(1) PSA V1811 or (2) SVS PB-2000 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 74Likes
post #181 of 203 Old 08-28-2018, 01:51 PM
imureh's Avatar
Quoted: 3591 Post(s)
Liked: 4913
Originally Posted by pda15 View Post
Oh wow. I just checked the dimensions and man they are huge. Looks like they are made for dedicated HTs like yours. I wish they can make smaller speakers for living rooms. Cheaper too. But I'm sure they sound great.
Did you look at the MT-110s? Mine are MTM 210s.
Subwoofers: Dual Rythmik FV18s Rev2 with Paper cone, BOSS Platform mini riser, 2 BK LFE
Speakers: PSA MTM-210 L/C/R - Klipsch 250S Surrounds, PSA MT 110sr Rear Surrounds, 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra. Apple TV, Minidsp 2X4 HD
imureh is online now
post #182 of 203 Old 08-28-2018, 01:56 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Yup. Even the 110s are a little too big for my living room. I like the size of the SVS Ultras. But they're overpriced IMO.
pda15 is offline
post #183 of 203 Old 08-28-2018, 02:05 PM
imureh's Avatar
Liked: 4913
Yep. The ultras are good but yes overpriced. PSA are much better. Look at Ascend acoustics as well and chane.
post #184 of 203 Old 08-28-2018, 04:27 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Originally Posted by ack_bk View Post
You just need a Y splitter from the back of your sub out on your receiver. Your sub plugs into one splitter, then another sub cable to the back of the amp to power your transducers. No you don't need a 3K watt amp, the Auras are rated at 50 watts so any decent 100-200 watt amp can power them. I would start with two fir a sofa and place one on each end. Installation instructions:
https://www.parts-express.com/pedocs...guide-1381.pdf
They are simple to wire.
Here is a good package:
https://www.parts-express.com/dayton...ndle--300-9004
Just pulled the trigger on this bundle. Let's kick some butts!
pda15 is offline
post #185 of 203 Old 08-28-2018, 05:51 PM
ack_bk's Avatar
Quoted: 1365 Post(s)
Liked: 1551
Your gonna like it I can't imagine not having them for action movies now.
ack_bk is offline
post #186 of 203 Old 08-28-2018, 05:52 PM
ack_bk's Avatar
Liked: 1551
Dude the speakers are awesome. I think for me they made my HT experience even better than subs did. Those PSA speakers are a very good performer especially at the price point they are at. Before these I had SVS SCS-01s.
Small world I used to rock some SVS ScS-01's in my first theater room. I gave them to my brother in law like 9 years ago and they are still going strong.
ack_bk is offline
post #187 of 203 Old 08-28-2018, 05:56 PM
imureh's Avatar
Liked: 4913
Yeah man those were really nice speakers. They used to sell them as package with the SBS-01s as surrounds. My friend bought them from me for a couple of hundred bucks plus the PC12-NSD for a few more.
post #188 of 203 Old 08-29-2018, 05:23 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
What's a good furniture pad to decouple the couch from carpet?
pda15 is offline
post #189 of 203 Old 08-30-2018, 05:04 AM
ack_bk's Avatar
Liked: 1551
Can't help you with that one, I am not sure you need to worry about decoupling if you are installing the transducer directly to the frame of the couch. I would say install it first and see if you feel like decoupling is necessary. I don't have my home theater chairs decoupled from the carpet.
ack_bk is offline
post #190 of 203 Old 09-07-2018, 08:44 AM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
@ack_bk
What's the difference between connecting the bass shakers in series and individually?
pda15 is offline
post #191 of 203 Old 09-07-2018, 09:03 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10970
So have a V1811 sub but the MT-110 speakers are too large? The 110's are not the large at all in comparison to the sub you have.
basshead81 is offline
post #192 of 203 Old 09-07-2018, 11:34 AM
ack_bk's Avatar
Liked: 1551
@ack_bk
The difference is the load and how many ouputs on your amp you have. They are 4ohm so a pair in series is 8ohm and individually you would get 4ohm. If your doing a pair I would try them in series first.
