Sunfire HRS8: Screws removed, how do I remove rear plate??? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By DonoMan
post #1 of 14 Old 07-04-2018, 08:40 AM - Thread Starter
jeffw_00's Avatar
Hi - I have a 8+ year old Sunfire HRS8 Subwoofer that has developed a hum. I get the hum with no inputs connected, and I tried locating the subwoofer in different places in my house, on different circuits/phases/etc. I also tried different power cords (including a 2-prong one). I believe it's a filter cap. I'd like to take a look (and also, some repair places ask you to send just the amp, not the whole subwoofer).
I've removed the 12 screws around the back, but I cannot budge the rear plate out of the box. Help?
/j
jeffw_00 is offline
post #2 of 14 Old 07-04-2018, 02:55 PM
Gorilla Killa's Avatar
Quoted: 1352 Post(s)
Liked: 1890
Ive never removed a Sunfire amp but I dont see why anything else would be holding it in. If you dont want to pry anymore pull the driver and see if somethings hung up.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is online now
post #3 of 14 Old 07-04-2018, 02:56 PM - Thread Starter
jeffw_00's Avatar
was trying to avoid messing with the driver - sometimes these are hard to put back in properly... After I remove the 12 screws (3 outer most on each of 4 sides of the back panel), the back panel should what, just drop out?
jeffw_00 is offline
post #4 of 14 Old 07-04-2018, 07:24 PM - Thread Starter
jeffw_00's Avatar
Hmmm - after wiggling it a bit - it just came loose. Nothing inside looks obviously broken though. Pics at http://kwcpa.com/HRS8
jeffw_00 is offline
post #5 of 14 Old 07-05-2018, 08:04 AM
Dolus's Avatar
Quoted: 83 Post(s)
Liked: 66
A bit late now but the advice I got from a UK subwoofer manufacturer was to use a hair drier or heat gun to loosen the seal. As it was winter and the central heating was on I placed it in front of a hot air vent for a couple of minutes.
Denon AVR-X6400H,Sony KDL50W829 ,Virgin Media V Box HD, WDTV, PS3, Philips DVP9560, Marantz CD67, BK Monolith Plus x 2, KEF TDM 23C,23F & 34DS, Jamo D500, Darbee Darblet, Belkin F9G6223uk3M, Buttkicker LFE kit, IsoAcoustics L8R430, Mede8er 800X3D, Behringer B1200d, AC Infinity Aircom T9
Dolus is offline
post #6 of 14 Old 07-05-2018, 08:08 AM - Thread Starter
jeffw_00's Avatar
Thanks - sending it to EBC electronics for repair...
jeffw_00 is offline
post #7 of 14 Old 07-05-2018, 12:31 PM
Liked: 1
Do the caps look swollen? http://kwcpa.com/HRS8/20180704_220232.jpg Or is it just me imagining it?
LotsaBoxes is offline
post #8 of 14 Old 07-05-2018, 12:35 PM - Thread Starter
jeffw_00's Avatar
Not obviously - I ran my finger around them and didn't detect any imperfections. I'm sending it out for repair (EBC Electronics) anyway. Unless I saw 1 cap obviously hosed that looked easy to replace, it's beyond my meager skillset to repair :-)
jeffw_00 is offline
post #9 of 14 Old 07-06-2018, 09:02 AM
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
Capacitors are often bad, but not visually, and must be tested with an ESR Meter or Leakage Detector to be found. ESR meters can be found cheap on Ebay (and generally speaking the cheap no-name ones do work fine). But yes if it's beyond your ability you can either send it out for repair, or you could add some terminals to the sub, hook those up to the driver, and use an external amp. Leave the plate amp on just so you don't have a giant hole in the side of your sub box. Don't actually hook it up to anything.
But repair is fine. I have no experience with that company so I don't know if they're a good repair shop or not.
DonoMan is offline
post #10 of 14 Old 07-06-2018, 11:00 AM
Liked: 1
https://www.ebay.com/itm/3-7V-of-ind...item2cd6232131
Is something like this sufficient, or do I need to get something a little better in the $30-40 range? I have some vintage amps and a Sunfire so I think I need to learn how to do this if I want to keep the stuff running without spending a lot.
I happened to fix my Sunfire after seeing this post and watching some youtube videos. I think I had a cracked solder joint. I could not see well enough to reflow all the components, however I did the caps and seems to have fixed my Sunfire now. I had a whole evening without humming
Now I want to learn more and check all the caps so I can replace any that are starting to fail. Maybe I can even add an additional Sunfire to the theater soon
post #11 of 14 Old 07-06-2018, 11:12 AM
DonoMan's Avatar
Quoted: 238 Post(s)
Liked: 191
that will be fine, just a bit less convenient to use - if it has no case then make sure not to set it down on anything metal and short it out
but it will work fine
I have the ~$40 MESR-100 one and it works great. I have relatively expensive multimeters from Agilent, Fluke and Klein (one each and the Klein one is a clamp-on), but I'm happy with the cheap ESR meter.
https://www.youtube.com/watch?time_c...&v=7Br3L1B80ow -- Dave Jones from EEVBlog thinks these are pretty decent also. This video is about the LCR/transistor model which is slight different but it's close and should be applicable.
Sometimes these work well in-circuit and sometimes not. But here's a general tip: if an ESR meter says your cap is bad, it is definitely bad. If it says it is good while out of circuit, it is almost definitely true. If it says it's good in-circuit, it may or may not be true. It can get confused in-circuit when you have a capacitor in parallel with other capacitors, or with low value resistors. Personally I always test in-circuit first, and move onto out-of-circuit testing if I deem that necessary.
NNG and LotsaBoxes like this.
DonoMan is offline
post #12 of 14 Old 07-06-2018, 12:27 PM
Liked: 1
Thanks, I watched the video and ordered a Mega 328 on amazon with case for $16 shipped to me. I just did a search on ebay for esr when I posted the link.
post #13 of 14 Old 07-10-2018, 09:25 AM
NNG
NNG's Avatar
I'm in the similar boat in many ways. A few non-working built-in sub amps with interest in DIY repairs. I will look to get the same ESR tester to aid in locating bad caps. The other issue is getting the replacement caps without having to buy larger lots.
NNG
NNG is online now
post #14 of 14 Old 07-16-2018, 08:43 PM
Liked: 1
Looks like my problem is not a cracked solder joint the hum came back after a few days. I'm not sure I'm using the meter correctly to check caps while on the board. I'm getting higher ESR and Vloss values while measuring on board. I'm still putting my list of caps together before I order. I still think the caps are bad. I happened to have a few 2200uF 25V caps on a amp board for a project I parted out. Decide to practice desolder some caps, and happen to notice they were some of the ones I needed. Did a quick test on the meter and these caps looked much better. Very low ESR values, very low Vloss, and capacity much closer to spec. I put the 2 2200uF caps onto the Sunfire board, and for now the problem seems to be fixed. I still want to replace more caps as I think they are going bad from age, I believe these are the original and the sub is close to 20 years old. This post shows 6 bad caps, 4 1000uF 25V and 2 2200uF 25V, https://www.ecoustics.com/electronic...io/618938.html When people say replace all the caps, are these the only 6, or should I be replacing all 40+ caps on the 2 boards?
Sub sounds good now, but to be sure I want to replace all the needed caps so I can enjoy the hum free sounds for years to come.
