Bass EQ for Filtered Movies - Page 284 - AVS Forum | Home Theater Discussions And Reviews
 23819Likes
post #8491 of 9672 Old 08-06-2019, 04:08 PM
toothboy's Avatar
Quoted: 35 Post(s)
Liked: 48
Quick question: is the BEQ for Fury OK to use for the Blu-ray version? It is NOT the Atmos version.
Edit: and if not, is there a way to request this? Thanks!
toothboy is offline
post #8492 of 9672 Old 08-06-2019, 04:19 PM
Originally Posted by aron7awol View Post
I'm already planning on doing it (along with all new releases) but I don't have any disc audio for it yet. Were you looking for a lossy version?
Oh didn't know. I will wait until the disc comes out then, the 1080p version is floating around 4GB.
Thanks tho.
greganka is offline
post #8493 of 9672 Old 08-06-2019, 05:06 PM
Quoted: 922 Post(s)
Liked: 968
Thor Ragnarok's BEQ is for Atmos only. Is there anyway that the Marvel movies can be BEQ'd for Atmos as well as the BD release since these movies have been available for the last 10 years and many more ppl have the BD's than the 4K's please?
GeoJustGeo is offline
post #8494 of 9672 Old 08-06-2019, 05:44 PM - Thread Starter
PioManiac's Avatar
Quoted: 3278 Post(s)
Liked: 8191
From the Page 1 FAQ...
Originally Posted by PioManiac View Post
BEQ FAQ:
4. Can I use the 4K/UHD/ATMOS BEQ for my Regular Bluray or 3D movies?
For the most part, Yes
Just don't run at reference levels unless it's been added to the list as (SAFE)
ATMOS is ATMOS regardless of the disc source (4K/UHD or Bluray)
But if it's a movie from a studio (like Disney/Sony etc...) ATMOS may be exclusive to the 4K/UHD release.
If that's the case, almost always the Bluray version has DTS-HD MA audio. (that can sometimes require totally different BEQ)
See Oblivion example here: https://www.avsforum.com/forum/113-s...l#post57881850
If the Bluray audio was TrueHD, then yes, the same BEQ applies to ATMOS/TrueHD because BOTH are from Dolby
ATMOS meta-data is actually embedded in the core 7.1 TrueHD Bitstream, so there is no change to the LFE/ULF where BEQ is concerned.
in an ATMOS capable system the meta-data is extracted and re-directed to the height channels. The LFE is not any different.
If you don't have the ATMOS version and still want to use the ATMOS BEQ on your DTS-HD MA track,
Simply use a lower Master Volume and stay away from reference levels, you'll be fine.
(down -5 should give you plenty of headroom, -10 if you want to be really cautious and you have an aggressive house curve already)
I've used this method on Dozens of 3D movies that mostly come with DTS-HD MA.
There are only a few DTS-HD MA tracks that are significantly louder than the ATMOS version.
To be 100% sure, use the BEQ-Designer App (links below) and generate your own graph and compare it to the ATMOS version.
I'll be updating the list to include both formats on titles deemed safe for use with the same BEQ settings
Others can often be checked against graphs from the Ultimate Bass in Movies thread
How to read a Frequency Graph for Bass output? Reading Graphs 101
I've been using that method for almost a full year now,
The ONLY time I ever had to jump for my remote was with the Fast and Furious collection,
...That's why they have a special warning on the page 1 list.
The BEQ's for the 4K/UHD/DTS:X tracks are Very Aggressive and NOT meant for the regular bluray audio tracks at all,
I think the menu screen is regular DD5.1 and on several of the titles, it's about 15dB Hotter than the DTS:X movie track
richardsim7 and GeoJustGeo like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #8495 of 9672 Old 08-06-2019, 06:14 PM
Quoted: 922 Post(s)
Liked: 968
BassEQ Thor: Ragnarok (2017) Atmos
Thanks Pio for the info.
