Bass EQ for Filtered Movies - Page 245 - AVS Forum | Home Theater Discussions And Reviews
 25542Likes
post #7321 of 10526 Old 06-11-2019, 03:45 PM
Quoted: 229 Post(s)
Liked: 179
Originally Posted by muad'dib View Post
Quick question..
I'm new to this thread and have a MiniDSP 2x4 HD.
To enter movie eq correction from this forum. Do I just enter those numbers on top right corner in photo into output eq section on minidsp?
Sorry if this seems silly to ask, just could not find the exact procedure on how we are on this forum entering the correction..
Welcome to the crowd, you're going to love it. I used to just enter the PEQ's as listed in the photo as you say, but instead of output side of the Mini, load them into the input side. That allows you to keep any house curve you want into your output side.
Did you notice I said "used to" do it that way. I wised up finally and downloaded the BEQdesigner app, did the merge and now have all the XML files on my laptop. Its a couple clicks and bang its done. Plenty of great instructions on page 1 of this thread on the how to's for setting you up that way.
galonzo likes this.
Sony 75X940E, Denon X6200w, Sony X700, Roku Ultra, MiniDSP 2x4HD
Parasound (2x)HCA-855a, HCA-750a, Sony ES4300, BKA-1000 & -300
Mission 705a L&R, dual 70c3 C, 703 SL&SR, 705 BL&BR, (4x)Yamaha NSIC800 Atmos
LFE- Front: M&K MX-200 & MX-150THX; Rear: (2x)M&K V-75's
ULF- Bk LFE(4x) & Advance + Aura shakers(2x) + Mini-riser BOSS(8x12" JBL's)
Kevnmin is offline
post #7322 of 10526 Old 06-11-2019, 04:05 PM
muad'dib's Avatar
Quoted: 407 Post(s)
Liked: 115
Thanks.. I'll download the program..
So does program search out on internet and get a updated listed of corrections?
Thanks again.. Now to have fun...
muad'dib is offline
post #7323 of 10526 Old 06-11-2019, 04:40 PM
Quoted: 229 Post(s)
Liked: 179
....So does program search out on internet and get a updated listed of corrections?
Not automatically, you have to merge again with a couple mouse clicks. The frequency that you manually do that is up to you. I would say no more than once a week or two. Just depends if you want to watch a movie that has been added to the list since your last update/merge. Myself I haven't updated in two weeks. Again, its all up to you.
galonzo likes this.
Kevnmin is offline
post #7324 of 10526 Old 06-11-2019, 05:39 PM
Quoted: 2803 Post(s)
Liked: 11979
BassEQ Us (2019) Atmos
galonzo, magicj1 and richardsim7 like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #7325 of 10526 Old 06-11-2019, 08:21 PM
Nalleh's Avatar
Quoted: 2572 Post(s)
Liked: 3458
Originally Posted by 3ll3d00d View Post
@aron7awol anecdotal impression only (i.e. I am too lazy to go and review previous filters) so take with a pinch of salt but have you lifted your target curve? I get the impression the beq'ed section is generally higher in level than the rest of the curve recently (or put another way, it is not just correcting hpf).
Originally Posted by aron7awol View Post
I just went back through the last few pages to look at my recent BEQs, and I think Fast Five is kind of the exception, but I do know what you're getting at. I'm definitely picking up the midbass in that particular case to shape the curve to "fit" between the final boosted levels of the ULF and the upper range.
Edit to add: Of course I can't know whether I'm actually countering a HPF since I don't know what the original HPFs added were, but compared to the shape of a "normal" mix it seems to dip in that range so I may in fact be countering a gentle HPF that rolled everything off in that range. I can't be sure, but I think it's preferable with the boosted level of the ULF anyway.