Example:
https://www.hometoys.com/article/201...theater/34699/
ack_bk is offline
post #193 of 203 Old 09-10-2018, 07:38 AM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Example:
What is that white wire?
pda15 is offline
post #194 of 203 Old 09-10-2018, 09:04 AM
jamiebosco's Avatar
Quoted: 1015 Post(s)
Liked: 2658
That's how you wire in series
For two bass shakers, connect the positive of one bass shaker to the negative of the other bass shaker (**the white wire**). Next, connect the unused positive and negative terminals on the bass shakers to the corresponding positive and negative terminals on the amplifier.
TV: Panasonic 65" P65ST60 AVR: Denon AVR-X4000 Speakers: PSA MTM-210C (Centre), PSA MTM-210 (Left & Right), PSA MT-110 (Surrounds) Subwoofers: Seaton SubMersives x 3
jamiebosco is offline
post #195 of 203 Old 09-10-2018, 09:13 AM
basshead81's Avatar
Quoted: 382 Post(s)
Liked: 10970
You wire in series to keep the impedance from dropping. This is done (opposed to standard parallel wiring) so the resistance level(ohms) doesn't drop below what the amplifier is capable of driving.
post #196 of 203 Old 09-10-2018, 09:16 AM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Should I get a 4-conductor wire like this https://www.amazon.com/Monoprice-Acc...er%2Bwire&th=1?
Cut the white wire and connect the two shakers?
What do I do with the green wire?
Can I use either black or red side of a 2-conductor speaker wire to connect the shakers?
Like this?
pda15 is offline
post #197 of 203 Old 09-10-2018, 01:21 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
I think I found my answer. I would cut up and use the red speaker wire to connect the two bass shakers.
pda15 is offline
post #198 of 203 Old 09-10-2018, 09:28 PM
bscool's Avatar
Quoted: 890 Post(s)
Liked: 717
@pda15 All you need is regular 2 wire speaker cable(2 conductor).
To get that extra piece of wire that runs between the two terminals for series wiring is to cut a chunk of the 2 conductor speaker cable off and just use 1 wire. No need to pay extra for the 4 wire unless you want to. It is kind of a waste though unless you are trying to do something else I am missing.
2 conductor speaker wire will pull apart easily so you can just use 1.
Edit I see you have two diferent diagrams of two different amps. One has 2 connectors and one has 4. If your amp only has 2 connectors you would only need 2 conductor speaker wire.
pda15 likes this.
HTPC, Sony 40es, 120" Silver Ticket, 7702mkii, Sunfire Amp 225w, JBL 590, JBL 520
PSA XS30, Seaton Submersive, 2 Um-18 8cf sealed, Outlaw Ultra x 12, Kappa Pro 18LF, BFM Tuba 60 horn, B&C 18TBW100 6cf 41hz, 34hz, 28hz tune
iNuke 3000 & 6000 DSP's, Crowson Motion Actuator
bscool is offline
post #199 of 203 Old 09-10-2018, 11:26 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Gotcha. My amp has 4 connectors. Thanks.
pda15 is offline
post #200 of 203 Old 09-11-2018, 09:47 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
I got them working. Do I have to change any settings on the AVR or sub? What crossover should I set on the bass shaker amp?
pda15 is offline
post #201 of 203 Old 09-12-2018, 05:27 AM
ack_bk's Avatar
Liked: 1551
You should not have to change any settings on the AVR or sub. You can try the various crossovers but I like 50-60hz and below. This seems to give me tactile feeling for the action scenes in movies but I don't find them shaking in non action scenes where I feel it could take away from the movie.
ack_bk is offline
post #202 of 203 Old 09-14-2018, 01:40 PM - Thread Starter
pda15's Avatar
Quoted: 467 Post(s)
Liked: 190
Loving the effects of the bass shakers. Must have for bassheads. Thanks @ack_bk for recommending this to me.
pda15 is offline
post #203 of 203 Old 09-14-2018, 05:13 PM
ack_bk's Avatar
Liked: 1551
Awesome! I used to think they were gimmicky but now I can't imagine action movies without them.
ack_bk is offline