Btw, the last EQ band (Peak) is not in the file. It only has 3 of the 4 bands pictured here.
post #8496 of 9672 Old 08-06-2019, 06:20 PM
toothboy's Avatar
Quoted: 35 Post(s)
Liked: 48
Oh my god...I have become THAT GUY
richardsim7 likes this.
toothboy is offline
post #8497 of 9672 Old 08-06-2019, 06:27 PM - Thread Starter
PioManiac's Avatar
Liked: 8191
In the Repo? I'll let @DesertDog know, that's his Baby (Team effort around here)
Thanks for the HeadsUp!
GeoJustGeo likes this.
post #8498 of 9672 Old 08-06-2019, 07:19 PM
DesertDog's Avatar
Quoted: 604 Post(s)
Liked: 1764
Fixed. That one was a brain fart. I entered it but left the filter bypassed.
MOberhardt, galonzo and GeoJustGeo like this.
BEQ Slack group
The struggle is real for Generation Xplain Digital to the Analog and Analog to the Digital.
Klipsch RF-7III, RC-64III
SI HS-24mkIII BOSS-Sac
Sony 85X900F, Denon 8500, nVidia Shield, Apple TV
DesertDog is online now
post #8499 of 9672 Old 08-06-2019, 07:35 PM - Thread Starter
PioManiac's Avatar
Liked: 8191
Here's an easy fix for setting your Master Volume using the ATMOS BEQ
... if Aron has provided a Spectrum heat map, go to the hottest passage, (brightest yellow)
Get the time stamp from the left margin, go to that section on your Bluray and adjust your volume to max without clipping,
...it's probably a safe bet it will not get any louder than that for the rest of the movie, go back to the start and hit play.
It's better than holding your remote for the whole movie "just in case"
toothboy, ddigler and GeoJustGeo like this.
post #8500 of 9672 Old 08-06-2019, 07:49 PM
Quoted: 922 Post(s)
Liked: 968
Unfortunately I just finished Thor Ragnarok and I started BEQ half way through It when I read your response. Even tho the mv adjustment shows +2.5 (I watch most of my movies at -12) I followed your warnings and watched 5db below the recommended, so mv -14.5. Yeah....wish I had the Atmos version because at that volume i knew I was missing both dynamics and deep bass. Oh well, now I know, thanks.
post #8501 of 9672 Old 08-06-2019, 09:02 PM
Quoted: 922 Post(s)
Liked: 968
I wanted to add the 4th EQ Band (is their a name for this?) but since I was already in unfamiliar waters using the BEQ for the Atmos version, I didn't want to add anymore than what it already had lol. I like to play it really safe when it comes to this stuff.
post #8502 of 9672 Old 08-06-2019, 11:08 PM
paulst's Avatar
Quoted: 208 Post(s)
Liked: 484
I'll check it for you in a couple of hours
MOberhardt likes this.
LG OLED65B8 ~ HTPC ~ Oppo BDP-93 ~ PS3 ~ PS4 ~ Toshiba HD-XE1 ~ Harmony One
Marantz SR7011 ~ M&K LCR 851 & CS35 ~ 2x4HD ~ PSA S1811 x 2
PC - i7 4790k & GTX970
HTPC - i5 4690k & GTX1060
paulst is online now
post #8503 of 9672 Old 08-07-2019, 12:13 AM
paulst's Avatar
Quoted: 208 Post(s)
Liked: 484
BassEQ Fury (2014) Atmos
Fury DTS-HD MA 5.1 Yeh that works OK..
If you felt the need for a bit more, you could probably get away with adding one more 18hz LS to get this..
This thread will be 1yr old tomorrow 8500 posts and over 900 titles BEQ'd.. That's an amazing achievement Big thanks to those that have made this process so easy and being responsible for making all my movies sound so damn good
post #8504 of 9672 Old 08-07-2019, 06:01 AM
Actually I take it back. I saw the 2160p HDR version drop around 15GB. Could you do the lossy version please?
greganka is offline
post #8505 of 9672 Old 08-07-2019, 06:47 AM
Quoted: 2654 Post(s)
Liked: 11435
I am working on the lossy Atmos track as we speak. I always do the lossy Atmos track for the major new releases.
galonzo and ddigler like this.