I am wondering if 3ll3 means that earlier(in the beginning) you seemed to target the curve at about -20dB, while lately it seems to be up at around -15dB. You are more "agressive" now.
richardsim7 likes this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 12xJBL 12" w/6xSLAPS M12 downfiring VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #7326 of 10526 Old 06-12-2019, 06:04 AM
mitchlampert's Avatar
Quoted: 122 Post(s)
Liked: 44
This might sound a little crazy but is there anyone in the southeast Florida area that would be willing to come to my house and help me set this up while teaching me how to continue to use it? It looks like an easy to use process with a very steep learning curve!!
mitchlampert is offline
post #7327 of 10526 Old 06-12-2019, 06:18 AM
3ll3d00d's Avatar
Quoted: 2486 Post(s)
Liked: 2704
yes, something like that. Note I don't mean this is good or bad, is just an observation.
random sample of early BEQs which fit my subjective perception of BEQs up to a few months, broadly flat or slightly downsloping curve beyond the original rolloff
vs 2 recent ones which have a bit more of a continuing upward slope
paulst, Nalleh and richardsim7 like this.
3ll3d00d is online now
post #7328 of 10526 Old 06-12-2019, 06:25 AM
richardsim7's Avatar
Quoted: 1395 Post(s)
Liked: 1824
Yeah, almost as if aron's adding in a house curve
galonzo likes this.
richardsim7 is offline
post #7329 of 10526 Old 06-12-2019, 07:09 AM
richsto's Avatar
Quoted: 48 Post(s)
Liked: 105
Think I previously posted concerns regarding over boosting resulting in boomy, tubby bass. Seemed to have only been a few titles but lately I’ve noticed more titles being a bit over blown. While the extra extension is terrific, not worth it if it comes at the expense of overall tight, defined impactful bass. Just my two cents.
richsto is online now
post #7330 of 10526 Old 06-12-2019, 07:20 AM
Sekosche's Avatar
Quoted: 1439 Post(s)
Liked: 3634
The movie Don’t Breathe definitely doesn’t “need” BEQ, but I’m giving it a re-spin now and noticed it’s not in the repo. Not sure how much you can do below 20Hz since the peaks are already crazy hot around there, but looks like the average level below 17-18Hz could maybe be brought up a bit. That said, not sure it honestly needs any more authority down low, because the dynamics of the contrasting quiet scenes surrounding the piercingly impactful bass moments are even more insane than I remember with the BOSS in play.
CallingMrBenzo and aron7awol like this.
Speakers: PSA MTM-210T x2, MTM-210C, MT-110SR x2; Atmos-SVS Satellite x2, DIY Volt-10 x2
Subs: PSA V1801 x2, DIY: 18" RSS460HO, 15" RSS390HO x2, BOSS w/JBL CX1200 x6
MA’s: Crowson Tech x2
Processing: Denon X4200, NU6KDSP, 3KDSP
Video: Epson 3700; Screen: Silver Ticket 106" High Contrast
Sekosche is offline
post #7331 of 10526 Old 06-12-2019, 07:54 AM
Nalleh's Avatar
Liked: 3458
I agree with 3ll3, not saying it is right or wrong, just an observation on my part too.
I guess Aron can do that now, both because he has learned more about it, doimg almost 800 of them!, but also because of the exellent tools he has at hand for BEQ’ing.
After all, he IS our Ninja BEQ master
galonzo, aron7awol and d-rail34 like this.
Nalleh’s HT
post #7332 of 10526 Old 06-12-2019, 09:00 AM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 502
Would The Conjuring be worth doing? I have the Blu Ray, but haven’t watched it yet. The graph in the other thread looks decent
aron7awol likes this.
Subwoofers: Dual Rythmik FV18
Speakers: L/R Ascend Acoustics Sierra 2EX - Center - Horizon w/RAAL Surrounds: Sonance VP62R SST/SUR. Vinyl:Rega Planar 3
Video: Sony XBR65X900e 65" 4K - Sony UBP-X800 Blu Ray
Power and Processing: Yamaha RXA1030 - Monolith 7X Amp - Minidsp 2X4 HD/WI-DG
jsc79 is online now
post #7333 of 10526 Old 06-12-2019, 09:29 AM - Thread Starter
PioManiac's Avatar
Quoted: 3341 Post(s)
Liked: 8449
Why not at least attempt the basics yourself, then ask here if you get stuck?
Originally Posted by PioManiac View Post
It's very little work actually, as Aron pointed out, the hard part is already done for you.
...and once you have your eyes (and ears) opened to the true potential, you won't want to watch a movie again without BEQ.
