Bass EQ for Filtered Movies - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 20402Likes
post #481 of 8277 Old 09-05-2018, 06:23 PM
SBuger's Avatar
Quoted: 1161 Post(s)
Liked: 3597
Originally Posted by tvuong View Post
@biga6761 , I will read that thread. Thanks for the pointer. I am not going to lie but looking at the beq graphs here making me want to revisit all of those movies, seriously 😳. Well done guys 👍. There won’t be a bad bass movie from this point
Originally Posted by markmon1 View Post
I dunno. I think a little roll off feels more natural. I think the transformers movies are about the best bass sound I’ve ever heard from anything. Specifically transformers 2. I think any boost on that makes it worse. Of course my subs are infinite baffle and go to 5hz flat. Perhaps other subs that go to those levels with some roll off might benefit from this but that feels more like the job of room correction to me. I’m fully on board with this for movies like avengers infinity wars and Star Wars that were just butchered. But once you start “correcting” ready player 1 and transformers I feel it becomes hard to take this seriously.
Well it'll come down to personal preference for sure on some of these and whether or not your system is capable of full bandwidth into the low teens and or single digits, which sounds like yours is. If you like the way TIH, Hellboy II and BvsS feel and sound, then most of these should be similar now. Like tvoung said above, at this point with the BEQs as fast as these guys are kicking them out, there really shouldn't be a bad bass mix at this point if you want it.
Most all of these graphs are looking damn impressive down low and look like a combo of the 3 films I listed above. Yes, some are already look really good as is and now fantastic. I know its already been said, but awesome job guys!!!
brahman12 and CallingMrBenzo like this.
My "Blacked Out" Home Theater Room
1400cuft sealed room, suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo 203 | Epson 5040 4K | Eyes 7' to 120" AT Seymour Screen | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' 6x JBL12s | MiniDSP 10x10HD
SBuger is offline
post #482 of 8277 Old 09-05-2018, 06:33 PM
DaBateman's Avatar
Quoted: 721 Post(s)
Liked: 517
Originally Posted by Ruppgu View Post
Steps to do a BEQ graph:
This is all you have to do:
1.) Rip movie to your PC using makemkv (https://www.makemkv.com/)
2.) In the beq designer (https://github.com/3ll3d00d/beqdesigner), select Extract Audio from the tools menu and select the mkv file.
3.) Click the extract button
4.) Click Add under signals and select the file that step 2 created
5.) Click preview and then ok
6.) Start adding filters until you are happy with the result. Most filters will be low shelf filters with a Q around 0.7-1.0.
I decided not to do pictures. I worry the UI of the app may change and then the instructions would need to be updated or they would be out of date. I'm not really sure pictures are needed, the steps are very simple.
Awesome! I’ll post some graphs tomorrow. Thanks fellows.
Also thanks @aron7awol for completing so many of my request a day later. I cannot wait to go back & watch these again!
I don’t think you guys can be commended enough for keeping the list updated and making the graphs for the list. I know it has to be time consuming but just know that it is very much appreciated. You guys are doing a stand up job.
| Eqmt | Vizio 4K M50-E1 | Yamaha RX-V681 | iNUKE 3kdsp x2 | Emotiva BasX A-100 | miniDSP UMIK-1 | Monolith M1060 | Monolith USB DAC |
| Sub | Trilithon | Stonehenge Variant Subwoofer - 18” - 9ft³ - 19Hz | Marty | Microcube 390HO - 22Hz | Monolith THX Ultra 12 | Monolith THX Select 10 |
| Spkrs | HSU CCB8 x3 | SVS Prime Elevation x2 | Polk S15 |
DaBateman is offline
post #483 of 8277 Old 09-05-2018, 06:43 PM
SBuger's Avatar
Liked: 3597
If one is worried about just a little bit of overshoot on some of these, then it can probably be corrected pretty easily with one more filter in addition to the LS’s. Instead of an another LS, a PEAK could be used with a little wider Q with a 1 to 1.5db boost (or however much it needs) in the middle of however far it spans. Just a thought. That or maybe bump to your sub trims up 1 more db to make up for it, which will increase your MB and ULF a little if the overshoot is dropping the area just a bit if I’m looking at it correctly. Like Aron said though, it’s probably not going to matter much and the ULF extension down low will more than make up for the slight loss in the area affected most likely.
