Bass EQ for Filtered Movies - Page 238 - AVS Forum | Home Theater Discussions And Reviews
 19882Likes
post #7111 of 8061 Old 05-28-2019, 02:13 AM
Ringnut's Avatar
Quoted: 20 Post(s)
Liked: 35
Here's a challenge for you Aron, Cirque du Soleil - World's Away. Any chance?
aron7awol likes this.
Ringnut is offline
post #7112 of 8061 Old 05-28-2019, 07:17 AM
Quoted: 2368 Post(s)
Liked: 10073
With the holiday weekend over, I'm back to work! Captain Marvel DD+Atmos coming up, and then the recent requests.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #7113 of 8061 Old 05-28-2019, 08:29 AM
Liked: 10073
BassEQ Captain Marvel (2019) Atmos / DD+ Atmos
DTS-HD MA 7.1:
Spoiler!
post #7114 of 8061 Old 05-28-2019, 09:01 AM
Liked: 10073
Updated...
Originally Posted by aron7awol View Post
BassEQ 13 Hours (2016) Atmos
post #7115 of 8061 Old 05-28-2019, 09:03 AM
paulst's Avatar
Quoted: 179 Post(s)
Liked: 383
Did you not have The Descent Aron? I can send you the signal file if you like to make it easier?
AmerCa likes this.
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is offline
post #7116 of 8061 Old 05-28-2019, 09:04 AM
MrGuru's Avatar
Quoted: 136 Post(s)
@PioManiac I've got a day to myself, so we're trying to get a house curve down! First couple passes are attached below - The dark blue line is a pass in REW with no filters or anything. The green line is another pass with a +5 db low shelf at 20Hz, and the light blue line adds in a +10db low shelf at 10Hz.
Does anything stand out as glaring? I assume that my 1 FV15HP can't really get much lower than 12Hz or so, which explains the beginning-roll-off at around there.
Edit: tweaked the 60-80Hz range. Since my crossover from my main speakers is at 80, I think that's close to as flat as I can get the sub, with the 5dB shelf at 20Hz and the 10dB shelf at 10Hz, of course.
ID:	2572710   Click image for larger version
Name:	second round.png
TV: LG OLED65C8PUA
Front L & R/Center: Sierra-2/Sierra-2 center
Front Highs/Surrounds: Polk RTi A3/Polk RTi A1
Receiver/Blu-ray: Marantz SR6012/Oppo 203-D
Subwoofer: Rythmik FV15HP w/ miniDSP 2x4 HD
MrGuru is offline
post #7117 of 8061 Old 05-28-2019, 09:45 AM
DesertDog's Avatar
Quoted: 510 Post(s)
Liked: 1467
Updated... 13 hours
Do we know if this matches the 4k release yet? Not sure if I need to mark them separately.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #7118 of 8061 Old 05-28-2019, 09:47 AM
Liked: 10073
I'll do it now. I don't need you to send anything, thanks though.
Don't know yet, but I'll confirm once the UHD drops.
DesertDog, galonzo, paulst and 1 others like this.
post #7119 of 8061 Old 05-28-2019, 10:50 AM
Liked: 10073
BassEQ The Descent (2005) DTS-HD MA 5.1
Alan P, galonzo and paulst like this.
post #7120 of 8061 Old 05-28-2019, 11:22 AM - Thread Starter
PioManiac's Avatar
Quoted: 3160 Post(s)
Liked: 7689
Thumbs up
Updated... 13 Hours
Excellent Work!
I like what you did over the original BEQ (21Hz +2 and 10Hz +3.5)
That 45Hz -4.3 LS filter keeps that Hot spot ~35Hz out of the danger zone (well above the -15dB line)
If someone had an aggressive house curve without your new BEQ,
...they may have found themselves jumping for the remote at the 2:00:00 mark
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #7121 of 8061 Old 05-28-2019, 11:29 AM
Liked: 10073
BassEQ Rim of the World (2019) Netflix DD+ Atmos
galonzo, femi, magicj1 and 3 others like this.
post #7122 of 8061 Old 05-28-2019, 11:37 AM - Thread Starter
PioManiac's Avatar
Liked: 7689
Do you have DEQ enabled in your AVR by chance? (Your baseline run isn't too bad)
Try to get a gentle slope from your crossover point to your peak output,
and don't go too crazy on the gain, +20dB difference is pretty hot. ...but not unheard of around here
Test drive a couple Bass heavy flicks (without BEQ) and keep your finger close to your MV
You could put 3 different curves in the miniDSP Config slots, leave Config 1 Bypassed
...then shift on the fly to hear for your self what the difference is.
