Bass EQ for Filtered Movies - Page 234 - AVS Forum | Home Theater Discussions And Reviews
 20352Likes
post #6991 of 8261 Old 05-14-2019, 11:39 AM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1484
Originally Posted by aron7awol View Post
The nanoAVR can be used but keep in mind you would be doing BEQ before bass management, so you'd need to reduce level enough to keep some headroom when your processor performs bass management. Doing it after bass management is just simpler since you don't have to worry about clipping at any point before the MiniDSP, assuming your signal chain is set up properly, of course.
I'm not familiar with the nanoAVR, so trying to understand it. Is the BEQ before bass management if it's done only on the sub output? The webpage for it says that it does bass management so I took that to be that the output was the post management signal. Am I misinterpreting that? I'm more hesitant to add merging support for it if it's pre management. I don't want to risk anyone's system that doesn't realize it needs to be adjusted.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #6992 of 8261 Old 05-14-2019, 12:00 PM
Quoted: 2392 Post(s)
Liked: 10280
I don't have one, but from looking at it, it outputs 7.1 PCM signal via HDMI, so even if you perform bass management with it you're still limited to the same clipping limits. Like I said, it can be used, but a level reduction will be necessary to prevent clipping. It's still a perfectly reasonable way to apply BEQ (as is remux), the user just has to make sure they are aware of this and properly account for it. Hopefully if one is performing BM within the nanoAVR they are already doing this, although a lesser extent is necessary without BEQ.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #6993 of 8261 Old 05-14-2019, 12:28 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1484
OK, thanks. I'm hesitant to add support then for it to BEQd or browser. It sounds like something users are going to have to do manually and tweak them when entering. cc @raynist
BEQ Slack group
post #6994 of 8261 Old 05-14-2019, 12:43 PM
3ll3d00d's Avatar
Quoted: 2298 Post(s)
Liked: 2391
If it is a case of copying the filters to every input channel then it is also easy to add a gain adjustment in the same way the remix screen calculates it for you. Perfectly doable. If someone wants this them just share the app (or sample config file) and be prepared to test it to confirm it works.
3ll3d00d is offline
post #6995 of 8261 Old 05-14-2019, 12:51 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1484
I'll get with you on. raynist was looking for it and has sent me stuff on it already. Outside of the gain adjustment it was looking straight forward with what's already implemented. Only one channel to copy everything too.
3ll3d00d likes this.
BEQ Slack group
post #6996 of 8261 Old 05-14-2019, 01:37 PM
raynist's Avatar
Quoted: 2066 Post(s)
Liked: 2231
Does the BEQ Designer work on a Mac?
JTR (3 215 RT, 5 212HTR, 2 Growlers, 4 S2's)
PSA (4 Triax's, 3 210T's)
Behringer (4 B1200 Midbass Modules)
raynist is online now
post #6997 of 8261 Old 05-14-2019, 01:40 PM
3ll3d00d's Avatar
Liked: 2391
yes
https://beqdesigner.readthedocs.io/en/latest/install/
3ll3d00d is offline
post #6998 of 8261 Old 05-14-2019, 02:08 PM
raynist's Avatar
Liked: 2231
Edit - nevermind - figured it out!
post #6999 of 8261 Old 05-14-2019, 02:18 PM
raynist's Avatar
Liked: 2231
Hi - I was able to install BeqDesigner on my MacBook pro and was able to use the Merge Minidsp XML to create the files for my subs. I have 3 minidsp HD's in my main setup for my different subs (4 JTR S2's, 4 B1200's and 2 BOSS platforms). I only need to BEQ the S2's and BOSS so it is easy enough to just load the config files for the 2 minidsp hd's. No need to make a special modification for my NanoAVR's. I had actually taken the NanoAVR's offline but figured I would add one back in if it was easy. Loading the config files onto 2 HD's is so much easier than manually adding the filters for 2 HD's.
Thanks!!
PioManiac likes this.
post #7000 of 8261 Old 05-14-2019, 03:39 PM
MOberhardt's Avatar
Quoted: 704 Post(s)
Liked: 302
What is the standard way on the MiniDSP that you set the output to just flat, so no changes made on out just on in? Is there some way to just bypass or do you have to bypass each individual filter and gain etc?
MOberhardt is online now
post #7001 of 8261 Old 05-14-2019, 06:11 PM - Thread Starter
PioManiac's Avatar
Quoted: 3183 Post(s)
Liked: 7775
You've got 4 Config memory slots available,
BEQ only loads to the Config 1 Input channels.