Let me dumb it down to caveman level (I figured it out, so surely anyone can)
Buy one of These: https://www.minidsp.com/products/min...minidsp-2x4-hd
Put it Here:
Download the README instructions and 700+ BEQ movie list through the GitHub Repo Here: https://github.com/bmiller/miniDSPBEQ
Click the File Load in the top left corner of the miniDSP HD-1 software, pick any movie off the list of 700+ titles, Hit Connect
The XML files will load the appropriate Low Shelf and Peak filters to the miniDSP input channels in a few seconds.
Watch your movie with Full Bandwidth ULF/LFE. Yes, it's really just that simple.
Everything Else on the first page is completely optional.
-measuring your room with REW and a UMIK-1 mic
-adding a wireless bridge (Wi-DG) eliminates the USB cable from your miniDSP to your Laptop https://www.minidsp.com/products/accessories/wi-dg
-adding a House Curve to your miniDSP output channels in XML format and merging it with the movie BEQ repo list with the BEQ'Designer App
-creating your own graphs or remux the audio instead of buying a miniSDP (for computer geeks only) using the BEQ'D App
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #7334 of 10526 Old 06-12-2019, 09:40 AM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 502
It really is easy, just stick to the directions and if you have a hiccup, ask on here.
I had one hiccup and PioManiac had me back on track in a few minutes.
PioManiac and cinemaniac93 like this.
jsc79 is online now
post #7335 of 10526 Old 06-12-2019, 09:44 AM
Quoted: 122 Post(s)
Liked: 44
Thanks! I plan on also using the mini dsp to eq my subs as well. I ordered all the necessary items this morning. Hopefully I won't need to ask to many questions!!
PioManiac and galonzo like this.
post #7336 of 10526 Old 06-12-2019, 10:19 AM
EricE's Avatar
Quoted: 121 Post(s)
Liked: 48
Planning on using BEQDesigner first to remux a few movies that I own to see how I like it first.
Since this is a post Bass Management setup is it just a matter of using the GitHub Repo XML file with BEQDesigner to do the remux?
EricE is offline
post #7337 of 10526 Old 06-12-2019, 10:25 AM
Liked: 11979
Yeah, I'm definitely more aggressive now than I was a while back, which I think goes back to when d00d added the peak spectrum functionality to BEQD which gave me a lot more insight into what I was actually boosting. With the MV adjustments, I'm targeting that -15 to -20dB band for the ULF and trying to get a reasonably smooth transition between that band and where the upper bass lies naturally. So I'm not necessarily trying to create a house curve, but more continue the slope that occurs naturally in most mixes.
SBuger, galonzo, 3ll3d00d and 3 others like this.
post #7338 of 10526 Old 06-12-2019, 10:26 AM
Liked: 11979
I thought I did that one because I know I watched it with BEQ. I'll publish one soon. I loved the movie, and I think I remember it was way too strong somewhere around 20-30Hz.
galonzo likes this.
post #7339 of 10526 Old 06-12-2019, 10:42 AM - Thread Starter
PioManiac's Avatar
Liked: 8449
When someone does get stuck and presents a new obstacle, things usually get resolved pretty quickly.
Then I often modify the setup guide to help new users past the same potential road blocks.
...so don't hesitate to ask. All shared information is valuable in an effort to make things easier.
I know there's a LOT of information posted on page one that can make it look overwhelming.
But once you have the tools right in front of you, it's very easy to step yourself through every process.
If you're using the miniDSP to EQ your subs (and/or create a house curve)
Those will be saved to their own xml file (miniDSP file format) using the Output Channels
To merge your personal Config file to the BEQ's (on the Input Channels)
You will be using the BEQ-Designer App (not DesertDog's Desktop Github Repo)
The BEQ-D App will still pull from the same Repo when you do a refresh/save (literally a 2 click merge process)
Going forward all you need to do is click load (miniDSP software) pick a title off your merged list, hit connect.
mitchlampert, galonzo and d-rail34 like this.
post #7340 of 10526 Old 06-12-2019, 10:54 AM
Liked: 11979
BassEQ Don't Breathe (2016) DTS-HD MA 5.1
Sekosche, d-rail34, AmerCa and 1 others like this.
