Bass EQ for Filtered Movies - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 19998Likes
post #7561 of 8091 Old 06-24-2019, 08:43 AM
Quoted: 2370 Post(s)
Liked: 10114
BassEQ Inferno (2016) Atmos
galonzo and paulst like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #7562 of 8091 Old 06-24-2019, 09:27 AM
mitchlampert's Avatar
Quoted: 118 Post(s)
Liked: 42
Originally Posted by CallingMrBenzo View Post
@aron7awol
Any chance we could refresh Spider-Man Homecoming.
It will be the first movie I do on my new ported beasts
Haven had a chance do run REW but once I do I will need advice on putting in a HPF switching from Sealed to ported 13.5 hz tune.
Which subs are those monsters!!
mitchlampert is offline
post #7563 of 8091 Old 06-24-2019, 09:30 AM
CallingMrBenzo's Avatar
Quoted: 424 Post(s)
Liked: 875
Power Sound Audio TV36’s with the B&C NEO drivers. They are not up on the website yet they are finishing up pre orders. But dual 18’s with an ice 1920 RMS amp 4000w peak. 6 inch port and tuned at 13.5 hz. I am flat to 10 hz in room.
Marantz 7011- Panasonic UB-820- Xbox One X - Epson HC 5050UB - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA VT36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is offline
post #7564 of 8091 Old 06-24-2019, 09:42 AM
Quoted: 118 Post(s)
Liked: 42
Looks great!!! Congrats!
post #7565 of 8091 Old 06-24-2019, 12:08 PM
lawdogx's Avatar
Quoted: 90 Post(s)
Liked: 92
I've been following this thread for months and finally decided to grab a minidsp and jump in. What a difference! I thought I was happy with the bass my theater was making before but wow, I had no idea what I was missing. We on AVS go crazy spending hundreds of hours and thousands of dollars tweaking our system and upgrading our equipment for a few dB gain in a narrow bandwidth and this $200 piece of hardware and free data gives dozens of dB gain over half the bass spectrum - amazing (and probably the biggest bang-for-the-buck upgrade I've made in home audio).
Many thanks to @aron7awol , @PioManiac , @3ll3d00d , and @DesertDog for your hard work!
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E Atmos; 4 x UM18-22 Mini Marty's.
COMPONENTS: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 2 x NX6000d; Epson 5040UB.
lawdogx is offline
post #7566 of 8091 Old 06-24-2019, 12:13 PM
3ll3d00d's Avatar
Quoted: 2286 Post(s)
Liked: 2372
@aron7awol there will be a beta up shortly which adds an option in Preferences named "Averaging", it has two options: Mean, Median. It applies to the way the average is calculated, current release uses mean, change to median and add the same signal again and you'll get the median version for comparison. Can you try this against something like Red Sparrow?
I used some random sample I had locally (BR2049 car landing scene) and you get the following, mean is yellow btw. The 100Hz spike is the bit to look at in this example.
Note that I expect this will change the reported signal level significantly for some (most?) tracks.
3ll3d00d is offline
post #7567 of 8091 Old 06-24-2019, 12:13 PM
paulst's Avatar
Quoted: 179 Post(s)
Liked: 383
I bet they sound awesome What size is the room and is it sealed?
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is offline
post #7568 of 8091 Old 06-24-2019, 12:14 PM
DesertDog's Avatar
Quoted: 512 Post(s)
Liked: 1469
I just got the repo caught up with everything from the last couple of day. While doing it I cleaned up the TV show file names so that they're all on a consistent format and included the streaming service in the name if it's not from disc. Due to that, I'd recommend nuking the git repo folder and letting BEQd redownload them if you're using the merge feature. Doing so will clean up the mass amount of duplicate files you'll have otherwise.
Along the lines of renaming things. I've stuck with using "gain" in the titles because it started that way so that everything is consistent instead of switching to "MV" like the graphs have it. Is there a preference among everyone on "gain" vs "MV"? I can go through and do a mass rename on every file and then start using it if there is. I don't really want to do it without consensus though since it'll muck with the BEQd merge and everyone will have to reset the repo after the change if I do it. It'd be nice if dulwich (the git library) ever fixed this bug.
