Bass EQ for Filtered Movies - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 18333Likes
post #3331 of 7416 Old 12-23-2018, 10:23 AM
DesertDog's Avatar
Quoted: 484 Post(s)
Liked: 1381
@aron7awol are Edge of Tomorrow and Battle LA the only no BEQ needed titles so far? They're the only ones that I remember.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #3332 of 7416 Old 12-23-2018, 10:32 AM
Quoted: 2261 Post(s)
Liked: 9492
Updated to DTS-HD MA 7.1
Originally Posted by aron7awol View Post
BassEQ Mile 22 (2018) DTS-HD MA 7.1
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #3333 of 7416 Old 12-23-2018, 10:32 AM
Liked: 9492
I'll take a look at them.
biga6761 likes this.
post #3334 of 7416 Old 12-23-2018, 10:44 AM
Liked: 9492
BassEQ Battle: Los Angeles (2011) DTS-HD MA 5.1
The -2.5dB gain is a MV decrease.
post #3335 of 7416 Old 12-23-2018, 10:45 AM - Thread Starter
PioManiac's Avatar
Quoted: 3065 Post(s)
Liked: 7375
Originally Posted by Nalleh View Post
Yes, a Harmony can be used. You have to program it from the laptop no matter what remote you want to use, and it wont work if you have a WI-DG connected to the USB(at least on the 10x10HD, not sure/confirmed on the 2x4HD), but other than that: smooth
No workie on 2x4 either (WI-DG)
Nalleh likes this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #3336 of 7416 Old 12-23-2018, 10:46 AM
DesertDog's Avatar
Quoted: 484 Post(s)
Liked: 1381
Thanks, I know we talked about Battle LA in like August and at the time it looked like there was nothing to be done with it. Here's your graph on it from ultimate bass thread, https://www.avsforum.com/forum/113-s...l#post56810602
Edge of Tomorrow is one that I thought couldn't be BEQed due to the sine wave hit at the start. Looking at the graph it's almost one to BEQ without the intro and you need to switch your config a couple minutes into it. Here's Mr. Grey's graphs of it https://www.avsforum.com/forum/113-s...l#post51173473
I wasn't sure if there was any others like this too. I'm trying to make a note of them.
galonzo likes this.
post #3337 of 7416 Old 12-23-2018, 11:17 AM
Oh ya I'm a Member
Medi0gre's Avatar
Quoted: 55 Post(s)
Liked: 65
Originally Posted by paulst View Post
You could do 3 movies and leave a config as default for quick switching on the fly, obviously you'd just need a remote unless you're taking the laptop along.
Which leads me to a next question, has anyone got a Harmony remote to work? I looked for it in devices but it said it wasn't ir compatible?
Yes you can use the Harmony, I have been meaning to post this...
I bought the miniDSP remote and outta the box it controls the miniDSP, it doesn't need to be programmed
So I went to the laptop and started to setup the device on the harmony software taking the time to use the IR learning function going through all the steps. Finally getting to the end of it all, only to have a warning pop up stating that the miniDSP Is not a IR device and then the software ignores it... Frustrating!
I tried this many times 6 different ways from Sunday, renaming the device, etc...
So long story short don't bother trying to program the harmony software using the desktop software, the software is broken at the moment and I wasted many hours trying work arounds to get it to go.
Use the Harmony app on your phone and go through the setup, no warnings and it worked the first time through.
I use the Harmony to switch between the four configs on the fly.
paulst likes this.
klaatu barada nik*cough*
Denon AVR-X4300H/Turd Sony- 7.4.4
Polk Rti A9 LCR, Volt6 Surrounds and Heights
Inuke 3000,6000- 2x HO18 sealed, 2x Ultimax18 sealed, MiniDSP HD
PT ae8000 Projector, Sony UBP-X800, Harmony Elite, Falcon 110 2:35.1 Screen
Medi0gre is online now
post #3338 of 7416 Old 12-23-2018, 11:30 AM
Oh ya I'm a Member
Medi0gre's Avatar
Quoted: 55 Post(s)
Liked: 65
I was also going to request EoT as well, aside from the opening the rest of the movie seemed like it could use some BEQ magic.