post #7341 of 10526 Old 06-13-2019, 07:32 AM
Liked: 11979
BassEQ Pride and Prejudice and Zombies (2016) Atmos
post #7342 of 10526 Old 06-13-2019, 08:47 AM
tvuong's Avatar
Quoted: 2621 Post(s)
Liked: 2377
Hotel Mumbai (2018) please, Aron? TIA
tvuong is offline
post #7343 of 10526 Old 06-13-2019, 11:38 AM
Liked: 11979
BassEQ Hotel Mumbai (2018) DTS-HD MA 5.1
galonzo likes this.
post #7344 of 10526 Old 06-13-2019, 05:33 PM
MOberhardt's Avatar
Quoted: 913 Post(s)
Liked: 579
I didn't think it needed anything! That is a nice clean unfiltered mix! Even with my modest dual svspb2000 setup, I could feel it.
galonzo and SuperFist like this.
MOberhardt is online now
post #7345 of 10526 Old 06-14-2019, 08:00 AM
EricE's Avatar
Quoted: 121 Post(s)
Liked: 48
Quick question and I'm not sure if this has been asked before but anyway...
Can the minidsp 2x4HD be bypassed when the unit is off?
Ideally, I would use it when I was running the theatre myself but it would be bypassed when off and other people were running the theatre. That would prevent any mistakes of selecting the wrong EQ or movie settings.
EricE is offline
post #7346 of 10526 Old 06-14-2019, 08:20 AM
jsc79's Avatar
Quoted: 423 Post(s)
Liked: 502
I finally was able to try out the BEQ for the first time with TRON yesterday. I started when he is at the arcade and gets teleported to the grid through the light cycle race. Wow, what a difference in the TR and the low end sound!. I run my subs 6 hot in the avr as well and mv -10.
Now I will be working on removing the 6db boost in the avr and replacing it with a 6 or 8db house curve in the MiniDSP.
MOberhardt, galonzo and aron7awol like this.
jsc79 is online now
post #7347 of 10526 Old 06-14-2019, 09:25 AM - Thread Starter
PioManiac's Avatar
Liked: 8449
Thumbs up
BassEQ Fast Five (2011) Extended DTS:X
Spoiler!
I had to leave the <10Hz down there or it would clip.
Originally Posted by zeus33 View Post
+41 @ 23 hz! That's what you call "lacking." I knew these neutered the low frequencies, but wow.
Un-watchable without BEQ!
The only 4K/UHD I bought (out of all 8) was the last one (Fate of the Furious)
... until I saw it pop up on amazon at 40% off for the 8-Pack last night (June 11/2019 release date)
Should have it sometime today (Prime 1 Day free shipping)
Link: https://www.blu-ray.com/movies/Fast-...lu-ray/240499/
So I guess the only ones missing from the BEQ list are 4 and 6? (TIA Aron )
Edit...this just in (ordered last night at 8:45pm arrived just after lunch today)
ID:	2579828   Click image for larger version
ID:	2579830   Click image for larger version
post #7348 of 10526 Old 06-14-2019, 10:57 AM - Thread Starter
PioManiac's Avatar
Liked: 8449
There's no power button on the miniDSP, it's always on.
If you disconnect the power source (pulling the plug) there is no pass through to your subs.
Your best option is to utilize the 4 Config slots in the miniDSP software.
Swap to an alternate Config when you're finished with a movie.
I swapped my configs around several times, but currently using:
Config 1 for loading BEQ'd Movie titles (merged for BEQ on Input, House Curve on Output)
Config 2 Input Channels all bypassed, Output Channels have house curve only
Config 3 Night Mode (sub output levels reduced by 5-10dB)
Config 4 Late Night mode (All sub output levels muted, Crowsons only)
EricE likes this.
post #7349 of 10526 Old 06-14-2019, 11:45 AM
tvuong's Avatar
Liked: 2377
Crypto (2019) please brother Aron? TIA.
tvuong is offline
post #7350 of 10526 Old 06-14-2019, 12:16 PM
EricE's Avatar
Quoted: 121 Post(s)
Liked: 48
Thanks for the advice PioManiac.
That sounds like a good workaround for a bypass.
Now for my sub amp, (Behringer EP2500 btw) it accepts 1/4" TRS connections. Do I just use a unbalanced RCA to 1/4" TRS adaptor or is it a TS adaptor?
Since it will be a mono signal from the MiniDSP, I'm assuming it will be TS...
EricE is offline
