Bass EQ for Filtered Movies - Page 244 - AVS Forum | Home Theater Discussions And Reviews
 20354Likes
post #7291 of 8261 Old 06-08-2019, 10:13 PM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1484
Originally Posted by 3ll3d00d View Post
Batman & Robin was quite the 35-40Hz monster before BEQ, nevertheless I don't any amount of bass hit would be enough to watch that again!
I was thinking the same thing when I just entered it for the repo. After forcing myself to watch Godzilla (1998) last week I don't think I can do this one. At least Godzilla had an atmos track that was worth hearing once.
Originally Posted by aron7awol View Post
BassEQ The Natural (1984) Atmos
Thanks, is this for the theatrical or director's cut? Double checking since the UHD has both on it. My guess is that it'll be good for either cut.
galonzo and d-rail34 like this.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #7292 of 8261 Old 06-08-2019, 11:12 PM
MOberhardt's Avatar
Quoted: 704 Post(s)
Liked: 302
I watched Pride and Prejudice and Zombies UHD last night. I know it isn't on the list, but there was some awesome thumping subwoofer heat in it.
femi, aron7awol and AmerCa like this.
MOberhardt is offline
post #7293 of 8261 Old 06-09-2019, 06:55 AM
Quoted: 2392 Post(s)
Liked: 10281
Director's Cut. Sorry, I meant to put that in the post. I just edited it.
DesertDog likes this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #7294 of 8261 Old 06-09-2019, 07:00 AM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
I’ve got everything downloaded, the movies, github, beq designer, etc.
I’m struggling on how to export my eq filters on my output to an xml file so I can do the quick beq loading. Do I do that from the mini dsp plug in, or rew?
The eq I loaded into the output of the mini dsp was a text file from rew
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2 - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #7295 of 8261 Old 06-09-2019, 07:37 AM - Thread Starter
PioManiac's Avatar
Quoted: 3184 Post(s)
Liked: 7776
Load the miniDSP software, bypass any filters you may have on the input channels
Make sure your output channels have your EQ settings and hit File>save configuration in the top left corner.
(create a new folder on your hard drive to save the new house curve.xml file)
Load the BEQ Designer app,
hit Ctrl-X (or select merge from the tools menu)
Where you are prompted for your "config file" select the file you just created.
Hit save and your entire movie list will be overwritten with your settings merged to the movie BEQ titles.
Load any movie to the miniDSP and double check the input/output channels have loaded correctly
jsc79 likes this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #7296 of 8261 Old 06-09-2019, 08:19 AM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
Thanks! Got it. I will have to mess with it some more. After I load the beq, the beq stuff shows up on the input, but my rew eq stuff doesn’t show up on the output side after I load the beq...or maybe it’s not supposed to?
I might have saved one of the empty configurations in the 2x4. I will need to recheck. My bachelor weekend is now over as the fam is returning today. My weekend of bass is coming to a halt. Lol
jsc79 is online now
post #7297 of 8261 Old 06-09-2019, 08:43 AM
lawdogx's Avatar
Quoted: 96 Post(s)
Liked: 97
Hey guys, read through a bunch of this over the past few days and would like to give it a try! I currently have 4 subs powered by 2 NX6000D's and am using the Behringer dsp for my HPF, a high shelf to get a little boost below 20HZ, and a single band PEQ. Can I use the Behringer DSP and just manually input the BEQ settings? If not, where in my signal chain would I put a 2x4hd? I currently run:
Denon x4400
(2 Rca cables)
Jensen Sub 2RX (an isolator for a ground loop issue, has Rca in and XLR out)
(2 XLR cables, one each to following amps)
2 NX6000d in biamp1 mode (single signal into 2 sub channels)
(4 speakon cables)
4 Mini Marty UM18-22 subwoofers
If it needs to be after the isolator I could replace it with a rca in/ rca out isolator? Thanks in advance for any direction you could offer!
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E Atmos; 4 x UM18-22 Mini Marty's.
