Bass EQ for Filtered Movies - Page 203 - AVS Forum | Home Theater Discussions And Reviews
 18788Likes
post #6061 of 7646 Old 04-05-2019, 12:36 PM
Nalleh's Avatar
Quoted: 2392 Post(s)
Liked: 3072
Originally Posted by paulst View Post
Save you the hassle, I did a quick guide to this on the thread over at Avforums..
Instructions on keeping your output settings while loading a BEQ file onto the inputs using BEQ Designer
Make sure you have your default config saved beforehand
1 select file/ADD BEQ Filter
2 select the BEQ file you wish to load
3 select file/export biquad and select 96000 and make sure MiniDSP is ticked and click the save icon and save to a text file in a location you'll remember
4 Using the 2x4 plugin software, select one of the inputs, then select PEQ, then advanced (bottom left) then import (on the right).
5 select the file you just saved and click open
6 You can also save the config again with a movie name and start to build up your own library of BEQ files for future use with all your outputs still in tact.
7 When you have finished watching, simply reload your default config back to the config slot
About 6 and 7:
You already save the BEQ biquad, and it is much faster to just do step. 4 for each movie, than saving each as a full config.
When done instead of reloading your default config(takes time), just go back to the PEQ and press "clear"(instant, no waiting).
The library would just be the BEQ biquad files
Alaric, magicj1, paulst and 1 others like this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #6062 of 7646 Old 04-05-2019, 03:26 PM
Quoted: 2306 Post(s)
Liked: 9642
I reckon it's safe to say Star Wars Last Jedi and Independence Day Resurgence are both good also.. Fifth Element Remastered was dubious but safe.. All 3 are posted here if you need to check them https://www.avsforum.com/forum/113-s...l#post57842996
Alright, I just updated all of the posts for these. I have one humble request for future ones. Can you please fully specify the track as 5.1 or 7.1? For John Wick 2 you did specify it, but for the others you just specified DTSMA and TrueHD. I like to fully specify it in my posts so there's no confusion for anyone between the mixes that have 5.1 and 7.1 versions. Thanks again for doing them!
galonzo and paulst like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #6063 of 7646 Old 04-05-2019, 11:43 PM
paulst's Avatar
Quoted: 172 Post(s)
Liked: 359
No probs..
Indepenence Day Resurgence was DTSMA 7.1 UK BD
Last Jedi was 7.1 DTSMA UK BD
Fifth Element Remastered was TrueHD 5.1 US BD
Gonna go for The Hunger Games today
pixphipau and magicj1 like this.
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is offline
post #6064 of 7646 Old 04-06-2019, 02:48 AM
Quoted: 12 Post(s)
Liked: 2
Thanks, worked a treat! Now is there a way we can batch convert the BEQ config files to biquads?
Also - I've been playing around with the BEQ designer. The main movies are always covered but I'm an avid watcher of TV shows and would like to create some BEQ for things like Arrowverse shows. Is there a good design tutorial? When I'm EQing for Subs REW has an automatic calculator to hit a target response. Is that something you can do with the BEQ designer? Or is it just tiral and error?
Dushyant Patel91 is offline
post #6065 of 7646 Old 04-06-2019, 02:54 AM
Alaric's Avatar
Quoted: 90 Post(s)
Liked: 105
I pondered this early on. The info is in the files and in theory could be scripted, however due to the 2x4 & 2x4HD having different frequencies (48/96hz) it's a bit more complex... And there's an app in development anyway!
Sent from my HTC U11 using Tapatalk
Sound - Marantz SR6011 (pre/atmos), Yamaha Z9, Mirage Om-6's, Om-C2's, 6x Om-R2's, 4x Nanosat (atmos), Dual Paradigim Servo 15's
Additional - MiniDSP : DDRC-88a, 2x4HD
Source -Panasonic DP-UB420, Toshiba HD-XE1, Sony SCD-XE620
Vision - Epson TW9400, eecolour Lut Box, 120" Spitfire Acoustically Transparent Screen
Alaric is offline
post #6066 of 7646 Old 04-06-2019, 08:31 AM
3ll3d00d's Avatar
Quoted: 2269 Post(s)
Liked: 2319
I hacked a quick batch updater together which allows you to pick your own minidsp config file and then blats out a copy of that file for each entry in the beq git repo overwriting the specified PEQ slots (i.e. where the beq filters live in that repo) as it goes with the contents of the BEQ
I can't test this at all as I don't have a minidsp so that means I have no idea if a minidsp will accept these files, the xml looks valid though so one would hope it does but I strongly recommend you check what comes out is valid If it blows up in some way then let me know what happens! I mean if the app blows up btw, you're on your own if you blow up your sub
note that I'm using a random file from the git repo as my master config file just because I have no other such config files, the intended use is that you export your current config (containing whatever eq you need for your subs) to an xml file and use that as the config file to feed into it
will publish a build shortly
@DesertDog I could build that for you if you like though if you do have access to a windows machine then just install anaconda and then update pip, if you use numpy/scipy then get conda to install that otherwise it's fine to just use pip (i.e. it's behaves the same as python on osx and linux).
