Bass EQ for Filtered Movies - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 20243Likes
post #4801 of 8215 Old 02-17-2019, 10:21 AM
paulst's Avatar
Quoted: 181 Post(s)
Liked: 398
Originally Posted by aron7awol View Post
Thanks for the feedback!
Yes, the older ones were more conservative for a couple of reasons. One, before I was dong MV adjustments I couldn't push it as hard because if someone does a significant +MV adjustment and it's already up at that -15 to -20 band, it could end up dangerously high. Two, without having the peak spectrum as a guide, it was difficult to know when I was boosting noise rather than real content.
No probs, I watched ep4 the other week and that was a nice improvement overall also.
Now, I suppose the ultimate question is, if you had to update the Star Wars BEQ's would they be any different?
galonzo and Nalleh like this.
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is offline
post #4802 of 8215 Old 02-17-2019, 10:21 AM
3ll3d00d's Avatar
Quoted: 2291 Post(s)
Liked: 2385
Originally Posted by SuperFist View Post
Yes, normally I'd agree with you, but the 8Hz filter with the -10 reduction was the only way I could tame that huge peak at around 3Hz.. otherwise it's up to scary levels (see below).
Try a high pass filter
galonzo, SuperFist and Nalleh like this.
3ll3d00d is online now
post #4803 of 8215 Old 02-17-2019, 10:23 AM
3ll3d00d's Avatar
Liked: 2385
I think any decent pc based software can filter down below 10Hz. I won't limit this in the app, users designing filters can choose their own limit instead.
post #4804 of 8215 Old 02-17-2019, 10:27 AM
Nalleh's Avatar
Quoted: 2403 Post(s)
Liked: 3132
Noted I was just hung up in our «Minidsp-bubble" over here
trhought likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is offline
post #4805 of 8215 Old 02-17-2019, 10:47 AM
SuperFist's Avatar
Quoted: 1267 Post(s)
Liked: 4960
Hey, @3ll3d00d
It seems the display of the High Pass Filter is jumbled in the graph as it adds another column on the right since the wording is more characters than the other fields.
I wonder if just the word "High" or "HPF" could fit in there and be sufficient?
Spoiler!
Nalleh likes this.
Subwoofers: PSA S3000i x 2 | L+R Front: Onkyo SKF-200F | Center: Onkyo SKC-200C | L+R Surround: Onkyo SKM-200S | Atmos: Pioneer SP-T22A-LR | AVR: Yamaha RX-A660BL | HTPC: Lenovo Q190
SuperFist is online now
post #4806 of 8215 Old 02-17-2019, 11:14 AM
Quoted: 2387 Post(s)
Liked: 10212
[CENTER]BassEQ The Quake (Skjelvet) (2018) Dolby Digital 5.1
I simply adjust my Main Volume (MV) as needed so I don't include them in the graph like Aron does. (Not technically adept at how he figures that out and makes it show up in the filter graph anyway.)
[CENTER]BassEQ Trollhunter (2010) DTS 5.1
I manually adjust the MV so it's not listed in the chart, but I think it's set just about right as that Troll is rolling with bass!
Just want to mention a couple things...
I've refrained from doing BEQs with lossy transcodes unless I can verify and share the source, so that I'm basically guaranteeing safety of my BEQ as long as the user's source explicitly matches mine. For example, the web streams like Amazon DD+ and Netflix DD+ are easy enough for people to know they are matching my source. But for something that's on BD/UHD BD I've only ever used the lossless audio, because the only way I can vet a lossy transcode and guarantee it's the same as the disc is to use the lossless audio anyway. Obviously you don't have to follow what I do, but I just figured I'd share the reasoning behind my approach and caution anyone using BEQs of lossy transcodes to at least know that they are doing so and knowingly accepting the risks.
I'd also like to clarify that I adjust MV by ear as well, and recommend that everyone do so. The purpose of the MV adjustment in the BEQ is not actually at all intended to be a recommendation. It is intended to be a guaranteed consistent maximum level in the ULF. With so many of us pushing our systems at or near their limits in the ULF with these BEQs, it gives everyone a MV adjustment that will put the ULF at a consistent level that we can know our systems handle a certain way. If someone runs that BEQ above or below that MV adjustment, it's perfectly fine, but they can know that the ULF peaks will be that much above/below the level that they are accustomed to on the normal mixes. So it's really just a guess at a MV that those of us adjusting by ear will end up at. It's not a perfect guess, but it's a really good guess that usually ends up really close, and much better than no guess at all. The concern I always had with designing a BEQ solely on curve shape and then adjusting MV by ear is that the peaks of the ULF could end up way higher than normal and/or safe on a particular system. Considering that the MV adjustments are often +/- 5dB (or even more in some cases), that's a big window of uncertainty as far as final ULF peaks when ignoring MV level during the BEQ design. Again, of course you don't have to follow what I do, but I just wanted to explain the reasoning behind what I do. I guess I've always felt like I have to stand behind my published BEQs with a guaranteed consistency and safety because I'd feel terrible if I did something that contributed to damaging someone's system. So it really comes down to establishing that consistent baseline that people are certainly encouraged to deviate from, just making sure they are knowingly doing so.