COMPONENTS: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d; Epson 5040UB.
lawdogx is offline
post #7298 of 8261 Old 06-09-2019, 09:53 AM - Thread Starter
PioManiac's Avatar
Liked: 7776
It is supposed to load the BEQ settings to the inputs and your personal EQ to the outputs at the same time.
Your merge function didn't work, which version of BEQ Designer are you using?
Did you notice the number of titles counting up to over 700 as they were written to your save folder?
Is it possible your merged files where saved in a different directory than the one you selected for loading in the miniDSP?
I had two different directories where my movie BEQ's were saved, the most current one will have a more recent date/time.
(I then went back in and deleted the old non-merged list so I wouldn't load from there by mistake)
jsc79 likes this.
post #7299 of 8261 Old 06-09-2019, 09:59 AM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
Thanks for all of the pointers, I will go through and double check all of those. I used the small version you referenced in the initial post on this thread.
When I did the merge it went 700+ files.
I will have To take a look at it again when I get home. I’m sure it’s something dumb/simple that I’m just missing.
jsc79 is online now
post #7300 of 8261 Old 06-09-2019, 10:08 AM
d-rail34's Avatar
Quoted: 377 Post(s)
Liked: 709
I recently watched Godzilla as well, and while it wasn't the easiest movie to sit through, B&R was so bad that it had me asking myself, "What the hell was Schumaker smoking whenever he put this thing together?".
On another note, I've been off the grid for a bit trying to get the new AVR integrated (replaced my Onkyo with a Denon). It seems that the Denon sends a hotter signal from the sub outs than the Onkyo did, so I had a bit of a time trying to get it re-calibrated. Since then, I've rewatched a few of my favorite BEQ's and have not only been impressed with the LFE, but the overall surround processing is so much better (more immersive) than what the Onyko provided. That's with or without BEQ.
Next up...Captain Marvel!
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon: AVR-X2400H/Hsu Research: HB-1 Bookshelfs (4)/Hsu Research: HC-1 Center (1)/SVS: PB12 Plus (1)/Samsung: UN65H7150/Sony: UBP-X800/PC: Built by D-Rail
Bedroom - Blose: Cinemate II GS 2.1/Sony: XBR49X800E/XBox: One S
d-rail34 is offline
post #7301 of 8261 Old 06-09-2019, 11:36 AM
DesertDog's Avatar
Quoted: 516 Post(s)
Liked: 1484
Excellent! That's great to hear since it was the DC that I had already ripped.
Denon x4400
(2 Rca cables)
(4 speakon cables)
You can't use the Behringer DSP for BEQ because it doesn't do filters < 20 hz. You'll lose a lot of BEQ if you can't do that. I'd recommend getting a miniDSP 2x4 HD for your setup since they're great and will allow you to us the rest of the tools we have going. You should be able to put it between the Denon and isolator so that you can keep the XLR going to the amps.
galonzo and Kevnmin like this.
BEQ Slack group
post #7302 of 8261 Old 06-09-2019, 12:06 PM
jsc79's Avatar
Quoted: 373 Post(s)
Liked: 431
Got it figured out! Thanks for the help!
I was thinking about spinning Deadpool but I’ve got a 3 year old sleeping upstairs. Dangit
galonzo likes this.
jsc79 is online now
post #7303 of 8261 Old 06-09-2019, 03:12 PM
Liked: 10281
Originally Posted by Tobias Secker View Post
Can you do "Shed Of The Dead" please @aron7awol ?
Originally Posted by Spidacat View Post
I watched 2001: A Space Odyssey, but didn't see 2010: The Year We Make Contact (BluRay, Dolby TrueHD). Could we get a BEQ for it when you get the chance?
I've got all 3 of these going now, so I should get them done by tomorrow.
MOberhardt and Spidacat like this.
post #7304 of 8261 Old 06-09-2019, 03:19 PM
Liked: 10281
BassEQ I Am Mother (2019) Netflix DD+ 5.1
I just watched this and everything seemed much hotter than expected. I am putting it in a spoiler tag while I investigate. I'd reduce the x6 multiplier to x4 if you want to watch it in the meantime.