You can certainly save several HC's in xml format in your HC save folder, rename each one.
Then when you do the merge function you can pick from Hot Medium or Light.
post #7123 of 8061 Old 05-28-2019, 12:13 PM
MrGuru's Avatar
Quoted: 136 Post(s)
Yup, I had DEQ on. I turned it off, and tried a very smooth curve, and got the following.
ID:	2572808   Click image for larger version
PioManiac likes this.
TV: LG OLED65C8PUA
MrGuru is offline
post #7124 of 8061 Old 05-28-2019, 12:22 PM
Liked: 10073
BassEQ Cirque du Soleil: Worlds Away (2012) DTS-HD MA 5.1
paulst and MaxTemp like this.
post #7125 of 8061 Old 05-28-2019, 12:27 PM
Liked: 10073
Assuming you crossover at or around 80Hz, running the subs hot will give you a nice ramp between ~40Hz-160Hz (and resulting chest kick) without adding group delay. Then if you want additional house curve <40Hz a shelf will work nicely for that.
galonzo likes this.
post #7126 of 8061 Old 05-28-2019, 12:41 PM - Thread Starter
PioManiac's Avatar
Liked: 7689
Yup, I had DEQ on.
Ha! I thought so
DEQ is very similar to using a house curve and works well for most at mid-low MV levels.
However, as you approach reference levels on your MV, I believe the dynamics roll off to zero.
(Which is why I never use it myself, I think Yamaha calls it "YPAO volume")
A House Curve gets you a constant increase as your MV increases.
...for those with the headroom and like louder ULF/LFE at reference levels.
MrGuru likes this.
post #7127 of 8061 Old 05-28-2019, 12:45 PM
MrGuru's Avatar
Quoted: 136 Post(s)
Ha! I thought so
Got it - thanks guys! I've settled on a house curve as I posted above, with a very mild curve starting at 80Hz. I've watched a few minutes of a handful of movies right now and it's excellent - time to merge the movie BEQs!
TV: LG OLED65C8PUA
MrGuru is offline
post #7128 of 8061 Old 05-28-2019, 12:45 PM
Quoted: 27 Post(s)
Liked: 76
Excellent Work!
I like what you did over the original (21Hz +2 and 10Hz +3.5)
That 45Hz -4.3 LS filter keeps that Hot spot ~35Hz out of the danger zone (above the -15dB line)
If someone had an aggressive house curve they may have found themselves reaching for the remote at the 2:00:00 mark
Can confirm...
First time watching this (pre BEQ and crowsons) I sent my crown xls 2002s into protection mode...
Only happened once... pretty freaky, absurd bass then.... nothing and flashing red lights, not good lol
Sent from my SM-G950W using Tapatalk
SuperFist likes this.
Sony hw45es | 100 inch screen | Yamaha RX-A3060 | Axiom ADA 1250-3 | Axiom M80s/VP180/QS10HPs | DIY SI DS4-18s sealed (2) | Crown XLS 2002 (2) | PSA S3601 | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x4) (coming soon)
Paulo Franco is offline
post #7129 of 8061 Old 05-28-2019, 12:56 PM - Thread Starter
PioManiac's Avatar
Liked: 7689
Originally Posted by Paulo Franco View Post
Can confirm...
Someone posted in the "other" bass thread 2 days ago looking for a graph from How To Train Your Dragon: Hidden World
Because his Subs bottomed out for the first time ever around the 1:19 mark, (he had a +6.5dB gain LS and was running -6 MV) no BEQ
Without BEQ that's a recipe for disaster,
(Aron added a negative -5 PEQ filter to tame the 19Hz spike, while still bringing up 10Hz safely).
Thread here: https://www.avsforum.com/forum/113-s...l#post58100288
19Hz peak reaches -9dB at 1:19 (right side) and is already White Hot, adding another +6.5 Gain put it Well over the top
I'm guessing none of @aron7awol recent BEQ's have any spikes over the -15dB line...
post #7130 of 8061 Old 05-28-2019, 01:18 PM
Liked: 10073
That's actually somewhat surprising considering how capable his subs are. I feel like my house would break before I bottomed out my subs with a 19Hz tone. I wonder if he clipped his amp(s) by not having his signal chain properly set up.
In any case, hearing the words "Without BEQ" makes me cringe, feeling like I just got castrated.
galonzo, Nalleh and cinemaniac93 like this.
post #7131 of 8061 Old 05-28-2019, 02:40 PM
Gorilla Killa's Avatar
Quoted: 1326 Post(s)
Liked: 1831
Full bandwidth, good wobble and movie to boot.