@PioManiac It looks like the front page is missing punisher season 2
https://www.avsforum.com/forum/113-s...l#post57475704
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is offline
post #7569 of 8091 Old 06-24-2019, 12:14 PM
Liked: 10114
Amen! That is exactly why I chose to put "Take the Red Pill" in my sig linking to this thread. Once you try your first BEQ, it's truly just an eye-opening experience and a game-changer and there's no going back!
Nalleh and d-rail34 like this.
post #7570 of 8091 Old 06-24-2019, 12:23 PM
3ll3d00d's Avatar
Liked: 2372
example for full track using RP1
here's the spectrum
and mean vs median, median in yellow this time
which one is the truer representation of the average signal level? lies, damned lies and statistics eh
ID:	2583964   Click image for larger version
galonzo and aron7awol like this.
3ll3d00d is offline
post #7571 of 8091 Old 06-24-2019, 12:27 PM
3ll3d00d's Avatar
Liked: 2372
OT.... median option is a recent addition to scipy so I thought to myself "I wonder if I can hack the code to produce a percentile too" .... then I see it cites Appendix B of https://arxiv.org/pdf/gr-qc/0509116.pdf ("FINDCHIRP: An algorithm for detection of gravitational waves from inspiraling compact binaries") and I back slowly away from the stats
3ll3d00d is offline
post #7572 of 8091 Old 06-24-2019, 12:32 PM
tvuong's Avatar
Quoted: 2540 Post(s)
Liked: 2186
Amen! I am so spoiled that I'm no longer watching a movie without BEQ as I rather wait for you. I told my wife before that I rather not watch a movie on TV and now I'm telling her I rather not watch a movie without beq. Thanks everyone especially to Aron, Piomaniac, Dood, and Desertdog for working tirelessly for our community
tvuong is offline
post #7573 of 8091 Old 06-24-2019, 12:45 PM
Liked: 10114
I'd love for you to add median as a third line because I think that would be the best way to observe median compared to the other two on a bunch of different mixes and decide where its value lies, but I'm guessing that they way you have structured the existing code would make that much more difficult than replacing mean with median by toggling that setting
post #7574 of 8091 Old 06-24-2019, 12:45 PM - Thread Starter
PioManiac's Avatar
Quoted: 3162 Post(s)
Liked: 7716
Thanks DD, Good catch!
I probably glanced over the post back in January but skipped it when I saw 2017 thinking it was a S1 update.
Pretty sure Season 2 release was 2019
BassEQ The Punisher (2017) Season 2 DD+ Atmos
Spoiler!
List on Page 1 fixed to include both Seasons
galonzo likes this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #7575 of 8091 Old 06-24-2019, 12:52 PM - Thread Starter
PioManiac's Avatar
Liked: 7716
Another one that should read 2019
I binged S1 this weekend just so I could remember who all the character were. (in all 3 decades)
It's been too long between seasons to rely on my crap memory.
BassEQ Dark (2017) Season 2 Netflix DD+
galonzo and CallingMrBenzo like this.
post #7576 of 8091 Old 06-24-2019, 12:53 PM
DesertDog's Avatar
Quoted: 512 Post(s)
Liked: 1469
TV Shows are usually listed by the year of their first season and not the year a particular season aired. It's more of an identifier than an air date to group them together in the case of multiple shows having the same name.
BEQ Slack group
post #7577 of 8091 Old 06-24-2019, 12:55 PM - Thread Starter
PioManiac's Avatar
Liked: 7716
I was referring to Aron's error on his posting of the graph
He has both Seasons on his graph page as 2017, same goes for Dark.
Should be 2017 S1 and 2019 S2 for both titles (all 4 pages indicate 2017)
post #7578 of 8091 Old 06-24-2019, 01:01 PM
Liked: 10114
I did that intentionally in both cases. I am identifying the TV series using its title and original release year (in case there is more than one series with the same name), and then the season, and then the audio format. Identifying TV series in that manner is the standard that I've always seen, which includes scrapers that pull info/artwork from TVDB.