Of course this could be extremely hazardous to the uninformed, thats why I refrained from asking.
galonzo and richardsim7 like this.
post #3339 of 7416 Old 12-23-2018, 12:15 PM
paulst's Avatar
Quoted: 169 Post(s)
Liked: 358
I have the old Harmony One, which doesn't use the hub so I can't use the app I've added the 2x4HD as a device but there are no buttons pre-programmed and as i don't have the actual remote I can't learn the functions, so I'll probably just buy the actual remote as they're only about £10 over here (UK)
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is online now
post #3340 of 7416 Old 12-23-2018, 01:09 PM
Oh ya I'm a Member
Medi0gre's Avatar
Quoted: 55 Post(s)
Liked: 65
Well all hope isnt lost, just use some remote you have laying around to use with the miniDSP as it has a learning function> teach the mini that remote> then learn that remote with the One and you should be good... if you have the learn feature on the One, that im not sure of* edit it can learn, see link if that helps>Page 23
https://images.harmonyremote.com/Eas...UserManual.pdf
paulst likes this.
post #3341 of 7416 Old 12-23-2018, 02:16 PM
femi's Avatar
Quoted: 237 Post(s)
Liked: 289
Hi @aron7awol , another request for BEQ: Netflix Bird Box.
Femi
aron7awol and biga6761 like this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #3342 of 7416 Old 12-23-2018, 05:19 PM
brahman12's Avatar
Quoted: 261 Post(s)
Liked: 677
Mission Impossible Fallout was so much fun. Saw this at an AMC Prime and immediately was anxious to see how it would be mixed for the home. Loved at the Prime and loved it at home with Aron's beq settings. The chopper climax scenes were marvelous Atmos and surround usage.....definitely love this franchise, especially from part 3 to Fallout. The vehicle chase scenes, the gunshots, the motorcycles...lots of sexy bass and now I gotta watch all of them again, lol.
Aquaman in an IMAX theater was an audio and visual feast. Acting, writing, and directing were all piss-poor cheese. However, if they stay faithful to the theatrical release on home video with regards to the fantastic special effects, and massively active surround mix...very intricate and busy surrounds, great height activity and it wasn't even a Dolby Atmos auditorium. There are endless/countless bass sweeps and bass impacts throughout the entire movie. Definitely a bassfest and I pray that they don't touch this mix much at all for home release.
SBuger, galonzo, SuperFist and 4 others like this.
Projector - JVC RS4910, Speakers - JBL Studio L890's fronts, L820's surrounds, L810's rears, L C2 center (blown tweeter, replaced with Martin Logan Motion 50XT center), Polk Audio OWM-5's for four Atmos ceiling speakers. Subwoofers - dual PSA V3600's, AVR - Yamaha 3040 with Crown XLS-1500 amps running the center and front towers. Bluray Player - Oppo BDP-105D, UHD 4K player - Philips BDP-7501. Projection Screen - 150" Elite Screens.
brahman12 is offline
post #3343 of 7416 Old 12-23-2018, 06:11 PM
Spidacat's Avatar
Quoted: 246 Post(s)
Liked: 320
A few BEQ requests when you get the chance. Thank you.
Split
The Shape of Water
Close Encounters of the Third Kind (if there's anything to boost)
Medi0gre and aron7awol like this.
Spidacat is online now
post #3344 of 7416 Old 12-23-2018, 06:36 PM
Liked: 9492
BassEQ Edge of Tomorrow (2014) DTS-HD MA 7.1
WARNING: If you don't do everything perfectly, this BassEQ will destroy your subwoofers. This is not a joke or an exaggeration. It will be the hottest signal ever sent to them, and it will very likely be the last signal ever sent to them. If you're not 100% confident in your abilities to implement this safely, just don't do it!
It is hidden in a spoiler tag for a reason. Please don't take these warnings lightly. This is legitimately dangerous and I am not responsible for any damage caused. You and only you are responsible for your sub(s) safety if you proceed beyond this point!
Spoiler!
post #3345 of 7416 Old 12-23-2018, 06:39 PM
Liked: 9492
Please don't add a config file for Edge of Tomorrow to your repository. It's just too dangerous.
post #3346 of 7416 Old 12-23-2018, 06:57 PM
Oh ya I'm a Member
Medi0gre's Avatar
Quoted: 55 Post(s)
Liked: 65
Wow!!! Thanks for making the graph. Really puts things into perspective, that is bloody insane! I am too scared to even think of trying it, even for "science".
One mistake and all my subs will end up on the healing bench in the garage!
post #3347 of 7416 Old 12-23-2018, 07:20 PM
SuperFist's Avatar
Quoted: 1247 Post(s)
Liked: 4740
Spoiler!
SBuger, paulst, aron7awol and 3 others like this.