Spoiler!
We just watched it and something seems off with the levels, it was much hotter than expected. I am investigating now.
Edit to add: The EAC3 track has dialnorm, but it's set to -31 which should result in no MV change.
I'm not finding anything out of the ordinary about this track. Can one of the experienced guys here who knows their system well give it a test and report back?
galonzo likes this.
post #7305 of 8261 Old 06-09-2019, 07:43 PM
SBuger's Avatar
Quoted: 1161 Post(s)
Liked: 3597
That movie has maybe the best sniper rifle transients I've ever felt on my system. They were truly EPIC! Not sure if you got to that part yet, but if not, the best is yet to come!
WOW!!! you were not just a kidding about those sniper rifle shots!!!
Just finished it up and after the movie I had to go back and replay those shots several times ...talk about a jolt the body Would be interesting to see the spectrum on about 3 of those last shots, and or run a VS on them too. Yep I think those are the kind of transients us Bass and TR junkies live for
My "Blacked Out" Home Theater Room
1400cuft sealed room, suspended floor | SY Triple Black Velvet for Blackout | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | GIK Treatments | Oppo 203 | Epson 5040 4K | Eyes 7' to 120" AT Seymour Screen | 6x 18" Sealed DIY Subs (4x SI DS4-18s & 2x UM22-18s) | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' 6x JBL12s | MiniDSP 10x10HD
SBuger is offline
post #7306 of 8261 Old 06-09-2019, 08:22 PM
tvuong's Avatar
Quoted: 2541 Post(s)
Liked: 2186
Momentum (2015) please, Aron? Was going to rewatch it tonight but rather wait. This one was pretty awesome IIRC. TIA
aron7awol likes this.
tvuong is offline
post #7307 of 8261 Old 06-09-2019, 11:46 PM
Liked: 4
A big thank you to PioManiac, aron7awol, 3ll3d00d and everyone else involved in this. I have been using the BEQdesigner and the difference it makes to watching movies is astonishing. It's like I'd just got a sub upgrade.
SBuger, aron7awol and d-rail34 like this.
cypaq is offline
post #7308 of 8261 Old 06-10-2019, 12:08 AM
richardsim7's Avatar
Quoted: 1312 Post(s)
Liked: 1682
The 50cal scene in The Accountant is great too
richardsim7 is offline
post #7309 of 8261 Old 06-10-2019, 10:33 AM
paulst's Avatar
Quoted: 181 Post(s)
Liked: 398
BassEQ Warrior (2011) Atmos
Warrior DTS-HD MA 7.1
With +2MV..
No MV adjustment..
SuperFist, magicj1 and AmerCa like this.
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is offline
post #7310 of 8261 Old 06-10-2019, 11:33 AM
paulst's Avatar
Quoted: 181 Post(s)
Liked: 398
Warrior DTS-HD MA 5.1 Safe with the +2MV I only did this purely because I just started watching it and my UK Bluray defaulted to audio track 2 which was the 5.1 track..
Editing an updated list to save me searching back for it..
Safe..
Alien Covenant DTS-HD MA 7.1
Aquaman DTS-HD MA 7.1
Deadpool DTS-HD MA 7.1
Fifth Element True HD 5.1 & PCM5.1
Ghostbusters DTS-HD MA 5.1
Goosebumps DTS-HD MA 5.1
Hunger Games DTS-HD MA 7.1
Independence Day DTS-HD MA 5.1
Independence Day Resurgence DTS-HD MA 7.1
John Wick 2 DTS-HD MA 5.1
Jurassic World DTS-HD MA 7.1
Kill Bill PCM 5.1
Lone Survivor DTS-HD MA 5.1
Man Of Steel DTS-HD MA 7.1 (-3MV is fine)
Saving Private Ryan DTS-HD MA 5.1
Star Wars Last Jedi DTS-HD MA 7.1
Safe/not ideal..
Gladiator EE DTS-HD MA 5.1 (link)
Unsafe/not ideal..