3ll3d00d is offline
post #6067 of 7646 Old 04-06-2019, 08:56 AM
3ll3d00d's Avatar
Liked: 2319
here's a build, I bumped it to stable since it's been a little while and @aron7awol commented it was working fine
https://github.com/3ll3d00d/beqdesig...ases/tag/0.6.2
galonzo, aron7awol, Nalleh and 2 others like this.
3ll3d00d is offline
post #6068 of 7646 Old 04-06-2019, 09:30 AM
Liked: 9642
Updated...
BassEQ The Hunger Games (2012) Atmos
Note: The DTS-HD MA 7.1 track has been validated as safe to use with this BEQ by @paulst
paulst and biga6761 like this.
post #6069 of 7646 Old 04-06-2019, 09:51 AM
paulst's Avatar
Quoted: 172 Post(s)
Liked: 359
Updated...
I thought this one might get updated I deleted the graph, I'll see if it fits the DTS track tomorrow.
paulst is offline
post #6070 of 7646 Old 04-06-2019, 09:59 AM
Liked: 9642
Updated...
BassEQ Transformers (2007) Atmos
galonzo and biga6761 like this.
post #6071 of 7646 Old 04-06-2019, 10:02 AM
Liked: 9642
I discovered there was something wrong with my Transformers Atmos track. I have no idea what happened to it, but I went back and re-did it from scratch and updated the BEQ. Since I take safety so seriously, I also went and checked all the other past tracks I've extracted for the same issue and didn't find any. Sorry for the mistake, fellas.
post #6072 of 7646 Old 04-06-2019, 10:14 AM
Liked: 9642
Originally Posted by drewp29 View Post
Curious, but what does the BEQ do for the Ironhide flip scene? Has anybody demoed that with and without BEQ? That's one of my favorite scenes to play for people because the end of the sweep causes major disruption of wall panels and anything not physically tied down, lol.
The Ironhide Flip is a sweep from 50Hz to 30Hz, and BEQ does give it more weight that should make the sweep feel fuller and more extended a bit:
post #6073 of 7646 Old 04-06-2019, 10:54 AM
Nalleh's Avatar
Liked: 3072
^^ Wow, that was a cool way of showing that effect ! Spectrum rules
Nalleh’s HT
post #6074 of 7646 Old 04-06-2019, 12:15 PM
Quoted: 125 Post(s)
Liked: 243
Thumbs up
Tested your latest build Visually. Everything looks good !!! now even my wife can apply BEQ
I did test the overlord BEQ.
https://www.avsforum.com/forum/113-s...l#post57576246
Excited with your new release . Thank you for the awesome release
what-i-d-do-differently-next-timehttps://www.avsforum.com/forum/19-ded...l#post55641388
Epson Projector Power Supply Failure.https://www.avsforum.com/forum/68-dig...lure-rate.html
avtvhdbass is offline
post #6075 of 7646 Old 04-06-2019, 12:26 PM
paulst's Avatar
Quoted: 172 Post(s)
Liked: 359
Looking good, thanks
galonzo likes this.
paulst is offline
post #6076 of 7646 Old 04-06-2019, 01:47 PM
AmerCa's Avatar
Quoted: 676 Post(s)
Liked: 1401
@paulst
By any chance do you have Power Rangers (2017) 5.1 DTS-MA? I'm noticing UK and Mexico get often the same audio tracks.
Enviado desde mi XT1032 mediante Tapatalk
Vizio 43" D Series 2017 || Onkyo TX383 7.2ch || Fronts: Sony SS-CS5 || Center: Pioneer SP-C22 || Sub: Polk HTS 12 || Surrounds: Micca MB42
AmerCa is offline
post #6077 of 7646 Old 04-06-2019, 05:24 PM
AdamAttewell's Avatar
Quoted: 559 Post(s)
Liked: 120
Any idea why when I follow these instructions when trying to import the biquad text file into the MiniDSP I get the error:
"Error input: Missing biquad value(s) Please re-enter."
biga6761 likes this.