I would recommend you pick Config 2 and hit the PEQ tab and set all 10 slots to BYPASSED for no BEQ.
Going forward that would always be your FLAT EQ setting, you can still put your house curve on the output channels (if you have one).
I use the other slots for Late Night mode where I have my subs dialed down (or muted) and just the Crowsons and or near-field subs active
MOberhardt and CallingMrBenzo like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #7002 of 8261 Old 05-14-2019, 06:41 PM - Thread Starter
PioManiac's Avatar
Liked: 7775
Thanks!!
Yes, using the BEQ'D app makes loading BEQ settings a single mouse click. Manually inputting values is so redundant now.
...I can't imagine anyone needing the list on the first page anymore, well other than to look at the pretty graphs
Glad you got it worked out so quickly!
post #7003 of 8261 Old 05-14-2019, 06:45 PM - Thread Starter
PioManiac's Avatar
Liked: 7775
Originally Posted by carp View Post
Oh my... it works. I'm good to go!
Thanks everyone for the help and the endless patience.
YES!
...another caveman has proven it is possible!
Welcome to the BEQ Crew Brother carp!
Alan P, galonzo, ddigler and 1 others like this.
post #7004 of 8261 Old 05-14-2019, 07:24 PM
MOberhardt's Avatar
Quoted: 704 Post(s)
Liked: 302
But what should you do for the output? Same? So for each output, do bypass EQ for each filter?
post #7005 of 8261 Old 05-14-2019, 07:56 PM - Thread Starter
PioManiac's Avatar
Liked: 7775
No need to do anything, the outputs are all at zero gain by default. (unless you want a house curve on them)
If you haven't made any changes to your other Config memory slots, the inputs are likely at zero as well, look for yourself, it only takes a second.
MOberhardt likes this.
post #7006 of 8261 Old 05-14-2019, 08:58 PM
Quoted: 25 Post(s)
Liked: 116
BEQ The Rock (1996) LPCM 5.1
PEQ at 55Hz is meant to balance the mix, therefore optional.
cinemaniac93 is offline
post #7007 of 8261 Old 05-14-2019, 09:07 PM
Quoted: 25 Post(s)
Liked: 116
BEQ Isle of Dogs (2018) DTS-HD MA 5.1
AmerCa likes this.
post #7008 of 8261 Old 05-15-2019, 08:46 AM
Quoted: 212 Post(s)
Liked: 117
I finally got around to integrating my MiniDSP 2x4 HD into the chain this last weekend. Quite a performer for such a little unit but I've run into a problem with it and wondering if anyone else has run into it.
It does not connect to the board anymore, the bridge window just counts and counts. I never get the synchronize window. Anybody else run into this?
Sony 75X940E, Denon X6200w, Sony X700, Roku Ultra, MiniDSP 2x4HD
Parasound (2x)HCA-855a, HCA-750a, Sony ES4300
Mission 705a L&R, dual 70c3 C, 703 SL&SR, 705 BL&BR, (4x)Yamaha NSIC800 Atmos
LFE- Front: M&K MX-200 & MX-150THX; Rear: M&K V-75 & Klipsch RW-12
ULF- 12" JBL(6x) Mini-riser BOSS + (3x)Aura AST-2B-4 shakers
Kevnmin is offline
post #7009 of 8261 Old 05-15-2019, 09:19 AM
Quoted: 125 Post(s)
Liked: 248
Are you using the Wi-Dg?. If you are check this post
https://www.avsforum.com/forum/113-s...l#post57371702
else post a screen shot of your HD
what-i-d-do-differently-next-timehttps://www.avsforum.com/forum/19-ded...l#post55641388
Epson Projector Power Supply Failure.https://www.avsforum.com/forum/68-dig...lure-rate.html
avtvhdbass is offline
post #7010 of 8261 Old 05-15-2019, 09:26 AM
Quoted: 212 Post(s)
Liked: 117
Not using wi-fi with it at all. Straight USB to laptop. Here's a screen shot of my laptop showing the bridge window of 2x4HD. Says the device is found, but status just counts bytes up to infinity and never gives the synchronize window.
Name:	screen shot of bridge.jpg
Kevnmin is offline
post #7011 of 8261 Old 05-15-2019, 09:43 AM
BryceDH's Avatar
Quoted: 174 Post(s)
Liked: 158
Looks like you are connected... dont worry about the pop up that shows bytes. The green "connected" spot in the upper right hand of your main screen shows you are good.