Subwoofers: PSA S3000i x 2 | L+R Front: Onkyo SKF-200F | Center: Onkyo SKC-200C | L+R Surround: Onkyo SKM-200S | Atmos: Pioneer SP-T22A-LR | AVR: Yamaha RX-A660BL | HTPC: Lenovo Q190
SuperFist is online now
post #3348 of 7416 Old 12-23-2018, 08:06 PM
imureh's Avatar
Quoted: 2586 Post(s)
Liked: 3019
OMG! Small foot with BEQ is the bomb! Movie is really good IMO and the bass is just awesome with BEQ. Kids loved it too! great job Aron.
Subwoofers: Dual Rythmik FV18s Rev 2 with Paper cone
Speakers: PSA MTM-210 L/C/R - PSA MT 110sr Surrounds - 4 x SVS Prime Elevation for Atmos
Video: Epson PowerLite Home Cinema 6500 UB; Room: 2100 cuft sealed on suspended floor
Receiver & Players: Denon X4400H, Oppo UDP-203, Roku Ultra & Premium, Apple TV, Minidsp 2X4 HD
imureh is online now
post #3349 of 7416 Old 12-23-2018, 08:26 PM
DesertDog's Avatar
Quoted: 484 Post(s)
Liked: 1381
I'll leave it out. Touching that one is dangerous. I'm even thinking of turning down my house curve a little the next time it's played. It pushes them hard. In my build thread I added a video that I took a couple days ago of the 24" playing the opening. It's nuts.
I'm thinking of maybe adding a file though for EoT with all the filters off and putting a note in the fill name to not add a BEQ for safety. That way if anyone goes looking for it they'll see it and hopefully not try to do one on their own. Any thoughts on this idea?
SBuger, aron7awol and Pradeep2 like this.
post #3350 of 7416 Old 12-23-2018, 08:36 PM
Liked: 9492
BassEQ Bird Box (2018) DD+ Atmos
The 4dB gain is a MV increase.
SBuger, galonzo, SuperFist and 3 others like this.
post #3351 of 7416 Old 12-23-2018, 08:58 PM
Liked: 9492
I think that makes 450 BEQs!
On toward the huge milestone of 500...
post #3352 of 7416 Old 12-23-2018, 09:09 PM
Liked: 9492
I've played it with my house curve active, and my subs are ported but are tuned low enough that they can do the last 10Hz tone serious justice. At one point, I tested it a few times in a row creeping up with the volume toward reference bass and I just had to stop because it was actually scary how much it was affecting my house. My wife was yelling at me saying that I was just being foolish and she was right!
When I was testing the limits of my subs when I first built them, I was testing 10Hz CEA-2010 burst tones and usually those bursts are a nice safer way to test limits, but even they were making the doors upstairs in my house slam violently back and forth within their jambs. The square waves of EoT just want to rip my house apart. It's actually crazy and maybe irresponsible that they would put that on a retail disc.
I don't really see any downside in doing what you are thinking with the blank file.
SBuger, galonzo, SuperFist and 1 others like this.
post #3353 of 7416 Old 12-23-2018, 09:26 PM
tvuong's Avatar
Quoted: 2522 Post(s)
Liked: 2123
Thanks Aron I really cannot keep up with you in entering these LS’s into jriver.
tvuong is online now
post #3354 of 7416 Old 12-23-2018, 09:39 PM
Liked: 9492
Updated...excited to try this one!
BassEQ Mad Max: Fury Road (2015) Atmos
The -4dB gain is a MV decrease.
SBuger, PioManiac, galonzo and 3 others like this.
post #3355 of 7416 Old 12-23-2018, 10:46 PM
SBuger's Avatar
Quoted: 1141 Post(s)
Liked: 3514
Yeah EOT intro really is insane (and can definitely be hard on gear if not careful). We used to use it quite a bit in the VS thread for a lot of different reasons with the 30, 25, 20, 15, and 10hz drop down sine steps. We used to pretty much run that thing full tilt and probably wasn't the smartest thing ever lol. Fun but may have had something to do with me having to have 2 of my MA's repaired, IDK. But on that last 10hz note, back when I had my rig in the living room, with the sealed 18's behind behind the seats and the MAs and BK's all going full throttle, I remember the couch seat looking like it was getting about an inch or more worth of up and down travel for the TR when standing off to the side VibSensing it Crazy noises from the house too, especially from the kitchen area from the cabinets, microwave, stove etc rattling. EOT intro cranked up is just brutal as hell and not just the ending tones. The starting 30hz tone is pretty insane too!
I don't think my setup is a slouch by any means for TR now in the new room, but I do miss my old setup sometimes for the insane amounts of TR that thing could dish out on that couch that had a ton of flex in the middle seat (some of the best TR fun I've ever had on a lot movies) ...