8hz ULF TR for the masses and the Cashless. Like a BOSS
If you can't stand behind our troops stand in front of them
Gorilla Killa is offline
post #7132 of 8061 Old 05-28-2019, 02:53 PM - Thread Starter
PioManiac's Avatar
Liked: 7689
A couple years ago I blew the dust off that one for a long overdue re-spin,
but it took 3 or 4 different players in my rack to finally find one that didn't automatically load the stupid commentary track with PiP.
...and no way to override it. I cant remember which player it finally worked on now.
I know there was a disc exchange program at one point,
but I was stubborn because I was sure I watched it already without issue,
... likely in 2008 on my old Fat PS3
EDIT...I found my old post in the Bass Movies thread, from October 2017
I've watched Sunshine several times without issue in the first few years after release with no problem at. Great Movie, Great Bass!
But just a couple months ago I loaded it up for a replay and got the same issue as you with the PiP pop-up.
There must have been a FW update that screwed things up. Tried my PS4,PS3, Sony BDP S5100 and my Panny UB900
Since I just added a new Oppo 203 a bit over a week ago
I thought I'd try it again and the picture in picture issue is gone.
Tried it in my Panasonic UB900 one more time, still there
post #7133 of 8061 Old 05-28-2019, 03:16 PM
MrGuru's Avatar
Quoted: 136 Post(s)
Finished tweaking and sampling. Merged my house curve with the BEQ movie repository and will be using Config 1 for those, and Config 2 will be my 'default' setting with just the house curve on. Thank you everyone for your help - now I might try seeing if I can run some type of correction on my 2.0 PC setup!
Side note - I assume I'll have to merge my house curve with the BEQ database every time I update the repo?
TV: LG OLED65C8PUA
MrGuru is offline
post #7134 of 8061 Old 05-28-2019, 03:18 PM
Alan P's Avatar
Quoted: 6144 Post(s)
Liked: 5366
Correct!
MrGuru likes this.
Alan P is offline
post #7135 of 8061 Old 05-28-2019, 05:13 PM - Thread Starter
PioManiac's Avatar
Liked: 7689
Just for Schitz and Giggles I just loaded up Sunshine
...and left my HTTYD Hidden World BEQ on the miniDSP
I kept my MV way down at -20 just to be safe, sort-of
Opening Chapter was a cool, Funk Driver and Crowson wobble
I replayed Ch.1 immediately after with my Config 4 setting (BYPASSED) and it was no where near as fun.
So Brother Aron, if you can add that to the cue?
I want to see what this looks like at higher volume without baking anything
Thanks'
There are a lot better Bass heavy scenes, this one was just a short one at the start
(sorry for the glare on the TV, had to have the overhead lights on to light up the Subs.
SuperFist and aron7awol like this.
post #7136 of 8061 Old 05-28-2019, 05:18 PM
Liked: 1831
That's rather strange lol. I had never heard of the movie, saw it on HBO and 20 minutes in I stopped it and bought the disc. Better bass and no PiP issues on the 900, worth the 10$ for sure
post #7137 of 8061 Old 05-28-2019, 05:31 PM - Thread Starter
PioManiac's Avatar
Liked: 7689
I'm pretty sure any BD's purchased within the last 8 years won't have the PiP bug.
Mine was bought in 2008/2009 when it was first released.
It was listed as a 4.5 Star Bass Movie on the Previous Master Bass List
https://www.avsforum.com/forum/113-s...l#post20404060
post #7138 of 8061 Old 05-28-2019, 05:44 PM
MOberhardt's Avatar
Quoted: 701 Post(s)
Liked: 293
Ugh, so irritating! I have that in my to rewatch pile. so will see how it fares on my panasonic UB9000
MOberhardt is online now
post #7139 of 8061 Old 05-28-2019, 07:08 PM
Sekosche's Avatar
Quoted: 1375 Post(s)
Liked: 3372
I actually played HTTY 3 with reference level bass with BEQ and I even slightly decreased the negative PEQ to -3dB at 19Hz and didn’t have any problems; there were a few good surprise hits throughout the movie, but nothing earth shattering.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is online now
post #7140 of 8061 Old 05-28-2019, 08:54 PM
Liked: 10073
I'm on it, extracting/analyzing now. I might not finish it tonight because it's getting late, but will definitely get it done tomorrow morning.
PioManiac and galonzo like this.