DesertDog and galonzo like this.
post #7579 of 8091 Old 06-24-2019, 01:08 PM - Thread Starter
PioManiac's Avatar
Liked: 7716
ok, my bad
I was just trying to follow a similar format as Movie releases
For example:
The Mummy (2017) 4K/UHD/ATMOS (Sept.12/2017)
The Mummy (1999) 4K/UHD/DTS:X (Sept.12/2017)
(just happened to release the same month/year)
post #7580 of 8091 Old 06-24-2019, 01:13 PM
Liked: 10114
My wife and I watched some Season 1 recap videos and read a recap article and then talked through all the characters, and I paused it a few times during the first episode so we could make sure the characters who were we thought they were, and what their relationships to the other characters were.
What a crazy show! Love it!
PioManiac and Nalleh like this.
post #7581 of 8091 Old 06-24-2019, 01:18 PM
Liked: 10114
ok, my bad
For example:
All good, brother!
The year I list in my posts is always intended to be that first year listed in your post above. It's the year that identifies the movie or series if there is more than one with the same name.
The second date that you list is the disc release date, right? Or in the case of a TV series, the date the season was released? So that's just additional information not included in my post. I think we're both doing things consistently for movies and TV series
DesertDog, PioManiac and galonzo like this.
post #7582 of 8091 Old 06-24-2019, 01:22 PM
3ll3d00d's Avatar
Liked: 2372
this was the 5 min bodge to get something usable in there, I don't think it will take that much more effort to make it available everywhere but it will slow everything down a bit (50% more lines to calculate and draw) and some of the changes will be quite dull to write so prefer not to do that until I try a few more tracks.
3ll3d00d is offline
post #7583 of 8091 Old 06-24-2019, 01:24 PM
Quoted: 424 Post(s)
Liked: 875
12w x 21 l x 8 h and it’s open at the back to a small area that has a tread mill / fish tank and desk.
paulst likes this.
post #7584 of 8091 Old 06-24-2019, 01:59 PM - Thread Starter
PioManiac's Avatar
Liked: 7716
Red face
All good.
Yes, whenever you post a new BEQ,
I try to provide users with specific bluray release its compatible with.
The Theatrical release date is only a starting point for me,
My first reference is to go to Bluray.com and grab the earliest available "Disc release date" on bluray that matches the audio format you posted the BEQ for.
For Example, Tron legacy was simple enough...
But some Movies have many Bluray releases for the same Theatrical release date,
...so I have to find the one that's the closest match to the BEQ you post.
For example, The Fifth Element (1997):
Original 2006 release was LPCM 5.1, in 2010 a TrueHD track was added to the Re-Mastered BD)
and you have to go to the 2015 Mastered in 4K release to get the ATMOS track (same as the 2017 4K/UHD ATMOS release)
In the case of "City of Lies" that you posted I found nothing at first,
so I had to change the country code from U.S, to World wide to reveal it was available in Italy
It's a lot more work doing the detective work sometimes, but I figure if someone really wants to watch a movie with BEQ,
making sure they are using the same release as the date on bluray.com is more defined and disc specific than just year the movie was released in theaters.
(sorry for the long-winded explanation)
Name:	Tron Legacy.png
ID:	2583994   Click image for larger version
Name:	Tron Legacy_2.png
ID:	2583996   Click image for larger version
Name:	The Fifth Element.png
ID:	2584000   Click image for larger version
Name:	City of Lies.png
post #7585 of 8091 Old 06-24-2019, 06:40 PM
Quoted: 27 Post(s)
Liked: 76
Hello all,
Wondering if anyone has experienced this before.
I had (luckily) finished watching a fairly heavy bass movie near reference, and was about halfway through Dark Season 2 Episode 1 when my Crowsons started to bottom out during a relatively quiet (bass) scene.