That damn intro is no joke though! Crazy that they would put such a thing in there, its so out of place and WAY hotter than the rest of the bass on that track. Fun (we sure as heck had our fun with it), but dangerous too. I got lucky I think that I didn't tear up anything gear wise, well may have to something to do with the MA's having problems, but not sure. It was kind of a weird issue Randy had never seen before. He fixed them no problem though free of charge so I was very thankful for that. Good guy for sure!!
@Nalleh , did you ever get the one you were having a bit of trouble with sent in an fixed up?
My "Blacked Out" Home Theater Room
1400cuft sealed room on suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo UDP 203 | Eyes 7' to 120" AT Seymour Drop Screen | Epson 5030 PJ | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | BOSS 'Sub Riser' 6x JBL-12s | MiniDSP 10x10HD
SBuger is offline
post #3356 of 7416 Old 12-23-2018, 11:20 PM
DesertDog's Avatar
Quoted: 484 Post(s)
Liked: 1381
Yup, that was #450 for Movies. There's 462 total if you include the TV shows that have been done. I've enjoyed everyone I've tried so far. I just finished The House with Clocks... While the movie was average the sound was top notch. Good bass throughout and they made really good use of the surround and height channels in the atmos mix.
I also just added the dummy file for EoT too. So we can call it 463 to get closer to the 500 celebration. It's not cheating too much since flat is the correct call for it and you did technically BEQ. We're just not including that BEQ as a file for safety and sanity's sake
post #3357 of 7416 Old 12-23-2018, 11:32 PM
Nalleh's Avatar
Quoted: 2369 Post(s)
Liked: 3021
Yup, it was fixed in record time: less than 3 weeks So i am back in action. However, did a order for 2 more BK’s, and they got lost in shipping, so will get a refund on that and will have to do a new order.
My MA had a blown voice coil, so it was replaced, had to pay for it, but still worth it, of course
Randolph said the NU6K was too much amp, but i have used it for years without problems, and i do not run the amp full tilt, so IDK.
However, both times they were blown, it happened on the ones under the right seat, not my leaft seat, and i watch movies alone probably half the times, so maybe the right ones bottoms out easier with the same power but less weight.
My 2 BK’s works very well with the settings i have on them now, and only a rare time do i hear the dreaded noise from them, maybe some music score in a movie with a steady beat that triggers a noise, but most times it is fine
SBuger, aron7awol and biga6761 like this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 4xSI-HT18v2 in 2xDO Sonos - 12x12" JBL GT-X1200 NF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873 - Harmony Ultimate.
Nalleh’s HT
Nalleh is online now
post #3358 of 7416 Old 12-24-2018, 12:53 AM
paulst's Avatar
Quoted: 169 Post(s)
Liked: 358
Thanks, I have one of those credit card type remotes lying around so I'll try that then teach the commands to the Harmony..
Medi0gre likes this.
post #3359 of 7416 Old 12-24-2018, 01:22 AM
Nalleh's Avatar
Liked: 3021
Or you can just import some random product into the Harmony(i used a Sony Tv that didn’t interfere with my other products) and then learn from the Minidsp plug-in the commands you want(and rename if needed on your Harmony). Learning remote commands are covered in the Minidsp manual.
galonzo and paulst like this.
Nalleh’s HT
post #3360 of 7416 Old 12-24-2018, 08:01 AM
Liked: 9492
I didn't realize the TV series weren't counting toward the total. Those series are like 10x the work of a movie!
What was the issue?
How many MAs do you run off the NU6K? Any idea how much power you are pushing to them in the most demanding scenes? Do you ever come close to or hit the limiter? I'm just curious because I am going to be testing my NU3K soon with my MAs.
Considering the Crowson amp is rated at 500W when driving 4 MAs (2 4-ohm loads), and if we assume it is exactly as capable as its specifications say, a NU3K should be able to push ~2x the power into the same loads, and a NU6K ~4-5x the power. The MAs are rated for 500W RMS so a bridged NU3K would seem to be well-matched to push a pair to their limits, and a NU6K well-matched to do the same for 4 of them. Hitting the limiter in either of those cases would be pushing them a bit beyond their rated limits. You may have already done this math, I'm just throwing this out there for anyone who might have similar situations.
Part of the reason I want to test with my new NX3000D is I currently don't really know exactly how hard I'm pushing my Crowson amp and MAs. It definitely seems like they don't need a lot of power to throw us around, but I wonder if I can eliminate the times where my couch goes a little out of control, maybe I can push my Crowsons even more, safely. Having the meters in the NX3000D software will be a nice indicator to finally inform me of how much power translates to certain levels of the MAs.