SBuger is offline
post #484 of 8277 Old 09-05-2018, 06:44 PM
richardsim7's Avatar
Quoted: 1312 Post(s)
Liked: 1682
Speaking of which, might it be worth the person posting the BEQ graph/details adding the title line in the same format as Pio does at the top of their post, so he can just copy/paste it? Or is that overkill?
richardsim7 is offline
post #485 of 8277 Old 09-05-2018, 07:42 PM
Quoted: 2395 Post(s)
Liked: 10304
BEQ Saving Private Ryan (1998) Atmos
LS 25Hz Q1.1 4.5dB x 5 (22.5dB total)
LS 70Hz Q0.7 3dB (overshoot compensation)
This one was a bit of a challenge because it required a super steep slope that resulted in 2dB+ overshoot, but I was able to find a LS to compensate perfectly.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #486 of 8277 Old 09-05-2018, 07:56 PM
SBuger's Avatar
Liked: 3597
^^^ Damn that looks awesome!!! I lost my mkv copy of SPR so will have to get it again and try it out.
EDIT: Man, some of these BEQ beautifully!!! Also nice overshoot compensation with the LS @70hz. I was thinking a PEAK might work good like I was trying to explain above in one of my posts, but looks like this completely nailed it. Nice!!
SBuger is offline
post #487 of 8277 Old 09-05-2018, 08:07 PM
Liked: 1682
This one was a bit of a challenge because it required a super steep slope that resulted 2dB+ overshoot, but I was able to find a LS to compensate perfectly.
Have you tried it out? How does it sound?
post #488 of 8277 Old 09-05-2018, 08:14 PM
Liked: 10304
Try it? I don't have any time to actually watch any of these. Making BEQs is my full-time job!
I'll test out the beach scene some time this week and report back.
post #489 of 8277 Old 09-05-2018, 08:20 PM
SBuger's Avatar
Liked: 3597
I don’t see Pacific Rim (the 1rst one) on the list, only PR2. I thought you had done that one. Maybe it was Biga with JRiver a while back over in the main movies bass thread.
EDIT: wow that list is growing sooo fast!!
SBuger is offline
post #490 of 8277 Old 09-05-2018, 08:29 PM
Liked: 10304
BassEQ Spider-Man: Homecoming (2017) Atmos
The small negative 10Hz is necessary to keep the peak signal in check, but there's still a good amount unlocked here.
post #491 of 8277 Old 09-05-2018, 08:31 PM
Liked: 1682
@PioManiac some release dates for you:
Hunt for Red October/Jack Ryan: Shadow Recruit/Sum of All Fears: Aug 21, 2018
Central Intelligence: Sep 27, 2016
As for GI Joe, looks like the BD and 4K have the same audio tracks, so might as well use the BD release date:
Rise of the cobra: Oct 19, 2010
Retaliation: Jul 30, 2013
Also you labelled Lucy as Lucy Hunter
post #492 of 8277 Old 09-05-2018, 08:38 PM
Ruppgu's Avatar
Quoted: 477 Post(s)
Liked: 537
Hey pio, i see you input your filters on the output of minidsp. That works fine... but if you want to have a filter on all your outputs then it's easier to add the beq to the input. The outputs are useful if you want to add a filter to only some of the outputs. Just make sure you don't switch ways and leave filters active on your output and then double dip by adding one to the input if you switch
richardsim7 likes this.
TV: Sony A9G 77" Oled & LG B7A 65" Oled
AVR: Denon AVRX4300H
F/L: Emotiva Airmotiv T2, Center: Emotiva Airmotiv C2, Surround: Emotiva Airmotiv B1 x4, Atmos: Elac A4 x4, Subwoofer: PSA V1811, Actuator: Crowson x2
4k Player: Panasonic UB 820
Ruppgu is offline
post #493 of 8277 Old 09-05-2018, 08:43 PM
Liked: 10304
BassEQ Pacific Rim (2013) Atmos
The -6dB gain is a MV decrease.
post #494 of 8277 Old 09-05-2018, 08:49 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ Doctor Strange (2016) DTS-HD MA 7.1
DesertDog is offline
post #495 of 8277 Old 09-05-2018, 08:52 PM
Liked: 10304
BEQ The Accountant (2017) DTS-HD MA 7.1
LS 18Hz Q1.1 4dB x 4 (16dB total)
post #496 of 8277 Old 09-05-2018, 08:55 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ Kingsman: The Secret Service (2014) DTS-HD MA 7.1
SuperFist likes this.
post #497 of 8277 Old 09-05-2018, 09:03 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Bourne Identity (2002) DTS:X
post #498 of 8277 Old 09-05-2018, 09:07 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Bourne Supremacy (2004) DTS:X
SuperFist and AmerCa like this.
post #499 of 8277 Old 09-05-2018, 09:10 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Bourne Ultimatum (2007) DTS:X
post #500 of 8277 Old 09-05-2018, 09:13 PM - Thread Starter
PioManiac's Avatar
Quoted: 3185 Post(s)
Liked: 7784
Where possible, it would help me if you note your disc source...BD or 4K/UHD. Audio track you selected, and the disc release date (not the theatre release)
I've been using the search at blu-ray.com, but some have many choices and I end up just guessing.
