Bass EQ for Filtered Movies - Page 274 - AVS Forum | Home Theater Discussions And Reviews
 27027Likes
post #8191 of 11155 Old 07-19-2019, 08:34 PM
lawdogx's Avatar
Quoted: 175 Post(s)
Liked: 208
I’m getting a kick out of following the BEQd discussion interspersed without comment by Aaron’s workmanlike and never ending new movie additions. Thanks again for your efforts gents!
galonzo, jamiebosco and aron7awol like this.
SPEAKERS: 3 x DIYSG 1099's LCR; DIYSG HTM 6's and 8's surround; 4 x RSL C34E's atmos.
SUBS: 4 x UM18-22 Mini Marty's and 2 x 21DS114-4 Devastators
SIGNAL CHAIN: Denon X4400; Minidsp 2x4 HD; 2 x Jensen Iso Sub 2RX; 3 x NX6000d.
lawdogx is offline
post #8192 of 11155 Old 07-19-2019, 08:54 PM
Quoted: 2908 Post(s)
Liked: 12358
BassEQ Unforgiven (1992) DTS-HD MA 5.1
Tons of noise in this one so I could only grab a bunch of 20-40Hz content.
galonzo, jamiebosco and Menquin like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Fusion-8 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is offline
post #8193 of 11155 Old 07-19-2019, 09:22 PM
darrellh44's Avatar
Quoted: 1078 Post(s)
Liked: 535
Originally Posted by Stereodude View Post
What do you mean? A human decided what filters to add (aron7awol). BEQ Designer shows before and after effects on the spectrum.
Are you asking how the spectrum is generated? That's by a FFT of the audio signal I'd imagine.
No, I meant what is the art for determining the overall BEQ curve fitted to each movie. Does aron7awol simply try to match the max/avg spectral levels across bass frequencies down to 10 Hz using the spectral graphs, or is there more to it?
The reason I asked about help from movie studios is I have several movies in both DVD and BluRay/4K format. In almost all cases I would say the DVD format doesn't really need BEQ, but the newer formats absolutely need it (eg, "Master and Commander"). IOW, it seems to me that the DVD version in many cases could be the BEQ standard for restoring bass to the same movie in BluRay/4K format.
I'm not trying to imply anything bad about BEQ, in fact, I'm in the process of setting up a miniDSP HD on my LFE for MSO and BEQ correction. I'm just curious how the curves for each movie are determined.
Darrell
darrellh44's Home Theater
Guide to Subwoofer Calibration and Bass Preferences
"Faith is not about everything turning out OK, Faith is being OK no matter how things turn out".
darrellh44 is online now
post #8194 of 11155 Old 07-19-2019, 10:08 PM
Liked: 12358
In general I'm trying to follow the natural shape of the mix, while bringing the ULF to a consistent level mix-to-mix so that those of us who have tuned our systems to the level that we like down there will get a consistent experience. At the same time, I'm trying to smoothly transition between the ULF and midbass, and trying to discern the filtering that was used and counter it, while watching out for noise and inconsistencies in the filtering. So I'm really trying to balance all of those things and tapping into my previous experiences designing them and then playing them to settle on what I think will be the most consistent and enjoyable experience for a particular mix, which sometimes means striking the right compromises when there are issues such as noise or inconsistent filtering.
post #8195 of 11155 Old 07-19-2019, 10:35 PM
darrellh44's Avatar
Liked: 535
Thanks for the explanation, and thanks especially for sharing all of your hard work.
aron7awol likes this.
post #8196 of 11155 Old 07-19-2019, 11:48 PM
MOberhardt's Avatar
Quoted: 981 Post(s)
Liked: 684
Originally Posted by aron7awol View Post
BassEQ Deepwater Horizon (2016) Atmos
I tried searching the thread, but couldn't find it, but is Patriots Day covered? Just most of Berg's other epics are here and popular!
galonzo and aron7awol like this.