Fast and Furious 7 DTS-HD MA 7.1 (safe if you remove one 28hz LS)
Pacific Rim DTS-HD MA 5.1 (link)
The Descent LPCM 7.1 (safe if you remove one 26hz LS)
Toy Story DTS-HD MA 5.1 (safe with a -3MV adjustment)
Toy Story 2 DTS-HD MA 5.1 (safe with a +1MV adjustment)
Toy Story 3 DTS-HD MA 7.1 (safe without the +2MV adjustment)
Warrior DTS-HD MA 7.1 (safe without the +2MV adjustment)
DesertDog, magicj1 and Kevnmin like this.
paulst is offline
post #7311 of 8261 Old 06-10-2019, 12:33 PM
Liked: 10281
BassEQ Momentum (2015) TrueHD 5.1
galonzo and AmerCa like this.
post #7312 of 8261 Old 06-10-2019, 12:43 PM
tvuong's Avatar
Liked: 2186
^^^ Sweeeeet. Thanks sir.
tvuong is offline
post #7313 of 8261 Old 06-10-2019, 12:50 PM
Liked: 10281
BassEQ 2010: The Year We Make Contact (1984) DTS-HD MA 5.1
galonzo and Spidacat like this.
post #7314 of 8261 Old 06-10-2019, 01:05 PM
Liked: 10281
BassEQ Shed of the Dead (2019) DTS-HD MA 5.1
Tobias Secker likes this.
post #7315 of 8261 Old 06-11-2019, 02:10 AM
Tobias Secker's Avatar
Quoted: 31 Post(s)
Thank you
TV-UE55H6400, AVR-Denon ARV-X2400H, Center-Tannoy Mercury MC, Mains-Celestion 9's, Surrounds-Tannoy Mercury M1, Atmos-Tannoy 621, Subs-Dual BK Monolith Plus DF, MiniDSP 2x4 HD.
Tobias Secker is offline
post #7316 of 8261 Old 06-11-2019, 12:39 PM
Liked: 10281
BassEQ Fast Five (2011) Extended DTS:X
I had to leave the <10Hz down there or it would clip.
galonzo likes this.
post #7317 of 8261 Old 06-11-2019, 02:20 PM
zeus33's Avatar
Quoted: 1782 Post(s)
Liked: 1765
+41 @ 23 hz! That's what you call "lacking." I knew these neutered the low frequencies, but wow.
zeus33 is offline
post #7318 of 8261 Old 06-11-2019, 02:33 PM
3ll3d00d's Avatar
Quoted: 2298 Post(s)
Liked: 2391
@aron7awol anecdotal impression only (i.e. I am too lazy to go and review previous filters) so take with a pinch of salt but have you lifted your target curve? I get the impression the beq'ed section is generally higher in level than the rest of the curve recently (or put another way, it is not just correcting hpf).
galonzo, aron7awol and richardsim7 like this.
3ll3d00d is offline
post #7319 of 8261 Old 06-11-2019, 03:07 PM
muad'dib's Avatar
Quoted: 392 Post(s)
Liked: 107
Quick question..
I'm new to this thread and have a MiniDSP 2x4 HD.
To enter movie eq correction from this forum. Do I just enter those numbers on top right corner in photo into output eq section on minidsp?
Sorry if this seems silly to ask, just could not find the exact procedure on how we are on this forum entering the correction..
muad'dib is offline
post #7320 of 8261 Old 06-11-2019, 03:25 PM
Liked: 10281
I just went back through the last few pages to look at my recent BEQs, and I think Fast Five is kind of the exception, but I do know what you're getting at. I'm definitely picking up the midbass in that particular case to shape the curve to "fit" between the final boosted levels of the ULF and the upper range.
Edit to add: Of course I can't know whether I'm actually countering a HPF since I don't know what the original HPFs added were, but compared to the shape of a "normal" mix it seems to dip in that range so I may in fact be countering a gentle HPF that rolled everything off in that range. I can't be sure, but I think it's preferable with the boosted level of the ULF anyway.