Take the Red Pill (BassEQ) BassEQ Demo Clips
Video: Sony 85" X900F @ 80" eyes-to-screen (49.4° viewing angle)
Audio: Denon AVR-X4400H 7.2.4 Atmos
Mains: Fusion-15 LR, Custom Tapered Ported Volt-6 Center, Ported Volt-10 Surrounds, Custom 45°/45° Double-Angled Ported Volt-6 Atmos
Subs: The Two Towers (HT18 32cf 11.5Hz x 2), UM18 4cf x 2, Crowson MAs x 4
aron7awol is online now
post #8506 of 9672 Old 08-07-2019, 07:27 AM
Liked: 11435
BassEQ Brightburn (2019) Atmos / DTS-HD MA 7.1
DD+ Atmos:
Spoiler!
post #8507 of 9672 Old 08-07-2019, 07:35 AM
mystigiandoll's Avatar
Quoted: 67 Post(s)
Liked: 53
No doubt about that, I am just finishing my theater and there is nothing more frustrating than putting all this work into audio design, setup, and dumping a bunch of subs into the room only for the studios to completely neuter their sound tracks. Leave it to some fine folks to have to pick up the slack on these studios and restore the track!
mystigiandoll is offline
post #8508 of 9672 Old 08-07-2019, 09:41 AM
DesertDog's Avatar
Quoted: 604 Post(s)
Liked: 1764
FYI, they're filters. For Ragnorok you didn't lose out on much by not having the 4th one. It was only the overshot correction PEQ filter that was turned off. Due to the first 3 filters there was a dip between 40-60 hz that lowered down the gain by .6 db max in it. So for that title it was pretty minor. Those initially started getting added in due to @SBuger and my OCD over that sort of thing.
SBuger, galonzo, ddigler and 1 others like this.
BEQ Slack group
post #8509 of 9672 Old 08-07-2019, 02:06 PM
SBuger's Avatar
Quoted: 1222 Post(s)
Liked: 3916
So, I finally got set up to stream Netflix in 4K HDR and Atmos with the Xbox One X Apple TV 4K as well. For a while now, I’ve been sooooo looking forward to watching a lot of these series on Netflix and Amazon that are getting BEQ’d in this thread. The list is getting pretty long for these. So cool!!
I haven’t checked out any of the ones from Amazon yet but checked out the first episode of Altered Carbon and Dark last night. WOW, just freaking WOW!!! I don’t think I was expecting that kind of quality from streaming I thought Altered Carbon looked and sounded absolutely AMAZING, like, super sharp and fantastic Atmos sound!!! As good as or maybe even better than some of the best I’ve heard yet on the actual 4K Atmos blu ray movies. At least from what I saw and heard last night (hopefully I’ll feel the same about it when I check it out again tonight). As for the Bass, seemed really good. Does bass lack much in comparison to an actual 4K blu ray disc? What’s the consensus on this from you knowledgeable bass loving streamers? I’m sure you guys have talked about this already at some point, but I probably missed it or skimmed over it (since I thought what all I mentioned up above and was so impressed with would probably take a big hit by streaming it). Plus, I wasn’t setup yet and didn’t know when that would happen.
Dark was awesome as well!! But haven’t figured out if I want to read the subtitles and get the original German language or put up with the English voices looking so jacked up with the German speaking lips LOL. I feel like I miss so many great visuals by always reading. Either way, I enjoyed Dark a LOT already. Awesome PQ, Atmos and bass as well. I’m stunned actually of the quality of these 4K Atmos streams!!!
PioManiac, galonzo, paulst and 3 others like this.