SBuger, trhought, galonzo and 4 others like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #4807 of 8215 Old 02-17-2019, 11:19 AM
Liked: 10212
Yes, normally I'd agree with you, but the 8Hz filter with the -10 reduction was the only way I could tame that huge peak at around 3Hz.. otherwise it's up to scary levels (see below). Unless Aron has another sane way to tame it.
I use negative 10Hz LS filters for this purpose. Most people enter their BEQ filters on their MiniDSP input(s) and a HPF can't be entered there, and the negative LS works well.
SuperFist, Nalleh and d-rail34 like this.
post #4808 of 8215 Old 02-17-2019, 11:22 AM
Liked: 10212
I'm sure they would be Between the MV adjustment and peak spectrum, I'm sure I could do a better job with those.
galonzo, paulst, Nalleh and 1 others like this.
post #4809 of 8215 Old 02-17-2019, 11:44 AM
SuperFist's Avatar
Liked: 4960
Hmmmmm.... This looks like a lot of filters just to achieve that. I don't really see yours being this voluminous.
I may just have to leave this BEQ crafting to you, Jedi Master Aron!
Spoiler!
post #4810 of 8215 Old 02-17-2019, 11:54 AM
Liked: 10212
I may just leave this BEQ crafting to you, Master Aron!
I usually use 10Hz Q0.9 filters for this, as they are a lot steeper than Q0.7. Hmm, that does seem like a lot of filters in general, especially with positive filters at 13Hz and negative filters at 10Hz.
On this one, I'd probably start with some really steep Q1.1 filters that hold the peak at ~25Hz and pick up as much as possible right beneath that. Then see where that leaves me and kind of attack it working my way down in frequency. If I end up in a position where I'm not really happy with how much I was able to boost the ULF and wanting to use filters below 10Hz, then I take another look at the higher filters to see what adjustments I can make to affect where I ended up.
galonzo, SuperFist and d-rail34 like this.
post #4811 of 8215 Old 02-17-2019, 12:25 PM
SuperFist's Avatar
Liked: 4960
I went back and placed Spoiler tags on all of mine so people on the forum won't get them confused with the official BEQs from you.
Here's my last college try... 1 less filter, but I really don't know how to make it look any better.
Spoiler!
However, I will attempt to revisit The Quake and Trollhunter once I get the blu-ray versions to keep in alignment with your BEQ posts on this forum.
aron7awol and Nalleh like this.
post #4812 of 8215 Old 02-17-2019, 12:54 PM
3ll3d00d's Avatar
Liked: 2385
thanks and yes I agree, added https://github.com/3ll3d00d/beqdesigner/issues/214
post #4813 of 8215 Old 02-17-2019, 01:03 PM
3ll3d00d's Avatar
Liked: 2385
Originally Posted by trhought View Post
For the Bass Management section of BEQ (circled in green below), is there a way to change the LPF so the summed SW signal will represent my particular LPF in my AVR?
the filter type is not currently user editable, it's hardcoded as an LR4. I could make this editable but I think it's important tbh as changing that is highly unlikely to make a material difference to the waveform peaks and that's all we're really interested in at this point. If there is some particular thing you're trying to do for which editing this is critical then feel free to log that on github and I may get to it at some point.
The frequency is editable via the preferences dialog though, look for the BM LPF field.
For the frequency domain graph circled in yellow, any idea what the red signal is? It looks to be a smoothed response of the green filtered signal above it....maybe 1/3 octave smoothing?
it's the PvA view so red is the A(verage)
trhought, aron7awol and biga6761 like this.
post #4814 of 8215 Old 02-17-2019, 01:15 PM
Liked: 10212
BassEQ Ralph Breaks the Internet (2018) Atmos
DTS-HD MA 7.1:
Spoiler!
SBuger, galonzo, SuperFist and 4 others like this.
post #4815 of 8215 Old 02-17-2019, 01:24 PM
Liked: 10212
Originally Posted by femi View Post
Hi @aron7awol , another BEQ request for you sir: Netflix series The Umbrella Academy.
Thanks man.
Femi
Thanks for requesting this one! I hadn't heard of it yet and it looks really good! I'm working on it now, should be able to get it finished tonight.
galonzo, femi, biga6761 and 1 others like this.
post #4816 of 8215 Old 02-17-2019, 01:46 PM
ArchBishopFocwod's Avatar
Quoted: 31 Post(s)
Liked: 80
I would like to put a request in for WaterWorld, it just got a remaster which looks great.
