By basshead81
  • 1 Post By MIX_MASTER_ICE
  • 2 Post By ack_bk
post #1 of 21 Old 06-04-2018, 04:04 PM - Thread Starter
rfss4's Avatar
Liked: 0
Hey guys,
Looking for a sub for my media room area - I included a picture with the screen up.. working on some new trim
The sub will sit behind the wall unit area with a larger area behind there so I can fit just about anything within reason
The room with some of the kitchen being added is 25x25x10 (6250 cubic feet) but we obviously sit closer than this. Not a sealed room.
It will be between the Monolith 12, Monolith 15, and R-115SW from Klipsch
Thank you so much for your help!
rfss4 is offline
post #2 of 21 Old 06-04-2018, 04:07 PM
imureh's Avatar
Quoted: 3555 Post(s)
Liked: 4834
Originally Posted by rfss4 View Post
Hey guys,
If those are your only choices then M15 hands down. But it would be good to get an idea of yiue budget, listening preferences, music vs movies etc as there many subs that could work.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is offline
post #3 of 21 Old 06-04-2018, 04:10 PM - Thread Starter
rfss4's Avatar
Liked: 0
Thanks! I would say $1250ish budget - 75% movies / 25% video games
rfss4 is offline
post #4 of 21 Old 06-04-2018, 04:12 PM
imureh's Avatar
Liked: 4834
For that space you need multiple subs, duals minimum. Is that your budget for both subs or per sub?
imureh is offline
post #5 of 21 Old 06-04-2018, 04:15 PM - Thread Starter
rfss4's Avatar
Liked: 0
I would be up for doing dual subs I have plenty of room behind there. I would want to stay around 1500 total to keep things reasonable. Thank you again for your help
Could do dual R-115SW 15's for $1300 total or dual monolith 12's for $1600 or if you have others that would fit better that would be great.
rfss4 is offline
post #6 of 21 Old 06-04-2018, 04:21 PM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2595
anything less than a strong 15inch + sub would be waste of money in that space.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #7 of 21 Old 06-04-2018, 04:28 PM
imureh's Avatar
Liked: 4834
I agree with Tori that you would need 15s at a minimum and ideally 18s. One route you could take is that get the biggest sub you can afford now and then add one later. If that is not an option then monolith 12 would be my choice. M15s are $1K more so quite over your budget. The M12s are good subs for the money.
imureh is offline
post #8 of 21 Old 06-04-2018, 04:40 PM - Thread Starter
rfss4's Avatar
Liked: 0
Not disagreeing at all on the larger setup. I have 1 10" sealed sub with a 250w amp in there now it is embarrassing when it tries to make it through anything in there.
What do you think would be the main differences to jump from two of the R-115SW's to two monolith 15's ?
Sounds like if it's a huge jump to order a single monolith 15 then just see how it goes before getting second
rfss4 is offline
post #9 of 21 Old 06-04-2018, 05:04 PM
smcmillan2's Avatar
Quoted: 1140 Post(s)
Liked: 964
General rule of thumb for larger rooms is get the largest you can afford/fit at the time, and keep the option open for more subs down the road. With your setup I would probably try a good sized sub nearfield - As close to the back of that couch at the MLP as possible.
What you may not know is that placing the sub(s) where you want them is rarely where they will provide their best output. Google "Subwoofer Crawl" to see the basics of how to determine the sub's best locations. And keep in mind that multiple subs will help even out the bass response to a wider area in your room (if placed where they have that ability).
ETA: If you are at all handy you might consider DIY. There's an entire subsection dedicated to us crazies: https://www.avsforum.com/forum/155-diy-speakers-subs/
The biggest bonus I see from DIY is you can build a sub to fit your space/needs, but it will require some learning (design, measuring, etc) to get the most out of it. There are some companies that offer flat packs so all you have to be able to do is glue up some MDF panels and wire it up.
Madmax67 likes this.
Sub builds: Yet another Infinity 1260 build | Twins! | Modified V.B.S.S. build | UM12-22 builds | AV stand and sealed UM18s
Speaker builds: DIYSG HTM-10 build | DIYSG Volt-6 build | DIYSG Fusion-8 builds
smcmillan2 is offline
post #10 of 21 Old 06-04-2018, 09:08 PM
DaBateman's Avatar
Quoted: 722 Post(s)
Liked: 521
Yeah it’d be a huge step up to get dual monolith 15’s.
The Klipsch’s aren’t horrible by average sub measurements but, for the price of the monolith nothing else really compares. They’ll dig deep into the teens in Hz. They’re incredibly tight, accurate, punchy. You can run them sealed, max extension, max output.
You might as well go ahead and order the Monolith 15, you won’t regret it.
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #11 of 21 Old 06-05-2018, 12:16 AM
blake18's Avatar
Quoted: 701 Post(s)
Liked: 409
The Monolith 15, easily.