MOberhardt is offline
post #8197 of 11155 Old 07-20-2019, 02:56 AM
3ll3d00d's Avatar
Quoted: 2547 Post(s)
Liked: 2833
Yes, I mean a single value for the entire track. I think my reply above adequately explains why I want it.
https://github.com/3ll3d00d/beqdesig...g/0.7.3-beta.6
3ll3d00d is online now
post #8198 of 11155 Old 07-20-2019, 03:43 AM
3ll3d00d's Avatar
Liked: 2833
BassEQ Snitch (2013) Atmos
<pic with giant spike in average snipped out>
can you post with the median for that one?
post #8199 of 11155 Old 07-20-2019, 06:06 AM
Stereodude's Avatar
Quoted: 4344 Post(s)
Liked: 3082
Originally Posted by 3ll3d00d View Post
Thanks. It won't start for me.
Code:
.\beqdesigner_0.7.3-beta.6.exe
Traceback (most recent call last):
  File "site-packages\PyInstaller\loader\rthooks\pyi_rth_certifi.py", line 11, in <module>
  File "c:\tools\miniconda3\envs\test\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 627, in exec_module
  File "ssl.py", line 98, in <module>
ImportError: DLL load failed: The specified module could not be found.
[22052] Failed to execute script pyi_rth_certifi
Edit: The small one starts, but nothing shows up on the frequency / signal graph after loading a signal (they display when I'm loading the signal in the Load Signal window). I see the signal in the lower waveform view.
Stereodude is offline
post #8200 of 11155 Old 07-20-2019, 07:09 AM
Liked: 12358
3ll3d00d likes this.
post #8201 of 11155 Old 07-20-2019, 07:31 AM
Liked: 12358
BassEQ Patriots Day (2016) DTS:X
MOberhardt and SuperFist like this.
post #8202 of 11155 Old 07-20-2019, 07:56 AM - Thread Starter
PioManiac's Avatar
Quoted: 3358 Post(s)
Liked: 8530
Wink
@aron7awol , just getting the list updated this morning and noticed a typo
Should be "Wrath" in your title text
(just in case someone is using the search)
Link: https://www.avsforum.com/forum/113-s...l#post58302670
BassEQ Clash of the Titans (2012) DTS-HD MA 5.1
MOberhardt and aron7awol like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #8203 of 11155 Old 07-20-2019, 08:08 AM
Liked: 12358
Thanks, I just fixed it. I'm excited to see what the count ends up at after this update
galonzo likes this.
post #8204 of 11155 Old 07-20-2019, 08:20 AM - Thread Starter
PioManiac's Avatar
Liked: 8530
BassEQ Underworld: Evolution (2006) DTS-HD MA 5.1
I can't find a DTS-HD MA 5.1 version of this one on Blu-ray.com,
looks like LPCM 5.1 from 2006, Was your disc part of a Trilogy pack or an import by chance?
Thanks Bud
post #8205 of 11155 Old 07-20-2019, 08:22 AM
muad'dib's Avatar
Quoted: 416 Post(s)
Liked: 115
Quick easy question..
If you set your sub spl level to let's say 80db(for more excitement) before you hookup a minidsp 2x4hd unit..
Then..
After you hookup the minidsp, and don't touch anything.. Jist leave flat, will spl levels be same or does minidsp drop the spl levels..
What happens after you upload BEQ filters... Does the overall spl drop..
If so Aprox how much....
I want to maintain my initial spl level...
muad'dib is offline
post #8206 of 11155 Old 07-20-2019, 08:30 AM
Stereodude's Avatar
Liked: 3082
Then..
That depends on which MiniDSP and how the jumpers are set.
The subwoofer level increases. By how much varies on a per movie per scene/LFE effect basis.
post #8207 of 11155 Old 07-20-2019, 08:35 AM
Liked: 12358
Thanks Bud
Fixed, thanks again.
galonzo likes this.
post #8208 of 11155 Old 07-20-2019, 08:41 AM
muad'dib's Avatar
Quoted: 416 Post(s)
Liked: 115
Thanks...