The other alternative is to eliminate that info altogether.
But that may cause issues for those loading your BEQ settings for a totally different release.
PioManiac is offline
post #501 of 8277 Old 09-05-2018, 09:21 PM - Thread Starter
PioManiac's Avatar
Liked: 7784
I prefer not to boost ULF frequencies that are going to my rear near field MBM subs. ULF only needs to be fed to the single digit capable Funks up front.
Nalleh likes this.
post #502 of 8277 Old 09-05-2018, 10:38 PM
3ll3d00d's Avatar
Quoted: 2298 Post(s)
Liked: 2391
Thanks. I have been using LS filter in jriver dsp. ‘Added S to the app’ huh, what is that? Perhaps it will be clear after reading your link?
https://wiki.jriver.com/index.php/Pa...ualizer#Q_or_S
You will need you enter the filters into my app and use the S value it calculates for you when entering it into jriver
biga6761 likes this.
3ll3d00d is offline
post #503 of 8277 Old 09-05-2018, 11:36 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Lord of the Rings: Fellowship of the Ring EE (2001) DTS-ES 6.1
BD May 1, 2012
Gave these a go to test BEQ Designer with DTS-ES 6.1.
SuperFist, biga6761 and d-rail34 like this.
post #504 of 8277 Old 09-05-2018, 11:37 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Lord of the Rings: Two Towers EE (2002) DTS-ES 6.1
BD May 1, 2012
post #505 of 8277 Old 09-05-2018, 11:40 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1487
BEQ The Lord of the Rings: The Return of the King EE (2003) DTS-ES 6.1
BD May 1, 2012
post #506 of 8277 Old 09-05-2018, 11:54 PM
3ll3d00d's Avatar
Liked: 2391
Originally Posted by DesertDog View Post
Anyone know what scenes cause the peaks around 40hz?
no but the analyser does, I could get it to dump out time periods for peak frequencies
brahman12, aron7awol and biga6761 like this.
3ll3d00d is offline
post #507 of 8277 Old 09-05-2018, 11:56 PM
3ll3d00d's Avatar
Liked: 2391
note the instructions I wrote earlier in https://www.avsforum.com/forum/113-s...l#post56690092
i.e. you need to have ffmpeg installed and set in the paths in preferences
3ll3d00d is offline
post #508 of 8277 Old 09-06-2018, 06:23 AM
Ruppgu's Avatar
Quoted: 477 Post(s)
Liked: 537
Thanks, I forgot about that step. I have updated my steps.
Ruppgu is offline
post #509 of 8277 Old 09-06-2018, 06:36 AM
Ruppgu's Avatar
Quoted: 477 Post(s)
Liked: 537
Hey @aron7awol
Since you are the main guy that creates and uses these BEQs, I was wondering if you could provide some info about your bass settings which might explain how you like the low end.
For example:
Do you have a house curve? How Strong?
How hot do you run your subs?
Do you have Dynamic EQ enabled?
What's your typical MV level?
I think the house curve especially can play a big factor because if someone is running a large house curve at the low end (probably because many movies roll off like this), they may not want as much as a bump from these BEQs... or maybe they should tone down their house curve.
Ruppgu is offline
post #510 of 8277 Old 09-06-2018, 06:43 AM - Thread Starter
PioManiac's Avatar
Liked: 7784
So far I've ran with Aron's BEQ settings for Atomic Blonde, Oblivion and Valerian.
No issues at all with my normal listening levels (around -18MV on my Yamaha)
No Dynamic EQ, 4 subs are measured in pairs and set to about 10dB hotter than my speakers with an SPL meter.
...but because there are 2 pair, that adds another +6dB (I think?)
When I pushed Oblivion to -14MV for "Coming in Hot!"
and the Cable Snap scene (LFE/ULF Sweep) at the library
... I had no problem (other than I peed a little )
My Funk 18.0's read at least +10dB higher at 14Hz than at 20-30Hz (before BEQ)
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