Sent from my SM-N960U using Tapatalk
richardsim7 and dgrizzard like this.
Equipment: Yamaha 3050, Oppo 103d, DIYSG HT12s (L,C,R), PSA mt 110s (SR,SL), 2 VBSS, Submaximus, 4 driver BOSS build, umik-1, Epson 3700
BryceDH is offline
post #7012 of 8261 Old 05-15-2019, 02:12 PM - Thread Starter
PioManiac's Avatar
Liked: 7775
@aron7awol any chance you've got the 1998 Godzilla 4K/UHD yet?
I was going to take a hard pass on this one initially (Matthew Broderick version),
...But the ATMOS fans seem pretty impressed....
Ralphs' Review: https://www.avsforum.com/forum/187-o...ay-review.html
I never did buy it on Bluray, so it's not like its a double dip for nothing.
..and it's only $20
post #7013 of 8261 Old 05-15-2019, 03:26 PM
Liked: 10280
No, but it's another one I'll be diving on at the first opportunity!
post #7014 of 8261 Old 05-15-2019, 05:12 PM
Sekosche's Avatar
Quoted: 1378 Post(s)
Liked: 3413
BassEQ Backdraft (1991) DTS:X
Snagged this on the way home, on deck for a reference spin tomorrow! Can’t wait, been a long while since I’ve seen it; Backdraft has such a great cast and it looks to use the LFE sparingly but to hopefully a great effect. It’ll be a welcome change from the non stop bassfests we’re becoming accustomed to.
Watching Happy Death Day 2U in a few and Mary Poppins Returns with the kids tomorrow, no bass in the latter even with a spoonful of BEQ!
CallingMrBenzo and aron7awol like this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #7015 of 8261 Old 05-15-2019, 05:50 PM
carp's Avatar
Quoted: 3513 Post(s)
Liked: 3196
YES!
Thanks!!
I know man... if we can figure it out then everyone can. I was cringing everytime I posted recently asking for help because I know it has to be an eye roller for those that know there way around a computer but I pushed through because I knew the reward would be worth it.
No way this isn't the best thread in AVS history.
carp is offline
post #7016 of 8261 Old 05-15-2019, 05:58 PM - Thread Starter
PioManiac's Avatar
Liked: 7775
I took a gamble and grabbed it the local BB on the way home.
...TOTALLY worth it for the ATMOS alone! (and I'm only 15 minutes in so far)
Someone who REALLY knew what they were doing worked their ATMOS skills to the level all should aspire to.
post #7017 of 8261 Old 05-16-2019, 06:21 AM
Sekosche's Avatar
Liked: 3413
Backdraft LFE and DTS:X soundtrack is awesome! This is how you remaster an 80’s movie; I’m not sure how the bass was on previous versions, but it’s legit on the UHD. I think the movie still holds up really well.
Sekosche is offline
post #7018 of 8261 Old 05-16-2019, 07:11 AM
Rowan611's Avatar
Quoted: 602 Post(s)
Liked: 699
@PioManiac @aron7awol
Forgive my ignorance, but where can I locate this?
Or Better yet, jump down the Rabbit Hole and get the entire list in XLM file format from the repository (aka "repo")
Downloaded to your laptop/pc/macbook then a single mouse click for your selection off the list to load into your MiniDSP and watch instantly.
HT: Oppo UHD-203 | Crown Amps | NX3000D | NX6000D | 1299s | Volt 8s | THTs | Crowson Shadow 8s | BOSS riser | Panamax 5300PM | LG OLED 65B6P
Family: Denon AVR-S740 | PSB Alpha AVs | Sony X900F | X1
Rowan611 is offline
post #7019 of 8261 Old 05-16-2019, 07:16 AM
Quoted: 88 Post(s)
Liked: 32
Aron can we have an update for GOT Season 8? Thanks in advance!😬. Getting spoilers all over while waiting for the Atmos version to come out lol.
aron7awol likes this.
TheBoom89 is offline
post #7020 of 8261 Old 05-16-2019, 07:17 AM
richardsim7's Avatar
Quoted: 1312 Post(s)
Liked: 1682
Originally Posted by Rowan611 View Post
@PioManiac aron7awol
https://beqdesigner.readthedocs.io/e...e_minidsp_xml/
galonzo likes this.
richardsim7 is offline