My 'Blacked Out' Home Theater | Tactile Response for BASS | BassEQ for Filtered Movies
1400cuft Sealed Room on Suspended Floor | SY Triple Black Velvet Blackout | GIK Treatments | Denon AVR-X6300H - 7.6.4 Atmos | KEF Q Series Speakers | Epson 5040UB 4K | Eyes 6.5' to 120" AT Seymour Screen | Oppo 203 | Xbox One X | Apple TV 4K | 6x 18" Sealed DIY Subs | 6x Crowson MAs | 4x BK LFEs | BOSS 'Sub Riser' w/ 6x JBL-12s | MiniDSP 10x10HD
SBuger is offline
post #8510 of 9672 Old 08-07-2019, 03:05 PM
powerdubs's Avatar
Quoted: 199 Post(s)
Liked: 131
I keep seeing this thread mentioned in other threads so I thought I'd check it out. I don't have a minidsp, but I do have an antimode dual core that has a lot of adjustable eq options. I am already using it for a house curve but it also has parametric equalizers for freq, bandwidth, and gain. I might pick a favorite bluray movie and set a profile for it and see what happens.
powerdubs is offline
post #8511 of 9672 Old 08-07-2019, 03:12 PM
Nalleh's Avatar
Quoted: 2515 Post(s)
Liked: 3386
Sell it and get the Minidsp 2x4HD !
The AM DC doesn’t have low shelf function, so it won’t work for BEQ
I promise you won’t regret it
galonzo and pixphipau like this.
Dual Atmos Receivers - Atmos 13.1.8/DTS X 9.1.8/Auro 3D 13.1 - Denon AVCX8500H+AVRX7200WA - Klipsch+KEF - 6xSI18" - 8xJBL 12" BOSS - 4xJBL 12" w/SLAPS M12" VNF - 3x2 stacked Crowson MA - 4xBK-LFE - 6xNU6K(fan&trig mod) - Minidsp 10x10HD - Oppo UDP203 - XBox OneX - Apple TV4K - JVC RS600 Dreamscreen V2 120"- Philips 65OLED873.
Nalleh’s HT
Nalleh is online now
post #8512 of 9672 Old 08-07-2019, 03:18 PM
d-rail34's Avatar
Quoted: 432 Post(s)
Liked: 805
Okay, so my room is way worse than I thought...and this is my best sub placement.
It looks like I'll be busy for awhile trying to figure out to correct this suckout.
Name:	My Room Sweep1.jpg
galonzo likes this.
"Sticking feathers up your butt does not make you a chicken." - Tyler Durden
Living Room - Denon AVR-X2400H/MiniDSP 2X4HD/Hsu Research HB-1 Bookshelfs (4)/HC-1 Center/SVS PB12 Plus (1)/Samsung UN65H7150/Sony UBP-X800/PC Built by D-Rail/XBox One S
d-rail34 is offline
post #8513 of 9672 Old 08-07-2019, 03:41 PM
Alan P's Avatar
Quoted: 6287 Post(s)
Liked: 5621
Not sure if it is the same with streaming, but I know on Blu Ray (and DVD before), the dubbed track is always of lower quality (i.e. TrueHD vs. Dolby Digital, DTS MA vs. DTS, etc.). For this reason...and because I cannot stand the words not matching the lips nor the horrible acting from the dubbers...I always watch foreign films with subs.
Alan P is online now
post #8514 of 9672 Old 08-07-2019, 03:57 PM
Liked: 11435
Well, you certainly picked two reference quality titles!
Altered Carbon remains the best HDR I've ever seen on a stream, hands down, and it's in the running for the best HDR period. It truly is flat out incredible and almost mesmerizing to watch because the visuals are just that great! Not to mention, the show is great on its own.
And then you go to Dark, which not only is one of my favorite shows ever, but the Atmos mix in that first season are also not only the best streaming Atmos track I've ever heard, but again, just in general, the sound design is mind-blowingly great and it's in the running for me as my favorite Atmos mix.
I'm happy for you that are getting to experience them for the first time! And experience is the right word! Enjoy it, brother!