SuperFist, aron7awol and biga6761 like this.
ArchBishopFocwod is offline
post #4817 of 8215 Old 02-17-2019, 01:56 PM
Quoted: 30 Post(s)
A few requests.
Can you do the other Rambo flicks.
Minions. ( done ) thank you.
Spider-Man ( Sam Raimu version )
Spider-Man 2 (Raimu )
Night at the Museum 2
Bram Stokers Dracula.
Total Recall ( Schwarzenegger )
The Golden Compass
Megamind
The Resident Evil flicks
Just a few, I will save the other 250 for another day.
Ted Mcvey is offline
post #4818 of 8215 Old 02-17-2019, 02:18 PM
SuperFist's Avatar
Liked: 4960
Originally Posted by Ted Mcvey View Post
A few requests.
Minions.
Independence Day.
Smallfoot.
The Golden Compass
Megamind
I'm seeing more than a few of those on the first page in the first post. For example, Independence Day and Smallfoot are already done, so make sure you take another gander and edit your post for those that really aren't done, yet.
aron7awol likes this.
post #4819 of 8215 Old 02-17-2019, 02:20 PM
Liked: 10212
BassEQ The Umbrella Academy (2019) Season 1 DD+
Alaric, galonzo, SuperFist and 3 others like this.
post #4820 of 8215 Old 02-17-2019, 03:13 PM
trhought's Avatar
Quoted: 547 Post(s)
Liked: 1006
3ll3d00d.....Thanks. Good to know about the editable frequency in the preferences....will check it out.
I think my AVR also uses a 24dB/octave filter type so that's good to know also but as you said, it's probably not going to make a big difference for the purpose of looking at waveform peaks.
Didn't realize that was PvA....makes sense now and follows the usual color nomenclature as the other PvA graphs.
Greatly appreciated!
trhought is offline
post #4821 of 8215 Old 02-17-2019, 03:18 PM
Liked: 10212
BassEQ Sex Education (2019) Season 1 DD+
galonzo, SuperFist, femi and 1 others like this.
post #4822 of 8215 Old 02-17-2019, 03:59 PM
Nalleh's Avatar
Liked: 3132
I did a little test tonight. I managed to install(not without problems) BEQd on my old laptop(couldn’t get it installed on my Mac), open a BEQ file, export the biquad file onto a thumbdrive, open on the Mac and import the BEQ to my 10x10HD. And it worked ! YEIIIIH.
I did not have to change to 6 biquads in BEQd, if the file had more than that, it simply ignored them when i imported the file. So if the BEQ has 6 or less biquads, it works just perfect.
And if those big BEQ has a overshoot filter and a PEQ as nr1 and2, then the LS above nr6 is ignored.
But still, this should be easier than typing the filters manually
I think if i divided the txt file, i could import the above 6 biquads to the output side.
SBuger and SuperFist like this.
Nalleh’s HT
Nalleh is offline
post #4823 of 8215 Old 02-17-2019, 04:20 PM
Liked: 10212
BassEQ Minions (2015) Atmos
SBuger, PioManiac, galonzo and 3 others like this.
post #4824 of 8215 Old 02-17-2019, 04:49 PM - Thread Starter
PioManiac's Avatar
Quoted: 3179 Post(s)
Liked: 7764
Pretty Sure all the Minions (Despicable Me) series is DTS:X in 4K/UHD format (not ATMOS)
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #4825 of 8215 Old 02-17-2019, 04:51 PM
Liked: 10212
I don't know about the Despicable Me series, but Minions is definitely Atmos.
Edit: I'll do the Despicable Me DTS:X mixes really soon too.
PioManiac, galonzo, Nalleh and 1 others like this.
post #4826 of 8215 Old 02-17-2019, 04:52 PM
Nalleh's Avatar
Liked: 3132
^^ Nope, Minions is Atmos
https://www.blu-ray.com/movies/Minio...lu-ray/182835/
Nalleh’s HT
Nalleh is offline
post #4827 of 8215 Old 02-17-2019, 05:01 PM - Thread Starter
PioManiac's Avatar
Liked: 7764
Yup, my bad
That's odd, I think Despicable Me was actually the First DTS:X title released on 4K UHD with Dolby Vision
....and then 2 and 3 followed shortly after. I wonder why they made the change for Minions?
post #4828 of 8215 Old 02-17-2019, 05:10 PM
Liked: 10212
BassEQ Despicable Me (2010) DTS:X
SBuger, galonzo, SuperFist and 3 others like this.
post #4829 of 8215 Old 02-17-2019, 05:13 PM
Liked: 10212
Yup, my bad
I think it's because Minions was mixed in Atmos from the beginning, while the first two DMs were re-mixed for the UHD releases.
post #4830 of 8215 Old 02-17-2019, 05:23 PM
Liked: 10212
BassEQ Despicable Me 2 (2013) DTS:X