Lumenlab "Community driven video lab".
blake18 is offline
post #12 of 21 Old 06-05-2018, 08:47 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10948
can you push up to 17-1800.00? if so dual HSU VTF3.5 would be a good option. If not then get the Mono15.
jjackkrash likes this.
basshead81 is offline
post #13 of 21 Old 06-05-2018, 09:17 AM
Elihawk's Avatar
Quoted: 2118 Post(s)
Liked: 2294
The day Klipsch makes a better than average sub will be the first! Some really good speakers, but not really good subs. I agree, get a 15ich sub in your budget now and plan on a second one as soon as funds allow.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Integra AV receiver
Set up #2: Def Tech CA Aero 2, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Slimline AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Integra AV receiver
Elihawk is offline
post #14 of 21 Old 06-05-2018, 09:49 AM
iceatola's Avatar
Quoted: 266 Post(s)
Liked: 235
My vote would be get 2 of R-115SW as long as you can get them on discount for around $550 per. I know Frys electronic store have them on sale quite often. If no discount can be found then you may want to go another route instead.
Video: BenQ HT3550 4K Projector - Elite Screens Manual Grande Series - 128inch
Pre Amp: Marantz 7705/ Power Amplifiers: Emotiva XPA-3, UPA-700
JBL - Stage A190 Towers L/R , Stage A135 Center , Stage A190 surrounds , Atmos Klipsch rp-500sa
Subwoofer PSA 2xV1801 / Xbox One X, Nvidia Shield, Darbee Darblet 5000
iceatola is offline
post #15 of 21 Old 06-05-2018, 09:53 AM
ack_bk's Avatar
Quoted: 1365 Post(s)
Liked: 1550
The R-115SW is not a bad sub at all, especially if you can get it at a good price:
https://hometheaterreview.com/klipsc...ofer-reviewed/
I love my Monolith 15's but if you can get dual Klipsch 115SW for around $1000-1200 I would likely do that since dual subwoofers offer some benefits a single sub can't.
ack_bk is offline
post #16 of 21 Old 06-05-2018, 10:28 AM
zworykin's Avatar
Originally Posted by ack_bk View Post
... since dual subwoofers offer some benefits a single sub can't.
Except--OP, correct me if I'm wrong--it sounds like the subwoofers in this room will be co-located? A lot of the benefit of duals (vs. a single sub that can match their combined output) comes from placing them in two separate locations...
zworykin is offline
post #17 of 21 Old 06-05-2018, 10:29 AM
ack_bk's Avatar
Liked: 1550
Then if that is the case then duals would not be preferred vs the biggest, baddest sub you can get
ack_bk is offline
post #18 of 21 Old 06-05-2018, 05:18 PM
MUDCAT45's Avatar
Quoted: 740 Post(s)
Liked: 491
What did you dislike about the R-115 when you heard it?
MUDCAT45 is offline
post #19 of 21 Old 06-05-2018, 05:28 PM
MIX_MASTER_ICE's Avatar
Quoted: 2678 Post(s)
Liked: 2493
If for nothing else, I would avoid the Klipsch R-115 for the suspect amp quality/reliability. It's also not particularly strong 25Hz and below for a 15" sub, with 12" subs like the Monolith THX Ultra 12 and SVS PB-2000 offering more output capability 25Hz and below.
Subs>RBH I-12e. HSU VTF-15H mk2. Monolith THX 12(x2), THX 10(x2). XTZ 1X12. SVS PB-1000(x2). Speakers>JBL Studio 270/235c/230/225c. Sony CS3/CS8/CS5. QA 3020i/3090Ci, 2020i/2000c. Monolith Cinema 5bs. Polk RTiA1/CSiA4. Other Audio>Sony MDR-Z7m2,V6, XB900n,700,XB72,XB32. Sennheiser HD58X,HD4.50,PC37X. HiFiMAN HE4XX. Philips SHP9500. JBL PartyBox100(x2), Xtreme2,Charge4,Link300. Sivga SV004. LG FH6,RK8,RK7,PK7,PK5. HK Onyx Studio4(x2)
MIX_MASTER_ICE is offline
post #20 of 21 Old 06-06-2018, 09:04 AM
Elihawk's Avatar
Liked: 2294
I have no specific experience with the R115. I have owned both the Klipsch Synergy and Klipsch RW12d subs and both were "sub" par! I have read enough reviews, however to know that the Klipsch R115 rarely get mentioned with comparable subs from HSU, SVS, Rythmiks, etc...
Elihawk is offline
post #21 of 21 Old 06-06-2018, 09:09 AM
ack_bk's Avatar
Liked: 1550
Because for similar money I doubt anyone here would recommend a Klipsch R115 over an Hsu/Rythmik, etc. But if you can get them for around $500 or less they become a very compelling argument. Dual 115's for around $1K or less is a lot of bang for the buck. Yes you don't get the extension like you do with other companies but it's a lot of output and the benefit of dual subs over a single sub (or 4 vs 2) should not be quickly dimissed.
I like subs that extend down past 20hz for sure, but the vast majority of content doesn't and for most people the 35hz-80hz range is the sweet spot and these R115's are no slouch (again at a discount).
ack_bk is offline