SBuger, galonzo, paulst and 1 others like this.
post #8515 of 9672 Old 08-07-2019, 03:59 PM
CallingMrBenzo's Avatar
Quoted: 589 Post(s)
Liked: 1268
So, I finally got set up to stream Netflix in 4K and Atmos with the Xbox One X Apple TV 4K as well but liking the Xbox better so far for it last night. For a while now, I’ve been sooooo looking forward to watching a lot of these series on Netflix and Amazon that are getting BEQ’d in this thread. The list is getting pretty long for these. So cool!!
100% German. The original mix is always the way to go
SBuger, galonzo, SuperFist and 1 others like this.
Marantz 7011- Panasonic UB-820- Xbox One X - Epson HC 5050UB *Calibrated by ChadB* - Elite Screen's 2:35:1 AT 115' - PSA MTM 110's L/C/R - Mixed Surrounds - SVS Elevations Atmos X2 - Dual PSA TV36 B&C Neo's *MiniDSP HD* Took the Red Pill BEQ
CallingMrBenzo is online now
post #8516 of 9672 Old 08-07-2019, 04:37 PM
Nalleh's Avatar
Liked: 3386
^^^ Agreed on the above about Altered Carbon and Dark on Netflix !!!!
Both picture and sound is better than at least 80% of all UHD HDR discs released so far, and honestly: they SHOULD be benchmark for how it should look and sound!!! ALL categories !
And yes, german audio on Dark!! No question
Nalleh’s HT
post #8517 of 9672 Old 08-07-2019, 05:44 PM
toothboy's Avatar
Quoted: 35 Post(s)
Liked: 48
When I first saw this thread I thought, oh god, one more thing I have to learn and deal with. Boy was I wrong. This has ended up becoming great fun and it's awesome to see these soundtracks enhanced with BEQ. Thanks guys for such an awesome idea and execution!
toothboy is offline
post #8518 of 9672 Old 08-07-2019, 06:12 PM
Quoted: 225 Post(s)
Liked: 171
@aron7awol - I was scanning the cheap blu rays on blu-ray.com the other day and it showed up with couple titles which from memory where rather good on the bass action. Do you think Assault on Precinct 13 and Enemy of the State are BEQ worthy?
aron7awol likes this.
Sony 75X940E, Denon X6200w, Sony X700, Roku Ultra, MiniDSP 2x4HD
Parasound (2x)HCA-855a, HCA-750a, Sony ES4300
Mission 705a L&R, dual 70c3 C, 703 SL&SR, 705 BL&BR, (4x)Yamaha NSIC800 Atmos
LFE- Front: M&K MX-200 & MX-150THX; Rear: (2x)M&K V-75's
ULF- Bk LFE & Advance + (2x)Aura AST-2B-4 shakers + Mini-riser BOSS(8x12" JBL's)
Kevnmin is offline
post #8519 of 9672 Old 08-07-2019, 06:53 PM
SBuger's Avatar
Liked: 3916
So, no wonder I was in such AWE with Altered Carbon and Dark, as its sounds like they are the cream of the crop and true reference quality that sets the bar!! Yeah, I remember several times watching these two that I just couldn’t hardly believe what I was seeing on screen, hearing too!!! Nicely put Aron with description of ‘mesmerizing’, that word sums it up pretty good
Thanks!! Yeah, I’m so excited about it!! With just Netflix alone, I think I’ve got HOURS of great quality stuff to watch. Since I’m late to the party, I feel like I’ve discovered a large goldmine of entertainment and makes it worth all the work and dollars we’ve put into our systems!! After, this is the main reason we all try to better our HT systems, so we can experience this kind of stuff in its full glory
SBuger is offline
post #8520 of 9672 Old 08-07-2019, 06:58 PM
Nalleh's Avatar
Liked: 3386
^^^ NOW you understand why i have been nagging you for months to try out Altered carbon ???? LOL
Nalleh’s HT