After 10 seconds I got concerned and thought my Crowson amp was failing, but checked my Minidsp 2x4hd output and noticed that my channel 3 output (Crowson front row seating) was significantly higher (about 25db) than my channel 1 (front subs) and channel 2 (rear sub).
Has anyone experienced anything like this before? Very glad that this didn't happen during a reference film or a heavy bass scene, as it could have spelled trouble. I at first reduced my crown amp from 24 to 1, then reduced my minidsp down via phone by about 25db then turned my crowson amp back up to finish the episode.
When taking the screenshot I returned my minidsp to near regular output (you will see channel 3 in low negatives) but MV back down to take a screenshot of the issue (attached) without clipping
I will also note that my Channel 3 output is linked with Channel 1 on the input stage (screenshot also attached). I imagine this is a weird anomaly and am hoping a restart to my PC will fix it (have not yet tried, decided to write this post first).
FYI channel 4 is off on purpose as that channel is for rear crowson seating.
ID:	2584094   Click image for larger version
Name:	Input stage.JPG
Sony hw45es | 100 inch screen | Yamaha RX-A3060 | Axiom ADA 1250-3 | Axiom M80s/VP180/QS10HPs | DIY SI DS4-18s sealed (2) | Crown XLS 2002 (2) | PSA S3601 | MiniDSP 2x4HD | Crowson D-501/Shadow-8 Actuators (x4) (coming soon)
Paulo Franco is offline
post #7586 of 8091 Old 06-24-2019, 08:32 PM
Liked: 10114
^^^ You'll have to show us the filters you have on each of those outputs to look for an explanation, but a quick guess is that you have HPF enabled on output 1 and 2 but not 3?
post #7587 of 8091 Old 06-25-2019, 12:59 AM
galonzo's Avatar
Quoted: 1302 Post(s)
Liked: 1627
@aron7awol , thanks again for doing the Da Vinci Code series
And to help you get to 800 (and help those of us who refuse to watch anything without BEQ anymore, but have a backlog of unwatched titles), another series that I have but haven't watched yet on UHD that has TrueHD Atmos is the DC Comics series RED (2010) and RED 2 (2013), if you would be so kind, sir
paulst, aron7awol and Kevnmin like this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #7588 of 8091 Old 06-25-2019, 04:40 AM
Quoted: 27 Post(s)
Liked: 76
Seems odd that it happened during this show only halfway through, and I have watched at least 30-40 full length movies with BEQ and never experienced anything like this before, and have not made any changes to my output filters in over 6 months
But I have attached as you requested, you are right, there is a highpass filter on channel 1 and 2.
Computer is restarted, not running any films, I loaded up the Dark Season 2 repo and am getting about 100dBFs and channel 1 and 2 and hitting high 60dBFs on channel 3 with zero content playing.
Never really monitored this before, maybe this is normal even when no content is playing since no HPF and there is a large boost in very LF content (which I want my Crowsons to get but not my SWs) but I know what happened last night during viewing was DEFINITELY not normal/as intended, and it has not happened before.
Name:	No Content.JPG
ID:	2584230   Click image for larger version
Name:	Channel 3 Output.JPG
ID:	2584232   Click image for larger version
Name:	Channel 1 & 2 Output.JPG
post #7589 of 8091 Old 06-25-2019, 05:16 AM
Quoted: 424 Post(s)
Liked: 875
Spent the weekend taking everything out. Putting up 40 yards of velvet. Need somebody to help me tuck the front carpet under those big boys. I think the end result looks great. This is with lights on and flash on the camera.
The Polk speakers are my current free speaker stands for the MTM-110’s. I switched the TV36’s to have the ports shooting into the side walls per the suggestions on this thread.
Thought I would post this here. Now that I am done setting everything up, I need to dial these bad boys in. That will take some trial and error then back o BEQ!!!
post #7590 of 8091 Old 06-25-2019, 06:32 AM
Quoted: 118 Post(s)
Liked: 42
If I'm using a minidsp HD 2x4 for ONLY BEQ, do I need to use the low pass crossovers or can I bypass ALL the crossovers in all the channels?