Im using the 2v input (default setting) for the minidsp 2x4hd..
muad'dib is offline
post #8209 of 11155 Old 07-20-2019, 08:47 AM
Nima's Avatar
Quoted: 237 Post(s)
Liked: 136
Watched Captain Marvel with BEQ yesterday. Really nice. Because of Atmouse I had increased MV to - 6 for clearer dialog(normally I watch at - 10) That resulted in clipping though and my crown xls 2502 power cycled at the 1:40 mark. Brutal!!!! &#x1f642;
Nima is online now
post #8210 of 11155 Old 07-20-2019, 08:51 AM
SuperFist's Avatar
Quoted: 1381 Post(s)
Liked: 5649
Thanks Bud
It looks like the Underworld: The Legacy Collection has English DTS-HD MA 5.1 audio...
https://www.blu-ray.com/movies/Under...Blu-ray/39628/
SuperFist is online now
post #8211 of 11155 Old 07-20-2019, 08:52 AM - Thread Starter
PioManiac's Avatar
Liked: 8530
Another one, I can only locate TrueHD 5.1 for this one
https://www.avsforum.com/forum/113-s...l#post58307078
BassEQ Underworld: Rise of the Lycans (2009) TrueHD 5.1
sorry
post #8212 of 11155 Old 07-20-2019, 08:53 AM
Liked: 12358
Captain Marvel has a -1.5dB MV adjustment, so if you played it +4 relative to your normal the bass will end up 5.5dB hotter than a typical BEQ on your system. You don't have to follow the MV adjustments, but you should be aware of them and the impact of the different MV change you are deciding to make.
galonzo, CallingMrBenzo and Nalleh like this.
post #8213 of 11155 Old 07-20-2019, 08:54 AM - Thread Starter
PioManiac's Avatar
Liked: 8530
...Yes, but for All 4 movies? I don't think so
post #8214 of 11155 Old 07-20-2019, 08:55 AM
Liked: 12358
sorry
I went through and double-checked them all after you mentioned the last one. It's actually already fixed in the post you quoted
PioManiac likes this.
post #8215 of 11155 Old 07-20-2019, 09:09 AM
Stereodude's Avatar
Liked: 3082
Thanks...
Your receiver can very likely put out a subwoofer signal that's higher than 2Vrms, but it may work okay for you depending on your specific settings and how loudly you listen.
post #8216 of 11155 Old 07-20-2019, 01:26 PM
galonzo's Avatar
Quoted: 1398 Post(s)
Liked: 1844
Thumbs up Thanks Aron!
Originally Posted by galonzo View Post
Man, you're getting fast @aron7awol !
I did a quick check through my UHD collection (around 300 UHD Blu's), and these are the ones I came up with that don't have BEQs:
  • Push
  • Salt
  • Shape of Water
  • Snitch
  • Sully
  • Unforgiven
Have any of those?
Huge tanks to @aron7awol for making short work of my list (above, I missed Patriot's Day in my quick once-over, but you even got that one as well, thanks to @ MOberhardt )
I know streaming series take a little more time, but if you get bored (or for anyone else who's into Kate Beckinsale), there's a series on Amazon Prime Video called The Widow that I watched in UHD/DD+ that was decent enough for the BEQ treatment; otherwise, I'll need to thoroughly check my collection against the list to see if there are any more potentials
Main: UN78HU9000/SEK-3500 | X4500H (Klipsch/HSU 5.1.4) | UDP-203 (fw 65-0131) | TiVo Bolt | Shield
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Hobbs & Shaw and other UHD Digital codes (and some HD codes)
galonzo is offline
post #8217 of 11155 Old 07-20-2019, 02:25 PM
MOberhardt's Avatar
Quoted: 981 Post(s)
Liked: 684
Thank you so much!
post #8218 of 11155 Old 07-20-2019, 08:23 PM
Liked: 12358
BassEQ Resident Evil: Retribution (2012) DTS-HD MA 5.1
post #8219 of 11155 Old 07-21-2019, 02:12 AM
3ll3d00d's Avatar
Liked: 2833
Code:
I've seen people report this before, never been able to reproduce it though so no idea what causes it atm. If the small one works, just use that. The small one is theoretically slower internally but I don't think anyone can tell the difference in practice.
looks like a new bug related to the addition of the median curve (added https://github.com/3ll3d00d/beqdesigner/issues/288), to workaround change the displayed analysis types using the dropdown (to some other value and then back to the selected one) and the graphs should appear
galonzo likes this.
post #8220 of 11155 Old 07-21-2019, 04:44 AM
Stereodude's Avatar
Liked: 3082
Well except for the median graph. It won't appear, but peak and average do.
Edit: Median will appear if I load the signal with only peak and average displayed and change to all, but not if I load it with it set to all and then change to something else and then back to all.