AdamAttewell is online now
post #6078 of 7646 Old 04-06-2019, 05:50 PM
Quoted: 125 Post(s)
Liked: 243
post #6079 of 7646 Old 04-06-2019, 07:16 PM
d-rail34's Avatar
Quoted: 366 Post(s)
Liked: 699
Hey guys,
Anybody else notice that the latest version of BEQD is a bit laggy?
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon: AVR-X2400H/Hsu Research: HB-1 Bookshelfs (4)/Hsu Research: HC-1 Center (1)/SVS: PB12 Plus (1)/Samsung: UN65H7150/Sony: UBP-X800/PC: Built by D-Rail
Bedroom - Blose: Cinemate II GS 2.1/Sony: XBR49X800E/XBox: One S
d-rail34 is offline
post #6080 of 7646 Old 04-07-2019, 12:58 AM
3ll3d00d's Avatar
Liked: 2319
Originally Posted by d-rail34 View Post
Hey guys,
When doing any particular actions? And/or in comparison to which build?
If it is in comparison to 0.6.1 then the change in the way smoothing works does cost some CPU but it should not be a significant effect. I guess that might depend on what you are running on though.
3ll3d00d is offline
post #6081 of 7646 Old 04-07-2019, 04:14 AM
paulst's Avatar
Quoted: 172 Post(s)
Liked: 359
Originally Posted by AmerCa View Post
@paulst
I don't have it on Bluray, it's been on Netflix for ages and I've not even watched that, sorry. If I see it cheap I'll try and grab it..
AmerCa likes this.
paulst is offline
post #6082 of 7646 Old 04-07-2019, 05:17 AM
femi's Avatar
Quoted: 237 Post(s)
Liked: 289
Hey @aron7awol , another BEQ request for you sir: Amazon series Hanna.
Thanks man.
Femi
galonzo, aron7awol and biga6761 like this.
(2)JTR Cap 4000's---(6) Enclosures Seal SI HT-18's---Behringer iNUKE 6000DSP--- Behringer iNUKE 3000DSP---Denon AVR-4250CI---(3)JBL 4722n---(5)Behringer Eurolive B215XL---(2)Klipsch SS-1 Surround---JVC RS500---Sony HW50es---VApex Fixed frame 135" 16:9---Sony UBP-X800---Oppo BDP-93---Toshiba HD DVD-XA2---Xbox 360---PS4---HDFURY Linker---Darbee Darblet DVP-5000---miniDSP Balanced 2x4---Harmony 1100 remote
femi is offline
post #6083 of 7646 Old 04-07-2019, 06:24 AM
d-rail34's Avatar
Quoted: 366 Post(s)
Liked: 699
I did a fresh install of it, and pretty much every action was lagging. The only lag that I had experienced with previous builds was during creating signals, and when adding filters to analyze the audio track. Hence my surpise with this one being so slow to respond.
I'll try re-installing and see if it may have just been a fluky thing going on. Hopefully that was the case.
d-rail34 is offline
post #6084 of 7646 Old 04-07-2019, 07:06 AM
Liked: 9642
BassEQ The Kid Who Would Be King (2019) Atmos
I tamed that HUGE spike at ~14Hz, but one could leave out that PEQ if they want to leave it intact.
post #6085 of 7646 Old 04-07-2019, 07:07 AM
Liked: 9642
Hey guys,
It's feeling about the same speed to me.
post #6086 of 7646 Old 04-07-2019, 07:28 AM
Liked: 9642
BassEQ Night at the Museum (2006) DTS-HD MA 5.1
post #6087 of 7646 Old 04-07-2019, 07:42 AM
Liked: 9642
BassEQ Hellboy Animated: Sword of Storms (2006) Atmos
SuperFist and biga6761 like this.
post #6088 of 7646 Old 04-07-2019, 07:52 AM
Liked: 9642
BassEQ Hellboy Animated: Blood and Iron (2007) Atmos
post #6089 of 7646 Old 04-07-2019, 08:37 AM
AmerCa's Avatar
Quoted: 676 Post(s)
Liked: 1401
Don't worry, man. I have the ATMOS version as well, I was just curious. Thank you anyways.
AmerCa is offline
post #6090 of 7646 Old 04-07-2019, 08:39 AM
d-rail34's Avatar
Quoted: 366 Post(s)
Liked: 699
It has to be something flukey going on then. Ill re-install it whenever I get home later to see if that corrects it.
d-rail34 is offline
